Home » Eclipse Projects » Eclipse Platform » SWT tutorial setting path name anomily
SWT tutorial setting path name anomily [message #277591] Mon, 13 December 2004 20:23
Originally posted by: anonymous.anonymous.com
In doing the SWT tutorial, you are requested to set the VM property to the
pathname of the library.
I had set up eclipse in my C:\Program Files\ directory.
When I put the path name in, it split Program and File to two lines and
needless to say could not find the library.
I moved the library folder to a directory D:\hold and everything worked ok.
Tried the path with quotes but to no avail.
As I am a newbie can someone tell me how to build the path name when there
are embedded blanks.
TIA
Bob
Previous Topic:Using Hibernate in a plugin
Next Topic:How to make a bundle'state becoming actived when OSGI framework lauches?
Current Time: Sat Sep 06 23:57:12 EDT 2025
Powered by FUDForum. Page generated in 0.03118 seconds
