| Testing Eclipse with Java 5.0 runtime [message #276871] |
Tue, 30 November 2004 11:32  |
Originally posted by: bandrews.nospam_bphnx.com
I know that Eclipse is currently being built and tested with J2SE 1.4.x.
I was wondering if anyone out there is using 5.0 to test with. I have
been using Eclipse 3.1M2 with J2SE 5.0 for about a month now, and have
not run into any problems. Just curious about anyone elses experiences.
thanks,
Barry
| Re: Testing Eclipse with Java 5.0 runtime [message #277070 is a reply to message #277062] |
Fri, 03 December 2004 12:59   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Chris Heald wrote:
> I've been using it with j2se5 since beta 2 in the summer. I have several
> problems but I'm not certain that they are related:
> Features don't build properly. If compiler compliance is set to 1.4 on all
> settings, i get '1.4' target mode requires '-1.4' compliance mode: 1.3 and
> the jar for each plugin contains only the xml. Other modes (1.3) work but a
> feature.jar is never created so i can't use the update site. V annoying....
> Using 3.1M3, I can compile plugins to 1.5 but eclipse doesn't seem to know
> how to run them...they simply won't load.
> Any ideas?
class files generated with 1.5 are not backwards compatible. If you
compile them with eclipse's 1.5, then you must be running eclipse with a
1.5 JRE. also 3.1m3 is not yet 100% compatible with the sun 1.5JRE.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
| Re: Testing Eclipse with Java 5.0 runtime [message #277207 is a reply to message #276871] |
Mon, 06 December 2004 15:00  |
I've been running with Java 5.0 since back when the first beta appeared.
Well, except for when I've been testing VM-specific bugs/features in
Eclipse. I haven't encountered any notable problems.
cheers,
d.
FUDForum. Page generated in 0.03948 seconds
