Home » Eclipse Projects » Eclipse Platform » How to get an instance of the IWorkbenchPart?
How to get an instance of the IWorkbenchPart? [message #275532] Tue, 09 November 2004 06:31 Go to next message
Originally posted by: pimenta.inatel.br
Hi.
I'm developing my plugin and now I'm codifying a concrete class
derived from an AbstractJavaLaunchConfigurationDelegate.
In a new method of such concrete class, I need the instance of the
IWorkbenchPart.
How can I get this instance??
Some time ago I worked with an IObjectActionDelegate and then it was easy
to get the WorkbenchPart, because such class has the method
setActivePart(IAction action, IWorkbenchPart targetPart) and a just had to
get thetargetPart.
Any hint will be very helpful.
Thanks.
Rodrigo Pimenta.
Re: How to get an instance of the IWorkbenchPart? [message #275534 is a reply to message #275532] Tue, 09 November 2004 07:02 Go to previous messageGo to next message
Originally posted by: brendan.moorehead.gmail.com
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage().getActivePart();
this will return current IWorkbenchPart
Rodrigo Pimenta Carvalho wrote:
> Hi.
> IWorkbenchPart.
> get thetargetPart.
> Thanks.
> Rodrigo Pimenta.
Re: How to get an instance of the IWorkbenchPart? [message #275591 is a reply to message #275534] Tue, 09 November 2004 11:47 Go to previous messageGo to next message
Ok. Thanks.
But, I tried it and got a Exception.
What could be wrong?
Hugs.
Rodrigo.
>> Hi.
>> IWorkbenchPart.
>> get thetargetPart.
>> Thanks.
>> Rodrigo Pimenta.
Re: How to get an instance of the IWorkbenchPart? [message #275605 is a reply to message #275534] Tue, 09 November 2004 16:38 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
See also: http://www.eclipsefaq.org/chris/faq/html/faq167.html
Chris
"Brendan Moorehead" <brendan.moorehead@gmail.com> wrote in message
news:cmqbku$vd2$1@eclipse.org...
vePart();
> > Hi.
> > IWorkbenchPart.
easy
to
> > get thetargetPart.
> > Thanks.
> > Rodrigo Pimenta.
Re: How to get an instance of the IWorkbenchPart? [message #275814 is a reply to message #275591] Fri, 12 November 2004 12:24 Go to previous messageGo to next message
Originally posted by: kim_horne.ca.ibm.com
What exception did you get?
Also note that this call must be done from the UI thread. If you're
making this call from a non-UI thread you'll need to do an (a)syncExec
on the display returned by PlatformUI.getWorkbench().getDisplay().
Rodrigo Pimenta wrote:
> Ok. Thanks.
> Hugs.
> Rodrigo.
>>> Hi.
>>> IWorkbenchPart.
>>> easy to get the WorkbenchPart, because such class has the method
>>> had to get thetargetPart.
>>> Thanks.
>>> Rodrigo Pimenta.
icon12.gif  Re: How to get an instance of the IWorkbenchPart? [message #698842 is a reply to message #275814] Wed, 20 July 2011 07:11 Go to previous message
Thanks a lot for the shortcut, really helped me Razz
Previous Topic:Find the Configuration directory
Next Topic:[solved] popupMenus on IMarker
Current Time: Wed Jul 23 15:33:25 EDT 2025
Powered by FUDForum. Page generated in 0.04276 seconds
