Home » Eclipse Projects » Eclipse Platform » I messed up installing examples, could use a little help.
I messed up installing examples, could use a little help. [message #275215] Thu, 04 November 2004 16:59 Go to next message
Originally posted by: pajensen.cs.utah.edu
I recently tried to install (unzip) the examples into my eclipse
directory, but in my haste I only closed the debug workbench, not the
primary workbench. Needless to say, the example installation appears to
have failed because
eclipse was not closed.
After reading old news posts, I tried to 'enable' the examples under
help->manage configuration, but no luck. I even
tried to disable and re-enable them, but still they remain disabled. I
tried backing up to the last known good configuration, but this didn't help
either. They remain in the disabled list, but marked as enabled, and none
of the examples will show
up under new->examples except for JUnit (and the readme template file).
Does anyone have any suggestions for how to de-install and re-install
the examples?
Peter J.
Re: I messed up installing examples, could use a little help. [message #275218 is a reply to message #275215] Thu, 04 November 2004 17:33 Go to previous message
Try running once with the -clean option on eclipse.exe
Rich Kulp
Previous Topic:Slow Response/LONG delay for builds
Next Topic:[2nd posting] Can't start UITestApplication with Run-time Workbench
Current Time: Sun Jul 20 22:14:28 EDT 2025
Powered by FUDForum. Page generated in 0.02921 seconds
