Home » Eclipse Projects » Eclipse Platform » Eclipse crashing on Linux
Eclipse crashing on Linux [message #274600] Tue, 26 October 2004 07:00 Go to next message
Originally posted by: radermacher.netcologne.de
I have a problem with Eclipse crashing on my Linux machine. Before I go
into detail, here's the relevant environment list:
- Gentoo Linux with kernel 2.6.8-gentoo-r3
- Sun Java JDK 1.4.2.06
- Eclipse 3.0.1 (no plugins)
The problem has occurred only recently, I've been able to use eclipse
perfectly until then. Now, however, when I start Eclipse, the GUI shows
up but as soon as I try to change to the CVS Repository Browsing
perspective, the program crashes and I get the console output I have
appended below. If I use my usual workspace, Eclipse also crashes on
other operations (like an ant build). With a fresh empty workspace it
crashes when I go to the CVS perspective.
I have tried reinstalling Eclipse and/or different Java packages, all
with no success. Googling found a possible solution with appending the
-Dosgi.locking=none parameter, but that did not help either. I have
tried with old and fresh empty workspaces, and so on.
I'm running out of ideas what to try to get this running again.
Has anybody had a similar experience? Is there a solution? I'd be very
grateful for any kind of help.
Stefan.
PS: Here's the console output from the crash:
------------------------ snip ------------------------
QPixmap: Invalid pixmap parameters
QPainter::begin: Cannot paint null pixmap
QPainter::setPen: Will be reset by begin()
QPainter::setBrush: Will be reset by begin()
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4D3FE523
Function=XSetForeground+0x1B
Library=/usr/X11R6/lib/libX11.so.6
Current Java thread:
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(Native Method)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:879)
at org.eclipse.swt.internal.gtk.OS.gtk_main_iteration(Native
Method)
- locked <0x48b57908> (a java.lang.Class)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2297)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Dynamic libraries:
08048000-08056000 r-xp 00000000 03:03 9319380
/opt/sun-jdk-1.4.2.06/bin/java
08056000-08059000 rw-p 0000d000 03:03 9319380
40000000-40016000 r-xp 00000000 03:03 8578341 /lib/ld-2.3.4.so
40016000-40017000 rw-p 00015000 03:03 8578341 /lib/ld-2.3.4.so
40030000-4003e000 r-xp 00000000 03:03 8578162 /lib/libpthread-0.10.so
4003e000-4003f000 rw-p 0000e000 03:03 8578162 /lib/libpthread-0.10.so
40081000-40083000 r-xp 00000000 03:03 8578320 /lib/libdl-2.3.4.so
40083000-40084000 rw-p 00001000 03:03 8578320 /lib/libdl-2.3.4.so
40084000-4018b000 r-xp 00000000 03:03 8578174 /lib/libc-2.3.4.so
4018b000-4018e000 rw-p 00106000 03:03 8578174 /lib/libc-2.3.4.so
40192000-4058e000 r-xp 00000000 03:03 9319873
/opt/sun-jdk-1.4.2.06/jre/lib/i386/client/libjvm.so
4058e000-405aa000 rw-p 003fb000 03:03 9319873
405d4000-405e5000 r-xp 00000000 03:03 8578173 /lib/libnsl-2.3.4.so
405e5000-405e6000 rw-p 00011000 03:03 8578173 /lib/libnsl-2.3.4.so
405e8000-40608000 r-xp 00000000 03:03 8578318 /lib/libm-2.3.4.so
40608000-40609000 rw-p 0001f000 03:03 8578318 /lib/libm-2.3.4.so
40609000-40611000 r-xp 00000000 03:03 9319869
/opt/sun-jdk-1.4.2.06/jre/lib/i386/native_threads/libhpi.so
40611000-40612000 rw-p 00007000 03:03 9319869
4062a000-40631000 r-xp 00000000 03:03 8575276 /lib/libnss_compat-2.3.4.so
40631000-40632000 rw-p 00006000 03:03 8575276 /lib/libnss_compat-2.3.4.so
40632000-4063a000 r-xp 00000000 03:03 8578319 /lib/libnss_nis-2.3.4.so
4063a000-4063b000 rw-p 00007000 03:03 8578319 /lib/libnss_nis-2.3.4.so
4063b000-40643000 r-xp 00000000 03:03 8578378 /lib/libnss_files-2.3.4.so
40643000-40644000 rw-p 00007000 03:03 8578378 /lib/libnss_files-2.3.4.so
40644000-40648000 rw-s 00000000 03:03 6920607
/tmp/hsperfdata_radermacher/8225
40648000-40658000 r-xp 00000000 03:03 9319862
/opt/sun-jdk-1.4.2.06/jre/lib/i386/libverify.so
40658000-4065a000 rw-p 0000f000 03:03 9319862
4065a000-4067a000 r-xp 00000000 03:03 9319879
/opt/sun-jdk-1.4.2.06/jre/lib/i386/libjava.so
4067a000-4067c000 rw-p 0001f000 03:03 9319879
4067c000-40690000 r-xp 00000000 03:03 9319868
/opt/sun-jdk-1.4.2.06/jre/lib/i386/libzip.so
40690000-40693000 rw-p 00013000 03:03 9319868
40693000-4203a000 r--s 00000000 03:03 9319995
/opt/sun-jdk-1.4.2.06/jre/lib/rt.jar
42084000-4209a000 r--s 00000000 03:03 9319954
/opt/sun-jdk-1.4.2.06/jre/lib/sunrsasign.jar
4209a000-42177000 r--s 00000000 03:03 9319927
/opt/sun-jdk-1.4.2.06/jre/lib/jsse.jar
42177000-42188000 r--s 00000000 03:03 9320003
/opt/sun-jdk-1.4.2.06/jre/lib/jce.jar
42188000-426e1000 r--s 00000000 03:03 9319993
/opt/sun-jdk-1.4.2.06/jre/lib/charsets.jar
4c810000-4c813000 r--s 00000000 03:03 9319854
/opt/sun-jdk-1.4.2.06/jre/lib/ext/dnsns.jar
4c813000-4c82f000 r--s 00000000 03:03 9319855
/opt/sun-jdk-1.4.2.06/jre/lib/ext/sunjce_provider.jar
4c82f000-4c83c000 r--s 00000000 03:03 9319856
/opt/sun-jdk-1.4.2.06/jre/lib/ext/ldapsec.jar
4c83c000-4c8f8000 r--s 00000000 03:03 9319857
/opt/sun-jdk-1.4.2.06/jre/lib/ext/localedata.jar
4c8f8000-4c8fd000 r--s 00000000 03:03 9442024
/usr/lib/eclipse-3/startup.jar
4c8fd000-4c935000 r--s 00000000 03:03 9438690
/usr/lib/eclipse-3/plugins/org.eclipse.osgi_3.0.1/core.jar
4c935000-4c93d000 r--s 00000000 03:03 9438685
/usr/lib/eclipse-3/plugins/org.eclipse.osgi_3.0.1/console.ja r
4c93d000-4c949000 r--s 00000000 03:03 9438682
/usr/lib/eclipse-3/plugins/org.eclipse.osgi_3.0.1/osgi.jar
4c949000-4c95f000 r--s 00000000 03:03 9438683
/usr/lib/eclipse-3/plugins/org.eclipse.osgi_3.0.1/resolver.j ar
4c95f000-4c975000 r--s 00000000 03:03 9438686
/usr/lib/eclipse-3/plugins/org.eclipse.osgi_3.0.1/defaultAda ptor.jar
4c975000-4c994000 r--s 00000000 03:03 9438693
/usr/lib/eclipse-3/plugins/org.eclipse.osgi_3.0.1/eclipseAda ptor.jar
4c994000-4c9eb000 r--s 00000000 03:03 9438851
/usr/lib/eclipse-3/plugins/org.eclipse.core.runtime_3.0.1/ru ntime.jar
4c9eb000-4c9fb000 r-xp 00000000 03:03 9319426
/opt/sun-jdk-1.4.2.06/jre/lib/i386/libnet.so
4c9fb000-4c9fc000 rw-p 0000f000 03:03 9319426
4c9fc000-4ca02000 r-xp 00000000 03:03 9319860
/opt/sun-jdk-1.4.2.06/jre/lib/i386/libnio.so
4ca02000-4ca03000 rw-p 00005000 03:03 9319860
4ca03000-4ca17000 r--s 00000000 03:03 9441952
/usr/lib/eclipse-3/plugins/org.eclipse.update.configurator_3 .0.0/configurator.jar
4ca17000-4cb64000 r--s 00000000 03:03 9440023
/usr/lib/eclipse-3/plugins/org.eclipse.ui.ide_3.0.1/ide.jar
4cb64000-4cb79000 r--s 00000000 03:03 9439395
/usr/lib/eclipse-3/plugins/org.eclipse.core.runtime.compatib ility_3.0.0/compatibility.jar
4cb79000-4cb7a000 r--s 00000000 03:03 9441949
/usr/lib/eclipse-3/plugins/org.eclipse.ui.workbench.compatib ility_3.0.0/compatibility.jar
4cb7a000-4cdad000 r--s 00000000 03:03 9439390
/usr/lib/eclipse-3/plugins/org.eclipse.ui.workbench_3.0.1/wo rkbench.jar
4cdad000-4ce2a000 r--s 00000000 03:03 9440301
/usr/lib/eclipse-3/plugins/org.eclipse.jface_3.0.0/jface.jar
4ce2a000-4ce2b000 r--s 00000000 03:03 9441289
/usr/lib/eclipse-3/plugins/org.eclipse.ui_3.0.1/ui.jar
4ce2b000-4ce3e000 r--s 00000000 03:03 9439366
/usr/lib/eclipse-3/plugins/org.eclipse.swt.gtk_3.0.1/ws/gtk/ swt-mozilla.jar
4ce3e000-4ce4b000 r--s 00000000 03:03 9439365
/usr/lib/eclipse-3/plugins/org.eclipse.swt.gtk_3.0.1/ws/gtk/ swt-pi.jar
4ce4b000-4cf26000 r--s 00000000 03:03 9439364
/usr/lib/eclipse-3/plugins/org.eclipse.swt.gtk_3.0.1/ws/gtk/ swt.jar
4cf26000-4cf61000 r-xp 00000000 03:03 9439360
/usr/lib/eclipse-3/plugins/org.eclipse.swt.gtk_3.0.1/os/linu x/x86/libswt-pi-gtk-3063.so
4cf61000-4cf62000 rw-p 0003b000 03:03 9439360
4cf63000-4cf73000 r--s 00000000 03:03 9440228
/usr/lib/eclipse-3/plugins/org.eclipse.help_3.0.0/help.jar
4cf7b000-4d222000 r-xp 00000000 03:03 9417028
/usr/lib/libgtk-x11-2.0.so.0.400.9
4d222000-4d22c000 rw-p 002a6000 03:03 9417028
4d22f000-4d297000 r-xp 00000000 03:03 9417049
/usr/lib/libgdk-x11-2.0.so.0.400.9
4d297000-4d29c000 rw-p 00068000 03:03 9417049
4d29c000-4d2b4000 r-xp 00000000 03:03 3315040
/usr/lib/libatk-1.0.so.0.600.1
4d2b4000-4d2b6000 rw-p 00017000 03:03 3315040
4d2b6000-4d2ca000 r-xp 00000000 03:03 9417086
/usr/lib/libgdk_pixbuf-2.0.so.0.400.9
4d2ca000-4d2cb000 rw-p 00014000 03:03 9417086
4d2cb000-4d2cf000 r-xp 00000000 03:03 6250486
/usr/lib/libpangoxft-1.0.so.0.400.1
4d2cf000-4d2d0000 rw-p 00003000 03:03 6250486
4d2d0000-4d2da000 r-xp 00000000 03:03 6250466
/usr/lib/libpangox-1.0.so.0.400.1
4d2da000-4d2db000 rw-p 0000a000 03:03 6250466
4d2db000-4d30a000 r-xp 00000000 03:03 6250475
/usr/lib/libpango-1.0.so.0.400.1
4d30a000-4d30f000 rw-p 0002e000 03:03 6250475
4d30f000-4d344000 r-xp 00000000 03:03 6339416
/usr/lib/libgobject-2.0.so.0.400.6
4d344000-4d346000 rw-p 00034000 03:03 6339416
4d346000-4d349000 r-xp 00000000 03:03 6339384
/usr/lib/libgmodule-2.0.so.0.400.6
4d349000-4d34a000 rw-p 00002000 03:03 6339384
4d34a000-4d34e000 r-xp 00000000 03:03 6339326
/usr/lib/libgthread-2.0.so.0.400.6
4d34e000-4d34f000 rw-p 00003000 03:03 6339326
4d34f000-4d3c9000 r-xp 00000000 03:03 6339389
/usr/lib/libglib-2.0.so.0.400.6
4d3c9000-4d3ca000 rw-p 0007a000 03:03 6339389
4d3ca000-4d3cf000 r-xp 00000000 03:03 9505527
/usr/X11R6/lib/libXtst.so.6.1
4d3cf000-4d3d0000 rw-p 00004000 03:03 9505527
4d3d0000-4d496000 r-xp 00000000 03:03 9505516
/usr/X11R6/lib/libX11.so.6.2
4d496000-4d49a000 rw-p 000c6000 03:03 9505516
4d49a000-4d49d000 r-xp 00000000 03:03 9505599
/usr/X11R6/lib/libXrandr.so.2.0
4d49d000-4d49e000 rw-p 00002000 03:03 9505599
4d49e000-4d4a5000 r-xp 00000000 03:03 9505792 /usr/X11R6/lib/libXi.so.6.0
4d4a5000-4d4a6000 rw-p 00006000 03:03 9505792 /usr/X11R6/lib/libXi.so.6.0
4d4a6000-4d4a8000 r-xp 00000000 03:03 9505697
/usr/X11R6/lib/libXinerama.so.1.0
4d4a8000-4d4a9000 rw-p 00001000 03:03 9505697
4d4a9000-4d4bc000 r-xp 00000000 03:03 9505788
/usr/X11R6/lib/libXft.so.2.1.2
4d4bc000-4d4bd000 rw-p 00012000 03:03 9505788
4d4bd000-4d525000 r-xp 00000000 03:03 7018382
/usr/lib/libfreetype.so.6.3.4
4d525000-4d52c000 rw-p 00068000 03:03 7018382
4d52c000-4d552000 r-xp 00000000 03:03 9162478
/usr/lib/libfontconfig.so.1.0.4
4d552000-4d555000 rw-p 00026000 03:03 9162478
4d556000-4d55f000 r-xp 00000000 03:03 9505848
/usr/X11R6/lib/libXcursor.so.1.0.2
4d55f000-4d560000 rw-p 00008000 03:03 9505848
4d560000-4d567000 r-xp 00000000 03:03 9505808
/usr/X11R6/lib/libXrender.so.1.2.2
4d567000-4d568000 rw-p 00006000 03:03 9505808
4d568000-4d576000 r-xp 00000000 03:03 9505830
/usr/X11R6/lib/libXext.so.6.4
4d576000-4d577000 rw-p 0000e000 03:03 9505830
4d577000-4d59c000 r-xp 00000000 03:03 6250535
/usr/lib/libpangoft2-1.0.so.0.400.1
4d59c000-4d59d000 rw-p 00025000 03:03 6250535
4d59d000-4d5c0000 r-xp 00000000 03:03 7663457 /usr/lib/libexpat.so.0.5.0
4d5c0000-4d5c2000 rw-p 00022000 03:03 7663457 /usr/lib/libexpat.so.0.5.0
4d5c2000-4d5d2000 r-xp 00000000 03:03 7181744 /lib/libz.so.1.2.1
4d5d2000-4d5d3000 rw-p 0000f000 03:03 7181744 /lib/libz.so.1.2.1
4d5d3000-4d5d5000 r-xp 00000000 03:03 9505501
/usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
4d5d5000-4d5d6000 rw-p 00001000 03:03 9505501
4d5d6000-4d5dc000 r--s 00000000 03:03 6336326
/usr/lib/gconv/gconv-modules.cache
4d5dc000-4d5de000 r-xp 00000000 03:03 8575701 /usr/lib/gconv/ISO8859-1.so
4d5de000-4d5df000 rw-p 00001000 03:03 8575701 /usr/lib/gconv/ISO8859-1.so
4d5df000-4d612000 r-xp 00000000 03:03 9442050
/usr/lib/eclipse-3/plugins/org.eclipse.swt.gtk_3.0.1/os/linu x/x86/libswt-gtk-3063.so
4d612000-4d614000 rw-p 00033000 03:03 9442050
4d614000-4d62e000 r-xp 00000000 03:03 9052196
/usr/lib/gtk-2.0/2.4.0/engines/libqtengine.so
4d62e000-4d62f000 rw-p 0001a000 03:03 9052196
4d62f000-4dcd0000 r-xp 00000000 03:03 7094298
/usr/qt/3/lib/libqt-mt.so.3.3.3
4dcd0000-4dd10000 rw-p 006a0000 03:03 7094298
4dd14000-4dd1c000 r-xp 00000000 03:03 9439359
/usr/lib/eclipse-3/plugins/org.eclipse.swt.gtk_3.0.1/os/linu x/x86/libswt-atk-gtk-3063.so
4dd1c000-4dd1d000 rw-p 00008000 03:03 9439359
4dd1d000-4dd2b000 r--s 00000000 03:03 9439414
/usr/lib/eclipse-3/plugins/org.eclipse.ui.views_3.0.0/views. jar
4dd2c000-4dd5b000 r-xp 00000000 03:03 2699330 /usr/lib/libpng.so.3.1.2.7
4dd5b000-4dd5c000 rw-p 0002f000 03:03 2699330 /usr/lib/libpng.so.3.1.2.7
4dd5c000-4dd64000 r-xp 00000000 03:03 9505736 /usr/X11R6/lib/libSM.so.6.0
4dd64000-4dd65000 rw-p 00007000 03:03 9505736 /usr/X11R6/lib/libSM.so.6.0
4dd65000-4dd78000 r-xp 00000000 03:03 9505804
/usr/X11R6/lib/libICE.so.6.3
4dd78000-4dd7a000 rw-p 00012000 03:03 9505804
4dd7b000-4de3a000 r-xp 00000000 03:03 7199444
/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/libstdc++.so.5.0.6
4de3a000-4de3f000 rw-p 000bf000 03:03 7199444
4de44000-4de4c000 r-xp 00000000 03:03 7199484
/usr/lib/gcc-lib/i686-pc-linux-gnu/3.3.4/libgcc_s.so.1
4de4c000-4de4d000 rw-p 00007000 03:03 7199484
4de4d000-4de8d000 r-xp 00000000 03:03 72349 /usr/lib/libmng.so.1.0.0
4de8d000-4de8f000 rw-p 00040000 03:03 72349 /usr/lib/libmng.so.1.0.0
4de8f000-4deae000 r-xp 00000000 03:03 73468 /usr/lib/libjpeg.so.62.0.0
4deae000-4deaf000 rw-p 0001e000 03:03 73468 /usr/lib/libjpeg.so.62.0.0
4deaf000-4dec9000 r-xp 00000000 03:03 9505720
/usr/X11R6/lib/X11/locale/lib/common/ximcp.so.2
4dec9000-4decb000 rw-p 00019000 03:03 9505720
4decb000-4dee9000 r-xp 00000000 03:03 9040618
/usr/kde/3.3/lib/kde3/plugins/styles/plastik.so
4dee9000-4deea000 rw-p 0001e000 03:03 9040618
4deea000-4df14000 r-xp 00000000 03:03 8770661
/usr/kde/3.3/lib/libkdefx.so.4.2.0
4df14000-4df16000 rw-p 00029000 03:03 8770661
4df16000-4df49000 r--p 00000000 03:03 78440
/usr/share/fonts/corefonts/tahoma.ttf
4df49000-4dfa9000 rw-s 00000000 00:06 2621450 /SYSV00000000 (deleted)
4dfa9000-4dfab000 r-xp 00000000 03:03 6250526
/usr/lib/pango/1.4.0/modules/pango-basic-fc.so
4dfab000-4dfac000 rw-p 00001000 03:03 6250526
4dfac000-4dfbb000 r--p 00000000 03:03 256141
/usr/share/fonts/ttf-bitstream-vera/VeraBd.ttf
4dfbb000-4e059000 r--s 00000000 03:03 9440712
/usr/lib/eclipse-3/plugins/org.eclipse.core.resources_3.0.1/ resources.jar
4e05a000-4e075000 r--s 00000000 03:03 9440050
/usr/lib/eclipse-3/plugins/org.eclipse.ui.externaltools_3.0. 1/externaltools.jar
4e075000-4e155000 r--s 00000000 03:03 9438843
/usr/lib/eclipse-3/plugins/org.eclipse.debug.ui_3.0.1/dtui.j ar
4e155000-4e18c000 r--s 00000000 03:03 9440703
/usr/lib/eclipse-3/plugins/org.eclipse.debug.core_3.0.1/dtco re.jar
4e18c000-4e198000 r--s 00000000 03:03 9439909
/usr/lib/eclipse-3/plugins/org.eclipse.core.expressions_3.0. 0/expressions.jar
4e198000-4e1c3000 r--s 00000000 03:03 9441377
/usr/lib/eclipse-3/plugins/org.eclipse.text_3.0.1/text.jar
4e1c3000-4e25c000 r--s 00000000 03:03 9440231
/usr/lib/eclipse-3/plugins/org.eclipse.jface.text_3.0.1/jfac etext.jar
4e25c000-4e262000 r--s 00000000 03:03 9438674
/usr/lib/eclipse-3/plugins/org.eclipse.update.scheduler_3.0. 0/scheduler.jar
4e262000-4e359000 r--s 00000000 03:03 9441291
/usr/lib/eclipse-3/plugins/org.eclipse.team.cvs.ui_3.0.1/tea mcvsui.jar
4e359000-4e385000 r--s 00000000 03:03 9441854
/usr/lib/eclipse-3/plugins/org.eclipse.team.core_3.0.0/team. jar
4e385000-4e3f5000 r--s 00000000 03:03 9441595
/usr/lib/eclipse-3/plugins/org.eclipse.team.cvs.core_3.0.1/c vs.jar
4e3f5000-4e467000 r--s 00000000 03:03 9441691
/usr/lib/eclipse-3/plugins/org.eclipse.team.ui_3.0.1/teamui. jar
4e467000-4e4c8000 r--s 00000000 03:03 9440236
/usr/lib/eclipse-3/plugins/org.eclipse.compare_3.0.0/compare .jar
4e4c8000-4e4d6000 r--s 00000000 03:03 9441045
/usr/lib/eclipse-3/plugins/org.eclipse.ui.console_3.0.0/cons ole.jar
4e4d6000-4e536000 rw-s 00000000 00:06 2654217 /SYSV00000000 (deleted)
4e536000-4e568000 r--p 00000000 03:03 78441
/usr/share/fonts/corefonts/tahomabd.ttf
4e568000-4e56b000 r-xp 00000000 03:03 6250532
/usr/lib/pango/1.4.0/modules/pango-arabic-fc.so
4e56b000-4e56c000 rw-p 00002000 03:03 6250532
4e56c000-4e56f000 r-xp 00000000 03:03 6250529
/usr/lib/pango/1.4.0/modules/pango-hangul-fc.so
4e56f000-4e570000 rw-p 00002000 03:03 6250529
4e570000-4ed3a000 r--p 00000000 03:03 6339454
/usr/share/fonts/kochi-substitute/kochi-gothic-subst.ttf
4ed6b000-4fab7000 r--p 00000000 03:03 8482785
/usr/share/fonts/baekmuk-fonts/batang.ttf
4faf5000-4ff61000 r--p 00000000 03:03 2613390
/usr/share/fonts/arphicfonts/gkai00mp.ttf
4ff61000-4ffbf000 r--s 00000000 03:03 9441869
/usr/lib/eclipse-3/plugins/org.eclipse.ui.workbench.textedit or_3.0.1/texteditor.jar
Heap at VM Abort:
Heap
def new generation total 832K, used 344K [0x44790000, 0x44870000,
0x44c70000)
eden space 768K, 36% used [0x44790000, 0x447d6268, 0x44850000)
from space 64K, 100% used [0x44860000, 0x44870000, 0x44870000)
to space 64K, 0% used [0x44850000, 0x44850000, 0x44860000)
tenured generation total 9880K, used 6334K [0x44c70000, 0x45616000,
0x48790000)
the space 9880K, 64% used [0x44c70000, 0x4529fa20, 0x4529fc00,
0x45616000)
compacting perm gen total 13312K, used 13215K [0x48790000,
0x49490000, 0x4c790000)
the space 13312K, 99% used [0x48790000, 0x49477cb8, 0x49477e00,
0x49490000)
Local Time = Tue Oct 26 12:59:56 2004
Elapsed Time = 320
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_06-b03 mixed mode)
# An error report file has been saved as hs_err_pid8225.log.
# Please refer to the file for further information.
Re: Eclipse crashing on Linux [message #274858 is a reply to message #274600] Fri, 29 October 2004 11:55 Go to previous messageGo to next message
There are a series of reports with a similar trace.
See
https://bugs.eclipse.org/bugs/buglist.cgi?short_desc_type=al lwordssubstr&short_desc=&long_desc_type=allwordssubs tr&long_desc=+org.eclipse.swt.internal.gtk.OS.gtk_main_d o_event&bug_file_loc_type=allwordssubstr&bug_file_lo c=&keywords_type=allwords&keywords=&bug_status=N EW&bug_status=ASSIGNED&bug_status=REOPENED&email type1=substring&email1=&emailtype2=substring&ema il2=&bugidtype=include&bug_id=&votes=&change din=&chfieldfrom=&chfieldto=Now&chfieldvalue=&am p;cmdtype=doit&namedcmd=2.0+F3+bugs&newqueryname=&am p;order=Reuse+same+sort+as+last+time&field0-0-0=noop& ;type0-0-0=noop&value0-0-0=
Tod Creasey
Platform UI Team
"Stefan Radermacher" <radermacher@netcologne.de> wrote in message
news:cllaec$ab4$1@eclipse.org...
> Regards,
> Stefan.
Method)
> Method)
> at
> at
> at
> at
> at
> at
java:335)
> at
> at
> at
> at
..java:25)
> Dynamic libraries:
r.jar
atibility.jar
atibility.jar
gtk-3063.so
gtk-3063.so
-3063.so
-3063.so
-gtk-3063.so
-gtk-3063.so
jar
r
tor.jar
> Heap at VM Abort:
> Heap
> 0x44c70000)
> 0x48790000)
> 0x45616000)
> 0x49490000)
> Elapsed Time = 320
Re: Eclipse crashing on Linux [message #274889 is a reply to message #274600] Fri, 29 October 2004 15:24 Go to previous messageGo to next message
Please disregard Tod's reply. Those bugs are not related to your problem.
What are your CFLAGS? It it possible your CFLAGS are too aggressive.
Please see "http://bugs.gentoo.org/show_bug.cgi?id=68282".
If your CFLAGS are okay, then please file a bug.
cheers,
d.
Re: Eclipse crashing on Linux [message #275389 is a reply to message #274889] Mon, 08 November 2004 05:47 Go to previous messageGo to next message
Sorry that I took so long to get back to your post, I was out of the
office for a week. I don't want to seem ungrateful for your help.
It's possible that this is the problem, my CFLAGS are "-march=pentium4
-O3 -pipe -fomit-frame-pointer".
What would I need to recompile with less aggressive CFLAGS, i.e. without
the "-fomit-frame-pointer"? Just eclipse? Or more?
Stefan.
Re: Eclipse crashing on Linux [message #275807 is a reply to message #275389] Fri, 12 November 2004 11:39 Go to previous message
Those CFLAGS shouldn't be too aggressive. Could you file a bug with SWT?
Include your window manager and GTK+ control theme, as well as the versions
of GTK+ and the window manager.
thanks,
d.
Previous Topic:problem with version change
Next Topic:Setting the menu label of a global action
Current Time: Sat Jul 19 03:52:49 EDT 2025
Powered by FUDForum. Page generated in 0.04194 seconds
