Home » Eclipse Projects » Eclipse Platform » TOC not showing with from update site
TOC not showing with from update site [message #273923] Wed, 13 October 2004 12:40 Go to next message
I've got a problem with TOC entries showing up in plugins published to a
local update site.
I created a simple plugin with just a table of contents (TOC) extension to
add an entry into the "Help Contents" window.
When I kickoff the runtime workbench, the entry shows in the TOC with all
my entries.
I then created a Feature Project and an Update Project for this plugin and
published it to a local update site.
I can then retrieve the plugin via "Help","Software Updates","Find and
Install", and the plugin downloads and installs as it should.
The Problem: The plugin's help documentation doesn't show in the TOC.
I have checked that the plugin is loaded through "Help","About Eclipse
Platform","Plugin Details" and it shows up. I have also read and re-read
the article on update sites and it looks like I'm doing everything Ok.
Just as a sanity check, I also copied the whole plugin that I developed
into an eclipse/plugins directory and ran a separate eclipse. The plugin
is located AND the TOC shows up.
Somehow, the publish isn't jaring up the help files or something weird.
Any help would be appreciated.
Re: TOC not showing with from update site [message #273926 is a reply to message #273923] Wed, 13 October 2004 12:49 Go to previous message
Nothing like answering your own question; and only a few minutes after
positing.
In the plugin.xml/Build tab, you specifiy that files and directories you
want to include in the build. Just had to select my help directory that I
placed all the help files and everything worked great.
> local update site.
> my entries.
Previous Topic:Disaster struck!
Next Topic:Combo box
Current Time: Wed Jul 23 17:37:40 EDT 2025
Powered by FUDForum. Page generated in 0.03801 seconds
