Home » Eclipse Projects » Eclipse Platform » Classloading in Eclipse
Classloading in Eclipse [message #273180] Fri, 01 October 2004 02:28 Go to next message
Hi!
Is there somewhere a tutorial or any other help / documentation on
classloading in eclipse?
Bernd
Mit freundlichen Gr
Re: Classloading in Eclipse [message #273353 is a reply to message #273180] Mon, 04 October 2004 19:01 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
Not really.
What are you interested in ?
PaScaL
Bernd Kolb wrote:
> Hi!
> Thanks
> Bernd
Re: Classloading in Eclipse [message #273437 is a reply to message #273353] Wed, 06 October 2004 04:44 Go to previous messageGo to next message
The problem is the following:
I have a plugin a. It contains only libs which are required by several other
plugins. One of the libs tries to laod a class via reflection. (The class
must be specified in a xml-file.) The class which should be loaded is in
plugin b which has a dependency to a. Now I'll get a ClassNotFound or sth
like that when the code in the lib in plugin a is executed. Obviously!.
I know that it is a cyclic dependency, but I do not see an other change
because I do not want to add the library to all the other plugins which
require it.
Bernd
"Pascal Rapicault" <pascal@ibm.canada> schrieb im Newsbeitrag
news:cjskeg$dqd$1@eclipse.org...
> Not really.
> PaScaL
> Bernd Kolb wrote:
> > Hi!
> > Thanks
> > Bernd
Re: Classloading in Eclipse [message #273448 is a reply to message #273437] Wed, 06 October 2004 10:20 Go to previous messageGo to next message
Originally posted by: igorf.ca.ibm.com
Bernd,
Can you be a little bit more specific about libraries, xml-files and
error message that you get? I have code that uses ClassLoader.loadClass
to load classes from required plugins and it works just fine. There is
however a problem with config files stored under META-INF directory
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=74664) so I wonder if
this is what you actually see.
> require it.
> Thanks
> Bernd
>>Not really.
>>PaScaL
>>Bernd Kolb wrote:
>>>Hi!
>>>Thanks
>>>Bernd
Re: Classloading in Eclipse [message #273450 is a reply to message #273448] Wed, 06 October 2004 10:46 Go to previous messageGo to next message
Hi!
The libs are out of a open source project. In one lib a ant-task should be
started. this ant-task gets itsconfigurationdetails from a xml-file. It is
not the bug described at 74664.
"Igor Fedorenko" <igorf@ca.ibm.com> schrieb im Newsbeitrag
news:ck0uo3$4jc$1@eclipse.org...
> Bernd,
other
class
sth
> > require it.
> > Thanks
> > Bernd
> >>Not really.
> >>PaScaL
> >>Bernd Kolb wrote:
> >>>Hi!
> >>>Thanks
> >>>Bernd
Re: Classloading in Eclipse [message #273502 is a reply to message #273450] Wed, 06 October 2004 18:51 Go to previous message
Originally posted by: ifedorenko.rogers.com
Unfortunately, I have not seen this problem. The best advice I can give
you is to prepare a small, self-contained example that demonstrates the
problem. You then be able to either debug this problem yourself or open
a bug report if you'll be convinced that this is Eclipse's fault.
Bernd Kolb wrote:
> Hi!
>>Bernd,
> other
> class
> sth
>>>require it.
>>>Thanks
>>>Bernd
>>>>Not really.
>>>>PaScaL
>>>>Bernd Kolb wrote:
>>>>>Hi!
>>>>>Thanks
>>>>>Bernd
Previous Topic:Generating build.xml files for a feature at command line? (2nd post attempt)
Next Topic:No suitable Log constructor ...
Current Time: Mon Nov 03 22:02:59 EST 2025
Powered by FUDForum. Page generated in 0.76299 seconds
