Home » Eclipse Projects » Eclipse Platform » newbie question
newbie question [message #272701] Sun, 26 September 2004 06:55 Go to next message
Originally posted by: guyvo.skynet.be
After reading the DrDobbs articles i was interested in getting to know this
environment.
I installed the latest SDK. Unzipped it to my drive.
When i try to startup the IDE it gives an error and write a log ( see
attach )
( JRE is installed and i did not any path changes yet.)
What is wrong here ?
Thnx
Re: newbie question [message #272704 is a reply to message #272701] Sun, 26 September 2004 09:36 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
guy wrote:
> environment.
> attach )
> Thnx
> !SESSION sep 26, 2004 13:26:09.377 ---------------------------------------------
> eclipse.buildId=I200409240800
> java.version=1.3.1_13
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=nl_BE
Hi guy,
Eclipse 3.0+ requires Java 1.4.1 or higher to run. Your error log
reports you are running java.version=1.3.1_13. If you need to specify a
Java vm other than the default one on your system you can use the
command line argument -vm "path to java installation" when launching
eclipse.
- Jeff
Re: newbie question [message #272879 is a reply to message #272704] Tue, 28 September 2004 12:03 Go to previous messageGo to next message
Hi jeff,
I tried to lanch from the command line but same result.
I downloaded the necessary sun packages from the links in the FAQ.
Still same result. The errors are :
!MESSAGE Error registering XML parser services.
class not found..
!MESSAGE Startup error
class not found..
!MESSAGE Bundle
initial@reference:file:c:/eclipse/plugins/org.eclipse.core.runtime_3.1.0/
[1] was not resolved.
I checked the presence of that plugin and it's there.
"Jeff Myers" <myersj@nospam.gmail.com> wrote in message
news:cj6gb7$2fj$1@eclipse.org...
> guy wrote:
> > Hi,
this
> > environment.
> > attach )
> > Thnx
> Hi guy,
> eclipse.
> - Jeff
Re: newbie question [message #272884 is a reply to message #272704] Tue, 28 September 2004 12:56 Go to previous message
http://java.sun.com/products/plugin/index-1.4.html
http://java.sun.com/j2se/1.4.2/download.html (take j2re download here)
I downloaded the 1_4_2 run time via above link and it works fine now.
The FAQ has to be updated:
-still point to version 1.3.
-command prompt -vm doens't work with 1.3
> guy wrote:
> > Hi,
this
> > environment.
> > attach )
> > Thnx
> Hi guy,
> eclipse.
> - Jeff
Previous Topic:!MESSAGE Error registering XML parser
Next Topic:JUnit test fails in debug, works if just run
Current Time: Fri Jul 18 20:06:16 EDT 2025
Powered by FUDForum. Page generated in 0.04275 seconds
