Home » Archived » Riena » error in an example on live.eclipse.org
error in an example on live.eclipse.org [message #27251] Tue, 30 June 2009 09:31 Go to next message
I watched the following video/webinar: http://live.eclipse.org/node/612
When I try it under eclipse 3.5, I get on the client side the following
error:
osgi> Tue Jun 30 15:28:38 CEST 2009 INFO [Framework Event Dispatcher] null
{org.osgi.service.log.LogReaderService,
org.eclipse.equinox.log.ExtendedLogReaderService}={service.i d=40} ServiceEvent
REGISTERED
{org.osgi.service.log.LogService,
org.eclipse.equinox.log.ExtendedLogService}={service.id=42} ServiceEvent
REGISTERED
org.eclipse.riena.internal.core.StartupsSafeRunnable Startup:
'org.eclipse.equinox.log' succesful.
FrameworkEvent INFO
FrameworkEvent INFO
BundleEvent STARTED
BundleEvent STARTED
Tue Jun 30 15:28:38 CEST 2009 INFO [DeferredLoggingForwarder]
org.eclipse.riena.internal.core.Activator DeferredLogEvent on Tue Jun 30
15:28:38 CEST 2009 (1246368518150 ms) in thread [Start Level Event
Dispatcher]:
LogLevel(INFO), Message(No stage information set.)
BundleEvent STARTED
Tue Jun 30 15:28:38 CEST 2009 INFO [Start Level Event Dispatcher] null
{org.eclipse.riena.communication.core.IRemoteServiceRegistry }={service.ranking=-100,
service.id=43} ServiceEvent REGISTERED
org.eclipse.riena.internal.communication.core.ssl.SSLConfigu ration No
configuration given!.
{org.eclipse.riena.communication.core.progressmonitor.IRemot eProgressMonitorRegistry}={service.id=44}
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
BundleEvent STARTED
org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory found
protocol [hessian]
org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @8a4916
{org.abram.common.ICustomerService}={service.url=http://localhost:8080/hessian/CusotmerWS,
service.protocol=hessian, service.id=45} ServiceEvent REGISTERED
Tue Jun 30 15:28:38 CEST 2009 DEBUG [Start Level Event Dispatcher]
org.eclipse.riena.internal.communication.core.registry.Remot eServiceRegistry
OSGi NEW service registered id: org.abram.common.ICustomerService
service.protocol=hessian, service.id=45} ServiceEvent UNREGISTERING
BundleEvent STOPPED
BundleEvent STARTED
BundleEvent STARTED
Tue Jun 30 15:28:38 CEST 2009 ERROR [Framework Event Dispatcher] null
FrameworkEvent ERROR
org.osgi.framework.BundleException: Exception in
org.abram.client.Activator.start() of bundle org.abram.client.
please test the example on http://live.eclipse.org/node/612, because this
is very important to understand what riena is.
Re: error in an example on live.eclipse.org [message #27290 is a reply to message #27251] Tue, 30 June 2009 10:03 Go to previous messageGo to next message
Originally posted by: ekkehard.gentz-software.de
hans-georg,
how does your installation look like ?
Eclipse 3.5 as IDE
Riena SDK 1.1.0 and Riena Examples 1.1. as Target Platform ?
Equinox SDK and RCP SDK should also be there
(or another way described here
http://ekkescorner.wordpress.com/2009/06/29/galileo-howto-de fine-a-simple-target-platform/
or you follow the wiki getting started
http://wiki.eclipse.org/Riena_Getting_started
please give some informations
ekke
> error:
> null {org.osgi.service.log.LogReaderService,
> REGISTERED
> FrameworkEvent INFO
> FrameworkEvent INFO
> BundleEvent STARTED
> BundleEvent STARTED
> Dispatcher]:
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> protocol [hessian]
> BundleEvent STOPPED
> BundleEvent STARTED
> BundleEvent STARTED
> this is very important to understand what riena is.
Re: error in an example on live.eclipse.org [message #27324 is a reply to message #27290] Tue, 30 June 2009 10:15 Go to previous messageGo to next message
I createt my own target plattform in this way
- I downloades eclipse 3.5
- I downloaded riena-1.1.0-platform-win32.win32.x86.zip
from this two files I made a new targetplattform
I work with Mac OSX 10.5
In the example, the server is running very good. No problems.
Re: error in an example on live.eclipse.org [message #27349 is a reply to message #27324] Tue, 30 June 2009 14:47 Go to previous messageGo to next message
You seem to have a typo in the URL. You specify http://localhost:8080/hessian/CusotmerWS while the correct one is
http://localhost:8080/hessian/CustomerWS
maybe that helps.....
if it doesnt we need to see the exception that happens here:
org.osgi.framework.BundleException: Exception in org.abram.client.Activator.start() of bundle org.abram.client.
write some code to catch the exception and write it to the console with stacktrace....
christian
Re: error in an example on live.eclipse.org [message #27764 is a reply to message #27349] Tue, 30 June 2009 16:06 Go to previous messageGo to next message
Christian,
seems your eyes are better then mine ;-)
I looked at the stacktrace and didn't notice this
ekke
Re: error in an example on live.eclipse.org [message #27808 is a reply to message #27764] Wed, 01 July 2009 06:00 Go to previous messageGo to next message
> Christian,
> ekke
thats really the only trick I can. Find typos on a large screen of characters in milliseconds.....
christian
Thanks [message #27848 is a reply to message #27808] Wed, 01 July 2009 07:54 Go to previous message
Thanks, now it's working
Re: error in an example on live.eclipse.org [message #582951 is a reply to message #27251] Tue, 30 June 2009 10:03 Go to previous message
hans-georg,
Eclipse 3.5 as IDE
ekke
> error:
> REGISTERED
> FrameworkEvent INFO
> FrameworkEvent INFO
> BundleEvent STARTED
> BundleEvent STARTED
> Dispatcher]:
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> protocol [hessian]
> BundleEvent STOPPED
> BundleEvent STARTED
> BundleEvent STARTED
Re: error in an example on live.eclipse.org [message #582959 is a reply to message #27290] Tue, 30 June 2009 10:15 Go to previous message
Re: error in an example on live.eclipse.org [message #582971 is a reply to message #27324] Tue, 30 June 2009 14:47 Go to previous message
christian
Re: error in an example on live.eclipse.org [message #582988 is a reply to message #27349] Tue, 30 June 2009 16:06 Go to previous message
Christian,
ekke
Re: error in an example on live.eclipse.org [message #583004 is a reply to message #27764] Wed, 01 July 2009 06:00 Go to previous message
> Christian,
> ekke
christian
Thanks [message #583011 is a reply to message #27808] Wed, 01 July 2009 07:54 Go to previous message
Previous Topic:error in an example on live.eclipse.org
Next Topic:Where to see the apis provided by Riena?
Current Time: Fri Jul 18 13:01:03 EDT 2025
Powered by FUDForum. Page generated in 1.10567 seconds
