Home » Newcomers » Newcomers » SWT FillLayout
SWT FillLayout [message #272268] Thu, 16 July 2009 05:49 Go to next message
Hi NG!
how can i dynamically add components to a layout (eg FillLayout)?
i was only able to find samples for "static" gui code.
it would be great if someone could point me to a sample.
thanks in advance
lumo
PS: static sample
<code>
setLayout(new FillLayout(SWT.HORIZONTAL));
key = new Label(this, SWT.NONE);
key.setText("description");
value = new Text(this, SWT.BORDER);
value.setText("<--data-->");
</code>
i was hoping for something like:
<code>
this.getLayout().addComponent(key)
this.getLayout().addComponent(value)
</code>
so i can add components also in loops...
Re: SWT FillLayout [message #272277 is a reply to message #272268] Thu, 16 July 2009 09:59 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
Ludwig Moser wrote:
> Hi NG!
> thanks in advance
> lumo
> PS: static sample
> <code>
> </code>
> <code>
> </code>
You don't add components to a Layout; once a Composite has a Layout
assigned, that layout will automatically arrange all child components of
that Composite.
So for example a loop could look something like this:
for (int i=0; i<5 ;i++) {
new Label(this, SWT.NONE).setText("Label " + i);
new Text(this, SWT.BORDER).setText("data " + i);
(note that is just an example; it would not necessarily produce a
desirable visual result).
Note that if you add components to a Composite after it has been drawn
on-screen, you'll need to call Composite.layout() on it to force the
layout to recalculate and draw the new widget.
Hope this helps,
Eric
Re: SWT FillLayout [message #272292 is a reply to message #272277] Fri, 17 July 2009 01:15 Go to previous messageGo to next message
thanks!
this helped a lot!
so my class looks like this now (works just fine!):
NOTE: DataControl = Composite with a label and a textfield on it
public class FormControl extends Composite {
	List<KeyValue> controls = new ArrayList<KeyValue>();
	 * Create the composite.
	 * @param parent
	 * @param style
	public FormControl(Composite parent, int style) {
		super(parent, style);
	protected void checkSubclass() {
		// Disable the check that prevents subclassing of SWT components
	public void addControl(String id, String key, String value) {
		controls.add(new KeyValue(id, key, value));
	public void generate() {
		setLayout(new FillLayout(SWT.VERTICAL));
		System.err.println(controls.size());
		for (int i = 0; i < controls.size(); i++) {
			DataControl dc = new DataControl(this, SWT.None);
			dc.setSize(this.getSize().y, 21);// set size to 21 height
			dc.setId(controls.get(i).id);
			dc.setKey(controls.get(i).key);
			dc.setValue(controls.get(i).value);
			System.err.println("[" + i + "]" + controls.get(i).id + "->"
					+ controls.get(i).key + "->" + controls.get(i).value);
	protected class KeyValue {
		public String id = "";
		public String key = "";
		public String value = "";
		 * @param key
		 * @param value
		public KeyValue(String id, String key, String value) {
			super();
			this.id = id;
			this.key = key;
			this.value = value;
Re: SWT FillLayout [message #272305 is a reply to message #272277] Fri, 17 July 2009 10:12 Go to previous message
thanks! works like charm
Previous Topic:Is Simple Syntax Highlighting Possible?
Next Topic:Hidden Double Quote
Current Time: Sun Jul 20 17:16:01 EDT 2025
Powered by FUDForum. Page generated in 0.07100 seconds
