Home » Language IDEs » PHP Development Tools (PDT) » XDebug and include path recursion
XDebug and include path recursion [message #27218] Mon, 11 June 2007 18:07 Go to next message
Originally posted by: wjbuys.gmail.com
For some reason the XDebug extension does not look for source files in
subfolders of folders that are included as Include Paths. I.e. I have
the following folder structure:
C:\cake
- \libs
- dispatcher.php
- \controller
- controller.php
E:\projects\CakeTest
- index.php
- \controllers
- print_controller.php
print_controller.php:
<?php
class PrintController extends Controller
var $uses = array();
var $name = "PrintController";
function index()
$this->set('result', 'Success!'); //Breakpoint here
and the following include paths:
C:\cake
Now when I debug the project, it successfully stops at the breakpoint in
print_controller.php fine, however, if I step into Controller::set() in
controller.php it gives me the error message:
Source not found for
C:\cake\libs\controller\controller.php.Controller->set : lineno 517.
Please add the file to the Project or Include Path in project, or
structure the files in Project/Include Path to more closely resemble the
layout of the files on the server.
However, it steps out of the index() function and back into
dispatcher.php and diplays the source correctly.
That lead me to conclude that subfolders of include paths aren't handled
correctly, so I added them as include paths:
C:\cake\libs
That solution works, but it becomes unwieldy, as there are many other
subfolders.
Can anyone think of another solution? Is this a problem with XDebug? Or
with PDT? Or am I just missing something? Any help would be greatly
appreciated.
Thankyou,
W. Jacob Buys
Re: XDebug and include path recursion [message #28273 is a reply to message #27218] Thu, 14 June 2007 07:36 Go to previous messageGo to next message
Hi Jacob, this is a problem with PDT rather than XDebug as XDebug support
reuses the source lookup mechanism of PDT.
There is a bugzilla open for this already.
Dave Kelsey
Jacob Buys wrote:
> C:\cake
> - \libs
> - dispatcher.php
> - \controller
> - controller.php
> - index.php
> - \controllers
> <?php
> function index()
> C:\cake
> C:\cake\libs
> subfolders.
> appreciated.
> Thankyou,
> W. Jacob Buys
Re: XDebug and include path recursion [message #28421 is a reply to message #28273] Thu, 14 June 2007 14:46 Go to previous message
Thanks, did look through the open tickets at BugZilla, but only for
XDebug, my bad. Can't wait for a fix though...
Previous Topic:nested arrays and xdebug
Next Topic:xdebug and firefox tabs
Current Time: Sun Oct 26 09:49:16 EDT 2025
Powered by FUDForum. Page generated in 0.03670 seconds
