Home » Modeling » OCL » An issue in EcoreEnvironment for extensibility
An issue in EcoreEnvironment for extensibility [message #26962] Thu, 07 June 2007 05:21 Go to next message
Originally posted by: alu2526.etsii.ull.es
Hi Christian,
Im in the battle again ;)
I would be very pleased if in the constructor EcoreEnvironment (Registry,
Resource) the TypeResolver is created with a factoryMethod
(createTypeResolver(Resource)) in order to extend EcoreEnvironment and
TypeResolverImpl with my OMEnvironment and OMTypeResolver with a resource as
constructor's parameter.
Im persisting the generated types by the TypeResolver in the same resource
where i have my output OM Model, and I have had some problems. I have some
ideas about the reason, but i need to research more about them. I will post
you as soon as i find out the problem.
Re: An issue in EcoreEnvironment for extensibility [message #27121 is a reply to message #26962] Thu, 07 June 2007 09:33 Go to previous messageGo to next message
Hi, Adolfo,
This sounds like a very sensible refactoring. Please raise an enhancement
request in bugzilla for it.
Christian
Adolfo S�chez-Barbudo Herrera wrote:
> Hi Christian,
> as constructor's parameter.
> post you as soon as i find out the problem.
Re: An issue in EcoreEnvironment for extensibility [message #27239 is a reply to message #27121] Thu, 07 June 2007 11:45 Go to previous message
Hi Christian,
Some comments
Sure it is ;)
Raised as https://bugs.eclipse.org/bugs/show_bug.cgi?id=191504
>> resource
>> some
It was my fault. I had not created the return type of a mapping operation
(which had not return value), and later an operationCallExp didnt work well.
I have successfully persisted all the collection types created during the
parsing in the same resource where i persist the output model ;)
Greetings !!!!
Adolfo
Previous Topic:emf validation examples
Next Topic:[Announce] MDT OCL 1.1.0 I200706071327 is available
Current Time: Fri Jul 18 18:44:57 EDT 2025
Powered by FUDForum. Page generated in 0.07045 seconds
