Home » Newcomers » Newcomers » export jars with referenced jars
export jars with referenced jars [message #271147] Wed, 27 May 2009 12:27 Go to next message
Originally posted by: faraz.fallahi.googlemail.com
Hi.
I need to export my Eclipse Java project as a jar and I want to include
the referenced libraries. Ive read that eclipse doesnt support this. But
today i found a post that says eclipse 3.5 is able to do this. if so,how
does it work. ive tried eclipse 3.5 and the steps for exporting a java
project as a jar seem to be similarto prior versions.
Does anybody know anything about this ? Or is there another easy way to
do this?
greez
Re: export jars with referenced jars [message #271149 is a reply to message #271147] Wed, 27 May 2009 12:40 Go to previous messageGo to next message
You can try exporting as a "runnable" jar. This packs all the
dependencies together.
Another option is to export the project as a plugin (it has to be a
plugin project first). By creating your jars as plugins, you get to
take advantage of all the PDE (plugin development environment) tooling.
cheers,
ian
exquisitus wrote:
> Hi.
> do this?
> greez
R. Ian Bull | EclipseSource Victoria | +1-888-679-8753
http://eclipsesource.com | http://twitter.com/eclipsesource
Re: export jars with referenced jars [message #271159 is a reply to message #271149] Wed, 27 May 2009 13:10 Go to previous messageGo to next message
doesnt a runnable jar require a main methode? i think ive tried it and
failed.
do u mean to extract the jars and take the bincode into a plugin?and
then import the plugin instead of the jar?
greez
> cheers,
> ian
> exquisitus wrote:
>> Hi.
>> include the referenced libraries. Ive read that eclipse doesnt support
>> this. But today i found a post that says eclipse 3.5 is able to do
>> this. if so,how does it work. ive tried eclipse 3.5 and the steps for
>> exporting a java project as a jar seem to be similarto prior versions.
>> to do this?
>> greez
Re: export jars with referenced jars [message #271164 is a reply to message #271159] Wed, 27 May 2009 13:18 Go to previous messageGo to next message
I don't know if the runnable jar requires a main. It might.
For the plugin option, I was thinking
File -> export -> deployable plugins
This should create a jar with the required jars inside. I don't know if
java handle nested jars. I know the equinox runtime does.
cheers,
ian
> failed.
> greez
>> cheers,
>> ian
>> exquisitus wrote:
>>> Hi.
>>> support this. But today i found a post that says eclipse 3.5 is able
>>> to do this. if so,how does it work. ive tried eclipse 3.5 and the
>>> steps for exporting a java project as a jar seem to be similarto
>>> prior versions.
>>> to do this?
>>> greez
Re: export jars with referenced jars [message #271167 is a reply to message #271164] Wed, 27 May 2009 13:21 Go to previous messageGo to next message
thx a lot.
i'll try tomorow
> cheers,
> ian
>> failed.
>> greez
>>> cheers,
>>> ian
>>> exquisitus wrote:
>>>> Hi.
>>>> prior versions.
>>>> to do this?
>>>> greez
Re: export jars with referenced jars [message #271191 is a reply to message #271147] Wed, 27 May 2009 22:15 Go to previous message
Originally posted by: eclipse-news.rizzoweb.com
exquisitus wrote:
> Hi.
> do this?
Java in general does not support nesting JARs inside other JARs; they
can't be included on the classpath. This is a limitation of Java, not
Eclipse specifically.
The most common approach is to package things up and include a script
for setting up the runtime classpath to include all necessary JARs. If
you're dealing with an application server (like Tomcat, Jetty, JBoss,
WebLogic, WebSphere, etc) then your app needs to be packaged as a WAR or
EAR, a different topic altogether.
Hope this helps,
Eric
Previous Topic:Problem with ANT build in Eclipse
Next Topic:default proxy setup in plugin_customization.ini
Current Time: Tue Nov 04 06:16:28 EST 2025
Powered by FUDForum. Page generated in 0.49667 seconds
