Home » Newcomers » Newcomers » Ganymede Ant error "Build failed. Reason: Unable to find an Ant file to run."
Ganymede Ant error "Build failed. Reason: Unable to find an Ant file to run." [message #265781] Fri, 24 October 2008 06:18 Go to next message
I've just installed Ganymede and got the error while trying to run ant
build. I have project with build.xml which works on the Europe without any
problems. But when I try to run ant build on this project in Ganymede it
fails with the error above. I googled the problem but found nothing. The
interest fact is that Ant does work correctly if I run Ant Build from the
menu Run->External Tools-><the name of ant configuration>. But if I try to
run ant from any other context (by key shortcut for example) it fails.
Could anybody help me pls to solve this problem?! thanks in advance.
Re: Ganymede Ant error "Build failed. Reason: Unable to find an Ant file to run." [message #265783 is a reply to message #265781] Fri, 24 October 2008 06:39 Go to previous messageGo to next message
ruslan wrote:
> The interest fact is that Ant does work correctly if I run Ant
> Build from the menu Run->External Tools-><the name of ant
> configuration>. But if I try to run ant from any other context (by key
After you run it from 'external tools', does the keybinding work?
Remy
Re: Ganymede Ant error "Build failed. Reason: Unable to find an Ant file to run." [message #265786 is a reply to message #265783] Fri, 24 October 2008 06:42 Go to previous messageGo to next message
No. :(
I also tried to switch some settings in the ant build configuration (for
example to point the build.xml file directly by entering the path of it on
the disk, etc) but got the same result.
Re: Ganymede Ant error "Build failed. Reason: Unable to find an Ant file to run." [message #265861 is a reply to message #265781] Mon, 27 October 2008 04:31 Go to previous messageGo to next message
I've checked this on diferent PC's, diferent installations of the Ganymede
and got the same result. This looks like stable bug for ganymede using PDT.
Re: Ganymede Ant error "Build failed. Reason: Unable to find an Ant file to run. [message #265910 is a reply to message #265786] Tue, 28 October 2008 08:20 Go to previous messageGo to next message
Hello, If you open the build.xml file in the editor the Ant task works
correctly, otherwise they say that can't execute the selected file.
Re: Ganymede Ant error "Build failed. Reason: Unable to find an Ant file to run." [message #271122 is a reply to message #265783] Tue, 26 May 2009 16:31 Go to previous message
I am experiencing this problem as well currently.
I am using JBoss Developer Studio Version: 2.0.0.CR2 and this is happening
in multiple worksspaces on different Java projects.
I am able to exec the target directly by double-clicking on it in Ant
perspective, however the "ALT-SHFT-D, O" hot key gives this error
described in the thread by original poster.
Any fix for this?? Very annoying.
*** Platform Details:
*** System properties:
J2EEcache=
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20090107-0800
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\java\jbdevstudio-2.0.0.CR2\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\java\jbdevstudio-2.0.0.CR2\eclipse\plugins\org.eclipse.eq uinox.launcher.win32.win32.x86_1.0.101.R34x_v20080731\eclips e_1115.dll
-startup
C:\java\jbdevstudio-2.0.0.CR2\eclipse\plugins\org.eclipse.eq uinox.launcher_1.0.101.R34x_v20081125.jar
-framework
plugins\org.eclipse.osgi_3.4.3.R34x_v20081215-1030.jar
-vm
C:\Program Files\Java\jdk1.5.0_17\bin\..\jre\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.home.location=file:/C:/java/jbdevstudio-2.0.0.CR2/ec lipse/
eclipse.launcher=C:\java\jbdevstudio-2.0.0.CR2\eclipse\eclip se.exe
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=SDKProfile
eclipse.product=com.jboss.jbds.product.product
eclipse.startTime=1243367318331
eclipse.vm=C:\Program Files\Java\jdk1.5.0_17\bin\..\jre\bin\client\jvm.dll
eclipse.vmargs=-Xms512m
-Xmx512m
-XX:MaxPermSize=256m
-Dosgi.bundles=reference:file:org.eclipse.equinox.simpleconfigurator_1.0.0.v20080604.jar@1:start,org.eclipse.equinox.transforms.xslt@1:start,org.jboss.tools.equinox.transforms.xslt@1:start
-Djava.net.preferIPv4Stack=true
-Djava.class.path=C:\java\jbdevstudio-2.0.0.CR2\eclipse\plug ins\org.eclipse.equinox.launcher_1.0.101.R34x_v20081125.jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\java\jbdevstudio-2.0.0.CR2\eclipse\plugin s\org.eclipse.equinox.launcher_1.0.101.R34x_v20081125.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jdk1.5.0_17\jre\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jdk1.5.0_17\jre\lib\ext
java.home=C:\Program Files\Java\jdk1.5.0_17\jre
java.io.tmpdir=C:\DOCUME~1\asookazi\LOCALS~1\Temp\
java.library.path=C:\java\jbdevstudio-2.0.0.CR2\eclipse;.;C: \WINDOWS\system32;C:\WINDOWS;C:\Program
Files\Graphviz2.22\bin;C:\Program
Files\PHP\;C:\java\mysql-5.1.33-win32\bin;C:\java\scala-2.7. 3.final\bin;C:\Program
Files\Subversion Server;C:\Program
Files\Java\jdk1.5.0_17\bin;C:\java\seaminaction\opt\jboss-as -4.2.2.GA\bin;C:\java\apache-ant-1.7.1\bin;C:\java\apache-an t-1.7.1\lib;C:\java\apache-maven-2.0.10\bin;C:\Oracle\Oracle 10\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wb em;C:\Program
Files\QuickTime\QTSystem\;C:\Program Files\Softricity\SoftGrid for Windows
Desktops;C:\Program Files\Microsoft SQL Server\80\Tools\Binn\;C:\Program
Files\Microsoft SQL Server\90\Tools\binn\;c:\Program Files\Microsoft SQL
Server\90\DTS\Binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Microsoft
Visual Studio 8\Common7\IDE\PrivateAssemblies\;C:\Program
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_17-b04
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_17
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_17-b04
line.separator=
Previous Topic:Debug View does not show Source Code
Next Topic:How to add a library to Eclipse?
Current Time: Fri Sep 12 15:20:20 EDT 2025
Powered by FUDForum. Page generated in 0.09368 seconds
