Home » Newcomers » Newcomers » HELP, import local history
HELP, import local history [message #271047] Mon, 25 May 2009 08:16 Go to next message
Originally posted by: mnm.criion.net
I have made a new installment of eclipse and would like to transfer the
history but when I copy the .history folder's contents, eclipse will not
"read" it. It gives a popup which states there is no history. So what am
I missing or can't this be done?
-michael
Re: HELP, import local history [message #271058 is a reply to message #271047] Mon, 25 May 2009 14:55 Go to previous messageGo to next message
I found out that I also needed the .projects folder in
\.metadata\.plugins\org.eclipse.core.resources
as that holds the maps for the history files..
Re: HELP, import local history [message #271181 is a reply to message #271047] Wed, 27 May 2009 17:28 Go to previous messageGo to next message
Is there a particular reason you don't just point the new Eclipse at
your existing workspace? That is usually the simplest path during an
upgrade of Eclipse.
Eric
Re: HELP, import local history [message #271257 is a reply to message #271181] Fri, 29 May 2009 03:08 Go to previous message
Well yes I deleted the old workspace to get a clean slate and also
because I restructured the folder tree for both eclipse and the
workspace, but you are right for those times when only eclipse is updated.
I have put both eclipse and the workspace into a versioned folder tree
e.g. ..\eclipse\332\<eclipse files or
...\workspace\eclipse\332\<workspace files> to better facilitate trying
new versions of eclipse and to only have one workspace for many IDEs or
other dev tools which use a workspace.
-michael
Previous Topic:Creating a project, and adding files, from a shell script?
Next Topic:Eclipse Europa 3.2.2 with JBoss 5.0.1 is not working.
Current Time: Fri Jul 25 00:03:09 EDT 2025
Powered by FUDForum. Page generated in 0.29479 seconds
