Home » Newcomers » Newcomers » Automatic Crash Recovery via Ctrl + Shift + r?
Automatic Crash Recovery via Ctrl + Shift + r? [message #271006] Thu, 21 May 2009 11:40 Go to next message
I am getting an "Automatic Crash Recovery" process when using the
following control keys:
Ctrl + Shift + r?
The desired "Open Resources" display is show but immediately after the
dialog appears and , after clearing suspicious processes, the dialog
changes the "Cancel" button to a "Close" button. If you let it go this
far, the Eclipse process is closed.
A workaround is to select the "Cancel" button before the "suspicious
processes" is completed.
Any ideas on why this happens and how to eliminate it.
Jim...
Re: Automatic Crash Recovery via Ctrl + Shift + r? [message #271008 is a reply to message #271006] Thu, 21 May 2009 15:38 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
Jim Crowell wrote:
> Hello,
> Ctrl + Shift + r?
I think you'll need to provide more detail in order for anyone to
provide help. For example, what specific Eclipse package and version?
what OS and JVM and specific versions? Are you specifying the JVM in
eclipse.ini (as described in http://wiki.eclipse.org/Eclipse.ini )?
Also, can you use Ctrl+Shit+T without problems?
As much detail as you can provide will go a long way towards someone
suggesting an answer.
Eric
Re: Automatic Crash Recovery via Ctrl + Shift + r? [message #271014 is a reply to message #271008] Fri, 22 May 2009 09:30 Go to previous messageGo to next message
> eclipse.ini (as described in )?
OK, thanks.
Eclipse 3.4.0 Bld ID 120080617-2000
Win Pro XP, ver 2002, sp2
JVM 1.5.0_16
eclipse.ini is the default setup with the recent upgrade to ver. 3.4.0.
The content is as follows:
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256M
-framework
plugins\org.eclipse.osgi_3.4.0.v20080605-1900.jar
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx256m
I tried renaming this file to _eclipse.ini and I received the same problem.
Yes.
Platform: AMD Athlon 1.73 GHz 480MB Ram
Re: Automatic Crash Recovery via Ctrl + Shift + r? [message #271018 is a reply to message #271014] Fri, 22 May 2009 10:14 Go to previous messageGo to next message
> OK, thanks.
> JVM 1.5.0_16
> -showsplash
> 256M
> -framework
> -vmargs
> -Xms40m
> -Xmx256m
First thing I would try is to add a -vm argument to eclipse.ini, as
described in the wiki page http://wiki.eclipse.org/Eclipse.ini (did I
forget to paste that link into my earlier message? Oops...)
On Windows, a lot of different things can put a JVM on the system path
and you may not be getting the one you think you are. Using eclipse.ini
insures that you know EXACTLY which JVM Eclipse is running under.
Other than that, open the Error Log view, clear it out (use the red X
button on the view's toolbar) and then make the crash happen. When you
restart Eclipse look to see if anything relevant was logged in the Error
Log. Post it here if you can't make sense of the log message(s).
Hope this helps,
Eric
Re: Automatic Crash Recovery via Ctrl + Shift + r? [message #271022 is a reply to message #271018] Fri, 22 May 2009 11:27 Go to previous messageGo to next message
>> OK, thanks.
>> JVM 1.5.0_16
>> -showsplash
>> 256M
>> -framework
>> pluginsorg.eclipse.osgi_3.4.0.v20080605-1900.jar
>> -vmargs
>> -Xms40m
>> -Xmx256m
You did not error with the eclipse.org link.
I think I deleted it when I cut it to paste into my Safari browser address
field.
I thought that Eclipse would use the JVM from the JAVA_HOME or the PATH
directives?
I just added it to the 'eclipse.ini' file, cleared the error log and reran
my application.
All is the same and there are no entries in the error log.
Do you know what the "Automatic Crash Recovery" feature is and how it is
controlled in the Eclipse Properties files?
Jim
Re: Automatic Crash Recovery via Ctrl + Shift + r? [message #271179 is a reply to message #271022] Wed, 27 May 2009 17:26 Go to previous message
Jim Crowell wrote:
> Eric Rizzo wrote:
>>>> version? what OS and JVM and specific versions? Are you specifying
>>>> the JVM in eclipse.ini (as described in )?
>>> OK, thanks.
>>> JVM 1.5.0_16
>>> -showsplash
>>> 256M
>>> -framework
>>> -vmargs
>>> -Xms40m
>>> -Xmx256m
>>> problem.
>> eclipse.ini insures that you know EXACTLY which JVM Eclipse is running
>> under.
> address field.
> directives?
>> Error Log. Post it here if you can't make sense of the log message(s).
> reran my application.
"Automatic Crash Recovery" is not an Eclipse thing. I googled it and it
seems to be something in IE (version 8?). I still think it could be
related to the JVM that is being used; can you post the full contents of
your eclipse.ini?
Eclipse will indeed use whatever JVM it finds on your system PATH
(JAVA_HOME does not come into play when searching for a JVM, AFAIK), in
fact it searches several places but that is not as reliable, IMO, as
specifying in eclipse.ini.
Eric
Previous Topic:`/etc/startup.mk' not found
Next Topic:Graphical Editor Plugin
Current Time: Mon Sep 15 00:53:19 EDT 2025
Powered by FUDForum. Page generated in 0.09413 seconds
