Problem logging in CVS via SSL (sf.net) [message #270616] |
Wed, 08 September 2004 11:01  |
Originally posted by: benjamion.cordes.sme.de
had a hard time today trying logging in the sourceforge CVS server via SSL.
Eclipse Version:
Version: 3.1.0
Build id: 200408122000
Platform: WinXP
SDK: 1.5 (beta)
First I tried with pserver: no problems with viewing, but I couldn't
commit anything because I don't have the add-right.
Tried following manuals and tips:
http://www.gnegg.ch/archives/eclipse_cvs_and_putty.html
http://krook.net/os/eclipse-cvs-setup.txt
http://www.stefanheimann.net/documentation/sf-cvs.php
A bug is reported here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=21180
No result.
I tried using PuTTy and Pageant:
1. Generated a public & private key.
2. Updated key in pageant.
3. Logged on to shell.sf.net with PuTTy.
4. Opened eclipse and connted with ext mode while giving the arguments
{host} -l {user}
I also tried {user}@{host} -pw Password
Also I tried using WinCVS and got the following:
cvs -z3 -d:ext:nnai@cvs.sourceforge.net:/cvsroot/myproject co myproject
***** CVS exited normally with code 1 *****
cvs checkout: warning: unrecognized response `The server's host key is
not cached in the registry. You
' from cvs server
cvs checkout: warning: unrecognized response `have no guarantee that the
server is the computer you
' from cvs server
cvs checkout: warning: unrecognized response `think it is.
' from cvs server
cvs checkout: warning: unrecognized response `The server's dss key
fingerprint is:
' from cvs server
cvs checkout: warning: unrecognized response `ssh-dss 1024
02:ab:7c:aa:49:ed:0b:a8:50:13:10:c2:3e:92:0f:42
' from cvs server
cvs checkout: warning: unrecognized response `If you trust this host,
enter "y" to add the key to
' from cvs server
cvs checkout: warning: unrecognized response `PuTTY's cache and carry on
connecting.
' from cvs server
cvs checkout: warning: unrecognized response `If you want to carry on
connecting just once, without
' from cvs server
cvs checkout: warning: unrecognized response `adding the key to the
cache, enter "n".
' from cvs server
cvs checkout: warning: unrecognized response `If you do not trust this
host, press Return to abandon the
' from cvs server
cvs checkout: warning: unrecognized response `connection.
' from cvs server
cvs checkout: warning: unrecognized response `Store key in cache? (y/n)
error unrecognized request `requests Checked-in New-entry Checksum
Copy-file Updated Created Update-existing Merged Patched Rcs-diff Mode
Mod-time Removed Renamed Remove-entry Set-static-directory
Clear-static-directory Set-sticky Clear-sticky Template Notified
Module-expansion Wrapper-rcsOption Clear-rename Rename EntriesExtra M
Mbinary E F MT'' from cvs server
cvs checkout: cwd=C:\ ,current=C:\
cvs server: cannot find module `lostcities' - ignored
cvs [checkout aborted]: cannot expand modules
Help or a pointer to further ressources would be very appreceated.
Re: Problem logging in CVS via SSL (sf.net) [message #270780 is a reply to message #270616] |
Thu, 09 September 2004 07:49   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
I too can't get ssh2 to work internally to Eclipse, though I have no
problem using external putty.
benjamin cordes wrote:
> Hello,
> Eclipse Version:
> Version: 3.1.0
> Platform: WinXP
> SDK: 1.5 (beta)
> No result.
> {host} -l {user}
> ' from cvs server
> ' from cvs server
> ' from cvs server
> fingerprint is:
> ' from cvs server
> ' from cvs server
> ' from cvs server
> connecting.
> ' from cvs server
> ' from cvs server
> cache, enter "n".
> ' from cvs server
> ' from cvs server
> ' from cvs server
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Problem logging in CVS via SSL (sf.net) [message #270979 is a reply to message #270972] |
Fri, 10 September 2004 03:41  |
>> How Did you get it work with putty?
>> What arguments do you hand over?
>> Is it {user}@{host}
>> or
>> {host} -l {user}
>> or
>> {host} -l {user} -pw yourpassword
>> or somehting else?
>> Did you use pageant?
> looking back at your original question i believe your problem is that
> you must first connect to sourceforce from outside of eclipse with
> whatever ssh program you plan to use from within eclipse.
> First connectin is always going to ask you a question, and eclipse does
> not offer the capability to respond to questions. at least 2.1 didnt.
Thanks for the response.
I logged on the shell.sf.net succesfully. Pageant handled my password
without any problems after it got my key from puttygen.
Then I gave eclipse a pointer to plink.exe
This is one the errors I got:
I/O has been interrupted.
The most likely cause of the interrupt is either an intermittent
network failure or a communications timeout.
The CVS communications timeout can be adjusted in the Team/CVS
preferences.
Another possible cause is the improper configuration of the "ext"
connection method.
The "ext" connection method can be configured on the Team/CVS/EXT
Connection Method preference page
Next I will try conntecting with eclipse 2.1
FUDForum. Page generated in 0.08768 seconds
