thisJoinPoint.getSignature() -> java.lang.IncompatibleClassChangeError [message #26248] |
Tue, 30 September 2003 11:58  |
Originally posted by: stoerzer.fmi.uni-passau.de
Hi everybody!
I have a problem using the thisJoinPoint construct when calling
getSignature(). Unfortunately, I always get a
IncompatibleClassChangeError. Here is an example:
public aspect Alpha {
pointcut test() : execution(* * (..)) && within(Foo);
after() : test() {
System.out.println(thisJoinPoint.getSignature());
Foo f = new Foo();
f.f();
class Foo {
void f() {
Result:
131> java -cp .../eclipse/plugins/org.aspectj.ajde_1.1.4/aspectjrt.jar:.
Alpha
Exception in thread "main" java.lang.IncompatibleClassChangeError
at Alpha.ajc$after$Alpha$54(Alpha.java:4)
at Foo.f(Alpha.java:15)
at Alpha.main(Alpha.java:9)
I am using the Eclipse AJDT plugin (1.1.4) together with Sun Java
1.4.2. on Linux (RedHat 7.1.) and WinXP.
It worked with 1.1.3 and broke after the update via Eclipse. Did I miss
any signature changes for the AspectJ API?
Can anyone help?
Thanks in advance,
Max
Maximilian Stoerzer
Lehrstuhl Software Systeme - FMI - University of Passau
Tel: +49 851 509 3096, eMail: stoerzer@fmi.uni-passau.de
Re: thisJoinPoint.getSignature() -> java.lang.IncompatibleClassChangeError [message #27117 is a reply to message #26332] |
Fri, 24 October 2003 17:23  |
It was a bug. It's been fixed in the tree. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=45441
Julie
AJDT Team
Maximilian Stoerzer wrote:
> Followup:
> If compiler compliance is set to Java 1.3 in the Eclipse preference,
> everything works fine, when set to 1.4, the exception occurs.
> Is there an incompatibility between SunJDK 1.4.2 / Java 1.4 and AspectJ
> 1.1.1?
> Regards,
> Max
> > Hi everybody!
> > after() : test() {
> > public static void main(String[] args) {
> > Foo f = new Foo();
> > f.f();
> > class Foo {
> > void f() {
> > Result:
> > Alpha
> > Can anyone help?
> > Thanks in advance,
> > Max
Re: thisJoinPoint.getSignature() -> java.lang.IncompatibleClassChangeError [message #571599 is a reply to message #26248] |
Wed, 01 October 2003 03:24  |
Followup:
1.1.1?
Max
> Hi everybody!
> after() : test() {
> Foo f = new Foo();
> f.f();
> class Foo {
> void f() {
> Result:
> Alpha
> Can anyone help?
> Thanks in advance,
> Max
Re: thisJoinPoint.getSignature() -> java.lang.IncompatibleClassChangeError [message #572343 is a reply to message #26332] |
Fri, 24 October 2003 17:21  |
http://bugs.eclipse.org/bugs/show_bug.cgi?id=45441
Julie
AJDT Team
> Followup:
> 1.1.1?
> Regards,
> Max
> > Hi everybody!
> > after() : test() {
> > Foo f = new Foo();
> > f.f();
> > class Foo {
> > void f() {
> > Result:
> > Alpha
> > Can anyone help?
> > Thanks in advance,
> > Max
Re: thisJoinPoint.getSignature() -> java.lang.IncompatibleClassChangeError [message #572356 is a reply to message #26332] |
Julie
AJDT Team
> Followup:
> 1.1.1?
> Regards,
> Max
> > Hi everybody!
> > after() : test() {
> > Foo f = new Foo();
> > f.f();
> > class Foo {
> > void f() {
> > Result:
> > Alpha
> > Can anyone help?
> > Thanks in advance,
> > Max
FUDForum. Page generated in 0.06515 seconds
