Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Error loading devices [configuration problem]
Error loading devices [configuration problem] [message #27030] Fri, 20 February 2009 14:40 Go to next message
Hi all, I installed MJT on a Windows Vista 64 bits. I couldn't configure
the WTK options. I did every step as suggested but it doesn't work. I
installed sun toolkit, i set the root up with the name where it was
installerd, and nothing.
The first time I intend to load the devices it works, but when I want to
see then the list is empty and a message appears:
"error loading devices" or "error reading device registry".
"An error (org.eclipse.mtj.core.persistence.PersistenceException:
InstantiationException:
org.eclipse.mtj.toolkit.uei.internal.UEIDeviceInternal) occurred reading
the device registry.
Please consult the error log for more information."
Despite of the following steps, it still remains without workink.
*I put in the path environment variable where java is installed
* I have no Microsoft VM installed
* I set the root up with the name where it was installerd, and nothing.
* I run eclipse as an administrator.
* Eclipse is installed under c:\eclipse directory.
I have EclipseME installed on a Windows XP 32 bits machine, and it works
fine.
I appreciate any suggestion you can give me. Thanks
best regards, kovi
Re: Error loading devices [configuration problem] [message #27070 is a reply to message #27030] Sat, 21 February 2009 11:57 Go to previous messageGo to next message
are you able to execute the emulator? just go to the wtk install folder
and then enter the bin folder and run "emulator.exe".
this is required to import the sdk into mtj
gep
Re: Error loading devices [configuration problem] [message #27148 is a reply to message #27070] Tue, 24 February 2009 20:43 Go to previous messageGo to next message
yeas, I was able to do it.
Actually I resintalled everything from the start and it began to goes fine.
I have no explanation.
Thanks for your reply and suggrestion
kovicic
"Gustavo de Paula" <wgp010@motorola.com> escribi
Re: Error loading devices [configuration problem] [message #27357 is a reply to message #27148] Fri, 27 February 2009 14:20 Go to previous message
i'm glad that it worked :) if you face any more issues, please let us know
gep
> kovicic
> "Gustavo de Paula" <wgp010@motorola.com> escribió en el mensaje
> news:79e593f3801dcbbe8e76612a1cdaff30$1@www.eclipse.org...
>> gep
Re: Error loading devices [configuration problem] [message #571517 is a reply to message #27030] Sat, 21 February 2009 11:57 Go to previous message
gep
Re: Error loading devices [configuration problem] [message #571581 is a reply to message #27070] Tue, 24 February 2009 20:43 Go to previous message
kovicic
Re: Error loading devices [configuration problem] [message #571800 is a reply to message #27148] Fri, 27 February 2009 14:20 Go to previous message
gep
> kovicic
>> gep
Previous Topic:Hidden /= Read/Only
Next Topic:can't custom formatter?
Current Time: Sun Jul 27 00:39:46 EDT 2025
Powered by FUDForum. Page generated in 0.07720 seconds
