Home » Eclipse Projects » Eclipse Platform » CVS: annoying files out of sync bug
CVS: annoying files out of sync bug [message #270368] Tue, 07 September 2004 04:57 Go to next message
Originally posted by: yilin.microshit.com
It's happened several times already. After modifying and saving a file
(Word document) using an external editor, the package list does not
refresh the package list. Then when I try to do CVS update, the
modified file never gets the dirty flag... problem is, need to perform
refresh first. It took me a while to figure this out. Maybe the
package explorer needs to be able to refresh automatically when
modification occurs with external editor (impossible?), or at least
when the CVS update is run, the package explorer should perform a
"Refresh" first.
Same is true for most other operations like Export. All of these
commands should refresh the package explorer, rather than having this
obscure error messages.
Re: CVS: annoying files out of sync bug [message #270373 is a reply to message #270368] Tue, 07 September 2004 05:07 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
> file (Word document) using an external editor, the package list does
> not refresh the package list. Then when I try to do CVS update, the
> "Refresh" first.
You can set Eclipse to refresh automatically:
Window > Preferences > Workbench - Refresh workspace automatically
Dani
Re: CVS: annoying files out of sync bug [message #270380 is a reply to message #270373] Tue, 07 September 2004 06:44 Go to previous messageGo to next message
>> "Refresh" first.
Great! How does it determine when to refresh though?
Eric
Re: CVS: annoying files out of sync bug [message #270382 is a reply to message #270380] Tue, 07 September 2004 06:56 Go to previous messageGo to next message
>>> perform refresh first. It took me a while to figure this out.
>>> Maybe the package explorer needs to be able to refresh automatically
>>> when modification occurs with external editor (impossible?), or at
>>> least when the CVS update is run, the package explorer should perform
>>> a "Refresh" first.
Magic ... (just kidding;-)
Googled for "eclipse auto refresh workspace". First hit is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=36962 which has a reference to
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/documents/auto_refresh.html
HTH
Markus
Re: CVS: annoying files out of sync bug [message #270408 is a reply to message #270382] Tue, 07 September 2004 10:22 Go to previous message
On 2004-09-07 18:56:03 +0800, Markus Keller <markus_keller@ch.ibm.com> said:
>>>> "Refresh" first.
> reference to
HTH
Markus
> HTH
> Markus
Thanks Markus
Previous Topic:How to register a new java.net.ContentHandler in Eclipse 3.0 ?
Next Topic:checkout modules in different branches from CVS
Current Time: Fri Sep 26 21:15:42 EDT 2025
Powered by FUDForum. Page generated in 0.26335 seconds
