Error loading devices [configuration problem] [message #27030] |
Fri, 20 February 2009 14:40  |
Hi all, I installed MJT on a Windows Vista 64 bits. I couldn't configure
the WTK options. I did every step as suggested but it doesn't work. I
installed sun toolkit, i set the root up with the name where it was
installerd, and nothing.
The first time I intend to load the devices it works, but when I want to
see then the list is empty and a message appears:
"error loading devices" or "error reading device registry".
"An error (org.eclipse.mtj.core.persistence.PersistenceException:
InstantiationException:
org.eclipse.mtj.toolkit.uei.internal.UEIDeviceInternal) occurred reading
the device registry.
Please consult the error log for more information."
Despite of the following steps, it still remains without workink.
*I put in the path environment variable where java is installed
* I have no Microsoft VM installed
* I set the root up with the name where it was installerd, and nothing.
* I run eclipse as an administrator.
* Eclipse is installed under c:\eclipse directory.
I have EclipseME installed on a Windows XP 32 bits machine, and it works
fine.
I appreciate any suggestion you can give me. Thanks
best regards, kovi
Re: Error loading devices [configuration problem] [message #27357 is a reply to message #27148] |
Fri, 27 February 2009 14:20  |
i'm glad that it worked :) if you face any more issues, please let us know
gep
rochi wrote:
> yeas, I was able to do it.
> Actually I resintalled everything from the start and it began to goes fine.
> I have no explanation.
> Thanks for your reply and suggrestion
> kovicic
> "Gustavo de Paula" <wgp010@motorola.com> escribió en el mensaje
> news:79e593f3801dcbbe8e76612a1cdaff30$1@www.eclipse.org...
>> are you able to execute the emulator? just go to the wtk install folder
>> and then enter the bin folder and run "emulator.exe".
>> this is required to import the sdk into mtj
>> gep
Re: Error loading devices [configuration problem] [message #571800 is a reply to message #27148] |
gep
> kovicic
>> gep
FUDForum. Page generated in 0.04441 seconds
