Home » Eclipse Projects » Eclipse Platform » How do I programmatically add a launch config to the run history?
How do I programmatically add a launch config to the run history? [message #269847] Thu, 02 September 2004 12:34 Go to next message
I have a wizard that creates a new Java project and populates it with
Java files. I also create a launch configuration for it.
How can i programmatically set this to be the last run configuration?
i.e. so that the user just has to press the green run button or press F9
to launch the project without having to select the launch.
Niall
Re: How do I programmatically add a launch config to the run history? [message #269876 is a reply to message #269847] Thu, 02 September 2004 15:14 Go to previous messageGo to next message
There is no API for setting the last launch. It is controlled internally via
the actual order of launching. Allowing API to change this could be
confusing to users (i.e. why has my last launch changed when I did not
launch anything?).
Darin
"Niall Murphy" <nmurphy@ie.ibm.com> wrote in message
news:ch7hs9$cae$1@eclipse.org...
> I have a wizard that creates a new Java project and populates it with Java
> How can i programmatically set this to be the last run configuration? i.e.
> so that the user just has to press the green run button or press F9 to
> Niall
Re: How do I programmatically add a launch config to the run history? [message #270182 is a reply to message #269876] Sat, 04 September 2004 11:43 Go to previous message
> launch anything?).
> Darin
>>Hi,
>>Thanks,
>>Niall
I see why it would be a bad thing to have it available too easily.
But I still need to do it.
What if i start launching their project automaticaly but kill it before
it starts? ;)
Previous Topic:How to use ResourceLocator
Next Topic:[NEWSGROUP] - Dedicated "Project" and "Newcomer" Discussion Groups
Current Time: Sat Sep 13 05:18:11 EDT 2025
Powered by FUDForum. Page generated in 0.04548 seconds
