Home » Eclipse Projects » Eclipse Platform » Graphics, Drap and Drop and XML
Graphics, Drap and Drop and XML [message #269636] Tue, 31 August 2004 23:54 Go to next message
Originally posted by: noreply.no-reply.com
Hi everyone.
I was asked to make a plugin for Eclipse and I need you to point me some
tutorials about graphic manipulation (i'm new to Eclipse). This is exactly
what I need to do:
* The user will have a toolbar with objects
* This objects can be drag-&-dropped into a blank canvas
* the user can move/connect the objects
* all this information will be saved in an XML
* the user can edit manually the XML and this information should be
reflected in the canvas.
So, as you see, I need lots of things so everything will help.
Thanks!
George
Re: Graphics, Drap and Drop and XML [message #269638 is a reply to message #269636] Wed, 01 September 2004 00:46 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
George wrote:
> Hi everyone.
> what I need to do:
> Thanks!
> George
Checking out the GEF project would be a good place to start. Your first
three bullet points are possible to do using their framework.
http://www.eclipse.org/gef/
Good luck!
- Jeff
Re: Graphics, Drap and Drop and XML [message #269680 is a reply to message #269638] Wed, 01 September 2004 10:53 Go to previous message
Thanks Jeff!
"Jeff Myers" <myersj@nospam.gmail.com> wrote in message
news:ch3jta$ueu$1@eclipse.org...
> George wrote:
> > Hi everyone.
exactly
> > what I need to do:
> > Thanks!
> > George
> Good luck!
> - Jeff
Previous Topic:Poor performance while editing Java code using Eclipse 3.0
Next Topic:class Id not found in registry result = -2147221018
Current Time: Sat Nov 08 00:49:13 EST 2025
Powered by FUDForum. Page generated in 0.03898 seconds
