Problem in extracting emf validation example [message #26750] |
Wed, 23 August 2006 06:10  |
Originally posted by: naveen.venkatesh.flextronicssoftware.com
Hi All,
Am very new to EMF,GEF and GMF frameworks.
I was trying to run an EMF validation example.
I extracted the org.eclipse.emf.validation.examples project
from the jar file available in the plugins folder.
By selecting import as-->sourceproject.
After extracting in the package explorer i was finding an error in
the Manifest file in the following lines....
Export-Package:
org.eclipse.emf.validation.examples.internal;x-internal:=tru e,org.eclipse.emf.validation.examples.internal.wizard;x-inte rnal:=true
These packages are not available in the imported
org.eclipse.emf.validation.examples project.
pls let me know how to fix this problem.
Thanx in advance.
Naveen
Re: Problem in extracting emf validation example [message #26959 is a reply to message #26750] |
Wed, 23 August 2006 07:45  |
If you would like to run the provided example, File -> Example -> Genera=
l =
Validation Example.
Run the projects that are copied to your workbench.
in the runtime workbench envi. Create a empty project and Then File -> N=
ew =
-> Example EMF Model Creation Wizards -> EXTLibrary Model.
Hope this is helpful to you.
Madanagopal.
On Wed, 23 Aug 2006 12:10:47 +0200, Naveen =
<naveen.venkatesh@flextronicssoftware.com> wrote:
> Hi All,
> I extracted the org.eclipse.emf.validation.examples project from the j=
ar =
> Export-Package: =
> org.eclipse.emf.validation.examples.internal;x-internal:=3Dt rue,org.ec=
lipse.emf.validation.examples.internal.wizard;x-internal:=3D true
> These packages are not available in the imported =
> Thanx in advance.
> Regards,
> Naveen
FUDForum. Page generated in 0.02981 seconds
