Home » Eclipse Projects » Eclipse Platform » Periodic workspace save: Could not save master table
Periodic workspace save: Could not save master table [message #268975] Fri, 27 August 2004 08:06 Go to next message
Originally posted by: news.elcipse.org.entrelacs.net
Hi there,
I have the following periodical Error:
Everything seems to be working fine except for that, any idea? The disk
is not full, maybe some permissions? I am no super user, under linux,
Version: 3.0.0
Build id: 200311211210
Christian Mercat
Re: Periodic workspace save: Could not save master table [message #269047 is a reply to message #268975] Fri, 27 August 2004 13:20 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
I recommend upgrading to the final Eclipse 3.0 release build (you are
using a development build). If you still get the error with the final
release, please enter a bug report in the Eclipse bugzilla. Attach your
workspace log file (workspace/.metadata/.log) to the bug report.
> Version: 3.0.0
Re: Periodic workspace save: Could not save master table [message #269206 is a reply to message #269047] Mon, 30 August 2004 08:22 Go to previous messageGo to next message
Having a better look at the error log, I saw that a file could not be
edited:
workspace/.metadata/.plugins/org.eclipse.core.resources/.saf etable/org.eclipse.core.resources
and it was indeed not mine but belonging to root! So I copied it, super
user deleted it and moved it back to its original name (I could have
super user chown'ed it but I never remember the syntax :o) ). And now it
works... I hope it might help others.
>> linux, Version: 3.0.0
I don't understand how I can do that, there is a update manager under
the help menu but even logged as root (that might be when the master
table got chown'ed to root), I could not make any use of it. It says
there are no updates available. The doc on upgrades is really thin, what
I could find on the forums was dating back to 2002 and obviously refered
to very old stuff... I don't want to lose the things (features seems to
be a reserved name) we have installed so far...
Re: Periodic workspace save: Could not save master table [message #269207 is a reply to message #269206] Mon, 30 August 2004 08:52 Go to previous messageGo to next message
Ok, I got it, simply download the zip and unzip where the old one was,
quite simple. But the update manager thing is misleading, I thought it
could handle eclipse platform's updates...
Re: Periodic workspace save: Could not save master table [message #269314 is a reply to message #269207] Mon, 30 August 2004 16:07 Go to previous message
The Eclipse update manager currently only upgrades between major
releases (2.1 to 3.0, for example). Since you had a build somewhere in
between, it wasn't able to upgrade. Infrastructure is being put in place
to make this work better in the future.
Previous Topic:moving views between folders
Next Topic:JDOM Problem
Current Time: Wed Nov 05 19:24:11 EST 2025
Powered by FUDForum. Page generated in 0.04321 seconds
