Home » Archived » OHF » Re: [ohf-dev] H3ET
Re: [ohf-dev] H3ET [message #26404] Tue, 16 January 2007 04:26 Go to next message
Ale,
There were two H3ET tools demonstrated at the HL7 working group meeting in
San Diego last Wednesday: a message instance editor that allows editing
message instances based on MIF models, and a MIF validation tool. Both the
message instance editor and the MIF validation tool will be donated to the
Eclipse OHF in the near future. (We will update the list when the timing
becomes clear.)
In the meantime, access to binary versions of these tools will be made
available to the HL7 community, probably at the HL7 Project Homebase. I will
update this list when the tools are publicly available.
Brandon
On 1/16/07 9:53 AM, "Alessandro Fredianelli"
<alessandro.fredianelli@italtbs.com> wrote:
> Hi all,
> any news about h3et tools commitment?
> Thank you very much.
> Regards, Ale.
> _______________________________________________
> ohf-dev mailing list
> ohf-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/ohf-dev
H3ET Tools Contribution [message #26717 is a reply to message #26404] Mon, 22 January 2007 08:21 Go to previous messageGo to next message
The source for the Message Instance Editor and MIF Validator tools will be
available from CVS within the next 48 hours.
Brandon
> Both the
> becomes clear.)
On 1/16/07 10:26 AM, in article C1D258C8.ADDF%bulrich@b2international.com,
"Brandon Ulrich" <bulrich@b2international.com> wrote:
> Ale,
> becomes clear.)
> Cheers,
> Brandon
>> Hi all,
>> Regards, Ale.
>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #26884 is a reply to message #26717] Fri, 26 January 2007 09:44 Go to previous messageGo to next message
Originally posted by: phenix.pu.qin.gmail.com
Brandon,
I'm trying to check out the H3ET through Eclipse H3ET and get a little
bit lost - there're two forks of H3ET related, i.e.:
- org.eclipse.ohf\H3ET\plugins\XXXXXXXXX
- org.eclipse.ohf\plugins\org.eclipse.ohf.h3et.XXXXXXXXX (from .core
to .vocab.tests)
What packages should I check out as the minimized requirement if I just
run as a HL7 V3 designer without using other OHF features?
Or is there any Getting Started tutorials?
I assume it's the correct source to get the v3 tools announced by
HL7/CFH/JIVA on Jan 11th re:
"Eclipse-Based Message Development and Validation Tools for HL7 Version
3 Released "
Thanks for your effort!
Phenix
On 2007-01-22 21:21:30 +0800, Brandon Ulrich
> Brandon
>> Both the
>> becomes clear.)
>> Ale,
>> becomes clear.)
>> Cheers,
>> Brandon
>>> Hi all,
>>> Regards, Ale.
>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #26924 is a reply to message #26884] Fri, 26 January 2007 10:09 Go to previous messageGo to next message
Brandon,
Just find the release post of H3ET in HL7 Tooling Maillist that may
answer the question I posted, thanks :).
Phenix
On 2007-01-26 22:44:14 +0800, Phenix Pu Qin <phenix.pu.qin@gmail.com> said:
> Brandon,
> to .vocab.tests)
> 3 Released "
> Phenix
>> Brandon
>>> Both the
>>> becomes clear.)
>>> Ale,
>>> becomes clear.)
>>> Cheers,
>>> Brandon
>>>> Hi all,
>>>> Regards, Ale.
>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #26964 is a reply to message #26884] Fri, 26 January 2007 10:16 Go to previous messageGo to next message
> to .vocab.tests)
The active development is in the org.eclipse.ohf\plugins directory.
You will need the following plug-ins:
org.eclipse.ohf.h3et.*
org.eclipse.ohf.utilities
org.apache.batik
org.apache.commons.codec
org.apache.commons.lang
org.xmlpull.v1
Sorry, the best place for help is on the newsgroup for now.
> 3 Released "
Yes, these are the tools referred to in the press release at
http://www.connectingforhealth.nhs.uk/technical/standards/ne ws/hl7_v3_releas
ed
As of this morning, binaries of these tools have also been made available by
the HL7 Tooling Collaborative. Installation instructions can be found at the
HTC Eclipse Tooling site under downloads. See
http://hl7projects.hl7.nscee.edu/projects/htc/
Brandon
On 1/26/07 3:44 PM, in article epd444$2ju$1@utils.eclipse.org, "Phenix Pu
Qin" <phenix.pu.qin@gmail.com> wrote:
> Brandon,
> to .vocab.tests)
> 3 Released "
> Phenix
>> Brandon
>>> Both the
>>> becomes clear.)
>>> Ale,
>>> becomes clear.)
>>> Cheers,
>>> Brandon
>>>> Hi all,
>>>> Regards, Ale.
>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #27044 is a reply to message #26964] Wed, 31 January 2007 06:12 Go to previous messageGo to next message
when i try to design a new mif instance i get the following exception:
java.lang.IllegalArgumentException: Index out of bounds
at org.eclipse.swt.SWT.error(SWT.java:3358)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at org.eclipse.swt.SWT.error(SWT.java:3268)
at org.eclipse.swt.widgets.Widget.error(Widget.java:435)
at org.eclipse.swt.widgets.Combo.getItem(Combo.java:575)
at
com.jivamedical.h3et.instanceeditor.ui.wizards.MessageInstan ceOptionsPage.getRootName(MessageInstanceOptionsPage.java:11 8)
at
com.jivamedical.h3et.instanceeditor.ui.wizards.NewMessageIns tanceWizard.canFinish(NewMessageInstanceWizard.java:157)
I got MIFs from the september ballot docs, the vocab is also coming from
that bundle but i'm not sure about oids.xml.
Is available any h3et working eclipse project?
Thanks.
"Brandon Ulrich" <bulrich@b2international.com> ha scritto nel messaggio
news:C1DFD9C4.D279%bulrich@b2international.com...
>> to .vocab.tests)
> org.apache.batik
> org.xmlpull.v1
>> 3 Released "
> ed
> by
> the
> Cheers,
> Brandon
>> Brandon,
>> to .vocab.tests)
>> 3 Released "
>> Phenix
>>> be
>>> Brandon
>>>> Both the
>>>> the
>>>> timing
>>>> becomes clear.)
>>>> Ale,
>>>> in
>>>> the
>>>> the
>>>> timing
>>>> becomes clear.)
>>>> will
>>>> Cheers,
>>>> Brandon
>>>>> Hi all,
>>>>> Regards, Ale.
>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #27086 is a reply to message #27044] Thu, 01 February 2007 04:49 Go to previous messageGo to next message
> This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
--B_3253171768_19938175
Content-type: text/plain;
charset="US-ASCII"
Content-transfer-encoding: 7bit
Unfortunately, there isn't a complete H3ET workspace available for you to
download since we cannot redistribute the HL7 files. You're fine using the
files that you mention from the September ballot.
We'll add a section to the Wiki that discusses configuring a new H3ET
project; for now, I've attached an oids.xml file that you can use.
The bug was encountered because the wizard was unable to identify a static
model in the MIF that you selected. This has been (previously) fixed in the
current source; an error message is now displayed when an improperly
formatted MIF is chosen.
Hope this helps,
Brandon
On 1/31/07 12:12 PM, in article epptjf$ogq$1@utils.eclipse.org, "Ale"
> at
> ootName(MessageInstanceOptionsPage.java:118)
> at
> Thanks.
>>> to .vocab.tests)
>> org.apache.batik
>> org.xmlpull.v1
>>> 3 Released "
>> ed
>> by
>> the
>> Cheers,
>> Brandon
>>> Brandon,
>>> to .vocab.tests)
>>> 3 Released "
>>> Phenix
>>>> be
>>>> Brandon
>>>>> Both the
>>>>> the
>>>>> timing
>>>>> becomes clear.)
>>>>> Ale,
>>>>> in
>>>>> the
>>>>> the
>>>>> timing
>>>>> becomes clear.)
>>>>> will
>>>>> Cheers,
>>>>> Brandon
>>>>>> Hi all,
>>>>>> Regards, Ale.
>>>>>> ohf-dev@eclipse.org
Content-type: application/octet-stream; name="oids.xml"
Content-disposition: attachment;
filename="oids.xml"
Content-transfer-encoding: base64
PGNvZGVTeXN0ZW1zPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi4y
NSIgbmFtZT0iQUJDY29kZXMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTA1MCIgbmFtZT0iQWNrbm93bGVkZ2VtZW50Q29uZGl0aW9uIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjExMDAiIG5hbWU9IkFj a25vd2xlZGdl
bWVudERldGFpbENvZGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjUuMTA4MiIgbmFtZT0iQWNrbm93bGVkZ2VtZW50RGV0YWlsVHlwZSIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xOCIgbmFtZT0iQWNrbm93 bGVkZ2VtZW50
VHlwZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu Ni43NiIgbmFt
ZT0iQUNSIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My41LjMiIG5h
bWU9IkFjdCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNS42IiBu
YW1lPSJBY3RDbGFzcyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
NS40IiBuYW1lPSJBY3RDb2RlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjUiIG5hbWU9IkFjdEludGVycHJldGF0aW9uIi8+CiAgPGNvZGVT eXN0ZW0gb2lk
PSIyLjE2Ljg0MC4xLjExMzg4My41LjEwNTEiIG5hbWU9IkFjdEludm9pY2VF bGVtZW50TW9k
aWZpZXIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjUuMTEwMyIg
bmFtZT0iQWN0aXZlIEluZ3JlZGllbnQgQ29kZSIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNS4xMTA0IiBuYW1lPSJBY3RpdmUgSW5ncmVkaWVu dCBHcm91cCBD
b2RlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41 LjExMDYiIG5h
bWU9IkFjdGl2ZSBJbmdyZWRpZW50IEdyb3VwIE51bWJlciIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDAxIiBuYW1lPSJBY3RNb29kIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjciIG5hbWU9IkFjdFBy aW9yaXR5Ii8+
CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjgiIG5h bWU9IkFjdFJl
YXNvbiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu NS4xMCIgbmFt
ZT0iQWN0UmVsYXRpb25zaGlwQ2hlY2twb2ludCIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNS4xMSIgbmFtZT0iQWN0UmVsYXRpb25zaGlwQ29u anVuY3Rpb24i
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTIi IG5hbWU9IkFj
dFJlbGF0aW9uc2hpcEpvaW4iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTMiIG5hbWU9IkFjdFJlbGF0aW9uc2hpcFNwbGl0Ii8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwOTkiIG5hbWU9IkFjdFJlbGF0 aW9uc2hpcFN1
YnNldCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu NS4xMDAyIiBu
YW1lPSJBY3RSZWxhdGlvbnNoaXBUeXBlIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My41LjEwNTIiIG5hbWU9IkFjdFNpdGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuMTQiIG5hbWU9IkFjdFN0YXR1cyIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMTA5IiBuYW1lPSJBY3RU aGVyYXB5RHVy
YXRpb25Xb3JraW5nTGlzdENvZGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjUuMTUiIG5hbWU9IkFjdFR5cGUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjUuMTA1MyIgbmFtZT0iQWN0VW5jZXJ0YWludHkiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTYiIG5hbWU9IkFkZHJl c3NQYXJ0VHlw
ZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4x NyIgbmFtZT0i
QWRkcmVzc1VzZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS4x
IiBuYW1lPSJBZG1pbmlzdHJhdGl2ZUdlbmRlciIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNi4yMzQiIG5hbWU9IkFIRlMiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMTExIiBuYW1lPSJBTFQiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA1NCIgbmFtZT0iQW1lcmljYW5J bmRpYW5BbGFz
a2FOYXRpdmVMYW5ndWFnZXMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuMTEyIiBuYW1lPSJBT0QiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjYuNzQiIG5hbWU9IkFSVCIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuMTkuOS4xIiBuYW1lPSJBcnRlZmFjdCBUeXBlOiBDREEgRG9j dW1lbnQiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjE5LjguMSIg bmFtZT0iQXJ0
ZWZhY3QgVHlwZTogSEw3IFYyIE1lc3NhZ2UiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjE5LjcuMSIgbmFtZT0iQXJ0ZWZhY3QgVHlwZTogSEw3 IFYzIE1lc3Nh
Z2UiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MzAiIG5hbWU9
IkFTNCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu Ni43OCIgbmFt
ZT0iQVM0RSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi43NyIg
bmFtZT0iQVRDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjEx Mzg4My42LjEx
MyIgbmFtZT0iQkkiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjYu
MTIiIG5hbWU9IkM0Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjgyIiBuYW1lPSJDNSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
NS4xMDU1IiBuYW1lPSJDYWxlbmRhciIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuNS4xMDE4IiBuYW1lPSJDYWxlbmRhciBjeWNsZSBvbmUgbGV0 dGVyIGNvZGUi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTAx OSIgbmFtZT0i
Q2FsZW5kYXIgY3ljbGUgdHdvIGxldHRlciBjb2RlIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My41LjkiIG5hbWU9IkNhbGVuZGFyQ3ljbGUiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA5MCIgbmFtZT0iQ2Fs ZW5kYXJDeWNs
ZU9uZUxldHRlciIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS4x
MDE3IiBuYW1lPSJDYWxlbmRhclR5cGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjYuMTkiIG5hbWU9IkNBTU5DVlMiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuNjEiIG5hbWU9IkNBUyIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi4yMzYiIG5hbWU9IkNDQyIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi45NSIgbmFtZT0iQ0NJIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjExNCIgbmFtZT0iQ0NQU1MiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTE1IiBuYW1lPSJDQ1Mi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTMiIG5hbWU9IkNE MiIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMzkiIG5hbWU9 IkNEQV9SVVMi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNTci IG5hbWU9IkNE
Q0EiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu NTgiIG5hbWU9
IkNEQ00iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuNzkiIG5h
bWU9IkNEUyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi4xMTYi
IG5hbWU9IkNEVCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi44
MCIgbmFtZT0iQ0UiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjUu
MjEiIG5hbWU9IkNoYXJzZXQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTA4MSIgbmFtZT0iQ0lISUFkaiIvPgogIDxjb2RlU3lzdGVtIG9p ZD0iMi4xNi44
NDAuMS4xMTM4ODMuNi44MSIgbmFtZT0iQ0xQIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My41LjIyIiBuYW1lPSJDb2RlU3lzdGVtIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwODUiIG5hbWU9IkNvZGVTeXN0 ZW1UeXBlIi8+
CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwNzQi IG5hbWU9IkNv
ZGluZ1JhdGlvbmFsZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
NS4xMDU2IiBuYW1lPSJDb21tdW5pY2F0aW9uRnVuY3Rpb25UeXBlIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwMDkiIG5hbWU9IkNvbXBy ZXNzaW9uQUxn
b3JpdGhtIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My41LjEwODgi
IG5hbWU9IkNvbmNlcHRDb2RlUmVsYXRpb25zaGlwIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My41LjI0IiBuYW1lPSJDb25jZXB0R2VuZXJhbGl0 eSIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDg3IiBuYW1l PSJDb25jZXB0
UHJvcGVydHkiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjUuMTA4
NiIgbmFtZT0iQ29uY2VwdFN0YXR1cyIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuNS4yNSIgbmFtZT0iQ29uZmlkZW50aWFsaXR5Ii8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjI2IiBuYW1lPSJDb250YWluZXJD YXAiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMjciIG5hbWU9 IkNvbnRhaW5l
clNlcGFyYXRvciIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS4x
MTEwIiBuYW1lPSJDb250ZW50UHJvY2Vzc2luZ01vZGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuMTA1NyIgbmFtZT0iQ29udGV4dENvbnRy b2wiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTE3IiBuYW1l PSJDT1NUQVIi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMjgi IG5hbWU9IkNv
dW50cnkiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuMTE4IiBu
YW1lPSJDUE0iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuMTIu
MSIgbmFtZT0iQ1BUU1AiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjYuMjM1IiBuYW1lPSJDU0FJRCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4x Ni44NDAuMS4x
MTM4ODMuNi4xMjAiIG5hbWU9IkNTUCIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuNi42MiIgbmFtZT0iQ1NUIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My41LjEwNTgiIG5hbWU9IkN1cnJlbmN5Ii8+CiAgPGNvZGVT eXN0ZW0gb2lk
PSIyLjE2Ljg0MC4xLjExMzg4My42LjU5IiBuYW1lPSJDVlgiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjQ0IiBuYW1lPSJEMUNTIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwMDciIG5hbWU9IkRhdGFU eXBlIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjgzIiBuYW1l PSJEQ0wiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMzEiIG5h bWU9IkRDTSIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMS4yLjg0MC4xMDAwOC4yLjE2LjQiIG5h bWU9IkRDTSIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xMjIi IG5hbWU9IkRE
QiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4x MDIiIG5hbWU9
IkRFRURTIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42Ljg5IiBu
YW1lPSJERUVEUyhvbGQpIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My42LjEwMi4yLjEwIiBuYW1lPSJERUVEUzIuMTAiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTAyLjQuMiIgbmFtZT0iREVFRFM0LjAyIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjEwMi40LjUiIG5hbWU9 IkRFRURTNC4w
NSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4x MDIuNC43IiBu
YW1lPSJERUVEUzQuMDciLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjYuMTAyLjQuOCIgbmFtZT0iREVFRFM0LjA4Ii8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My42LjEwMi40LjEyIiBuYW1lPSJERUVEUzQuMTIiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTAyLjQuMTQiIG5hbWU9 IkRFRURTNC4x
NCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4x MDIuNC4xNSIg
bmFtZT0iREVFRFM0LjE1Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My42LjEwMi40LjE2IiBuYW1lPSJERUVEUzQuMTYiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTAyLjQuMTgiIG5hbWU9IkRFRURTNC4xOCIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xMDIuNC4yMiIgbmFt ZT0iREVFRFM0
LjIyIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjEwMi40LjI0
IiBuYW1lPSJERUVEUzQuMjQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuMTAyLjQuMjciIG5hbWU9IkRFRURTNC4yNyIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi4xMDIuNS42IiBuYW1lPSJERUVEUzUuMDYi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTAyLjUuOCIgbmFt ZT0iREVFRFM1
LjA4Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjEwMi41LjE5
IiBuYW1lPSJERUVEUzUuMTkiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTA4MCIgbmFtZT0iRGVudGl0aW9uIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My41LjEwODkiIG5hbWU9IkRlbnRpdGlvbiIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4zMSIgbmFtZT0iRGV2aWNlQWxl cnRMZXZlbCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yNTIi IG5hbWU9IkRJ
QUdOT1NUSUMgSU1BR0UgTUVUSE9EIENPREUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjUuMzIiIG5hbWU9IkRpZXRTZXJ2aWNlIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjMuMyIgbmFtZT0iRE1ESUNEMTAi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjI3LjEiIG5hbWU9 IkRNRFVNRCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4zMyIg bmFtZT0iRG9j
dW1lbnRDb21wbGV0aW9uIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41LjM0IiBuYW1lPSJEb2N1bWVudFN0b3JhZ2UiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMzIiIG5hbWU9IkRRTCIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi4xMjUiIG5hbWU9IkRTTTNSIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjEyNiIgbmFtZT0iRFNNNCIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xMjciIG5hbWU9IkRYUCIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4zNCIgbmFtZT0iRSIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4zNSIgbmFtZT0iRTUi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMzYiIG5hbWU9IkU2 Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjM3IiBuYW1lPSJF NyIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4zNSIgbmFtZT0i RWRpdFN0YXR1
cyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4x MDc3IiBuYW1l
PSJFZHVjYXRpb25MZXZlbCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNS4xMDU5IiBuYW1lPSJFbXBsb3llZUpvYkNsYXNzIi8+CiAgPGNvZGVT eXN0ZW0gb2lk
PSIyLjE2Ljg0MC4xLjExMzg4My41LjExMDgiIG5hbWU9IkVuY29kZS1GTSIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4zNiIgbmFtZT0iRW5j b3VudGVyQWNj
aWRlbnQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjUuMTA4NCIg
bmFtZT0iRW5jb3VudGVyQWN1aXR5Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My41LjM4IiBuYW1lPSJFbmNvdW50ZXJBZG1pc3Npb25Qcmlvcml0 eSIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4zNyIgbmFtZT0i RW5jb3VudGVy
QWRtaXNzaW9uU291cmNlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41LjM5IiBuYW1lPSJFbmNvdW50ZXJSZWZlcnJhbFNvdXJjZSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS40MCIgbmFtZT0iRW5jb3VudGVy U3BlY2lhbENv
dXJ0ZXN5Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My41LjQxIiBu
YW1lPSJFbnRpdHlDbGFzcyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNS4xMDYwIiBuYW1lPSJFbnRpdHlDb2RlIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My41LjMwIiBuYW1lPSJFbnRpdHlEZXRlcm1pbmVyIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjQyIiBuYW1lPSJFbnRp dHlIYW5kbGlu
ZyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS40 MyIgbmFtZT0i
RW50aXR5TmFtZVBhcnRRdWFsaWZpZXIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjUuNDQiIG5hbWU9IkVudGl0eU5hbWVQYXJ0VHlwZSIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS40NSIgbmFtZT0iRW50aXR5 TmFtZVVzZSIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS40NiIg bmFtZT0iRW50
aXR5UmlzayIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNS40NyIg
bmFtZT0iRW50aXR5Um9sZVJlbGF0aW9uc2hpcFR5cGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuMTA2MSIgbmFtZT0iRW50aXR5U3RhdHVz Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjQ4IiBuYW1lPSJF bnRpdHlUeXBl
Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjMz IiBuYW1lPSJF
TlpDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjI0MiIgbmFt
ZT0iRVBTRyBHZW9kZXRpYyBwYXJhbWV0ZXIgZGF0YXNldCIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNS40OSIgbmFtZT0iRXF1aXBtZW50QWxl cnRMZXZlbCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS41MCIg bmFtZT0iRXRo
bmljaXR5Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42LjI0NyIg
bmFtZT0iRVRITklDSVRZIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41LjEwMjMiIG5hbWU9IkV2ZW50IGNvZGUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjE5LjUuMSIgbmFtZT0iRXhhbXBsZSBjb2RlIHN5c3Rl bXMiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNjQiIG5hbWU9 IkZEREMiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNjMiIG5h bWU9IkZERFgi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMzgi IG5hbWU9IkZE
SyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi45 MiIgbmFtZT0i
RklQU1BVQjIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuOTMi
IG5hbWU9IkZJUFNQVUI2LTQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuOTEiIG5hbWU9IkZJUFNQVUI5MiIvPgogIDxjb2RlU3lzdGVtIG9p ZD0iMi4xNi44
NDAuMS4xMTM4ODMuNi4yNDgiIG5hbWU9IkZJUlNUIE5BVElPTlMgU1RBVFVT Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjExOSIgbmFtZT0i Rk1BIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjUxIiBuYW1l PSJHZW5kZXJT
dGF0dXMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuMTI4IiBu
YW1lPSJHTyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNS4xMDIy
IiBuYW1lPSJHVFNBYmJyZXZpYXRpb24iLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjYuNDAiIG5hbWU9IkhCIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My42LjEyOSIgbmFtZT0iSENEVCIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNi4xMzAiIG5hbWU9IkhDUFQiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuNTMiIG5hbWU9IkhlYWx0aGNhcmVQcm92 aWRlclRheG9u
b215SElQQUEiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuMTci
IG5hbWU9IkhIQ0MiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjYu
MzkiIG5hbWU9IkhJIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My41
LjU0IiBuYW1lPSJITDdDb21taXR0ZWVJREluUklNIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My41LjU1IiBuYW1lPSJITDdDb25mb3JtYW5jZUlu Y2x1c2lvbiIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS41NiIg bmFtZT0iSEw3
RGVmaW5lZFJvc2VQcm9wZXJ0eSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4x Ni44NDAuMS4x
MTM4ODMuNS4xMTAxIiBuYW1lPSJITDdEb21haW5zIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My41LjEwOTIiIG5hbWU9IkhMN0lUU1ZlcnNpb25D b2RlIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwOTciIG5h bWU9IkhMN1N0
YW5kYXJkVmVyc2lvbkNvZGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuNTciIG5hbWU9IkhMN1VwZGF0ZU1vZGUiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjUuMTA3OSIgbmFtZT0iSEw3VjMiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTMyIiBuYW1lPSJITFJFTCIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNCIgbmFtZT0iSFBDIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjU4IiBuYW1lPSJIdG1s TGlua1R5cGUi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTMz IiBuYW1lPSJI
VUdPIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjQyIiBuYW1l
PSJJOSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu Ni4xOCIgbmFt
ZT0iSUIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuNDQiIG5h
bWU9IklDMiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi4zIiBu
YW1lPSJJQ0QxMCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi4z
LjEiIG5hbWU9IklDRDEwQUUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuMTM1IiBuYW1lPSJJQ0QxMEFNIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My42LjEzNS4xIiBuYW1lPSJJQ0QxMEFNQUUiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuOTQiIG5hbWU9IklDRDEwLUNhIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjkwIiBuYW1lPSJJQ0Qx MENNIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjMuMiIgbmFt ZT0iSUNEMTBE
VVQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu NCIgbmFtZT0i
SUNEMTBQQ1MiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuMiIg
bmFtZT0iSUNEOUNNIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjEwMyIgbmFtZT0iSUNELTlDTSAoZGlhZ25vc2lzIGNvZGVzKSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xMDQiIG5hbWU9IklDRC05Q00g KHByb2NlZHVy
ZSBjb2RlcykiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuNDMi
IG5hbWU9IklDRE8iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjYu
OTciIG5hbWU9IklDTlAiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjYuMTM4IiBuYW1lPSJJQ1BDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My42LjEzOS4xIiBuYW1lPSJJQ1BDMkVEVVQiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTM5IiBuYW1lPSJJQ1BDMkVFTkciLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTQyLjEiIG5hbWU9IklDUEMy SUNEMTBEVVQi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTQy IiBuYW1lPSJJ
Q1BDMklDRDEwRU5HIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjE0MC4yIiBuYW1lPSJJQ1BDMlAiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjYuMTM4LjEiIG5hbWU9IklDUENCQVEiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTM4LjIiIG5hbWU9IklDUENEQU4iLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTM4LjMiIG5hbWU9IklDUENE VVQiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTM4LjQiIG5h bWU9IklDUENG
SU4iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MTM4LjUiIG5h
bWU9IklDUENGUkUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjYu
MTM4LjYiIG5hbWU9IklDUENHRVIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjYuMTM4LjciIG5hbWU9IklDUENIRUIiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTM4LjgiIG5hbWU9IklDUENIVU4iLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTM4LjkiIG5hbWU9IklDUENJ VEEiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTM4LjEwIiBu YW1lPSJJQ1BD
Tk9SIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjE0MC4xIiBu
YW1lPSJJQ1BDUEFFIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjEzOC4xMSIgbmFtZT0iSUNQQ1BPUiIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuNi4xMzguMTIiIG5hbWU9IklDUENTUEEiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMTM4LjEzIiBuYW1lPSJJQ1BDU1dFIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjQxIiBuYW1lPSJJQ1Mi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNDUiIG5hbWU9IklD U0QiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuODQiIG5hbWU9 IklFVEYxNzY2
Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjEy MSIgbmFtZT0i
SUVURjMwNjYiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjUuMTAx
MCIgbmFtZT0iSW50ZWdyaXR5Q2hlY2tBbGdvcml0aG0iLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuMSIgbmFtZT0iSVNPMzE2Ni0xIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2LjIi
IG5hbWU9IklTTzMxNjYtMiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi4z IiBuYW1lPSJJ
U08zMTY2LTMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuOSIg
bmFtZT0iSVNPNDIxNyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
Ni45OSIgbmFtZT0iSVNPNjM5LTEiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjYuMTAwIiBuYW1lPSJJU082MzktMiIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNi40NyIgbmFtZT0iSVVQQyIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi40NiIgbmFtZT0iSVVQUCIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNTgiIG5hbWU9IkpBQkwiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNDgiIG5hbWU9IkpDOCIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS42MCIgbmFtZT0iTGFuZ3Vh Z2VBYmlsaXR5
TW9kZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu NS42MSIgbmFt
ZT0iTGFuZ3VhZ2VBYmlsaXR5UHJvZmljaWVuY3kiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTU5IiBuYW1lPSJMQ0giLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuNjIiIG5hbWU9Ikxpc3RUeXBlIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjYzIiBuYW1lPSJMaXZpbmdB cnJhbmdlbWVu
dCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS42 NCIgbmFtZT0i
TGl2aW5nU3ViamVjdFByb2R1Y3Rpb25DbGFzcyIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNi4xIiBuYW1lPSJMTiIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNS42NSIgbmFtZT0iTG9jYWxNYXJrdXBJZ25vcmUi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuNjYiIG5hbWU9Ikxv Y2FsUmVtb3Rl
Q29udHJvbFN0YXRlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My41
LjEwNjIiIG5hbWU9Ik1hbmFnZWRQYXJ0aWNpcGF0aW9uU3RhdHVzIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjY3IiBuYW1lPSJNYXBSZWxh dGlvbnNoaXAi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMiIg bmFtZT0iTWFy
aXRhbFN0YXR1cyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS4x
MDk0IiBuYW1lPSJNYXRjaEFsZ29yaXRobSIvPgogIDxjb2RlU3lzdGVtIG9p ZD0iMi4xNi44
NDAuMS4xMTM4ODMuNS42OSIgbmFtZT0iTWF0ZXJpYWxEYW5nZXIiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuNzAiIG5hbWU9Ik1hdGVyaWFs SGFuZGxpbmci
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuNzEi IG5hbWU9Ik1h
dGVyaWFsUmVsYXRpb25zaGlwIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjcyIiBuYW1lPSJNYXRlcmlhbFJlc3BvbnNpYmlsaXR5Ii8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjczIiBuYW1lPSJNYXRlcmlh bFR5cGUiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTYwIiBu YW1lPSJNQkQi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTYx IiBuYW1lPSJN
Q00iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MjQiIG5hbWU9
Ik1EQyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu Ni4xNjIiIG5h
bWU9Ik1EREIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuNjUi
IG5hbWU9Ik1ERFgiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjUu
NzQiIG5hbWU9Ik1ERkF0dHJpYnV0ZVR5cGUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjUuNzUiIG5hbWU9Ik1kZkhtZE1ldFNvdXJjZVR5cGUi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuNzYiIG5hbWU9Ik1k ZkhtZFJvd1R5
cGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUu NzciIG5hbWU9
Ik1kZlJtaW1Sb3dUeXBlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41Ljc4IiBuYW1lPSJNREZTdWJqZWN0QXJlYVByZWZpeCIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNjMiIG5hbWU9Ik1EUiIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNjMuMSIgbmFtZT0iTURSQUUi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTYzLjIiIG5hbWU9 Ik1EUkRVVCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNjQu MSIgbmFtZT0i
TURSRUEiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuMTY0IiBu
YW1lPSJNRFJFWCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi4x
NjMuMyIgbmFtZT0iTURSRlJFIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My42LjE2My40IiBuYW1lPSJNRFJHRVIiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjYuMTYzLjUiIG5hbWU9Ik1EUlBPUiIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNjMuNiIgbmFtZT0iTURSU1BBIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjE3MiIgbmFtZT0iTUVE Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjY3IiBuYW1lPSJN RURDIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjI2IiBuYW1l PSJNRURDSU4i
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuNzki IG5hbWU9Ik1l
ZGlhVHlwZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi4xNzMi
IG5hbWU9Ik1FRExJTkVQTFVTIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My42LjcwIiBuYW1lPSJNRURSIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My42LjY2IiBuYW1lPSJNRURYIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My41LjgwIiBuYW1lPSJNZXNzYWdlQ29uZGl0aW9uIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwODMiIG5hbWU9Ik1lc3Nh Z2VXYWl0aW5n
UHJpb3JpdHkiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuMjQ5
IiBuYW1lPSJNRVRBQk9MSUMgU1lORFJPTUUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjYuNjgiIG5hbWU9Ik1HUEkiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTc0IiBuYW1lPSJNSU0iLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMTAiIG5hbWU9Ik1JTUUiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTc1IiBuYW1lPSJNTVNMIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjE3NiIgbmFtZT0iTU1YIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjgxIiBuYW1lPSJNb2Rp ZnlJbmRpY2F0
b3IiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MTc3IiBuYW1l
PSJNU0giLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuMTc3LjEi
IG5hbWU9Ik1TSENaRSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
Ni4xNzcuMiIgbmFtZT0iTVNIRFVUIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My42LjE3Ny4zIiBuYW1lPSJNU0hGSU4iLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTc3LjQiIG5hbWU9Ik1TSEZSRSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNzcuNSIgbmFtZT0iTVNIR0VS Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjE3Ny42IiBuYW1l PSJNU0hJVEEi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTc3 LjciIG5hbWU9
Ik1TSEpQTiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi4xNzcu
OCIgbmFtZT0iTVNIUE9SIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My42LjE3Ny45IiBuYW1lPSJNU0hSVVMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjYuMTc3LjEwIiBuYW1lPSJNU0hTUEEiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMTc3LjExIiBuYW1lPSJNU0hTV0UiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTg5IiBuYW1lPSJNVEgi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTkwIiBuYW1lPSJN VEhDSCIvPgog
IDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xOTEiIG5h bWU9Ik1USEZE
QSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4x OTIiIG5hbWU9
Ik1USEhIIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42LjE5MyIg
bmFtZT0iTVRISUNEOSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
Ni4xMzkuMiIgbmFtZT0iTVRISUNQQzJFQUUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjYuMTQyLjIiIG5hbWU9Ik1USElDUEMySUNEMTA3QiIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNDIuMyIgbmFtZT0i TVRISUNQQzJJ
Q0QxMEFFIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42LjE2NSIg
bmFtZT0iTVRITURSU1BBIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My42LjE5OCIgbmFtZT0iTVRITVNUIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My42LjE5OC4xIiBuYW1lPSJNVEhNU1RGUkUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMTk4LjIiIG5hbWU9Ik1USE1TVElUQSIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMDEiIG5hbWU9Ik1U SFBEUSIvPgog
IDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMDIiIG5h bWU9Ik1USFND
VCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4y MDIuMSIgbmFt
ZT0iTVRIU0NUU1BBIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjI3IiBuYW1lPSJNVUxUVU0iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuNjAiIG5hbWU9Ik1WWCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4x Ni44NDAuMS4x
MTM4ODMuNi43IiBuYW1lPSJOQUFDQ1IiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjYuODUiIG5hbWU9Ik5BSUNTIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My42LjIwNCIgbmFtZT0iTkFOIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My42LjIwNSIgbmFtZT0iTkNCSSIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMDYiIG5hbWU9Ik5DSSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuMy4yNi4xLjUiIG5hbWU9Ik5DSSBW ZXJzaW9uIG9m
IE5ERi1SVCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi4yMDci
IG5hbWU9Ik5DSVNFRVIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjYuMjAiIG5hbWU9Ik5EQSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNi42OSIgbmFtZT0iTkRDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My42LjIwOCIgbmFtZT0iTkRERiIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuNi4yMDkiIG5hbWU9Ik5ERlJUIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My42LjIxMCIgbmFtZT0iTkVVIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My42LjE1IiBuYW1lPSJOSUMiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMjExIiBuYW1lPSJOTE0tTUVEIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42Ljg3IiBuYW1lPSJOTURTIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjIzIiBuYW1lPSJOTU1E UyIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNiIgbmFtZT0i Tk9DIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjIxIiBuYW1l PSJOVUJDLVVC
OTIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MTAxIiBuYW1l
PSJOVUNDIFByb3ZpZGVyIENvZGVzIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My41LjEwMDgiIG5hbWU9Ik51bGxGbGF2b3IiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuODMiIG5hbWU9Ik9ic2VydmF0aW9uSW50 ZXJwcmV0YXRp
b24iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUu ODQiIG5hbWU9
Ik9ic2VydmF0aW9uTWV0aG9kIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjEwNjMiIG5hbWU9Ik9ic2VydmF0aW9uVmFsdWUiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNDkiIG5hbWU9Ik9IQSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi45OCIgbmFtZT0iT01TIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjExMDIiIG5hbWU9Ik9ubGlu ZSBQcm9kdWN0
IElkZW50aWZpY2F0aW9uIE51bWJlciBJbmRleCBvZiBOb3ZhIFNjb3RpYSIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS44NSIgbmFtZT0iT3Jk ZXJhYmxlRHJ1
Z0Zvcm0iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjUuMTAxNiIg
bmFtZT0iT3JnYW5pemF0aW9uTmFtZVR5cGUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjUuODciIG5hbWU9IlBhcmFtZXRlcml6ZWREYXRhVHlw ZSIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMTUiIG5hbWU9 IlBhcnRpY2lw
YXRpb25BY3RvciIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS44
OCIgbmFtZT0iUGFydGljaXBhdGlvbkZ1bmN0aW9uIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My41LjEwNjQiIG5hbWU9IlBhcnRpY2lwYXRpb25N b2RlIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41Ljg5IiBuYW1l PSJQYXJ0aWNp
cGF0aW9uU2lnbmF0dXJlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41LjkwIiBuYW1lPSJQYXJ0aWNpcGF0aW9uVHlwZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNS4xMDc1IiBuYW1lPSJQYXRpZW50SW1wb3J0 YW5jZSIvPgog
IDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS45MSIgbmFt ZT0iUGF5bWVu
dFRlcm1zIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42LjIxMiIg
bmFtZT0iUENEUyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi4y
MTMiIG5hbWU9IlBEUSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
NS4xMDIxIiBuYW1lPSJQZXJpb2RpY0ludGVydmFsT2ZUaW1lQWJicmV2aWF0 aW9uIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwMTQiIG5h bWU9IlBlcnNv
biBOYW1lIHBhcnQgdHlwZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNS4xMDE1IiBuYW1lPSJQZXJzb24gTmFtZSBwYXJ0IHR5cGUiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuOTMiIG5hbWU9IlBlcnNvbkRp c2FiaWxpdHlU
eXBlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41 Ljk2IiBuYW1l
PSJQZXJzb25OYW1lUHVycG9zZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4x Ni44NDAuMS4x
MTM4ODMuNi4yMzgiIG5hbWU9IlBIX1JhY2VBbmRFdGhuaWNpdHlfQ0RDIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjIyIiBuYW1lPSJQTkRT Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwOTUiIG5hbWU9 IlBvbGljeUhv
bGRlclJvbGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuNTAi
IG5hbWU9IlBPUyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS4x
MDEzIiBuYW1lPSJQb3N0YWwgQWRkcmVzcyBwYXJ0IHR5cGUiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTAxMiIgbmFtZT0iUG9zdGFsQWRk cmVzc1VzZSIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMTQi IG5hbWU9IlBQ
QUMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUu OTgiIG5hbWU9
IlByYWN0aWNlU2V0dGluZyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNS4xMDIwIiBuYW1lPSJQcm9iYWJpbGl0eURpc3RyaWJ1dGlvblR5cGUi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA2NSIgbmFtZT0i UHJvY2VkdXJl
TWV0aG9kIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My41LjEwMCIg
bmFtZT0iUHJvY2Vzc2luZ0lEIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjEwMSIgbmFtZT0iUHJvY2Vzc2luZ01vZGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMjE1IiBuYW1lPSJQU1kiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjE2IiBuYW1lPSJRTVIiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA3OCIgbmFtZT0iUXVlcnlF dmVudFN0YXR1
cyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4x MDk2IiBuYW1l
PSJRdWVyeVBhcmFtZXRlclZhbHVlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My41LjEwMiIgbmFtZT0iUXVlcnlQcmlvcml0eSIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDY2IiBuYW1lPSJRdWVyeVF1YW50 aXR5VW5pdCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDY3 IiBuYW1lPSJR
dWVyeVJlc3BvbnNlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My41
LjEwMyIgbmFtZT0iUXVlcnlTdGF0dXNDb2RlIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My41LjEwNCIgbmFtZT0iUmFjZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi4yMTciIG5hbWU9IlJBTSIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi42IiBuYW1lPSJSQyIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMjAuMiIgbmFtZT0iUkNEQUUiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjIwLjEiIG5hbWU9IlJD RFNBIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjIyMCIgbmFt ZT0iUkNEU1ki
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjgi IG5hbWU9IlJD
RkIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MjkiIG5hbWU9
IlJDVjIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjUuMTA1IiBu
YW1lPSJSZWxhdGlvbmFsT3BlcmF0b3IiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjUuMTA2IiBuYW1lPSJSZWxhdGlvbnNoaXBDb25qdW5jdGlv biIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDc2IiBuYW1l PSJSZWxpZ2lv
dXNBZmZpbGlhdGlvbiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
NS4xMDgiIG5hbWU9IlJlc3BvbnNlTGV2ZWwiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjUuMTA5IiBuYW1lPSJSZXNwb25zZU1vZGFsaXR5Ii8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjI1MCIgbmFtZT0iUkVU SU5PUEFUSFkg
SU5URVJQUkVUQVRJT04iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjUuMTEwIiBuYW1lPSJSb2xlQ2xhc3MiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjUuMTExIiBuYW1lPSJSb2xlQ29kZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNS4xMDciIG5hbWU9IlJvbGVMaW5rVHlwZSIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDY4IiBuYW1lPSJS b2xlU3RhdHVz
Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEx MiIgbmFtZT0i
Um91dGVPZkFkbWluaXN0cmF0aW9uIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My42Ljg4IiBuYW1lPSJSeE5vcm0iLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjYuMjQxIiBuYW1lPSJTQ0RIRUMgR0lTIFNwYXRpYWwg QWNjdXJhY3kg
VGllcnMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuOTYuMSIg
bmFtZT0iU0NUU1BBIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjUzIiBuYW1lPSJTRE0iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjUuMTEzIiBuYW1lPSJTZXF1ZW5jaW5nIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My41LjExNCIgbmFtZT0iU2VydmljZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNS4xMDAzIiBuYW1lPSJTZXJ2aWNlIGFjdG9y IHR5cGUiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTAwNCIg bmFtZT0iU2Vy
dmljZSB0YXJnZXQgdHlwZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNS4xMTYiIG5hbWU9IlNlcnZpY2VBY3RvckZ1bmN0aW9uIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjExNyIgbmFtZT0iU2VydmljZUFj dG9yU2lnbmF0
dXJlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41 LjExOCIgbmFt
ZT0iU2VydmljZUNvbmZpZGVudGlhbGl0eSIvPgogIDxjb2RlU3lzdGVtIG9p ZD0iMi4xNi44
NDAuMS4xMTM4ODMuNS4xMTkiIG5hbWU9IlNlcnZpY2VJbnRlcnByZXRhdGlv biIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMjAiIG5hbWU9 IlNlcnZpY2VM
aXN0VHlwZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNS4xMjEi
IG5hbWU9IlNlcnZpY2VNb29kIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjEyMiIgbmFtZT0iU2VydmljZVByaW9yaXR5Ii8+CiAgPGNvZGVT eXN0ZW0gb2lk
PSIyLjE2Ljg0MC4xLjExMzg4My41LjEyNCIgbmFtZT0iU2VydmljZVJlbGF0 aW9uc2hpcENo
ZWNrUG9pbnQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjUuMTI1
IiBuYW1lPSJTZXJ2aWNlUmVsYXRpb25zaGlwQ29uanVuY3Rpb24iLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTI2IiBuYW1lPSJTZXJ2aWNl UmVsYXRpb25z
aGlwSm9pbiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNS4xMjci
IG5hbWU9IlNlcnZpY2VSZWxhdGlvbnNoaXBTcGxpdCIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNS4xMjMiIG5hbWU9IlNlcnZpY2VSZWxhdGlv bnNoaXBUeXBl
Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEy OCIgbmFtZT0i
U2VydmljZVRhcmdldFR5cGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTA2OSIgbmFtZT0iU2V0T3BlcmF0b3IiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMjMyIiBuYW1lPSJTSUMiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMjUxIiBuYW1lPSJTTU9LRVIiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNSIgbmFtZT0iU05NIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjUxIiBuYW1lPSJTTk0zIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42Ljk2IiBuYW1lPSJTTk9N RUQtQ1QiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNTIiIG5h bWU9IlNOVCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yNDMi IG5hbWU9IlNP
QyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuMTku Ni4xIiBuYW1l
PSJTcGVjaWFsQXJyYW5nZW1lbnQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjUuMTI5IiBuYW1lPSJTcGVjaW1lblR5cGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMjI0IiBuYW1lPSJTUE4iLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA5OCIgbmFtZT0iU3R5bGVUeXBl Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwNzAiIG5hbWU9 IlN1YnN0YW5j
ZUFkbWluU3Vic3RpdHV0aW9uIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjEwNzEiIG5hbWU9IlN1YnN0aXR1dGlvbkNvbmRpdGlvbiIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMzAiIG5hbWU9IlN1cHBs eVNlcnZpY2Ui
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTMx IiBuYW1lPSJU
YWJsZUNlbGxIb3Jpem9udGFsQWxpZ24iLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjUuMTMyIiBuYW1lPSJUYWJsZUNlbGxTY29wZSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMzMiIG5hbWU9IlRhYmxlQ2Vs bFZlcnRpY2Fs
QWxpZ24iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjUuMTM0IiBu
YW1lPSJUYWJsZUZyYW1lIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41LjEzNSIgbmFtZT0iVGFibGVSb3dHcm91cFR5cGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuMTM2IiBuYW1lPSJUYWJsZVJ1bGVzIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEzNyIgbmFtZT0iVGFy Z2V0QXdhcmVu
ZXNzIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41 LjEwMTEiIG5h
bWU9IlRlbGVjb21tdW5pY2F0aW9uQWRkcmVzc1VzZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi4yNDYiIG5hbWU9IlRlbGluIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEzOSIgbmFtZT0iVGltaW5nRXZl bnQiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA5MyIgbmFt ZT0iVHJhbnNs
YXRpb25RdWFsaXR5Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My41
LjE0MCIgbmFtZT0iVHJpYmFsRW50aXR5VVMiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjYuMjQ1IiBuYW1lPSJVLlMuIEJvYXJkIG9uIEdlb2dy YXBoaWMgTmFt
ZXMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu NTQiIG5hbWU9
IlVDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjgiIG5hbWU9
IlVDVU0iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuMjI2IiBu
YW1lPSJVTFQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuNzUi
IG5hbWU9IlVNRCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi4y
MjciIG5hbWU9IlVNRCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
Ni41NiIgbmFtZT0iVU1MIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My42Ljg2IiBuYW1lPSJVTUxTIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjEwNzIiIG5hbWU9IlVuaXRPZk1lYXN1cmVQcmVmaXgiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA3MyIgbmFtZT0iVW5pdE9m TWVhc3VyZVBy
ZWZpeENhc2VTZW5zaXRpdmUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTQxIiBuYW1lPSJVbml0c09mTWVhc3VyZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNS4xNDIiIG5hbWU9IlVuaXRzT2ZNZWFzdXJl Q2FzZVNlbnNp
dGl2ZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu Ni41NSIgbmFt
ZT0iVVBDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42LjExIiBu
YW1lPSJVUkwiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjUuMTQz
IiBuYW1lPSJVUkxTY2hlbWUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuMjMxIiBuYW1lPSJVUyBaSVBDT0RFUyIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNi4yNDAiIG5hbWU9IlVTX0NPQyIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMjgiIG5hbWU9IlVXREEiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTQ0IiBuYW1lPSJWYWNjaW5l TWFudWZhY3R1
cmVyIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41 LjE0NSIgbmFt
ZT0iVmFjY2luZVR5cGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjUuMTQ2IiBuYW1lPSJWYWx1ZVNldE9wZXJhdG9yIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My42LjIyOSIgbmFtZT0iVkFOREYiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA5MSIgbmFtZT0iVmVyc2lvbiBp ZGVudGlmaWVy
cyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4y MzMiIG5hbWU9
IlZIQSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu NS4xNDciIG5h
bWU9IlZvY2FidWxhcnlEb21haW5RdWFsaWZpZXIiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuNzEiIG5hbWU9IlcxLVcyIi8+CiAgPGNvZGVT eXN0ZW0gb2lk
PSIyLjE2Ljg0MC4xLjExMzg4My42LjcyIiBuYW1lPSJXNCIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi43MyIgbmFtZT0iV0MiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjMwIiBuYW1lPSJXSE8iLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjMwLjEiIG5hbWU9IldIT0ZS RSIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMzAuMiIgbmFt ZT0iV0hPR0VS
Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjIz MC4zIiBuYW1l
PSJXSE9QT1IiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuMjMw
LjQiIG5hbWU9IldIT1NQQSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuMi4xLjMuMi40LjE1IiBuYW1lPSJTbm9tZWRDVCIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuMi4xLjMuMi40LjE1IiBuYW1lPSJCbG9vZFBy ZXNzdXJlU25D
VCIvPgo8L2NvZGVTeXN0ZW1zPg==
--B_3253171768_19938175--
Re: H3ET Tools Contribution [message #27126 is a reply to message #27086] Thu, 01 February 2007 05:42 Go to previous messageGo to next message
Thank you very much Brandon,
but i'm still unable to create a mif instance cause the editor is unable to
find the mif's root.
Could you suggest a mif from the ballot which should work?
I tryied with PRPA_*.mif in the ballot...
Thanks.
news:C1E77635.D405%bulrich@b2international.com...
> the
> Hope this helps,
> Brandon
>> at
>> at
>> Thanks.
>>>> to .vocab.tests)
>>> org.apache.batik
>>> org.xmlpull.v1
>>>> 3 Released "
>>> ed
>>> available
>>> by
>>> the
>>> Cheers,
>>> Brandon
>>> Pu
>>>> Brandon,
>>>> to .vocab.tests)
>>>> 3 Released "
>>>> Phenix
>>>>> will
>>>>> be
>>>>> Brandon
>>>>>> Both the
>>>>>> to
>>>>>> the
>>>>>> timing
>>>>>> becomes clear.)
>>>>>> Ale,
>>>>>> meeting
>>>>>> in
>>>>>> editing
>>>>>> Both
>>>>>> the
>>>>>> to
>>>>>> the
>>>>>> timing
>>>>>> becomes clear.)
>>>>>> made
>>>>>> I
>>>>>> will
>>>>>> Cheers,
>>>>>> Brandon
>>>>>>> Hi all,
>>>>>>> Regards, Ale.
>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #27165 is a reply to message #27086] Thu, 01 February 2007 05:45 Go to previous messageGo to next message
Thanks.
> the
> Hope this helps,
> Brandon
>> at
>> at
>> Thanks.
>>>> to .vocab.tests)
>>> org.apache.batik
>>> org.xmlpull.v1
>>>> 3 Released "
>>> ed
>>> available
>>> by
>>> the
>>> Cheers,
>>> Brandon
>>> Pu
>>>> Brandon,
>>>> to .vocab.tests)
>>>> 3 Released "
>>>> Phenix
>>>>> will
>>>>> be
>>>>> Brandon
>>>>>> Both the
>>>>>> to
>>>>>> the
>>>>>> timing
>>>>>> becomes clear.)
>>>>>> Ale,
>>>>>> meeting
>>>>>> in
>>>>>> editing
>>>>>> Both
>>>>>> the
>>>>>> to
>>>>>> the
>>>>>> timing
>>>>>> becomes clear.)
>>>>>> made
>>>>>> I
>>>>>> will
>>>>>> Cheers,
>>>>>> Brandon
>>>>>>> Hi all,
>>>>>>> Regards, Ale.
>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #27279 is a reply to message #27165] Fri, 02 February 2007 04:15 Go to previous messageGo to next message
Here are some static models that work from the September ballot docs that
you're using:
PRPA_MT101301.mif
PRPA_MT101304.mif
PRPA_RM101003.mif
In general, PRPA_MT* and PRPA_RM* static models should work, however these
static models may themselves have errors. If you view the static model in
the MIF editor (double-click e.g. PRPA_MT101302.mif), you will see
annotations describing warnings and errors in the static model.
Brandon
On 2/1/07 11:45 AM, in article epsgca$e29$1@utils.eclipse.org, "Ale"
> Thanks.
>> the
>> Hope this helps,
>> Brandon
>>> at
>>> tR
>>> at
>>> in
>>> Thanks.
>>>>> to .vocab.tests)
>>>> org.apache.batik
>>>> org.xmlpull.v1
>>>>> 3 Released "
http://www.connectingforhealth.nhs.uk/technical/standards/ne ws/hl7_v3_relea>>>>
s
>>>> ed
>>>> available
>>>> by
>>>> the
>>>> Cheers,
>>>> Brandon
>>>> Pu
>>>>> Brandon,
>>>>> to .vocab.tests)
>>>>> 3 Released "
>>>>> Phenix
>>>>>> will
>>>>>> be
>>>>>> Brandon
>>>>>>> Both the
>>>>>>> to
>>>>>>> the
>>>>>>> timing
>>>>>>> becomes clear.)
>>>>>>> Ale,
>>>>>>> meeting
>>>>>>> in
>>>>>>> editing
>>>>>>> Both
>>>>>>> the
>>>>>>> to
>>>>>>> the
>>>>>>> timing
>>>>>>> becomes clear.)
>>>>>>> made
>>>>>>> I
>>>>>>> will
>>>>>>> Cheers,
>>>>>>> Brandon
>>>>>>>> Hi all,
>>>>>>>> Regards, Ale.
>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #27315 is a reply to message #27279] Sat, 03 February 2007 05:56 Go to previous messageGo to next message
I checked out the CVS version, i get the error on the wizard pane and that's
the exception :
java.io.FileNotFoundException:
C:\work\development\tools\eclipses\jbosside2.0beta\..\org.ec lipse.ohf.h3et.mif.core\Resources\MIFStaticModelSerializatio nToFlat.xsl
(Impossibile trovare il percorso specificato)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:106)
at java.io.FileInputStream.<init>(FileInputStream.java:66)
at
sun.net.www.protocol.file.FileURLConnection.connect(FileURLC onnection.java:70)
at
sun.net.www.protocol.file.FileURLConnection.getInputStream(F ileURLConnection.java:161)
at
com.sun.org.apache.xerces.internal.impl.XMLEntityManager.set upCurrentEntity(XMLEntityManager.java:973)
at
com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.d etermineDocVersion(XMLVersionDetector.java:184)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:798)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
at
com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(D OMParser.java:250)
at
com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl. parse(DocumentBuilderImpl.java:292)
at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java :172)
at
org.eclipse.ohf.h3et.mif.core.MIFConvertorImpl.getTransforme rFromFile(MIFConvertorImpl.java:96)
at
org.eclipse.ohf.h3et.mif.core.MIFConvertorImpl.convertFromSe rializeToFlat(MIFConvertorImpl.java:114)
at
org.eclipse.ohf.h3et.mif.core.MIFConvertorImpl.convertV1ToV2 (MIFConvertorImpl.java:141)
at
org.eclipse.ohf.h3et.mif.core.MIFConvertorImpl.convertV1ToV2 (MIFConvertorImpl.java:128)
at
org.eclipse.ohf.h3et.mif.core.formats.MIFDocumentParser.pars e(MIFDocumentParser.java:285)
at org.eclipse.ohf.h3et.mif.core.MIFManager.loadDocument(MIFMan ager.java:56)
at
org.eclipse.ohf.h3et.mif.core.MIFContextImpl.loadNewDocInCac he(MIFContextImpl.java:144)
at
org.eclipse.ohf.h3et.mif.core.MIFContextImpl.load(MIFContext Impl.java:238)
at
org.eclipse.ohf.h3et.staticmodel.core.StaticModelContextImpl .load(StaticModelContextImpl.java:211)
at
org.eclipse.ohf.h3et.staticmodel.core.StaticModelContextImpl .getEntryPoint(StaticModelContextImpl.java:94)
at
org.eclipse.ohf.h3et.instanceeditor.ui.wizards.MessageInstan ceOptionsPage.createNameSuggestions(MessageInstanceOptionsPa ge.java:302)
at
org.eclipse.ohf.h3et.instanceeditor.ui.wizards.SelectMessage DefinitionPage.validatePage(SelectMessageDefinitionPage.java :128)
at
org.eclipse.ohf.h3et.instanceeditor.ui.wizards.SelectMessage DefinitionPage.access$0(SelectMessageDefinitionPage.java:115 )
at
org.eclipse.ohf.h3et.instanceeditor.ui.wizards.SelectMessage DefinitionPage$1$1.run(SelectMessageDefinitionPage.java:63)
news:C1E8BFC8.D480%bulrich@b2international.com...
> you're using:
> PRPA_MT101301.mif
> PRPA_MT101304.mif
> PRPA_RM101003.mif
> Brandon
>> to
>> Thanks.
>>>> from
>>> to
>>> the
>>> static
>>> the
>>> Hope this helps,
>>> Brandon
>>>> at
>>>> tR
>>>> at
>>>> in
>>>> from
>>>> Thanks.
>>>>>> little
>>>>>> to .vocab.tests)
>>>>>> just
>>>>> org.apache.batik
>>>>> org.xmlpull.v1
>>>>>> Version
>>>>>> 3 Released "
> s
>>>>> ed
>>>>> available
>>>>> by
>>>>> at
>>>>> the
>>>>> Cheers,
>>>>> Brandon
>>>>> Pu
>>>>>> Brandon,
>>>>>> little
>>>>>> to .vocab.tests)
>>>>>> just
>>>>>> Version
>>>>>> 3 Released "
>>>>>> Phenix
>>>>>>> will
>>>>>>> be
>>>>>>> Brandon
>>>>>>>> Both the
>>>>>>>> to
>>>>>>>> the
>>>>>>>> timing
>>>>>>>> becomes clear.)
>>>>>>>> Ale,
>>>>>>>> meeting
>>>>>>>> in
>>>>>>>> editing
>>>>>>>> Both
>>>>>>>> the
>>>>>>>> to
>>>>>>>> the
>>>>>>>> timing
>>>>>>>> becomes clear.)
>>>>>>>> made
>>>>>>>> Homebase.
>>>>>>>> I
>>>>>>>> will
>>>>>>>> Cheers,
>>>>>>>> Brandon
>>>>>>>>> Hi all,
>>>>>>>>> Regards, Ale.
>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #27755 is a reply to message #27279] Sat, 03 February 2007 06:07 Go to previous messageGo to next message
On the PRPA_MT101301.mif i get :
MIF Document Error : Wrong version null.
What is this meaning? What is it expecting?
> you're using:
> PRPA_MT101301.mif
> PRPA_MT101304.mif
> PRPA_RM101003.mif
> Brandon
>> to
>> Thanks.
>>>> from
>>> to
>>> the
>>> static
>>> the
>>> Hope this helps,
>>> Brandon
>>>> at
>>>> tR
>>>> at
>>>> in
>>>> from
>>>> Thanks.
>>>>>> little
>>>>>> to .vocab.tests)
>>>>>> just
>>>>> org.apache.batik
>>>>> org.xmlpull.v1
>>>>>> Version
>>>>>> 3 Released "
> s
>>>>> ed
>>>>> available
>>>>> by
>>>>> at
>>>>> the
>>>>> Cheers,
>>>>> Brandon
>>>>> Pu
>>>>>> Brandon,
>>>>>> little
>>>>>> to .vocab.tests)
>>>>>> just
>>>>>> Version
>>>>>> 3 Released "
>>>>>> Phenix
>>>>>>> will
>>>>>>> be
>>>>>>> Brandon
>>>>>>>> Both the
>>>>>>>> to
>>>>>>>> the
>>>>>>>> timing
>>>>>>>> becomes clear.)
>>>>>>>> Ale,
>>>>>>>> meeting
>>>>>>>> in
>>>>>>>> editing
>>>>>>>> Both
>>>>>>>> the
>>>>>>>> to
>>>>>>>> the
>>>>>>>> timing
>>>>>>>> becomes clear.)
>>>>>>>> made
>>>>>>>> Homebase.
>>>>>>>> I
>>>>>>>> will
>>>>>>>> Cheers,
>>>>>>>> Brandon
>>>>>>>>> Hi all,
>>>>>>>>> Regards, Ale.
>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #27791 is a reply to message #27755] Mon, 05 February 2007 03:23 Go to previous messageGo to next message
Are you using PRPA_MT101301.mif directly from the ballot pack? The validator
is expecting a MIF 2.0 file; i.e. the schemaVersion attribute of
mif:staticModel is expected to have a value of "2.0"
The message text can obviously be improved. ;)
In the message instance editor, MIF 1.0 to 2.0 conversions happen
on-the-fly. If you are editing a MIF directly, though, you will need to
explicitly convert the MIF 1.0 file to MIF 2.0. There is a provided utility
for this; right-click a MIF, choose HL7 MIF Operations > Convert to MIF 2.0.
Brandon
On 2/3/07 12:07 PM, in article eq1qe8$4fe$1@utils.eclipse.org, "Ale"
>> you're using:
>> PRPA_MT101301.mif
>> PRPA_MT101304.mif
>> PRPA_RM101003.mif
>> Brandon
>>> to
>>> Thanks.
>>>>> from
>>>> to
>>>> the
>>>> static
>>>> the
>>>> Hope this helps,
>>>> Brandon
>>>>> at
>>>>> ge
>>>>> tR
>>>>> at
>>>>> nF
>>>>> in
>>>>> from
>>>>> Thanks.
>>>>>>> little
>>>>>>> to .vocab.tests)
>>>>>>> just
>>>>>> org.apache.batik
>>>>>> org.xmlpull.v1
>>>>>>> Version
>>>>>>> 3 Released "
>> s
>>>>>> ed
>>>>>> available
>>>>>> by
>>>>>> at
>>>>>> the
>>>>>> Cheers,
>>>>>> Brandon
>>>>>> Pu
>>>>>>> Brandon,
>>>>>>> little
>>>>>>> to .vocab.tests)
>>>>>>> just
>>>>>>> Version
>>>>>>> 3 Released "
>>>>>>> Phenix
>>>>>>>> will
>>>>>>>> be
>>>>>>>> Brandon
>>>>>>>>> Both the
>>>>>>>>> to
>>>>>>>>> the
>>>>>>>>> timing
>>>>>>>>> becomes clear.)
>>>>>>>>> Ale,
>>>>>>>>> meeting
>>>>>>>>> in
>>>>>>>>> editing
>>>>>>>>> Both
>>>>>>>>> the
>>>>>>>>> to
>>>>>>>>> the
>>>>>>>>> timing
>>>>>>>>> becomes clear.)
>>>>>>>>> made
>>>>>>>>> Homebase.
>>>>>>>>> I
>>>>>>>>> will
>>>>>>>>> Cheers,
>>>>>>>>> Brandon
>>>>>>>>>> Hi all,
>>>>>>>>>> Regards, Ale.
>>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #27832 is a reply to message #27791] Mon, 05 February 2007 18:41 Go to previous messageGo to next message
I've imported all prpa* mifs from the september ballot into the h3et's mif
dir.
Concerning the schemaVersion, are you talking about the coremif?
Are no mif:staticModel elements on prpa* mifs... I'm a bit confused :)
I'm no more able to compile the cvs version, now i'm getting an error on
...mif.ui,
ModelValidator.java.
news:C1ECA811.D4E5%bulrich@b2international.com...
> validator
> utility
> 2.0.
> Brandon
>>> that
>>> you're using:
>>> PRPA_MT101301.mif
>>> PRPA_MT101304.mif
>>> PRPA_RM101003.mif
>>> these
>>> in
>>> Brandon
>>>> unable
>>>> to
>>>> Thanks.
>>>>>> from
>>>>> to
>>>>> the
>>>>>> exception:
>>>>> static
>>>>> in
>>>>> the
>>>>> Hope this helps,
>>>>> Brandon
>>>>>> exception:
>>>>>> at
>>>>>> ge
>>>>>> tR
>>>>>> at
>>>>>> nF
>>>>>> in
>>>>>> from
>>>>>> Thanks.
>>>>>> messaggio
>>>>>>>> little
>>>>>>>> .core
>>>>>>>> to .vocab.tests)
>>>>>>>> just
>>>>>>> org.apache.batik
>>>>>>> org.xmlpull.v1
>>>>>>>> Version
>>>>>>>> 3 Released "
>>> s
>>>>>>> ed
>>>>>>> available
>>>>>>> by
>>>>>>> found
>>>>>>> at
>>>>>>> the
>>>>>>> Cheers,
>>>>>>> Brandon
>>>>>>> "Phenix
>>>>>>> Pu
>>>>>>>> Brandon,
>>>>>>>> little
>>>>>>>> .core
>>>>>>>> to .vocab.tests)
>>>>>>>> just
>>>>>>>> Version
>>>>>>>> 3 Released "
>>>>>>>> Phenix
>>>>>>>>> will
>>>>>>>>> be
>>>>>>>>> Brandon
>>>>>>>>>> Both the
>>>>>>>>>> donated
>>>>>>>>>> to
>>>>>>>>>> the
>>>>>>>>>> timing
>>>>>>>>>> becomes clear.)
>>>>>>>>>> Ale,
>>>>>>>>>> meeting
>>>>>>>>>> in
>>>>>>>>>> editing
>>>>>>>>>> Both
>>>>>>>>>> the
>>>>>>>>>> donated
>>>>>>>>>> to
>>>>>>>>>> the
>>>>>>>>>> timing
>>>>>>>>>> becomes clear.)
>>>>>>>>>> made
>>>>>>>>>> Homebase.
>>>>>>>>>> I
>>>>>>>>>> will
>>>>>>>>>> Cheers,
>>>>>>>>>> Brandon
>>>>>>>>>>> Hi all,
>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #27873 is a reply to message #27791] Mon, 05 February 2007 18:50 Go to previous messageGo to next message
I'm not sure i correctly configured the prj.
i created the Mif dir with the mifs, coremif and cmetinfo, than i created
Vocab dir with oids.xml and
vocabulary.xml from the ballot?
correct? anything else?
> validator
> utility
> 2.0.
> Brandon
>>> that
>>> you're using:
>>> PRPA_MT101301.mif
>>> PRPA_MT101304.mif
>>> PRPA_RM101003.mif
>>> these
>>> in
>>> Brandon
>>>> unable
>>>> to
>>>> Thanks.
>>>>>> from
>>>>> to
>>>>> the
>>>>>> exception:
>>>>> static
>>>>> in
>>>>> the
>>>>> Hope this helps,
>>>>> Brandon
>>>>>> exception:
>>>>>> at
>>>>>> ge
>>>>>> tR
>>>>>> at
>>>>>> nF
>>>>>> in
>>>>>> from
>>>>>> Thanks.
>>>>>> messaggio
>>>>>>>> little
>>>>>>>> .core
>>>>>>>> to .vocab.tests)
>>>>>>>> just
>>>>>>> org.apache.batik
>>>>>>> org.xmlpull.v1
>>>>>>>> Version
>>>>>>>> 3 Released "
>>> s
>>>>>>> ed
>>>>>>> available
>>>>>>> by
>>>>>>> found
>>>>>>> at
>>>>>>> the
>>>>>>> Cheers,
>>>>>>> Brandon
>>>>>>> "Phenix
>>>>>>> Pu
>>>>>>>> Brandon,
>>>>>>>> little
>>>>>>>> .core
>>>>>>>> to .vocab.tests)
>>>>>>>> just
>>>>>>>> Version
>>>>>>>> 3 Released "
>>>>>>>> Phenix
>>>>>>>>> will
>>>>>>>>> be
>>>>>>>>> Brandon
>>>>>>>>>> Both the
>>>>>>>>>> message instance editor and the MIF validation tool will be
>>>>>>>>>> donated
>>>>>>>>>> to
>>>>>>>>>> the
>>>>>>>>>> Eclipse OHF in the near future. (We will update the list when the
>>>>>>>>>> timing
>>>>>>>>>> becomes clear.)
>>>>>>>>>> Ale,
>>>>>>>>>> There were two H3ET tools demonstrated at the HL7 working group
>>>>>>>>>> meeting
>>>>>>>>>> in
>>>>>>>>>> San Diego last Wednesday: a message instance editor that allows
>>>>>>>>>> editing
>>>>>>>>>> message instances based on MIF models, and a MIF validation tool.
>>>>>>>>>> Both
>>>>>>>>>> the
>>>>>>>>>> donated
>>>>>>>>>> to
>>>>>>>>>> the
>>>>>>>>>> timing
>>>>>>>>>> becomes clear.)
>>>>>>>>>> In the meantime, access to binary versions of these tools will be
>>>>>>>>>> made
>>>>>>>>>> available to the HL7 community, probably at the HL7 Project
>>>>>>>>>> Homebase.
>>>>>>>>>> I
>>>>>>>>>> will
>>>>>>>>>> update this list when the tools are publicly available.
>>>>>>>>>> Cheers,
>>>>>>>>>> Brandon
>>>>>>>>>> On 1/16/07 9:53 AM, "Alessandro Fredianelli"
>>>>>>>>>> <alessandro.fredianelli@italtbs.com> wrote:
>>>>>>>>>>> Hi all,
>>>>>>>>>>> any news about h3et tools commitment?
>>>>>>>>>>> Thank you very much.
>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> ohf-dev mailing list
>>>>>>>>>>> ohf-dev@eclipse.org
>>>>>>>>>>> https://dev.eclipse.org/mailman/listinfo/ohf-dev
Re: H3ET Tools Contribution [message #27913 is a reply to message #27873] Mon, 05 February 2007 19:06 Go to previous messageGo to next message
running the last cvs version i get this error :
"Ale" <alessandro.fredianelli@italtbs.com> ha scritto nel messaggio
news:eq8fro$cj6$1@utils.eclipse.org...
>> validator
>> utility
>> 2.0.
>> Brandon
>>>> that
>>>> you're using:
>>>> PRPA_MT101301.mif
>>>> PRPA_MT101304.mif
>>>> PRPA_RM101003.mif
>>>> these
>>>> in
>>>> Brandon
>>>>> unable
>>>>> to
>>>>> Thanks.
>>>>> messaggio
>>>>>>> from
>>>>>> you
>>>>>> to
>>>>>> using
>>>>>> the
>>>>>>> exception:
>>>>>> static
>>>>>> in
>>>>>> the
>>>>>> Hope this helps,
>>>>>> Brandon
>>>>>>> exception:
>>>>>>> at
>>>>>>> ge
>>>>>>> tR
>>>>>>> at
>>>>>>> nF
>>>>>>> in
>>>>>>> from
>>>>>>> Thanks.
>>>>>>> messaggio
>>>>>>>>> I'm trying to check out the H3ET through Eclipse H3ET and get a
>>>>>>>>> little
>>>>>>>>> bit lost - there're two forks of H3ET related, i.e.:
>>>>>>>>> - org.eclipse.ohf\H3ET\plugins\XXXXXXXXX
>>>>>>>>> - org.eclipse.ohf\plugins\org.eclipse.ohf.h3et.XXXXXXXXX (from
>>>>>>>>> .core
>>>>>>>>> to .vocab.tests)
>>>>>>>>> What packages should I check out as the minimized requirement if I
>>>>>>>>> just
>>>>>>>>> run as a HL7 V3 designer without using other OHF features?
>>>>>>>> org.apache.batik
>>>>>>>> org.xmlpull.v1
>>>>>>>>> Or is there any Getting Started tutorials?
>>>>>>>>> I assume it's the correct source to get the v3 tools announced by
>>>>>>>>> HL7/CFH/JIVA on Jan 11th re:
>>>>>>>>> "Eclipse-Based Message Development and Validation Tools for HL7
>>>>>>>>> Version
>>>>>>>>> 3 Released "
>>>> s
>>>>>>>> ed
>>>>>>>> available
>>>>>>>> by
>>>>>>>> found
>>>>>>>> at
>>>>>>>> the
>>>>>>>> Cheers,
>>>>>>>> Brandon
>>>>>>>> "Phenix
>>>>>>>> Pu
>>>>>>>>> Brandon,
>>>>>>>>> little
>>>>>>>>> .core
>>>>>>>>> to .vocab.tests)
>>>>>>>>> just
>>>>>>>>> Version
>>>>>>>>> 3 Released "
>>>>>>>>> Thanks for your effort!
>>>>>>>>> Phenix
>>>>>>>>> On 2007-01-22 21:21:30 +0800, Brandon Ulrich
>>>>>>>>> <bulrich@b2international.com> said:
>>>>>>>>>> The source for the Message Instance Editor and MIF Validator
>>>>>>>>>> tools
>>>>>>>>>> will
>>>>>>>>>> be
>>>>>>>>>> available from CVS within the next 48 hours.
>>>>>>>>>> Brandon
>>>>>>>>>>> Both the
>>>>>>>>>>> donated
>>>>>>>>>>> to
>>>>>>>>>>> the
>>>>>>>>>>> the
>>>>>>>>>>> timing
>>>>>>>>>>> becomes clear.)
>>>>>>>>>> On 1/16/07 10:26 AM, in article
>>>>>>>>>> C1D258C8.ADDF%bulrich@b2international.com,
>>>>>>>>>> "Brandon Ulrich" <bulrich@b2international.com> wrote:
>>>>>>>>>>> Ale,
>>>>>>>>>>> meeting
>>>>>>>>>>> in
>>>>>>>>>>> editing
>>>>>>>>>>> tool.
>>>>>>>>>>> Both
>>>>>>>>>>> the
>>>>>>>>>>> donated
>>>>>>>>>>> to
>>>>>>>>>>> the
>>>>>>>>>>> the
>>>>>>>>>>> timing
>>>>>>>>>>> becomes clear.)
>>>>>>>>>>> be
>>>>>>>>>>> made
>>>>>>>>>>> Homebase.
>>>>>>>>>>> I
>>>>>>>>>>> will
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Brandon
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>>> ohf-dev@eclipse.org
H3ET Project Configuration Instructions [message #28076 is a reply to message #27873] Wed, 07 February 2007 04:46 Go to previous messageGo to next message
That sounds correct. We're attempting to get permission to release a
pre-configured project with the necessary file structure to HL7 members. In
the meantime, I've added a wiki page with end-user project configuration
instructions at http://wiki.eclipse.org/index.php/H3ET_Project_Configuration
Brandon
On 2/6/07 12:50 AM, in article eq8fro$cj6$1@utils.eclipse.org, "Ale"
>> validator
>> utility
>> 2.0.
>> Brandon
>>>> that
>>>> you're using:
>>>> PRPA_MT101301.mif
>>>> PRPA_MT101304.mif
>>>> PRPA_RM101003.mif
>>>> these
>>>> in
>>>> Brandon
>>>>> unable
>>>>> to
>>>>> Thanks.
>>>>>>> from
>>>>>> to
>>>>>> the
>>>>>>> when i try to design a new mif instance i get the following
>>>>>>> exception:
>>>>>> static
>>>>>> in
>>>>>> the
>>>>>> Hope this helps,
>>>>>> Brandon
>>>>>>> exception:
>>>>>>> java.lang.IllegalArgumentException: Index out of bounds
>>>>>>> at org.eclipse.swt.SWT.error(SWT.java:3358)
>>>>>>> at org.eclipse.swt.SWT.error(SWT.java:3297)
>>>>>>> at org.eclipse.swt.SWT.error(SWT.java:3268)
>>>>>>> at org.eclipse.swt.widgets.Widget.error(Widget.java:435)
>>>>>>> at org.eclipse.swt.widgets.Combo.getItem(Combo.java:575)
>>>>>>> at
>>>>>>> com.jivamedical.h3et.instanceeditor.ui.wizards.MessageInstan ceOptionsPag
>>>>>>> e.
>>>>>>> ge
>>>>>>> tR
>>>>>>> at
>>>>>>> com.jivamedical.h3et.instanceeditor.ui.wizards.NewMessageIns tanceWizard.
>>>>>>> ca
>>>>>>> nF
>>>>>>> in
>>>>>>> ish(NewMessageInstanceWizard.java:157)
>>>>>>> I got MIFs from the september ballot docs, the vocab is also coming
>>>>>>> from
>>>>>>> that bundle but i'm not sure about oids.xml.
>>>>>>> Is available any h3et working eclipse project?
>>>>>>> Thanks.
>>>>>>> "Brandon Ulrich" <bulrich@b2international.com> ha scritto nel
>>>>>>> messaggio
>>>>>>> news:C1DFD9C4.D279%bulrich@b2international.com...
>>>>>>>>> little
>>>>>>>>> .core
>>>>>>>>> to .vocab.tests)
>>>>>>>> The active development is in the org.eclipse.ohf\plugins directory.
>>>>>>>>> just
>>>>>>>> You will need the following plug-ins:
>>>>>>>> org.eclipse.ohf.h3et.*
>>>>>>>> org.eclipse.ohf.utilities
>>>>>>>> org.apache.batik
>>>>>>>> org.apache.commons.codec
>>>>>>>> org.apache.commons.lang
>>>>>>>> org.xmlpull.v1
>>>>>>>> Sorry, the best place for help is on the newsgroup for now.
>>>>>>>>> Version
>>>>>>>>> 3 Released "
>>>>>>>> Yes, these are the tools referred to in the press release at
>>>> s
>>>>>>>> ed
>>>>>>>> As of this morning, binaries of these tools have also been made
>>>>>>>> available
>>>>>>>> by
>>>>>>>> the HL7 Tooling Collaborative. Installation instructions can be
>>>>>>>> found
>>>>>>>> at
>>>>>>>> the
>>>>>>>> HTC Eclipse Tooling site under downloads. See
>>>>>>>> http://hl7projects.hl7.nscee.edu/projects/htc/
>>>>>>>> Cheers,
>>>>>>>> Brandon
>>>>>>>> On 1/26/07 3:44 PM, in article epd444$2ju$1@utils.eclipse.org,
>>>>>>>> "Phenix
>>>>>>>> Pu
>>>>>>>> Qin" <phenix.pu.qin@gmail.com> wrote:
>>>>>>>>> Brandon,
>>>>>>>>> little
>>>>>>>>> .core
>>>>>>>>> to .vocab.tests)
>>>>>>>>> just
>>>>>>>>> Version
>>>>>>>>> 3 Released "
>>>>>>>>> Phenix
>>>>>>>>>> The source for the Message Instance Editor and MIF Validator tools
>>>>>>>>>> will
>>>>>>>>>> be
>>>>>>>>>> Brandon
>>>>>>>>>>> Both the
>>>>>>>>>>> donated
>>>>>>>>>>> to
>>>>>>>>>>> the
>>>>>>>>>>> timing
>>>>>>>>>>> becomes clear.)
>>>>>>>>>>> Ale,
>>>>>>>>>>> meeting
>>>>>>>>>>> in
>>>>>>>>>>> editing
>>>>>>>>>>> Both
>>>>>>>>>>> the
>>>>>>>>>>> donated
>>>>>>>>>>> to
>>>>>>>>>>> the
>>>>>>>>>>> timing
>>>>>>>>>>> becomes clear.)
>>>>>>>>>>> made
>>>>>>>>>>> Homebase.
>>>>>>>>>>> I
>>>>>>>>>>> will
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Brandon
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #28115 is a reply to message #27913] Wed, 07 February 2007 04:52 Go to previous messageGo to next message
You are missing some HL7 resource files, which you should be able to find in
your ballot. We'll add some getting started information to the wiki; for now
I suggest sticking with the released version from HL7's GForge site.
Brandon
On 2/6/07 1:06 AM, in article eq8gqb$e15$1@utils.eclipse.org, "Ale"
> .core\Resources\MIFStaticModelSerializationToFlat.xsl
>> "Brandon Ulrich" <bulrich@b2international.com> ha scritto nel messaggio
>>> validator
>>> utility
>>> 2.0.
>>> Brandon
>>>>> that
>>>>> you're using:
>>>>> PRPA_MT101301.mif
>>>>> PRPA_MT101304.mif
>>>>> PRPA_RM101003.mif
>>>>> these
>>>>> in
>>>>> Brandon
>>>>>> unable
>>>>>> to
>>>>>> Thanks.
>>>>>> messaggio
>>>>>>>> from
>>>>>>> Unfortunately, there isn't a complete H3ET workspace available for
>>>>>>> you
>>>>>>> to
>>>>>>> download since we cannot redistribute the HL7 files. You're fine
>>>>>>> using
>>>>>>> the
>>>>>>> files that you mention from the September ballot.
>>>>>>> We'll add a section to the Wiki that discusses configuring a new H3ET
>>>>>>> project; for now, I've attached an oids.xml file that you can use.
>>>>>>>> exception:
>>>>>>> The bug was encountered because the wizard was unable to identify a
>>>>>>> static
>>>>>>> model in the MIF that you selected. This has been (previously) fixed
>>>>>>> in
>>>>>>> the
>>>>>>> current source; an error message is now displayed when an improperly
>>>>>>> formatted MIF is chosen.
>>>>>>> Hope this helps,
>>>>>>> Brandon
>>>>>>> On 1/31/07 12:12 PM, in article epptjf$ogq$1@utils.eclipse.org, "Ale"
>>>>>>>> exception:
>>>>>>>> at
>>>>>>>> ge.
>>>>>>>> ge
>>>>>>>> tR
>>>>>>>> ootName(MessageInstanceOptionsPage.java:118)
>>>>>>>> at
>>>>>>>> .ca
>>>>>>>> nF
>>>>>>>> in
>>>>>>>> from
>>>>>>>> Thanks.
>>>>>>>> messaggio
>>>>>>>>>> little
>>>>>>>>>> .core
>>>>>>>>>> to .vocab.tests)
>>>>>>>>>> just
>>>>>>>>> org.apache.batik
>>>>>>>>> org.xmlpull.v1
>>>>>>>>>> Version
>>>>>>>>>> 3 Released "
>>>>> a>>
>>>>> s
>>>>>>>>> ed
>>>>>>>>> available
>>>>>>>>> by
>>>>>>>>> found
>>>>>>>>> at
>>>>>>>>> the
>>>>>>>>> Cheers,
>>>>>>>>> Brandon
>>>>>>>>> "Phenix
>>>>>>>>> Pu
>>>>>>>>>> Brandon,
>>>>>>>>>> little
>>>>>>>>>> .core
>>>>>>>>>> to .vocab.tests)
>>>>>>>>>> just
>>>>>>>>>> Version
>>>>>>>>>> 3 Released "
>>>>>>>>>> Phenix
>>>>>>>>>>> tools
>>>>>>>>>>> will
>>>>>>>>>>> be
>>>>>>>>>>> Brandon
>>>>>>>>>>>> Both the
>>>>>>>>>>>> donated
>>>>>>>>>>>> to
>>>>>>>>>>>> the
>>>>>>>>>>>> the
>>>>>>>>>>>> timing
>>>>>>>>>>>> becomes clear.)
>>>>>>>>>>>> Ale,
>>>>>>>>>>>> meeting
>>>>>>>>>>>> in
>>>>>>>>>>>> editing
>>>>>>>>>>>> tool.
>>>>>>>>>>>> Both
>>>>>>>>>>>> the
>>>>>>>>>>>> donated
>>>>>>>>>>>> to
>>>>>>>>>>>> the
>>>>>>>>>>>> the
>>>>>>>>>>>> timing
>>>>>>>>>>>> becomes clear.)
>>>>>>>>>>>> be
>>>>>>>>>>>> made
>>>>>>>>>>>> Homebase.
>>>>>>>>>>>> I
>>>>>>>>>>>> will
>>>>>>>>>>>> Cheers,
>>>>>>>>>>>> Brandon
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Project Configuration Instructions [message #28157 is a reply to message #28076] Wed, 07 February 2007 06:37 Go to previous message
It seems the only thing i still miss is cmetList.mif, where can i get it?
Does it have any relationship with cmetinfo.coremif from the ballot?
news:C1EF5E8A.D55E%bulrich@b2international.com...
> In
> instructions at
> Brandon
>>> validator
>>> utility
>>> 2.0.
>>> Brandon
>>>>> that
>>>>> you're using:
>>>>> PRPA_MT101301.mif
>>>>> PRPA_MT101304.mif
>>>>> PRPA_RM101003.mif
>>>>> these
>>>>> in
>>>>> Brandon
>>>>>> unable
>>>>>> to
>>>>>> Thanks.
>>>>>> messaggio
>>>>>>>> from
>>>>>>> you
>>>>>>> to
>>>>>>> using
>>>>>>> the
>>>>>>> H3ET
>>>>>>>> exception:
>>>>>>> static
>>>>>>> in
>>>>>>> the
>>>>>>> Hope this helps,
>>>>>>> Brandon
>>>>>>> "Ale"
>>>>>>>> exception:
>>>>>>>> at
>>>>>>>> e.
>>>>>>>> ge
>>>>>>>> tR
>>>>>>>> at
>>>>>>>> ca
>>>>>>>> nF
>>>>>>>> in
>>>>>>>> from
>>>>>>>> Thanks.
>>>>>>>> messaggio
>>>>>>>>>> little
>>>>>>>>>> .core
>>>>>>>>>> to .vocab.tests)
>>>>>>>>> directory.
>>>>>>>>>> I
>>>>>>>>>> just
>>>>>>>>> org.apache.batik
>>>>>>>>> org.xmlpull.v1
>>>>>>>>>> Version
>>>>>>>>>> 3 Released "
>>>>> s
>>>>>>>>> ed
>>>>>>>>> available
>>>>>>>>> by
>>>>>>>>> found
>>>>>>>>> at
>>>>>>>>> the
>>>>>>>>> Cheers,
>>>>>>>>> Brandon
>>>>>>>>> "Phenix
>>>>>>>>> Pu
>>>>>>>>>> Brandon,
>>>>>>>>>> little
>>>>>>>>>> .core
>>>>>>>>>> to .vocab.tests)
>>>>>>>>>> I
>>>>>>>>>> just
>>>>>>>>>> Version
>>>>>>>>>> 3 Released "
>>>>>>>>>> Phenix
>>>>>>>>>>> tools
>>>>>>>>>>> will
>>>>>>>>>>> be
>>>>>>>>>>> Brandon
>>>>>>>>>>>> Both the
>>>>>>>>>>>> donated
>>>>>>>>>>>> to
>>>>>>>>>>>> the
>>>>>>>>>>>> the
>>>>>>>>>>>> timing
>>>>>>>>>>>> becomes clear.)
>>>>>>>>>>>> Ale,
>>>>>>>>>>>> meeting
>>>>>>>>>>>> in
>>>>>>>>>>>> editing
>>>>>>>>>>>> tool.
>>>>>>>>>>>> Both
>>>>>>>>>>>> the
>>>>>>>>>>>> donated
>>>>>>>>>>>> to
>>>>>>>>>>>> the
>>>>>>>>>>>> the
>>>>>>>>>>>> timing
>>>>>>>>>>>> becomes clear.)
>>>>>>>>>>>> be
>>>>>>>>>>>> made
>>>>>>>>>>>> Homebase.
>>>>>>>>>>>> I
>>>>>>>>>>>> will
>>>>>>>>>>>> Cheers,
>>>>>>>>>>>> Brandon
>>>>>>>>>>>>> Hi all,
>>>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>>>> ohf-dev@eclipse.org
H3ET Tools Contribution [message #577293 is a reply to message #26404] Mon, 22 January 2007 08:21 Go to previous message
The source for the Message Instance Editor and MIF Validator tools will be
Brandon
> Both the
> message instance editor and the MIF validation tool will be donated to the
> Eclipse OHF in the near future. (We will update the list when the timing
> becomes clear.)
On 1/16/07 10:26 AM, in article C1D258C8.ADDF%bulrich@b2international.com,
> Ale,
> There were two H3ET tools demonstrated at the HL7 working group meeting in
> San Diego last Wednesday: a message instance editor that allows editing
> message instances based on MIF models, and a MIF validation tool. Both the
> becomes clear.)
> In the meantime, access to binary versions of these tools will be made
> available to the HL7 community, probably at the HL7 Project Homebase. I will
> Cheers,
> Brandon
>> Hi all,
>> Regards, Ale.
>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577413 is a reply to message #26717] Fri, 26 January 2007 09:44 Go to previous message
Originally posted by: phenix.pu.qin.gmail.com
Brandon,
I'm trying to check out the H3ET through Eclipse H3ET and get a little
- org.eclipse.ohf\plugins\org.eclipse.ohf.h3et.XXXXXXXXX (from .core
to .vocab.tests)
What packages should I check out as the minimized requirement if I just
"Eclipse-Based Message Development and Validation Tools for HL7 Version
3 Released "
Phenix
> Brandon
>> Both the
>> becomes clear.)
>> Ale,
>> becomes clear.)
>> Cheers,
>> Brandon
>>> Hi all,
>>> Regards, Ale.
>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577432 is a reply to message #26884] Fri, 26 January 2007 10:09 Go to previous message
Brandon,
Just find the release post of H3ET in HL7 Tooling Maillist that may
answer the question I posted, thanks :).
Phenix
On 2007-01-26 22:44:14 +0800, Phenix Pu Qin <phenix.pu.qin@gmail.com> said:
> Brandon,
> to .vocab.tests)
> 3 Released "
> Phenix
>> Brandon
>>> Both the
>>> becomes clear.)
>>> Ale,
>>> becomes clear.)
>>> Cheers,
>>> Brandon
>>>> Hi all,
>>>> Regards, Ale.
>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577455 is a reply to message #26884] Fri, 26 January 2007 10:16 Go to previous message
> to .vocab.tests)
org.apache.batik
org.xmlpull.v1
> 3 Released "
http://www.connectingforhealth.nhs.uk/technical/standards/ne ws/hl7_v3_releas
ed
As of this morning, binaries of these tools have also been made available by
the HL7 Tooling Collaborative. Installation instructions can be found at the
Brandon
On 1/26/07 3:44 PM, in article epd444$2ju$1@utils.eclipse.org, "Phenix Pu
> Brandon,
> to .vocab.tests)
> 3 Released "
> Phenix
>> Brandon
>>> Both the
>>> becomes clear.)
>>> Ale,
>>> becomes clear.)
>>> Cheers,
>>> Brandon
>>>> Hi all,
>>>> Regards, Ale.
>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577506 is a reply to message #26964] Wed, 31 January 2007 06:12 Go to previous message
when i try to design a new mif instance i get the following exception:
at
com.jivamedical.h3et.instanceeditor.ui.wizards.MessageInstan ceOptionsPage.getRootName(MessageInstanceOptionsPage.java:11 8)
at
com.jivamedical.h3et.instanceeditor.ui.wizards.NewMessageIns tanceWizard.canFinish(NewMessageInstanceWizard.java:157)
I got MIFs from the september ballot docs, the vocab is also coming from
Thanks.
>> to .vocab.tests)
> org.apache.batik
> org.xmlpull.v1
>> 3 Released "
> ed
> by
> the
> Cheers,
> Brandon
>> Brandon,
>> to .vocab.tests)
>> 3 Released "
>> Phenix
>>> be
>>> Brandon
>>>> Both the
>>>> the
>>>> timing
>>>> becomes clear.)
>>>> Ale,
>>>> in
>>>> the
>>>> the
>>>> timing
>>>> becomes clear.)
>>>> will
>>>> Cheers,
>>>> Brandon
>>>>> Hi all,
>>>>> Regards, Ale.
>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577526 is a reply to message #27044] Thu, 01 February 2007 04:49 Go to previous message
> This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
Content-type: text/plain;
charset="US-ASCII"
Content-transfer-encoding: 7bit
Unfortunately, there isn't a complete H3ET workspace available for you to
download since we cannot redistribute the HL7 files. You're fine using the
The bug was encountered because the wizard was unable to identify a static
model in the MIF that you selected. This has been (previously) fixed in the
Hope this helps,
Brandon
> at
> at
> Thanks.
>>> to .vocab.tests)
>> org.apache.batik
>> org.xmlpull.v1
>>> 3 Released "
>> ed
>> by
>> the
>> Cheers,
>> Brandon
>>> Brandon,
>>> to .vocab.tests)
>>> 3 Released "
>>> Phenix
>>>> be
>>>> Brandon
>>>>> Both the
>>>>> the
>>>>> timing
>>>>> becomes clear.)
>>>>> Ale,
>>>>> in
>>>>> the
>>>>> the
>>>>> timing
>>>>> becomes clear.)
>>>>> will
>>>>> Cheers,
>>>>> Brandon
>>>>>> Hi all,
>>>>>> Regards, Ale.
>>>>>> ohf-dev@eclipse.org
Content-type: application/octet-stream; name="oids.xml"
Content-disposition: attachment;
filename="oids.xml"
Content-transfer-encoding: base64
PGNvZGVTeXN0ZW1zPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi4y
NSIgbmFtZT0iQUJDY29kZXMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTA1MCIgbmFtZT0iQWNrbm93bGVkZ2VtZW50Q29uZGl0aW9uIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjExMDAiIG5hbWU9IkFj a25vd2xlZGdl
bWVudERldGFpbENvZGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjUuMTA4MiIgbmFtZT0iQWNrbm93bGVkZ2VtZW50RGV0YWlsVHlwZSIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xOCIgbmFtZT0iQWNrbm93 bGVkZ2VtZW50
VHlwZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu Ni43NiIgbmFt
ZT0iQUNSIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My41LjMiIG5h
bWU9IkFjdCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNS42IiBu
YW1lPSJBY3RDbGFzcyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
NS40IiBuYW1lPSJBY3RDb2RlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjUiIG5hbWU9IkFjdEludGVycHJldGF0aW9uIi8+CiAgPGNvZGVT eXN0ZW0gb2lk
PSIyLjE2Ljg0MC4xLjExMzg4My41LjEwNTEiIG5hbWU9IkFjdEludm9pY2VF bGVtZW50TW9k
aWZpZXIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjUuMTEwMyIg
bmFtZT0iQWN0aXZlIEluZ3JlZGllbnQgQ29kZSIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNS4xMTA0IiBuYW1lPSJBY3RpdmUgSW5ncmVkaWVu dCBHcm91cCBD
b2RlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41 LjExMDYiIG5h
bWU9IkFjdGl2ZSBJbmdyZWRpZW50IEdyb3VwIE51bWJlciIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDAxIiBuYW1lPSJBY3RNb29kIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjciIG5hbWU9IkFjdFBy aW9yaXR5Ii8+
CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjgiIG5h bWU9IkFjdFJl
YXNvbiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu NS4xMCIgbmFt
ZT0iQWN0UmVsYXRpb25zaGlwQ2hlY2twb2ludCIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNS4xMSIgbmFtZT0iQWN0UmVsYXRpb25zaGlwQ29u anVuY3Rpb24i
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTIi IG5hbWU9IkFj
dFJlbGF0aW9uc2hpcEpvaW4iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTMiIG5hbWU9IkFjdFJlbGF0aW9uc2hpcFNwbGl0Ii8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwOTkiIG5hbWU9IkFjdFJlbGF0 aW9uc2hpcFN1
YnNldCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu NS4xMDAyIiBu
YW1lPSJBY3RSZWxhdGlvbnNoaXBUeXBlIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My41LjEwNTIiIG5hbWU9IkFjdFNpdGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuMTQiIG5hbWU9IkFjdFN0YXR1cyIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMTA5IiBuYW1lPSJBY3RU aGVyYXB5RHVy
YXRpb25Xb3JraW5nTGlzdENvZGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjUuMTUiIG5hbWU9IkFjdFR5cGUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjUuMTA1MyIgbmFtZT0iQWN0VW5jZXJ0YWludHkiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTYiIG5hbWU9IkFkZHJl c3NQYXJ0VHlw
ZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4x NyIgbmFtZT0i
QWRkcmVzc1VzZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS4x
IiBuYW1lPSJBZG1pbmlzdHJhdGl2ZUdlbmRlciIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNi4yMzQiIG5hbWU9IkFIRlMiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMTExIiBuYW1lPSJBTFQiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA1NCIgbmFtZT0iQW1lcmljYW5J bmRpYW5BbGFz
a2FOYXRpdmVMYW5ndWFnZXMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuMTEyIiBuYW1lPSJBT0QiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjYuNzQiIG5hbWU9IkFSVCIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuMTkuOS4xIiBuYW1lPSJBcnRlZmFjdCBUeXBlOiBDREEgRG9j dW1lbnQiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjE5LjguMSIg bmFtZT0iQXJ0
ZWZhY3QgVHlwZTogSEw3IFYyIE1lc3NhZ2UiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjE5LjcuMSIgbmFtZT0iQXJ0ZWZhY3QgVHlwZTogSEw3 IFYzIE1lc3Nh
Z2UiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MzAiIG5hbWU9
IkFTNCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu Ni43OCIgbmFt
ZT0iQVM0RSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi43NyIg
bmFtZT0iQVRDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjEx Mzg4My42LjEx
MyIgbmFtZT0iQkkiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjYu
MTIiIG5hbWU9IkM0Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjgyIiBuYW1lPSJDNSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
NS4xMDU1IiBuYW1lPSJDYWxlbmRhciIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuNS4xMDE4IiBuYW1lPSJDYWxlbmRhciBjeWNsZSBvbmUgbGV0 dGVyIGNvZGUi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTAx OSIgbmFtZT0i
Q2FsZW5kYXIgY3ljbGUgdHdvIGxldHRlciBjb2RlIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My41LjkiIG5hbWU9IkNhbGVuZGFyQ3ljbGUiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA5MCIgbmFtZT0iQ2Fs ZW5kYXJDeWNs
ZU9uZUxldHRlciIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS4x
MDE3IiBuYW1lPSJDYWxlbmRhclR5cGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjYuMTkiIG5hbWU9IkNBTU5DVlMiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuNjEiIG5hbWU9IkNBUyIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi4yMzYiIG5hbWU9IkNDQyIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi45NSIgbmFtZT0iQ0NJIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjExNCIgbmFtZT0iQ0NQU1MiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTE1IiBuYW1lPSJDQ1Mi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTMiIG5hbWU9IkNE MiIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMzkiIG5hbWU9 IkNEQV9SVVMi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNTci IG5hbWU9IkNE
Q0EiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu NTgiIG5hbWU9
IkNEQ00iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuNzkiIG5h
bWU9IkNEUyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi4xMTYi
IG5hbWU9IkNEVCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi44
MCIgbmFtZT0iQ0UiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjUu
MjEiIG5hbWU9IkNoYXJzZXQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTA4MSIgbmFtZT0iQ0lISUFkaiIvPgogIDxjb2RlU3lzdGVtIG9p ZD0iMi4xNi44
NDAuMS4xMTM4ODMuNi44MSIgbmFtZT0iQ0xQIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My41LjIyIiBuYW1lPSJDb2RlU3lzdGVtIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwODUiIG5hbWU9IkNvZGVTeXN0 ZW1UeXBlIi8+
CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwNzQi IG5hbWU9IkNv
ZGluZ1JhdGlvbmFsZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
NS4xMDU2IiBuYW1lPSJDb21tdW5pY2F0aW9uRnVuY3Rpb25UeXBlIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwMDkiIG5hbWU9IkNvbXBy ZXNzaW9uQUxn
b3JpdGhtIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My41LjEwODgi
IG5hbWU9IkNvbmNlcHRDb2RlUmVsYXRpb25zaGlwIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My41LjI0IiBuYW1lPSJDb25jZXB0R2VuZXJhbGl0 eSIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDg3IiBuYW1l PSJDb25jZXB0
UHJvcGVydHkiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjUuMTA4
NiIgbmFtZT0iQ29uY2VwdFN0YXR1cyIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuNS4yNSIgbmFtZT0iQ29uZmlkZW50aWFsaXR5Ii8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjI2IiBuYW1lPSJDb250YWluZXJD YXAiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMjciIG5hbWU9 IkNvbnRhaW5l
clNlcGFyYXRvciIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS4x
MTEwIiBuYW1lPSJDb250ZW50UHJvY2Vzc2luZ01vZGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuMTA1NyIgbmFtZT0iQ29udGV4dENvbnRy b2wiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTE3IiBuYW1l PSJDT1NUQVIi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMjgi IG5hbWU9IkNv
dW50cnkiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuMTE4IiBu
YW1lPSJDUE0iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuMTIu
MSIgbmFtZT0iQ1BUU1AiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjYuMjM1IiBuYW1lPSJDU0FJRCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4x Ni44NDAuMS4x
MTM4ODMuNi4xMjAiIG5hbWU9IkNTUCIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuNi42MiIgbmFtZT0iQ1NUIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My41LjEwNTgiIG5hbWU9IkN1cnJlbmN5Ii8+CiAgPGNvZGVT eXN0ZW0gb2lk
PSIyLjE2Ljg0MC4xLjExMzg4My42LjU5IiBuYW1lPSJDVlgiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjQ0IiBuYW1lPSJEMUNTIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwMDciIG5hbWU9IkRhdGFU eXBlIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjgzIiBuYW1l PSJEQ0wiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMzEiIG5h bWU9IkRDTSIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMS4yLjg0MC4xMDAwOC4yLjE2LjQiIG5h bWU9IkRDTSIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xMjIi IG5hbWU9IkRE
QiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4x MDIiIG5hbWU9
IkRFRURTIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42Ljg5IiBu
YW1lPSJERUVEUyhvbGQpIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My42LjEwMi4yLjEwIiBuYW1lPSJERUVEUzIuMTAiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTAyLjQuMiIgbmFtZT0iREVFRFM0LjAyIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjEwMi40LjUiIG5hbWU9 IkRFRURTNC4w
NSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4x MDIuNC43IiBu
YW1lPSJERUVEUzQuMDciLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjYuMTAyLjQuOCIgbmFtZT0iREVFRFM0LjA4Ii8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My42LjEwMi40LjEyIiBuYW1lPSJERUVEUzQuMTIiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTAyLjQuMTQiIG5hbWU9 IkRFRURTNC4x
NCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4x MDIuNC4xNSIg
bmFtZT0iREVFRFM0LjE1Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My42LjEwMi40LjE2IiBuYW1lPSJERUVEUzQuMTYiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTAyLjQuMTgiIG5hbWU9IkRFRURTNC4xOCIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xMDIuNC4yMiIgbmFt ZT0iREVFRFM0
LjIyIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjEwMi40LjI0
IiBuYW1lPSJERUVEUzQuMjQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuMTAyLjQuMjciIG5hbWU9IkRFRURTNC4yNyIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi4xMDIuNS42IiBuYW1lPSJERUVEUzUuMDYi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTAyLjUuOCIgbmFt ZT0iREVFRFM1
LjA4Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjEwMi41LjE5
IiBuYW1lPSJERUVEUzUuMTkiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTA4MCIgbmFtZT0iRGVudGl0aW9uIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My41LjEwODkiIG5hbWU9IkRlbnRpdGlvbiIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4zMSIgbmFtZT0iRGV2aWNlQWxl cnRMZXZlbCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yNTIi IG5hbWU9IkRJ
QUdOT1NUSUMgSU1BR0UgTUVUSE9EIENPREUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjUuMzIiIG5hbWU9IkRpZXRTZXJ2aWNlIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjMuMyIgbmFtZT0iRE1ESUNEMTAi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjI3LjEiIG5hbWU9 IkRNRFVNRCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4zMyIg bmFtZT0iRG9j
dW1lbnRDb21wbGV0aW9uIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41LjM0IiBuYW1lPSJEb2N1bWVudFN0b3JhZ2UiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMzIiIG5hbWU9IkRRTCIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi4xMjUiIG5hbWU9IkRTTTNSIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjEyNiIgbmFtZT0iRFNNNCIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xMjciIG5hbWU9IkRYUCIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4zNCIgbmFtZT0iRSIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4zNSIgbmFtZT0iRTUi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMzYiIG5hbWU9IkU2 Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjM3IiBuYW1lPSJF NyIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4zNSIgbmFtZT0i RWRpdFN0YXR1
cyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4x MDc3IiBuYW1l
PSJFZHVjYXRpb25MZXZlbCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNS4xMDU5IiBuYW1lPSJFbXBsb3llZUpvYkNsYXNzIi8+CiAgPGNvZGVT eXN0ZW0gb2lk
PSIyLjE2Ljg0MC4xLjExMzg4My41LjExMDgiIG5hbWU9IkVuY29kZS1GTSIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4zNiIgbmFtZT0iRW5j b3VudGVyQWNj
aWRlbnQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjUuMTA4NCIg
bmFtZT0iRW5jb3VudGVyQWN1aXR5Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My41LjM4IiBuYW1lPSJFbmNvdW50ZXJBZG1pc3Npb25Qcmlvcml0 eSIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4zNyIgbmFtZT0i RW5jb3VudGVy
QWRtaXNzaW9uU291cmNlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41LjM5IiBuYW1lPSJFbmNvdW50ZXJSZWZlcnJhbFNvdXJjZSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS40MCIgbmFtZT0iRW5jb3VudGVy U3BlY2lhbENv
dXJ0ZXN5Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My41LjQxIiBu
YW1lPSJFbnRpdHlDbGFzcyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNS4xMDYwIiBuYW1lPSJFbnRpdHlDb2RlIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My41LjMwIiBuYW1lPSJFbnRpdHlEZXRlcm1pbmVyIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjQyIiBuYW1lPSJFbnRp dHlIYW5kbGlu
ZyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS40 MyIgbmFtZT0i
RW50aXR5TmFtZVBhcnRRdWFsaWZpZXIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjUuNDQiIG5hbWU9IkVudGl0eU5hbWVQYXJ0VHlwZSIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS40NSIgbmFtZT0iRW50aXR5 TmFtZVVzZSIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS40NiIg bmFtZT0iRW50
aXR5UmlzayIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNS40NyIg
bmFtZT0iRW50aXR5Um9sZVJlbGF0aW9uc2hpcFR5cGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuMTA2MSIgbmFtZT0iRW50aXR5U3RhdHVz Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjQ4IiBuYW1lPSJF bnRpdHlUeXBl
Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjMz IiBuYW1lPSJF
TlpDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjI0MiIgbmFt
ZT0iRVBTRyBHZW9kZXRpYyBwYXJhbWV0ZXIgZGF0YXNldCIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNS40OSIgbmFtZT0iRXF1aXBtZW50QWxl cnRMZXZlbCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS41MCIg bmFtZT0iRXRo
bmljaXR5Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42LjI0NyIg
bmFtZT0iRVRITklDSVRZIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41LjEwMjMiIG5hbWU9IkV2ZW50IGNvZGUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjE5LjUuMSIgbmFtZT0iRXhhbXBsZSBjb2RlIHN5c3Rl bXMiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNjQiIG5hbWU9 IkZEREMiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNjMiIG5h bWU9IkZERFgi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMzgi IG5hbWU9IkZE
SyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi45 MiIgbmFtZT0i
RklQU1BVQjIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuOTMi
IG5hbWU9IkZJUFNQVUI2LTQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuOTEiIG5hbWU9IkZJUFNQVUI5MiIvPgogIDxjb2RlU3lzdGVtIG9p ZD0iMi4xNi44
NDAuMS4xMTM4ODMuNi4yNDgiIG5hbWU9IkZJUlNUIE5BVElPTlMgU1RBVFVT Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjExOSIgbmFtZT0i Rk1BIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjUxIiBuYW1l PSJHZW5kZXJT
dGF0dXMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuMTI4IiBu
YW1lPSJHTyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNS4xMDIy
IiBuYW1lPSJHVFNBYmJyZXZpYXRpb24iLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjYuNDAiIG5hbWU9IkhCIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My42LjEyOSIgbmFtZT0iSENEVCIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNi4xMzAiIG5hbWU9IkhDUFQiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuNTMiIG5hbWU9IkhlYWx0aGNhcmVQcm92 aWRlclRheG9u
b215SElQQUEiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuMTci
IG5hbWU9IkhIQ0MiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjYu
MzkiIG5hbWU9IkhJIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My41
LjU0IiBuYW1lPSJITDdDb21taXR0ZWVJREluUklNIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My41LjU1IiBuYW1lPSJITDdDb25mb3JtYW5jZUlu Y2x1c2lvbiIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS41NiIg bmFtZT0iSEw3
RGVmaW5lZFJvc2VQcm9wZXJ0eSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4x Ni44NDAuMS4x
MTM4ODMuNS4xMTAxIiBuYW1lPSJITDdEb21haW5zIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My41LjEwOTIiIG5hbWU9IkhMN0lUU1ZlcnNpb25D b2RlIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwOTciIG5h bWU9IkhMN1N0
YW5kYXJkVmVyc2lvbkNvZGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuNTciIG5hbWU9IkhMN1VwZGF0ZU1vZGUiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjUuMTA3OSIgbmFtZT0iSEw3VjMiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTMyIiBuYW1lPSJITFJFTCIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNCIgbmFtZT0iSFBDIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjU4IiBuYW1lPSJIdG1s TGlua1R5cGUi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTMz IiBuYW1lPSJI
VUdPIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjQyIiBuYW1l
PSJJOSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu Ni4xOCIgbmFt
ZT0iSUIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuNDQiIG5h
bWU9IklDMiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi4zIiBu
YW1lPSJJQ0QxMCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi4z
LjEiIG5hbWU9IklDRDEwQUUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuMTM1IiBuYW1lPSJJQ0QxMEFNIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My42LjEzNS4xIiBuYW1lPSJJQ0QxMEFNQUUiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuOTQiIG5hbWU9IklDRDEwLUNhIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjkwIiBuYW1lPSJJQ0Qx MENNIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjMuMiIgbmFt ZT0iSUNEMTBE
VVQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu NCIgbmFtZT0i
SUNEMTBQQ1MiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuMiIg
bmFtZT0iSUNEOUNNIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjEwMyIgbmFtZT0iSUNELTlDTSAoZGlhZ25vc2lzIGNvZGVzKSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xMDQiIG5hbWU9IklDRC05Q00g KHByb2NlZHVy
ZSBjb2RlcykiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuNDMi
IG5hbWU9IklDRE8iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjYu
OTciIG5hbWU9IklDTlAiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjYuMTM4IiBuYW1lPSJJQ1BDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My42LjEzOS4xIiBuYW1lPSJJQ1BDMkVEVVQiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTM5IiBuYW1lPSJJQ1BDMkVFTkciLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTQyLjEiIG5hbWU9IklDUEMy SUNEMTBEVVQi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTQy IiBuYW1lPSJJ
Q1BDMklDRDEwRU5HIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjE0MC4yIiBuYW1lPSJJQ1BDMlAiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjYuMTM4LjEiIG5hbWU9IklDUENCQVEiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTM4LjIiIG5hbWU9IklDUENEQU4iLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTM4LjMiIG5hbWU9IklDUENE VVQiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTM4LjQiIG5h bWU9IklDUENG
SU4iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MTM4LjUiIG5h
bWU9IklDUENGUkUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjYu
MTM4LjYiIG5hbWU9IklDUENHRVIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjYuMTM4LjciIG5hbWU9IklDUENIRUIiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTM4LjgiIG5hbWU9IklDUENIVU4iLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTM4LjkiIG5hbWU9IklDUENJ VEEiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTM4LjEwIiBu YW1lPSJJQ1BD
Tk9SIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjE0MC4xIiBu
YW1lPSJJQ1BDUEFFIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjEzOC4xMSIgbmFtZT0iSUNQQ1BPUiIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuNi4xMzguMTIiIG5hbWU9IklDUENTUEEiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMTM4LjEzIiBuYW1lPSJJQ1BDU1dFIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjQxIiBuYW1lPSJJQ1Mi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNDUiIG5hbWU9IklD U0QiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuODQiIG5hbWU9 IklFVEYxNzY2
Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjEy MSIgbmFtZT0i
SUVURjMwNjYiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjUuMTAx
MCIgbmFtZT0iSW50ZWdyaXR5Q2hlY2tBbGdvcml0aG0iLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuMSIgbmFtZT0iSVNPMzE2Ni0xIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2LjIi
IG5hbWU9IklTTzMxNjYtMiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi4z IiBuYW1lPSJJ
U08zMTY2LTMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuOSIg
bmFtZT0iSVNPNDIxNyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
Ni45OSIgbmFtZT0iSVNPNjM5LTEiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjYuMTAwIiBuYW1lPSJJU082MzktMiIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNi40NyIgbmFtZT0iSVVQQyIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi40NiIgbmFtZT0iSVVQUCIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNTgiIG5hbWU9IkpBQkwiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNDgiIG5hbWU9IkpDOCIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS42MCIgbmFtZT0iTGFuZ3Vh Z2VBYmlsaXR5
TW9kZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu NS42MSIgbmFt
ZT0iTGFuZ3VhZ2VBYmlsaXR5UHJvZmljaWVuY3kiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTU5IiBuYW1lPSJMQ0giLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuNjIiIG5hbWU9Ikxpc3RUeXBlIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjYzIiBuYW1lPSJMaXZpbmdB cnJhbmdlbWVu
dCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS42 NCIgbmFtZT0i
TGl2aW5nU3ViamVjdFByb2R1Y3Rpb25DbGFzcyIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNi4xIiBuYW1lPSJMTiIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNS42NSIgbmFtZT0iTG9jYWxNYXJrdXBJZ25vcmUi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuNjYiIG5hbWU9Ikxv Y2FsUmVtb3Rl
Q29udHJvbFN0YXRlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My41
LjEwNjIiIG5hbWU9Ik1hbmFnZWRQYXJ0aWNpcGF0aW9uU3RhdHVzIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjY3IiBuYW1lPSJNYXBSZWxh dGlvbnNoaXAi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMiIg bmFtZT0iTWFy
aXRhbFN0YXR1cyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS4x
MDk0IiBuYW1lPSJNYXRjaEFsZ29yaXRobSIvPgogIDxjb2RlU3lzdGVtIG9p ZD0iMi4xNi44
NDAuMS4xMTM4ODMuNS42OSIgbmFtZT0iTWF0ZXJpYWxEYW5nZXIiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuNzAiIG5hbWU9Ik1hdGVyaWFs SGFuZGxpbmci
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuNzEi IG5hbWU9Ik1h
dGVyaWFsUmVsYXRpb25zaGlwIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjcyIiBuYW1lPSJNYXRlcmlhbFJlc3BvbnNpYmlsaXR5Ii8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjczIiBuYW1lPSJNYXRlcmlh bFR5cGUiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTYwIiBu YW1lPSJNQkQi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTYx IiBuYW1lPSJN
Q00iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MjQiIG5hbWU9
Ik1EQyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu Ni4xNjIiIG5h
bWU9Ik1EREIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuNjUi
IG5hbWU9Ik1ERFgiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEu MTEzODgzLjUu
NzQiIG5hbWU9Ik1ERkF0dHJpYnV0ZVR5cGUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjUuNzUiIG5hbWU9Ik1kZkhtZE1ldFNvdXJjZVR5cGUi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuNzYiIG5hbWU9Ik1k ZkhtZFJvd1R5
cGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUu NzciIG5hbWU9
Ik1kZlJtaW1Sb3dUeXBlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41Ljc4IiBuYW1lPSJNREZTdWJqZWN0QXJlYVByZWZpeCIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNjMiIG5hbWU9Ik1EUiIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNjMuMSIgbmFtZT0iTURSQUUi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTYzLjIiIG5hbWU9 Ik1EUkRVVCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNjQu MSIgbmFtZT0i
TURSRUEiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuMTY0IiBu
YW1lPSJNRFJFWCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi4x
NjMuMyIgbmFtZT0iTURSRlJFIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My42LjE2My40IiBuYW1lPSJNRFJHRVIiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjYuMTYzLjUiIG5hbWU9Ik1EUlBPUiIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNjMuNiIgbmFtZT0iTURSU1BBIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjE3MiIgbmFtZT0iTUVE Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjY3IiBuYW1lPSJN RURDIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjI2IiBuYW1l PSJNRURDSU4i
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuNzki IG5hbWU9Ik1l
ZGlhVHlwZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi4xNzMi
IG5hbWU9Ik1FRExJTkVQTFVTIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My42LjcwIiBuYW1lPSJNRURSIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My42LjY2IiBuYW1lPSJNRURYIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My41LjgwIiBuYW1lPSJNZXNzYWdlQ29uZGl0aW9uIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwODMiIG5hbWU9Ik1lc3Nh Z2VXYWl0aW5n
UHJpb3JpdHkiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuMjQ5
IiBuYW1lPSJNRVRBQk9MSUMgU1lORFJPTUUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjYuNjgiIG5hbWU9Ik1HUEkiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTc0IiBuYW1lPSJNSU0iLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMTAiIG5hbWU9Ik1JTUUiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTc1IiBuYW1lPSJNTVNMIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjE3NiIgbmFtZT0iTU1YIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjgxIiBuYW1lPSJNb2Rp ZnlJbmRpY2F0
b3IiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MTc3IiBuYW1l
PSJNU0giLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuMTc3LjEi
IG5hbWU9Ik1TSENaRSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
Ni4xNzcuMiIgbmFtZT0iTVNIRFVUIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My42LjE3Ny4zIiBuYW1lPSJNU0hGSU4iLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMTc3LjQiIG5hbWU9Ik1TSEZSRSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNzcuNSIgbmFtZT0iTVNIR0VS Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjE3Ny42IiBuYW1l PSJNU0hJVEEi
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTc3 LjciIG5hbWU9
Ik1TSEpQTiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi4xNzcu
OCIgbmFtZT0iTVNIUE9SIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My42LjE3Ny45IiBuYW1lPSJNU0hSVVMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjYuMTc3LjEwIiBuYW1lPSJNU0hTUEEiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMTc3LjExIiBuYW1lPSJNU0hTV0UiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTg5IiBuYW1lPSJNVEgi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMTkwIiBuYW1lPSJN VEhDSCIvPgog
IDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xOTEiIG5h bWU9Ik1USEZE
QSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4x OTIiIG5hbWU9
Ik1USEhIIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42LjE5MyIg
bmFtZT0iTVRISUNEOSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
Ni4xMzkuMiIgbmFtZT0iTVRISUNQQzJFQUUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjYuMTQyLjIiIG5hbWU9Ik1USElDUEMySUNEMTA3QiIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNDIuMyIgbmFtZT0i TVRISUNQQzJJ
Q0QxMEFFIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42LjE2NSIg
bmFtZT0iTVRITURSU1BBIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My42LjE5OCIgbmFtZT0iTVRITVNUIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My42LjE5OC4xIiBuYW1lPSJNVEhNU1RGUkUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMTk4LjIiIG5hbWU9Ik1USE1TVElUQSIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMDEiIG5hbWU9Ik1U SFBEUSIvPgog
IDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMDIiIG5h bWU9Ik1USFND
VCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4y MDIuMSIgbmFt
ZT0iTVRIU0NUU1BBIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjI3IiBuYW1lPSJNVUxUVU0iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuNjAiIG5hbWU9Ik1WWCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4x Ni44NDAuMS4x
MTM4ODMuNi43IiBuYW1lPSJOQUFDQ1IiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjYuODUiIG5hbWU9Ik5BSUNTIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My42LjIwNCIgbmFtZT0iTkFOIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My42LjIwNSIgbmFtZT0iTkNCSSIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMDYiIG5hbWU9Ik5DSSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuMy4yNi4xLjUiIG5hbWU9Ik5DSSBW ZXJzaW9uIG9m
IE5ERi1SVCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNi4yMDci
IG5hbWU9Ik5DSVNFRVIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjYuMjAiIG5hbWU9Ik5EQSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNi42OSIgbmFtZT0iTkRDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My42LjIwOCIgbmFtZT0iTkRERiIvPgogIDxjb2RlU3lzdGVtIG9pZD0i Mi4xNi44NDAu
MS4xMTM4ODMuNi4yMDkiIG5hbWU9Ik5ERlJUIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My42LjIxMCIgbmFtZT0iTkVVIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My42LjE1IiBuYW1lPSJOSUMiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMjExIiBuYW1lPSJOTE0tTUVEIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42Ljg3IiBuYW1lPSJOTURTIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjIzIiBuYW1lPSJOTU1E UyIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4xNiIgbmFtZT0i Tk9DIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjIxIiBuYW1l PSJOVUJDLVVC
OTIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MTAxIiBuYW1l
PSJOVUNDIFByb3ZpZGVyIENvZGVzIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My41LjEwMDgiIG5hbWU9Ik51bGxGbGF2b3IiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuODMiIG5hbWU9Ik9ic2VydmF0aW9uSW50 ZXJwcmV0YXRp
b24iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUu ODQiIG5hbWU9
Ik9ic2VydmF0aW9uTWV0aG9kIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjEwNjMiIG5hbWU9Ik9ic2VydmF0aW9uVmFsdWUiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNDkiIG5hbWU9Ik9IQSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi45OCIgbmFtZT0iT01TIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjExMDIiIG5hbWU9Ik9ubGlu ZSBQcm9kdWN0
IElkZW50aWZpY2F0aW9uIE51bWJlciBJbmRleCBvZiBOb3ZhIFNjb3RpYSIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS44NSIgbmFtZT0iT3Jk ZXJhYmxlRHJ1
Z0Zvcm0iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjUuMTAxNiIg
bmFtZT0iT3JnYW5pemF0aW9uTmFtZVR5cGUiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjUuODciIG5hbWU9IlBhcmFtZXRlcml6ZWREYXRhVHlw ZSIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMTUiIG5hbWU9 IlBhcnRpY2lw
YXRpb25BY3RvciIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS44
OCIgbmFtZT0iUGFydGljaXBhdGlvbkZ1bmN0aW9uIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My41LjEwNjQiIG5hbWU9IlBhcnRpY2lwYXRpb25N b2RlIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41Ljg5IiBuYW1l PSJQYXJ0aWNp
cGF0aW9uU2lnbmF0dXJlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41LjkwIiBuYW1lPSJQYXJ0aWNpcGF0aW9uVHlwZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNS4xMDc1IiBuYW1lPSJQYXRpZW50SW1wb3J0 YW5jZSIvPgog
IDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS45MSIgbmFt ZT0iUGF5bWVu
dFRlcm1zIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42LjIxMiIg
bmFtZT0iUENEUyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi4y
MTMiIG5hbWU9IlBEUSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
NS4xMDIxIiBuYW1lPSJQZXJpb2RpY0ludGVydmFsT2ZUaW1lQWJicmV2aWF0 aW9uIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwMTQiIG5h bWU9IlBlcnNv
biBOYW1lIHBhcnQgdHlwZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNS4xMDE1IiBuYW1lPSJQZXJzb24gTmFtZSBwYXJ0IHR5cGUiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuOTMiIG5hbWU9IlBlcnNvbkRp c2FiaWxpdHlU
eXBlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41 Ljk2IiBuYW1l
PSJQZXJzb25OYW1lUHVycG9zZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4x Ni44NDAuMS4x
MTM4ODMuNi4yMzgiIG5hbWU9IlBIX1JhY2VBbmRFdGhuaWNpdHlfQ0RDIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjIyIiBuYW1lPSJQTkRT Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwOTUiIG5hbWU9 IlBvbGljeUhv
bGRlclJvbGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuNTAi
IG5hbWU9IlBPUyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNS4x
MDEzIiBuYW1lPSJQb3N0YWwgQWRkcmVzcyBwYXJ0IHR5cGUiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTAxMiIgbmFtZT0iUG9zdGFsQWRk cmVzc1VzZSIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMTQi IG5hbWU9IlBQ
QUMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUu OTgiIG5hbWU9
IlByYWN0aWNlU2V0dGluZyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNS4xMDIwIiBuYW1lPSJQcm9iYWJpbGl0eURpc3RyaWJ1dGlvblR5cGUi Lz4KICA8Y29k
ZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA2NSIgbmFtZT0i UHJvY2VkdXJl
TWV0aG9kIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My41LjEwMCIg
bmFtZT0iUHJvY2Vzc2luZ0lEIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjEwMSIgbmFtZT0iUHJvY2Vzc2luZ01vZGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMjE1IiBuYW1lPSJQU1kiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjE2IiBuYW1lPSJRTVIiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA3OCIgbmFtZT0iUXVlcnlF dmVudFN0YXR1
cyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4x MDk2IiBuYW1l
PSJRdWVyeVBhcmFtZXRlclZhbHVlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My41LjEwMiIgbmFtZT0iUXVlcnlQcmlvcml0eSIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDY2IiBuYW1lPSJRdWVyeVF1YW50 aXR5VW5pdCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDY3 IiBuYW1lPSJR
dWVyeVJlc3BvbnNlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My41
LjEwMyIgbmFtZT0iUXVlcnlTdGF0dXNDb2RlIi8+CiAgPGNvZGVTeXN0ZW0g b2lkPSIyLjE2
Ljg0MC4xLjExMzg4My41LjEwNCIgbmFtZT0iUmFjZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi4yMTciIG5hbWU9IlJBTSIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi42IiBuYW1lPSJSQyIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMjAuMiIgbmFtZT0iUkNEQUUiLz4K ICA8Y29kZVN5
c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjIwLjEiIG5hbWU9IlJD RFNBIi8+CiAg
PGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjIyMCIgbmFt ZT0iUkNEU1ki
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjgi IG5hbWU9IlJD
RkIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu MjkiIG5hbWU9
IlJDVjIiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjUuMTA1IiBu
YW1lPSJSZWxhdGlvbmFsT3BlcmF0b3IiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjUuMTA2IiBuYW1lPSJSZWxhdGlvbnNoaXBDb25qdW5jdGlv biIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDc2IiBuYW1l PSJSZWxpZ2lv
dXNBZmZpbGlhdGlvbiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
NS4xMDgiIG5hbWU9IlJlc3BvbnNlTGV2ZWwiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjUuMTA5IiBuYW1lPSJSZXNwb25zZU1vZGFsaXR5Ii8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjI1MCIgbmFtZT0iUkVU SU5PUEFUSFkg
SU5URVJQUkVUQVRJT04iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjUuMTEwIiBuYW1lPSJSb2xlQ2xhc3MiLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjUuMTExIiBuYW1lPSJSb2xlQ29kZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNS4xMDciIG5hbWU9IlJvbGVMaW5rVHlwZSIv PgogIDxjb2Rl
U3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMDY4IiBuYW1lPSJS b2xlU3RhdHVz
Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEx MiIgbmFtZT0i
Um91dGVPZkFkbWluaXN0cmF0aW9uIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIy LjE2Ljg0MC4x
LjExMzg4My42Ljg4IiBuYW1lPSJSeE5vcm0iLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjYuMjQxIiBuYW1lPSJTQ0RIRUMgR0lTIFNwYXRpYWwg QWNjdXJhY3kg
VGllcnMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuOTYuMSIg
bmFtZT0iU0NUU1BBIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My42
LjUzIiBuYW1lPSJTRE0iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjUuMTEzIiBuYW1lPSJTZXF1ZW5jaW5nIi8+CiAgPGNvZGVTeXN0ZW0gb2lk PSIyLjE2Ljg0
MC4xLjExMzg4My41LjExNCIgbmFtZT0iU2VydmljZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNS4xMDAzIiBuYW1lPSJTZXJ2aWNlIGFjdG9y IHR5cGUiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTAwNCIg bmFtZT0iU2Vy
dmljZSB0YXJnZXQgdHlwZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuNS4xMTYiIG5hbWU9IlNlcnZpY2VBY3RvckZ1bmN0aW9uIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjExNyIgbmFtZT0iU2VydmljZUFj dG9yU2lnbmF0
dXJlIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41 LjExOCIgbmFt
ZT0iU2VydmljZUNvbmZpZGVudGlhbGl0eSIvPgogIDxjb2RlU3lzdGVtIG9p ZD0iMi4xNi44
NDAuMS4xMTM4ODMuNS4xMTkiIG5hbWU9IlNlcnZpY2VJbnRlcnByZXRhdGlv biIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMjAiIG5hbWU9 IlNlcnZpY2VM
aXN0VHlwZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNS4xMjEi
IG5hbWU9IlNlcnZpY2VNb29kIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjEyMiIgbmFtZT0iU2VydmljZVByaW9yaXR5Ii8+CiAgPGNvZGVT eXN0ZW0gb2lk
PSIyLjE2Ljg0MC4xLjExMzg4My41LjEyNCIgbmFtZT0iU2VydmljZVJlbGF0 aW9uc2hpcENo
ZWNrUG9pbnQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjUuMTI1
IiBuYW1lPSJTZXJ2aWNlUmVsYXRpb25zaGlwQ29uanVuY3Rpb24iLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTI2IiBuYW1lPSJTZXJ2aWNl UmVsYXRpb25z
aGlwSm9pbiIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4 ODMuNS4xMjci
IG5hbWU9IlNlcnZpY2VSZWxhdGlvbnNoaXBTcGxpdCIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNS4xMjMiIG5hbWU9IlNlcnZpY2VSZWxhdGlv bnNoaXBUeXBl
Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEy OCIgbmFtZT0i
U2VydmljZVRhcmdldFR5cGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTA2OSIgbmFtZT0iU2V0T3BlcmF0b3IiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuMjMyIiBuYW1lPSJTSUMiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMjUxIiBuYW1lPSJTTU9LRVIiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNSIgbmFtZT0iU05NIi8+CiAg PGNvZGVTeXN0
ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjUxIiBuYW1lPSJTTk0zIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42Ljk2IiBuYW1lPSJTTk9N RUQtQ1QiLz4K
ICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuNTIiIG5h bWU9IlNOVCIv
PgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yNDMi IG5hbWU9IlNP
QyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuMTku Ni4xIiBuYW1l
PSJTcGVjaWFsQXJyYW5nZW1lbnQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIu MTYuODQwLjEu
MTEzODgzLjUuMTI5IiBuYW1lPSJTcGVjaW1lblR5cGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjYuMjI0IiBuYW1lPSJTUE4iLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA5OCIgbmFtZT0iU3R5bGVUeXBl Ii8+CiAgPGNv
ZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEwNzAiIG5hbWU9 IlN1YnN0YW5j
ZUFkbWluU3Vic3RpdHV0aW9uIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjEwNzEiIG5hbWU9IlN1YnN0aXR1dGlvbkNvbmRpdGlvbiIvPgog IDxjb2RlU3lz
dGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMzAiIG5hbWU9IlN1cHBs eVNlcnZpY2Ui
Lz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTMx IiBuYW1lPSJU
YWJsZUNlbGxIb3Jpem9udGFsQWxpZ24iLz4KICA8Y29kZVN5c3RlbSBvaWQ9 IjIuMTYuODQw
LjEuMTEzODgzLjUuMTMyIiBuYW1lPSJUYWJsZUNlbGxTY29wZSIvPgogIDxj b2RlU3lzdGVt
IG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNS4xMzMiIG5hbWU9IlRhYmxlQ2Vs bFZlcnRpY2Fs
QWxpZ24iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjUuMTM0IiBu
YW1lPSJUYWJsZUZyYW1lIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My41LjEzNSIgbmFtZT0iVGFibGVSb3dHcm91cFR5cGUiLz4KICA8Y29kZVN5 c3RlbSBvaWQ9
IjIuMTYuODQwLjEuMTEzODgzLjUuMTM2IiBuYW1lPSJUYWJsZVJ1bGVzIi8+ CiAgPGNvZGVT
eXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEzNyIgbmFtZT0iVGFy Z2V0QXdhcmVu
ZXNzIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41 LjEwMTEiIG5h
bWU9IlRlbGVjb21tdW5pY2F0aW9uQWRkcmVzc1VzZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNi4yNDYiIG5hbWU9IlRlbGluIi8+CiAgPGNv ZGVTeXN0ZW0g
b2lkPSIyLjE2Ljg0MC4xLjExMzg4My41LjEzOSIgbmFtZT0iVGltaW5nRXZl bnQiLz4KICA8
Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA5MyIgbmFt ZT0iVHJhbnNs
YXRpb25RdWFsaXR5Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4x LjExMzg4My41
LjE0MCIgbmFtZT0iVHJpYmFsRW50aXR5VVMiLz4KICA8Y29kZVN5c3RlbSBv aWQ9IjIuMTYu
ODQwLjEuMTEzODgzLjYuMjQ1IiBuYW1lPSJVLlMuIEJvYXJkIG9uIEdlb2dy YXBoaWMgTmFt
ZXMiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYu NTQiIG5hbWU9
IlVDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42 LjgiIG5hbWU9
IlVDVU0iLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEzODgz LjYuMjI2IiBu
YW1lPSJVTFQiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuNzUi
IG5hbWU9IlVNRCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4x MTM4ODMuNi4y
MjciIG5hbWU9IlVNRCIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAu MS4xMTM4ODMu
Ni41NiIgbmFtZT0iVU1MIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0 MC4xLjExMzg4
My42Ljg2IiBuYW1lPSJVTUxTIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2 Ljg0MC4xLjEx
Mzg4My41LjEwNzIiIG5hbWU9IlVuaXRPZk1lYXN1cmVQcmVmaXgiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA3MyIgbmFtZT0iVW5pdE9m TWVhc3VyZVBy
ZWZpeENhc2VTZW5zaXRpdmUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjUuMTQxIiBuYW1lPSJVbml0c09mTWVhc3VyZSIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuNS4xNDIiIG5hbWU9IlVuaXRzT2ZNZWFzdXJl Q2FzZVNlbnNp
dGl2ZSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu Ni41NSIgbmFt
ZT0iVVBDIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4 My42LjExIiBu
YW1lPSJVUkwiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjUuMTQz
IiBuYW1lPSJVUkxTY2hlbWUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYu ODQwLjEuMTEz
ODgzLjYuMjMxIiBuYW1lPSJVUyBaSVBDT0RFUyIvPgogIDxjb2RlU3lzdGVt IG9pZD0iMi4x
Ni44NDAuMS4xMTM4ODMuNi4yNDAiIG5hbWU9IlVTX0NPQyIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMjgiIG5hbWU9IlVXREEiLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTQ0IiBuYW1lPSJWYWNjaW5l TWFudWZhY3R1
cmVyIi8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My41 LjE0NSIgbmFt
ZT0iVmFjY2luZVR5cGUiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQw LjEuMTEzODgz
LjUuMTQ2IiBuYW1lPSJWYWx1ZVNldE9wZXJhdG9yIi8+CiAgPGNvZGVTeXN0 ZW0gb2lkPSIy
LjE2Ljg0MC4xLjExMzg4My42LjIyOSIgbmFtZT0iVkFOREYiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjUuMTA5MSIgbmFtZT0iVmVyc2lvbiBp ZGVudGlmaWVy
cyIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4y MzMiIG5hbWU9
IlZIQSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMu NS4xNDciIG5h
bWU9IlZvY2FidWxhcnlEb21haW5RdWFsaWZpZXIiLz4KICA8Y29kZVN5c3Rl bSBvaWQ9IjIu
MTYuODQwLjEuMTEzODgzLjYuNzEiIG5hbWU9IlcxLVcyIi8+CiAgPGNvZGVT eXN0ZW0gb2lk
PSIyLjE2Ljg0MC4xLjExMzg4My42LjcyIiBuYW1lPSJXNCIvPgogIDxjb2Rl U3lzdGVtIG9p
ZD0iMi4xNi44NDAuMS4xMTM4ODMuNi43MyIgbmFtZT0iV0MiLz4KICA8Y29k ZVN5c3RlbSBv
aWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjMwIiBuYW1lPSJXSE8iLz4KICA8 Y29kZVN5c3Rl
bSBvaWQ9IjIuMTYuODQwLjEuMTEzODgzLjYuMjMwLjEiIG5hbWU9IldIT0ZS RSIvPgogIDxj
b2RlU3lzdGVtIG9pZD0iMi4xNi44NDAuMS4xMTM4ODMuNi4yMzAuMiIgbmFt ZT0iV0hPR0VS
Ii8+CiAgPGNvZGVTeXN0ZW0gb2lkPSIyLjE2Ljg0MC4xLjExMzg4My42LjIz MC4zIiBuYW1l
PSJXSE9QT1IiLz4KICA8Y29kZVN5c3RlbSBvaWQ9IjIuMTYuODQwLjEuMTEz ODgzLjYuMjMw
LjQiIG5hbWU9IldIT1NQQSIvPgogIDxjb2RlU3lzdGVtIG9pZD0iMi4xNi44 NDAuMS4xMTM4
ODMuMi4xLjMuMi40LjE1IiBuYW1lPSJTbm9tZWRDVCIvPgogIDxjb2RlU3lz dGVtIG9pZD0i
Mi4xNi44NDAuMS4xMTM4ODMuMi4xLjMuMi40LjE1IiBuYW1lPSJCbG9vZFBy ZXNzdXJlU25D
VCIvPgo8L2NvZGVTeXN0ZW1zPg==
--B_3253171768_19938175--
Re: H3ET Tools Contribution [message #577550 is a reply to message #27086] Thu, 01 February 2007 05:42 Go to previous message
Thank you very much Brandon,
but i'm still unable to create a mif instance cause the editor is unable to
find the mif's root.
Could you suggest a mif from the ballot which should work?
I tryied with PRPA_*.mif in the ballot...
Thanks.
news:C1E77635.D405%bulrich@b2international.com...
> the
> Hope this helps,
> Brandon
>> at
>> at
>> Thanks.
>>>> to .vocab.tests)
>>> org.apache.batik
>>> org.xmlpull.v1
>>>> 3 Released "
>>> ed
>>> available
>>> by
>>> the
>>> Cheers,
>>> Brandon
>>> Pu
>>>> Brandon,
>>>> to .vocab.tests)
>>>> 3 Released "
>>>> Phenix
>>>>> will
>>>>> be
>>>>> Brandon
>>>>>> Both the
>>>>>> to
>>>>>> the
>>>>>> timing
>>>>>> becomes clear.)
>>>>>> Ale,
>>>>>> meeting
>>>>>> in
>>>>>> editing
>>>>>> Both
>>>>>> the
>>>>>> to
>>>>>> the
>>>>>> timing
>>>>>> becomes clear.)
>>>>>> made
>>>>>> I
>>>>>> will
>>>>>> Cheers,
>>>>>> Brandon
>>>>>>> Hi all,
>>>>>>> Regards, Ale.
>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577570 is a reply to message #27086] Thu, 01 February 2007 05:45 Go to previous message
Thanks.
> the
> Hope this helps,
> Brandon
>> at
>> at
>> Thanks.
>>>> to .vocab.tests)
>>> org.apache.batik
>>> org.xmlpull.v1
>>>> 3 Released "
>>> ed
>>> available
>>> by
>>> the
>>> Cheers,
>>> Brandon
>>> Pu
>>>> Brandon,
>>>> to .vocab.tests)
>>>> 3 Released "
>>>> Phenix
>>>>> will
>>>>> be
>>>>> Brandon
>>>>>> Both the
>>>>>> to
>>>>>> the
>>>>>> timing
>>>>>> becomes clear.)
>>>>>> Ale,
>>>>>> meeting
>>>>>> in
>>>>>> editing
>>>>>> Both
>>>>>> the
>>>>>> to
>>>>>> the
>>>>>> timing
>>>>>> becomes clear.)
>>>>>> made
>>>>>> I
>>>>>> will
>>>>>> Cheers,
>>>>>> Brandon
>>>>>>> Hi all,
>>>>>>> Regards, Ale.
>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577682 is a reply to message #27165] Fri, 02 February 2007 04:15 Go to previous message
Here are some static models that work from the September ballot docs that
you're using:
PRPA_MT101301.mif
PRPA_MT101304.mif
PRPA_RM101003.mif
In general, PRPA_MT* and PRPA_RM* static models should work, however these
static models may themselves have errors. If you view the static model in
the MIF editor (double-click e.g. PRPA_MT101302.mif), you will see
annotations describing warnings and errors in the static model.
Brandon
On 2/1/07 11:45 AM, in article epsgca$e29$1@utils.eclipse.org, "Ale"
> Thanks.
>> the
>> Hope this helps,
>> Brandon
>>> at
>>> tR
>>> at
>>> in
>>> Thanks.
>>>>> to .vocab.tests)
>>>> org.apache.batik
>>>> org.xmlpull.v1
>>>>> 3 Released "
http://www.connectingforhealth.nhs.uk/technical/standards/ne ws/hl7_v3_relea>>>>
s
>>>> ed
>>>> available
>>>> by
>>>> the
>>>> Cheers,
>>>> Brandon
>>>> Pu
>>>>> Brandon,
>>>>> to .vocab.tests)
>>>>> 3 Released "
>>>>> Phenix
>>>>>> will
>>>>>> be
>>>>>> Brandon
>>>>>>> Both the
>>>>>>> to
>>>>>>> the
>>>>>>> timing
>>>>>>> becomes clear.)
>>>>>>> Ale,
>>>>>>> meeting
>>>>>>> in
>>>>>>> editing
>>>>>>> Both
>>>>>>> the
>>>>>>> to
>>>>>>> the
>>>>>>> timing
>>>>>>> becomes clear.)
>>>>>>> made
>>>>>>> I
>>>>>>> will
>>>>>>> Cheers,
>>>>>>> Brandon
>>>>>>>> Hi all,
>>>>>>>> Regards, Ale.
>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577695 is a reply to message #27279] Sat, 03 February 2007 05:56 Go to previous message
I checked out the CVS version, i get the error on the wizard pane and that's
the exception :
java.io.FileNotFoundException:
C:\work\development\tools\eclipses\jbosside2.0beta\..\org.ec lipse.ohf.h3et.mif.core\Resources\MIFStaticModelSerializatio nToFlat.xsl
(Impossibile trovare il percorso specificato)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:106)
at java.io.FileInputStream.<init>(FileInputStream.java:66)
at
sun.net.www.protocol.file.FileURLConnection.connect(FileURLC onnection.java:70)
at
sun.net.www.protocol.file.FileURLConnection.getInputStream(F ileURLConnection.java:161)
at
com.sun.org.apache.xerces.internal.impl.XMLEntityManager.set upCurrentEntity(XMLEntityManager.java:973)
at
com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.d etermineDocVersion(XMLVersionDetector.java:184)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:798)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:764)
at
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:148)
at
com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(D OMParser.java:250)
at
com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl. parse(DocumentBuilderImpl.java:292)
at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java :172)
at
org.eclipse.ohf.h3et.mif.core.MIFConvertorImpl.getTransforme rFromFile(MIFConvertorImpl.java:96)
at
org.eclipse.ohf.h3et.mif.core.MIFConvertorImpl.convertFromSe rializeToFlat(MIFConvertorImpl.java:114)
at
org.eclipse.ohf.h3et.mif.core.MIFConvertorImpl.convertV1ToV2 (MIFConvertorImpl.java:141)
at
org.eclipse.ohf.h3et.mif.core.MIFConvertorImpl.convertV1ToV2 (MIFConvertorImpl.java:128)
at
org.eclipse.ohf.h3et.mif.core.formats.MIFDocumentParser.pars e(MIFDocumentParser.java:285)
at org.eclipse.ohf.h3et.mif.core.MIFManager.loadDocument(MIFMan ager.java:56)
at
org.eclipse.ohf.h3et.mif.core.MIFContextImpl.loadNewDocInCac he(MIFContextImpl.java:144)
at
org.eclipse.ohf.h3et.mif.core.MIFContextImpl.load(MIFContext Impl.java:238)
at
org.eclipse.ohf.h3et.staticmodel.core.StaticModelContextImpl .load(StaticModelContextImpl.java:211)
at
org.eclipse.ohf.h3et.staticmodel.core.StaticModelContextImpl .getEntryPoint(StaticModelContextImpl.java:94)
at
org.eclipse.ohf.h3et.instanceeditor.ui.wizards.MessageInstan ceOptionsPage.createNameSuggestions(MessageInstanceOptionsPa ge.java:302)
at
org.eclipse.ohf.h3et.instanceeditor.ui.wizards.SelectMessage DefinitionPage.validatePage(SelectMessageDefinitionPage.java :128)
at
org.eclipse.ohf.h3et.instanceeditor.ui.wizards.SelectMessage DefinitionPage.access$0(SelectMessageDefinitionPage.java:115 )
at
org.eclipse.ohf.h3et.instanceeditor.ui.wizards.SelectMessage DefinitionPage$1$1.run(SelectMessageDefinitionPage.java:63)
news:C1E8BFC8.D480%bulrich@b2international.com...
> you're using:
> PRPA_MT101301.mif
> PRPA_MT101304.mif
> PRPA_RM101003.mif
> Brandon
>> to
>> Thanks.
>>>> from
>>> to
>>> the
>>> static
>>> the
>>> Hope this helps,
>>> Brandon
>>>> at
>>>> tR
>>>> at
>>>> in
>>>> from
>>>> Thanks.
>>>>>> little
>>>>>> bit lost - there're two forks of H3ET related, i.e.:
>>>>>> - org.eclipse.ohf\H3ET\plugins\XXXXXXXXX
>>>>>> to .vocab.tests)
>>>>>> just
>>>>>> run as a HL7 V3 designer without using other OHF features?
>>>>> org.apache.batik
>>>>> org.xmlpull.v1
>>>>>> Or is there any Getting Started tutorials?
>>>>>> I assume it's the correct source to get the v3 tools announced by
>>>>>> HL7/CFH/JIVA on Jan 11th re:
>>>>>> Version
>>>>>> 3 Released "
> s
>>>>> ed
>>>>> available
>>>>> by
>>>>> at
>>>>> the
>>>>> Cheers,
>>>>> Brandon
>>>>> Pu
>>>>>> Brandon,
>>>>>> little
>>>>>> to .vocab.tests)
>>>>>> just
>>>>>> Version
>>>>>> 3 Released "
>>>>>> Thanks for your effort!
>>>>>> Phenix
>>>>>> On 2007-01-22 21:21:30 +0800, Brandon Ulrich
>>>>>>> will
>>>>>>> be
>>>>>>> available from CVS within the next 48 hours.
>>>>>>> Brandon
>>>>>>>> Both the
>>>>>>>> to
>>>>>>>> the
>>>>>>>> timing
>>>>>>>> becomes clear.)
>>>>>>> "Brandon Ulrich" <bulrich@b2international.com> wrote:
>>>>>>>> Ale,
>>>>>>>> meeting
>>>>>>>> in
>>>>>>>> editing
>>>>>>>> Both
>>>>>>>> the
>>>>>>>> to
>>>>>>>> the
>>>>>>>> timing
>>>>>>>> becomes clear.)
>>>>>>>> made
>>>>>>>> Homebase.
>>>>>>>> I
>>>>>>>> will
>>>>>>>> update this list when the tools are publicly available.
>>>>>>>> Cheers,
>>>>>>>> Brandon
>>>>>>>> On 1/16/07 9:53 AM, "Alessandro Fredianelli"
>>>>>>>>> Hi all,
>>>>>>>>> any news about h3et tools commitment?
>>>>>>>>> Thank you very much.
>>>>>>>>> Regards, Ale.
>>>>>>>>> _______________________________________________
>>>>>>>>> ohf-dev mailing list
>>>>>>>>> ohf-dev@eclipse.org
>>>>>>>>> https://dev.eclipse.org/mailman/listinfo/ohf-dev
Re: H3ET Tools Contribution [message #577722 is a reply to message #27279] Sat, 03 February 2007 06:07 Go to previous message
On the PRPA_MT101301.mif i get :
MIF Document Error : Wrong version null.
What is this meaning? What is it expecting?
> you're using:
> PRPA_MT101301.mif
> PRPA_MT101304.mif
> PRPA_RM101003.mif
> Brandon
>> to
>> Thanks.
>>>> from
>>> to
>>> the
>>> static
>>> the
>>> Hope this helps,
>>> Brandon
>>>> java.lang.IllegalArgumentException: Index out of bounds
>>>> at org.eclipse.swt.SWT.error(SWT.java:3358)
>>>> at org.eclipse.swt.SWT.error(SWT.java:3297)
>>>> at org.eclipse.swt.SWT.error(SWT.java:3268)
>>>> at org.eclipse.swt.widgets.Widget.error(Widget.java:435)
>>>> at org.eclipse.swt.widgets.Combo.getItem(Combo.java:575)
>>>> at
>>>> tR
>>>> at
>>>> in
>>>> from
>>>> that bundle but i'm not sure about oids.xml.
>>>> Is available any h3et working eclipse project?
>>>> Thanks.
>>>>>> little
>>>>>> to .vocab.tests)
>>>>>> just
>>>>> org.apache.batik
>>>>> org.xmlpull.v1
>>>>>> Version
>>>>>> 3 Released "
> s
>>>>> ed
>>>>> available
>>>>> by
>>>>> at
>>>>> the
>>>>> Cheers,
>>>>> Brandon
>>>>> Pu
>>>>>> Brandon,
>>>>>> little
>>>>>> to .vocab.tests)
>>>>>> just
>>>>>> Version
>>>>>> 3 Released "
>>>>>> Phenix
>>>>>>> will
>>>>>>> be
>>>>>>> Brandon
>>>>>>>> Both the
>>>>>>>> to
>>>>>>>> the
>>>>>>>> timing
>>>>>>>> becomes clear.)
>>>>>>>> Ale,
>>>>>>>> meeting
>>>>>>>> in
>>>>>>>> editing
>>>>>>>> Both
>>>>>>>> the
>>>>>>>> to
>>>>>>>> the
>>>>>>>> timing
>>>>>>>> becomes clear.)
>>>>>>>> made
>>>>>>>> Homebase.
>>>>>>>> I
>>>>>>>> will
>>>>>>>> Cheers,
>>>>>>>> Brandon
>>>>>>>>> Hi all,
>>>>>>>>> Regards, Ale.
>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577736 is a reply to message #27755] Mon, 05 February 2007 03:23 Go to previous message
Are you using PRPA_MT101301.mif directly from the ballot pack? The validator
is expecting a MIF 2.0 file; i.e. the schemaVersion attribute of
mif:staticModel is expected to have a value of "2.0"
The message text can obviously be improved. ;)
In the message instance editor, MIF 1.0 to 2.0 conversions happen
on-the-fly. If you are editing a MIF directly, though, you will need to
explicitly convert the MIF 1.0 file to MIF 2.0. There is a provided utility
for this; right-click a MIF, choose HL7 MIF Operations > Convert to MIF 2.0.
Brandon
On 2/3/07 12:07 PM, in article eq1qe8$4fe$1@utils.eclipse.org, "Ale"
>> you're using:
>> PRPA_MT101301.mif
>> PRPA_MT101304.mif
>> PRPA_RM101003.mif
>> Brandon
>>> to
>>> Thanks.
>>>>> from
>>>> to
>>>> the
>>>> static
>>>> the
>>>> Hope this helps,
>>>> Brandon
>>>>> at
>>>>> ge
>>>>> tR
>>>>> at
>>>>> nF
>>>>> in
>>>>> from
>>>>> Thanks.
>>>>> news:C1DFD9C4.D279%bulrich@b2international.com...
>>>>>>> little
>>>>>>> to .vocab.tests)
>>>>>> The active development is in the org.eclipse.ohf\plugins directory.
>>>>>>> just
>>>>>> You will need the following plug-ins:
>>>>>> org.eclipse.ohf.h3et.*
>>>>>> org.eclipse.ohf.utilities
>>>>>> org.apache.batik
>>>>>> org.apache.commons.codec
>>>>>> org.apache.commons.lang
>>>>>> org.xmlpull.v1
>>>>>> Sorry, the best place for help is on the newsgroup for now.
>>>>>>> Version
>>>>>>> 3 Released "
>>>>>> Yes, these are the tools referred to in the press release at
>> s
>>>>>> ed
>>>>>> available
>>>>>> by
>>>>>> at
>>>>>> the
>>>>>> HTC Eclipse Tooling site under downloads. See
>>>>>> http://hl7projects.hl7.nscee.edu/projects/htc/
>>>>>> Cheers,
>>>>>> Brandon
>>>>>> Pu
>>>>>> Qin" <phenix.pu.qin@gmail.com> wrote:
>>>>>>> Brandon,
>>>>>>> little
>>>>>>> to .vocab.tests)
>>>>>>> just
>>>>>>> Version
>>>>>>> 3 Released "
>>>>>>> Phenix
>>>>>>>> will
>>>>>>>> be
>>>>>>>> Brandon
>>>>>>>>> Both the
>>>>>>>>> to
>>>>>>>>> the
>>>>>>>>> timing
>>>>>>>>> becomes clear.)
>>>>>>>>> Ale,
>>>>>>>>> meeting
>>>>>>>>> in
>>>>>>>>> editing
>>>>>>>>> Both
>>>>>>>>> the
>>>>>>>>> to
>>>>>>>>> the
>>>>>>>>> timing
>>>>>>>>> becomes clear.)
>>>>>>>>> made
>>>>>>>>> Homebase.
>>>>>>>>> I
>>>>>>>>> will
>>>>>>>>> Cheers,
>>>>>>>>> Brandon
>>>>>>>>>> Hi all,
>>>>>>>>>> Regards, Ale.
>>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577745 is a reply to message #27791] Mon, 05 February 2007 18:41 Go to previous message
I've imported all prpa* mifs from the september ballot into the h3et's mif
dir.
Concerning the schemaVersion, are you talking about the coremif?
Are no mif:staticModel elements on prpa* mifs... I'm a bit confused :)
I'm no more able to compile the cvs version, now i'm getting an error on
...mif.ui,
ModelValidator.java.
"Brandon Ulrich" <bulrich@b2international.com> ha scritto nel messaggio
news:C1ECA811.D4E5%bulrich@b2international.com...
> validator
> utility
> 2.0.
> Brandon
>>> that
>>> you're using:
>>> PRPA_MT101301.mif
>>> PRPA_MT101304.mif
>>> PRPA_RM101003.mif
>>> these
>>> in
>>> Brandon
>>>> unable
>>>> to
>>>> Thanks.
>>>>>> from
>>>>> to
>>>>> the
>>>>> files that you mention from the September ballot.
>>>>> We'll add a section to the Wiki that discusses configuring a new H3ET
>>>>> project; for now, I've attached an oids.xml file that you can use.
>>>>>> exception:
>>>>> static
>>>>> in
>>>>> the
>>>>> current source; an error message is now displayed when an improperly
>>>>> formatted MIF is chosen.
>>>>> Hope this helps,
>>>>> Brandon
>>>>> On 1/31/07 12:12 PM, in article epptjf$ogq$1@utils.eclipse.org, "Ale"
>>>>>> exception:
>>>>>> at
>>>>>> ge
>>>>>> tR
>>>>>> ootName(MessageInstanceOptionsPage.java:118)
>>>>>> at
>>>>>> nF
>>>>>> in
>>>>>> from
>>>>>> Thanks.
>>>>>> messaggio
>>>>>>>> little
>>>>>>>> .core
>>>>>>>> to .vocab.tests)
>>>>>>>> just
>>>>>>> org.apache.batik
>>>>>>> org.xmlpull.v1
>>>>>>>> Version
>>>>>>>> 3 Released "
>>> s
>>>>>>> ed
>>>>>>> available
>>>>>>> by
>>>>>>> found
>>>>>>> at
>>>>>>> the
>>>>>>> Cheers,
>>>>>>> Brandon
>>>>>>> "Phenix
>>>>>>> Pu
>>>>>>>> Brandon,
>>>>>>>> little
>>>>>>>> .core
>>>>>>>> to .vocab.tests)
>>>>>>>> just
>>>>>>>> Version
>>>>>>>> 3 Released "
>>>>>>>> Phenix
>>>>>>>>> will
>>>>>>>>> be
>>>>>>>>> Brandon
>>>>>>>>>> Both the
>>>>>>>>>> donated
>>>>>>>>>> to
>>>>>>>>>> the
>>>>>>>>>> timing
>>>>>>>>>> becomes clear.)
>>>>>>>>>> Ale,
>>>>>>>>>> meeting
>>>>>>>>>> in
>>>>>>>>>> editing
>>>>>>>>>> Both
>>>>>>>>>> the
>>>>>>>>>> donated
>>>>>>>>>> to
>>>>>>>>>> the
>>>>>>>>>> timing
>>>>>>>>>> becomes clear.)
>>>>>>>>>> made
>>>>>>>>>> Homebase.
>>>>>>>>>> I
>>>>>>>>>> will
>>>>>>>>>> Cheers,
>>>>>>>>>> Brandon
>>>>>>>>>>> Hi all,
>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577756 is a reply to message #27791] Mon, 05 February 2007 18:50 Go to previous message
I'm not sure i correctly configured the prj.
i created the Mif dir with the mifs, coremif and cmetinfo, than i created
Vocab dir with oids.xml and
vocabulary.xml from the ballot?
correct? anything else?
> validator
> utility
> 2.0.
> Brandon
>>> that
>>> you're using:
>>> PRPA_MT101301.mif
>>> PRPA_MT101304.mif
>>> PRPA_RM101003.mif
>>> these
>>> in
>>> Brandon
>>>> unable
>>>> to
>>>> Thanks.
>>>>>> from
>>>>> to
>>>>> the
>>>>>> exception:
>>>>> static
>>>>> in
>>>>> the
>>>>> Hope this helps,
>>>>> Brandon
>>>>>> exception:
>>>>>> at
>>>>>> ge
>>>>>> tR
>>>>>> at
>>>>>> nF
>>>>>> in
>>>>>> from
>>>>>> Thanks.
>>>>>> messaggio
>>>>>>>> little
>>>>>>>> .core
>>>>>>>> to .vocab.tests)
>>>>>>>> just
>>>>>>> org.apache.batik
>>>>>>> org.xmlpull.v1
>>>>>>>> Version
>>>>>>>> 3 Released "
>>> s
>>>>>>> ed
>>>>>>> available
>>>>>>> by
>>>>>>> found
>>>>>>> at
>>>>>>> the
>>>>>>> Cheers,
>>>>>>> Brandon
>>>>>>> "Phenix
>>>>>>> Pu
>>>>>>>> Brandon,
>>>>>>>> little
>>>>>>>> .core
>>>>>>>> to .vocab.tests)
>>>>>>>> just
>>>>>>>> Version
>>>>>>>> 3 Released "
>>>>>>>> Phenix
>>>>>>>>> The source for the Message Instance Editor and MIF Validator tools
>>>>>>>>> will
>>>>>>>>> be
>>>>>>>>> Brandon
>>>>>>>>>> Both the
>>>>>>>>>> message instance editor and the MIF validation tool will be
>>>>>>>>>> donated
>>>>>>>>>> to
>>>>>>>>>> the
>>>>>>>>>> Eclipse OHF in the near future. (We will update the list when the
>>>>>>>>>> timing
>>>>>>>>>> becomes clear.)
>>>>>>>>> On 1/16/07 10:26 AM, in article
>>>>>>>>> C1D258C8.ADDF%bulrich@b2international.com,
>>>>>>>>>> Ale,
>>>>>>>>>> There were two H3ET tools demonstrated at the HL7 working group
>>>>>>>>>> meeting
>>>>>>>>>> in
>>>>>>>>>> San Diego last Wednesday: a message instance editor that allows
>>>>>>>>>> editing
>>>>>>>>>> message instances based on MIF models, and a MIF validation tool.
>>>>>>>>>> Both
>>>>>>>>>> the
>>>>>>>>>> donated
>>>>>>>>>> to
>>>>>>>>>> the
>>>>>>>>>> timing
>>>>>>>>>> becomes clear.)
>>>>>>>>>> In the meantime, access to binary versions of these tools will be
>>>>>>>>>> made
>>>>>>>>>> available to the HL7 community, probably at the HL7 Project
>>>>>>>>>> Homebase.
>>>>>>>>>> I
>>>>>>>>>> will
>>>>>>>>>> Cheers,
>>>>>>>>>> Brandon
>>>>>>>>>>> Hi all,
>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577764 is a reply to message #27873] Mon, 05 February 2007 19:06 Go to previous message
running the last cvs version i get this error :
"Ale" <alessandro.fredianelli@italtbs.com> ha scritto nel messaggio
news:eq8fro$cj6$1@utils.eclipse.org...
>> validator
>> utility
>> 2.0.
>> Brandon
>>>> that
>>>> you're using:
>>>> PRPA_MT101301.mif
>>>> PRPA_MT101304.mif
>>>> PRPA_RM101003.mif
>>>> these
>>>> in
>>>> Brandon
>>>>> unable
>>>>> to
>>>>> Thanks.
>>>>> messaggio
>>>>>>> from
>>>>>> you
>>>>>> to
>>>>>> using
>>>>>> the
>>>>>>> exception:
>>>>>> static
>>>>>> in
>>>>>> the
>>>>>> Hope this helps,
>>>>>> Brandon
>>>>>>> exception:
>>>>>>> at
>>>>>>> ge
>>>>>>> tR
>>>>>>> at
>>>>>>> nF
>>>>>>> in
>>>>>>> from
>>>>>>> Thanks.
>>>>>>> messaggio
>>>>>>>>> I'm trying to check out the H3ET through Eclipse H3ET and get a
>>>>>>>>> little
>>>>>>>>> - org.eclipse.ohf\plugins\org.eclipse.ohf.h3et.XXXXXXXXX (from
>>>>>>>>> .core
>>>>>>>>> to .vocab.tests)
>>>>>>>>> What packages should I check out as the minimized requirement if I
>>>>>>>>> just
>>>>>>>> org.apache.batik
>>>>>>>> org.xmlpull.v1
>>>>>>>>> "Eclipse-Based Message Development and Validation Tools for HL7
>>>>>>>>> Version
>>>>>>>>> 3 Released "
>>>> s
>>>>>>>> ed
>>>>>>>> available
>>>>>>>> by
>>>>>>>> found
>>>>>>>> at
>>>>>>>> the
>>>>>>>> Cheers,
>>>>>>>> Brandon
>>>>>>>> "Phenix
>>>>>>>> Pu
>>>>>>>>> Brandon,
>>>>>>>>> little
>>>>>>>>> .core
>>>>>>>>> to .vocab.tests)
>>>>>>>>> just
>>>>>>>>> Version
>>>>>>>>> 3 Released "
>>>>>>>>> Phenix
>>>>>>>>>> tools
>>>>>>>>>> will
>>>>>>>>>> be
>>>>>>>>>> Brandon
>>>>>>>>>>> Both the
>>>>>>>>>>> donated
>>>>>>>>>>> to
>>>>>>>>>>> the
>>>>>>>>>>> the
>>>>>>>>>>> timing
>>>>>>>>>>> becomes clear.)
>>>>>>>>>>> Ale,
>>>>>>>>>>> meeting
>>>>>>>>>>> in
>>>>>>>>>>> editing
>>>>>>>>>>> tool.
>>>>>>>>>>> Both
>>>>>>>>>>> the
>>>>>>>>>>> donated
>>>>>>>>>>> to
>>>>>>>>>>> the
>>>>>>>>>>> the
>>>>>>>>>>> timing
>>>>>>>>>>> becomes clear.)
>>>>>>>>>>> be
>>>>>>>>>>> made
>>>>>>>>>>> Homebase.
>>>>>>>>>>> I
>>>>>>>>>>> will
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Brandon
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>>> ohf-dev@eclipse.org
H3ET Project Configuration Instructions [message #577820 is a reply to message #27873] Wed, 07 February 2007 04:46 Go to previous message
That sounds correct. We're attempting to get permission to release a
pre-configured project with the necessary file structure to HL7 members. In
the meantime, I've added a wiki page with end-user project configuration
instructions at http://wiki.eclipse.org/index.php/H3ET_Project_Configuration
Brandon
On 2/6/07 12:50 AM, in article eq8fro$cj6$1@utils.eclipse.org, "Ale"
>> validator
>> utility
>> 2.0.
>> Brandon
>>>> that
>>>> you're using:
>>>> PRPA_MT101301.mif
>>>> PRPA_MT101304.mif
>>>> PRPA_RM101003.mif
>>>> these
>>>> in
>>>> Brandon
>>>>> unable
>>>>> to
>>>>> Thanks.
>>>>>>> from
>>>>>> to
>>>>>> the
>>>>>>> when i try to design a new mif instance i get the following
>>>>>>> exception:
>>>>>> static
>>>>>> in
>>>>>> the
>>>>>> Hope this helps,
>>>>>> Brandon
>>>>>>> exception:
>>>>>>> at
>>>>>>> com.jivamedical.h3et.instanceeditor.ui.wizards.MessageInstan ceOptionsPag
>>>>>>> e.
>>>>>>> ge
>>>>>>> tR
>>>>>>> at
>>>>>>> com.jivamedical.h3et.instanceeditor.ui.wizards.NewMessageIns tanceWizard.
>>>>>>> ca
>>>>>>> nF
>>>>>>> in
>>>>>>> ish(NewMessageInstanceWizard.java:157)
>>>>>>> I got MIFs from the september ballot docs, the vocab is also coming
>>>>>>> from
>>>>>>> Thanks.
>>>>>>> messaggio
>>>>>>>>> little
>>>>>>>>> .core
>>>>>>>>> to .vocab.tests)
>>>>>>>>> just
>>>>>>>> org.apache.batik
>>>>>>>> org.xmlpull.v1
>>>>>>>>> Version
>>>>>>>>> 3 Released "
>>>> s
>>>>>>>> ed
>>>>>>>> As of this morning, binaries of these tools have also been made
>>>>>>>> available
>>>>>>>> by
>>>>>>>> the HL7 Tooling Collaborative. Installation instructions can be
>>>>>>>> found
>>>>>>>> at
>>>>>>>> the
>>>>>>>> Cheers,
>>>>>>>> Brandon
>>>>>>>> On 1/26/07 3:44 PM, in article epd444$2ju$1@utils.eclipse.org,
>>>>>>>> "Phenix
>>>>>>>> Pu
>>>>>>>>> Brandon,
>>>>>>>>> little
>>>>>>>>> .core
>>>>>>>>> to .vocab.tests)
>>>>>>>>> just
>>>>>>>>> Version
>>>>>>>>> 3 Released "
>>>>>>>>> Phenix
>>>>>>>>>> will
>>>>>>>>>> be
>>>>>>>>>> Brandon
>>>>>>>>>>> Both the
>>>>>>>>>>> donated
>>>>>>>>>>> to
>>>>>>>>>>> the
>>>>>>>>>>> timing
>>>>>>>>>>> becomes clear.)
>>>>>>>>>>> Ale,
>>>>>>>>>>> meeting
>>>>>>>>>>> in
>>>>>>>>>>> editing
>>>>>>>>>>> Both
>>>>>>>>>>> the
>>>>>>>>>>> donated
>>>>>>>>>>> to
>>>>>>>>>>> the
>>>>>>>>>>> timing
>>>>>>>>>>> becomes clear.)
>>>>>>>>>>> made
>>>>>>>>>>> Homebase.
>>>>>>>>>>> I
>>>>>>>>>>> will
>>>>>>>>>>> Cheers,
>>>>>>>>>>> Brandon
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Tools Contribution [message #577848 is a reply to message #27913] Wed, 07 February 2007 04:52 Go to previous message
You are missing some HL7 resource files, which you should be able to find in
your ballot. We'll add some getting started information to the wiki; for now
I suggest sticking with the released version from HL7's GForge site.
Brandon
On 2/6/07 1:06 AM, in article eq8gqb$e15$1@utils.eclipse.org, "Ale"
> .core\Resources\MIFStaticModelSerializationToFlat.xsl
>>> validator
>>> utility
>>> 2.0.
>>> Brandon
>>>>> that
>>>>> you're using:
>>>>> PRPA_MT101301.mif
>>>>> PRPA_MT101304.mif
>>>>> PRPA_RM101003.mif
>>>>> these
>>>>> in
>>>>> Brandon
>>>>>> unable
>>>>>> to
>>>>>> Thanks.
>>>>>> messaggio
>>>>>>>> from
>>>>>>> Unfortunately, there isn't a complete H3ET workspace available for
>>>>>>> you
>>>>>>> to
>>>>>>> download since we cannot redistribute the HL7 files. You're fine
>>>>>>> using
>>>>>>> the
>>>>>>>> exception:
>>>>>>> The bug was encountered because the wizard was unable to identify a
>>>>>>> static
>>>>>>> model in the MIF that you selected. This has been (previously) fixed
>>>>>>> in
>>>>>>> the
>>>>>>> Hope this helps,
>>>>>>> Brandon
>>>>>>>> exception:
>>>>>>>> at
>>>>>>>> ge.
>>>>>>>> ge
>>>>>>>> tR
>>>>>>>> at
>>>>>>>> .ca
>>>>>>>> nF
>>>>>>>> in
>>>>>>>> from
>>>>>>>> Thanks.
>>>>>>>> messaggio
>>>>>>>>>> little
>>>>>>>>>> .core
>>>>>>>>>> to .vocab.tests)
>>>>>>>>>> just
>>>>>>>>> org.apache.batik
>>>>>>>>> org.xmlpull.v1
>>>>>>>>>> Version
>>>>>>>>>> 3 Released "
>>>>> a>>
>>>>> s
>>>>>>>>> ed
>>>>>>>>> available
>>>>>>>>> by
>>>>>>>>> found
>>>>>>>>> at
>>>>>>>>> the
>>>>>>>>> Cheers,
>>>>>>>>> Brandon
>>>>>>>>> "Phenix
>>>>>>>>> Pu
>>>>>>>>>> Brandon,
>>>>>>>>>> little
>>>>>>>>>> .core
>>>>>>>>>> to .vocab.tests)
>>>>>>>>>> just
>>>>>>>>>> Version
>>>>>>>>>> 3 Released "
>>>>>>>>>> Phenix
>>>>>>>>>>> tools
>>>>>>>>>>> will
>>>>>>>>>>> be
>>>>>>>>>>> Brandon
>>>>>>>>>>>> Both the
>>>>>>>>>>>> donated
>>>>>>>>>>>> to
>>>>>>>>>>>> the
>>>>>>>>>>>> the
>>>>>>>>>>>> timing
>>>>>>>>>>>> becomes clear.)
>>>>>>>>>>>> Ale,
>>>>>>>>>>>> meeting
>>>>>>>>>>>> in
>>>>>>>>>>>> editing
>>>>>>>>>>>> tool.
>>>>>>>>>>>> Both
>>>>>>>>>>>> the
>>>>>>>>>>>> donated
>>>>>>>>>>>> to
>>>>>>>>>>>> the
>>>>>>>>>>>> the
>>>>>>>>>>>> timing
>>>>>>>>>>>> becomes clear.)
>>>>>>>>>>>> be
>>>>>>>>>>>> made
>>>>>>>>>>>> Homebase.
>>>>>>>>>>>> I
>>>>>>>>>>>> will
>>>>>>>>>>>> Cheers,
>>>>>>>>>>>> Brandon
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>>> ohf-dev@eclipse.org
Re: H3ET Project Configuration Instructions [message #577859 is a reply to message #28076] Wed, 07 February 2007 06:37 Go to previous message
It seems the only thing i still miss is cmetList.mif, where can i get it?
Does it have any relationship with cmetinfo.coremif from the ballot?
news:C1EF5E8A.D55E%bulrich@b2international.com...
> In
> instructions at
> Brandon
>>> validator
>>> utility
>>> 2.0.
>>> Brandon
>>>>> that
>>>>> you're using:
>>>>> PRPA_MT101301.mif
>>>>> PRPA_MT101304.mif
>>>>> PRPA_RM101003.mif
>>>>> these
>>>>> in
>>>>> Brandon
>>>>>> unable
>>>>>> to
>>>>>> Thanks.
>>>>>> messaggio
>>>>>>>> from
>>>>>>> you
>>>>>>> to
>>>>>>> using
>>>>>>> the
>>>>>>> H3ET
>>>>>>>> exception:
>>>>>>> static
>>>>>>> in
>>>>>>> the
>>>>>>> Hope this helps,
>>>>>>> Brandon
>>>>>>> "Ale"
>>>>>>>> exception:
>>>>>>>> at
>>>>>>>> e.
>>>>>>>> ge
>>>>>>>> tR
>>>>>>>> at
>>>>>>>> ca
>>>>>>>> nF
>>>>>>>> in
>>>>>>>> from
>>>>>>>> Thanks.
>>>>>>>> messaggio
>>>>>>>>>> little
>>>>>>>>>> .core
>>>>>>>>>> to .vocab.tests)
>>>>>>>>> directory.
>>>>>>>>>> I
>>>>>>>>>> just
>>>>>>>>> org.apache.batik
>>>>>>>>> org.xmlpull.v1
>>>>>>>>>> Version
>>>>>>>>>> 3 Released "
>>>>> s
>>>>>>>>> ed
>>>>>>>>> available
>>>>>>>>> by
>>>>>>>>> found
>>>>>>>>> at
>>>>>>>>> the
>>>>>>>>> Cheers,
>>>>>>>>> Brandon
>>>>>>>>> "Phenix
>>>>>>>>> Pu
>>>>>>>>>> Brandon,
>>>>>>>>>> little
>>>>>>>>>> .core
>>>>>>>>>> to .vocab.tests)
>>>>>>>>>> I
>>>>>>>>>> just
>>>>>>>>>> Version
>>>>>>>>>> 3 Released "
>>>>>>>>>> Phenix
>>>>>>>>>>> tools
>>>>>>>>>>> will
>>>>>>>>>>> be
>>>>>>>>>>> Brandon
>>>>>>>>>>>> Both the
>>>>>>>>>>>> donated
>>>>>>>>>>>> to
>>>>>>>>>>>> the
>>>>>>>>>>>> the
>>>>>>>>>>>> timing
>>>>>>>>>>>> becomes clear.)
>>>>>>>>>>>> Ale,
>>>>>>>>>>>> meeting
>>>>>>>>>>>> in
>>>>>>>>>>>> editing
>>>>>>>>>>>> tool.
>>>>>>>>>>>> Both
>>>>>>>>>>>> the
>>>>>>>>>>>> donated
>>>>>>>>>>>> to
>>>>>>>>>>>> the
>>>>>>>>>>>> the
>>>>>>>>>>>> timing
>>>>>>>>>>>> becomes clear.)
>>>>>>>>>>>> be
>>>>>>>>>>>> made
>>>>>>>>>>>> Homebase.
>>>>>>>>>>>> I
>>>>>>>>>>>> will
>>>>>>>>>>>> Cheers,
>>>>>>>>>>>> Brandon
>>>>>>>>>>>>> Hi all,
>>>>>>>>>>>>> Regards, Ale.
>>>>>>>>>>>>> ohf-dev@eclipse.org
Previous Topic:Is there a rhioConfig.xml for the IBM servers?
Next Topic:problem with H3ET tool
Current Time: Sat Jul 26 20:31:51 EDT 2025
Powered by FUDForum. Page generated in 0.37774 seconds
