Home » Eclipse Projects » Eclipse Platform » eclipse3, svn and synchronization
eclipse3, svn and synchronization [message #268772] Thu, 26 August 2004 03:26 Go to next message
Originally posted by: jimworke.yahoo.com
I'm using Eclipse 3.0 with sftp plugin (from www.klomp.org) and php plugin
(from www.phpeclipse.de). I'm also using subversion version control
system, but without using any eclipse plugin for that.
Here's the full story on my development process:
1) Using console, svn checkout my project into eclipse's workspace
2) Do an import project into Eclipse
3) Do an export project in Eclipse to a sftp site
4) Make changes to the code
5) Synchronize the changes to the web server using sftp
6) Once the code is working, I'd go to console and do a svn commit
Now, the problem is, in synchronize view (sync to sftp site where apache
reside) is also showing the ".svn" directories. I don't want to sync the
".svn" dir....
I've tried to add a ".svn" in the Team->Ignore resources before I do the
importing into eclipse.
I'm not sure who to ask this question. eclipse or sftp owner?
Anyone can help me?
Re: eclipse3, svn and synchronization [message #268792 is a reply to message #268772] Thu, 26 August 2004 04:51 Go to previous messageGo to next message
For what particular reason don't you use the subclipse plugin?
(http://subclipse.tigris.org/)
Currently we're still using Visual SourceSafe but plan to migrate
to svn asap. Thus I've got no experience with svn and subclipse, yet.
So Subclipse is just an idea, because I expect it to become the standard
plugin to be included into the Eclipse releases to come, just like the
cvs team support.
Does someone use svn with Eclipse already?
Marcus
Re: eclipse3, svn and synchronization [message #268794 is a reply to message #268792] Thu, 26 August 2004 05:17 Go to previous messageGo to next message
Hello Marcus Olk,
> cvs team support.
We have used svn for a period of two weeks but went back to cvs after
recognizing, that at least the current plugin does not provide the
complete functionality of the corresponding cvs plugin (e.g. refactoring
capability) and showed a very bad performance compared to cvs.
Furtheron the Team->Disconnect function has an error (because it does
not remove recursively **all** .svn directories + their contents), which
is really annoying.
A brother of mine also tested svn (not the plugin) some month ago in a
large project which had to store html files with names of rare character
sets. During a normal client-server interaction involving such an
unusually named html file (I don't know the details here), the
repository was completely destroyed and they immediatly fell back to
cvs.
Please don't misunderstand that message here. I strongly assume, that
svn is "the" future open source version control system, but I wouldn't
use it in the moment for important projects...
Just my personal 0.02 Euro cent,
Daniel Krügler
Re: eclipse3, svn and synchronization [message #268828 is a reply to message #268772] Thu, 26 August 2004 10:25 Go to previous messageGo to next message
Jim,
You could try contacting the SFTP plugin providers but I suspect they
use the synchronize infrastructure that is provided by the base Eclipse
and it does not currently support ignored resources for deployment
providers (e.g. FTP, WebDAV, etc).
Michael
> ".svn" dir....
> Anyone can help me?
Re: eclipse3, svn and synchronization [message #268943 is a reply to message #268792] Thu, 26 August 2004 21:29 Go to previous messageGo to next message
I experienced intermittent hang using it. I don't really know what is the
cause. I "think" it's because of the ".project" file which I put inside
the svn repository (I used the console svn the last time). When I use the
plugin to "Checkout as Project", it just hang there. I don't want to
delete the ".project" file in the repository, that's why I reverted to
using console svn.
Re: eclipse3, svn and synchronization [message #268944 is a reply to message #268828] Thu, 26 August 2004 21:30 Go to previous messageGo to next message
Michael Valenta wrote:
> Jim,
Yes it uses the synchronize infrastructure provided by eclipse. Is there
any workaround?
thanks
Re: eclipse3, svn and synchronization [message #268991 is a reply to message #268944] Fri, 27 August 2004 08:57 Go to previous messageGo to next message
If your using the sync view, the only workaround currently is upload
individual files and exclude the ones you don't want.
>>Jim,
> any workaround?
> thanks
Re: eclipse3, svn and synchronization [message #269128 is a reply to message #268991] Sat, 28 August 2004 21:38 Go to previous message
Ok, thanks. I'll try that for now.
But, is there any plan to have something similar to Ignored resources for
the sync view?
Previous Topic:Help: DialogCellEditor does not work properly
Next Topic:adding File Navigator to RCP application
Current Time: Wed Nov 05 19:10:31 EST 2025
Powered by FUDForum. Page generated in 0.08845 seconds
