Home » Eclipse Projects » Eclipse Platform » ant task debug
ant task debug [message #268064] Fri, 20 August 2004 15:38 Go to next message
Is it possible in eclipse and how ?
thanks
Re: ant task debug [message #268072 is a reply to message #268064] Fri, 20 August 2004 13:43 Go to previous messageGo to next message
If you mean step through the Java code that is behind the Ant task:
On the JRE tab for your Ant build add the following VM args
"-Xdebug -Xrundjwp:transport=dt_socket,address=locathost:8000,server= y,suspe
nd=y"
Start the Ant build. It will wait for a debug connection.
Start a Remote Java Application launch configuration using the port
specified about (8000 in this case)
Debug as normal (breakpoints, etc)
HTH
Darins
"snpe" <snpe@snpe.co.yu> wrote in message news:cg5bi1$ono$1@eclipse.org...
> thanks
Re: ant task debug [message #268147 is a reply to message #268072] Sun, 22 August 2004 18:44 Go to previous messageGo to next message
How I can get JRE tab for ant build ?
> "-Xdebug
> -Xrundjwp:transport=dt_socket,address=locathost:8000,server= y,suspe nd=y"
> HTH
> Darins
>> thanks
Re: ant task debug [message #268170 is a reply to message #268072] Mon, 23 August 2004 03:59 Go to previous messageGo to next message
Originally posted by: Wolfgang.Haug[NO_SPAM].vector-consulting.de
I tried this, but if I want to start the Ant build I receive the message:
"Could not create the Java virtual machine."
What's wrong ?
If I start without the vm parameter the build is running.
Wolfgang
"Darin Swanson" <Darin_Swanson@us.ibm.com> schrieb im Newsbeitrag
news:cg5d6i$qu0$1@eclipse.org...
> nd=y"
> HTH
> Darins
> > thanks
Re: ant task debug [message #268190 is a reply to message #268170] Mon, 23 August 2004 10:16 Go to previous messageGo to next message
What is JRE for ant build ? Is it global JRE in windows - preferences - java
regards
> What's wrong ?
> Wolfgang
> "-Xdebug
>> nd=y"
>> HTH
>> Darins
>> > thanks
Re: ant task debug [message #268218 is a reply to message #268190] Mon, 23 August 2004 10:31 Go to previous messageGo to next message
YES, it is....
(Java 1.4.2_03)
"snpe" <snpe@snpe.co.yu> schrieb im Newsbeitrag
news:cgclpe$r67$1@eclipse.org...
java
> regards
message:
> > What's wrong ?
> > Wolfgang
> > "-Xdebug
> >> nd=y"
> >> HTH
> >> Darins
> >> > thanks
Re: ant task debug [message #268259 is a reply to message #268218] Mon, 23 August 2004 13:14 Go to previous messageGo to next message
Not necessarily.
With your Ant buildfile selection, right click > Run>Ant Build...
Go to the JRE tab and set the JRE you wish to use. The build must occur in
the separate VM for this way of debugging to work.
Specify the JRE you wish to use.
(specify these CORRECT VM args there as well..sorry about that)
-Xdebug -Xnoagent -Djava.compiler=NONE -Xrunjdwp:transport=dt_socket,server=
y,suspend=y,address=8000
HTH
Darins
"Wolfgang Haug" <Wolfgang.Haug[NO_SPAM]@vector-consulting.de> wrote in
message news:cgcut9$eva$1@eclipse.org...
> YES, it is....
> (Java 1.4.2_03)
> java
> > regards
> message:
> > > What's wrong ?
> > > Wolfgang
> > > "-Xdebug
> > >> nd=y"
> > >> HTH
> > >> Darins
> > >> > thanks
Re: ant task debug [message #268293 is a reply to message #268259] Mon, 23 August 2004 17:32 Go to previous messageGo to next message
when I do run -> ant build I get build direct , no dialog window
What is problem ?
regards
> Not necessarily.
> -Xrunjdwp:transport=dt_socket,server= y,suspend=y,address=8000
> HTH
> Darins
>> YES, it is....
>> (Java 1.4.2_03)
>> java
>> > regards
>> message:
>> > > What's wrong ?
>> > > Wolfgang
>> > > "-Xdebug
>> > >> nd=y"
>> > >> HTH
>> > >> Darins
>> > >> > thanks
Re: ant task debug [message #268301 is a reply to message #268293] Mon, 23 August 2004 16:06 Go to previous messageGo to next message
That would be because I said to use "Run>Ant Build..."
Darins
"snpe" <snpe@snpe.co.yu> wrote in message news:cgdfan$b87$1@eclipse.org...
> What is problem ?
> regards
> > Not necessarily.
in
> > HTH
> > Darins
> >> YES, it is....
> >> (Java 1.4.2_03)
preferences -
> >> java
> >> > regards
> >> message:
> >> > > What's wrong ?
> >> > > Wolfgang
task:
> >> > > "-Xdebug
> >> > >> nd=y"
port
> >> > >> HTH
> >> > >> Darins
> >> > >> > thanks
Re: ant task debug [message #268305 is a reply to message #268301] Mon, 23 August 2004 18:57 Go to previous messageGo to next message
Darins,
I do run - > Ant Build and I don't get dialog with JRE tab
-ant current task execute direct
How I can dialog with tabs (JRE and other) with Run->Ant Build
regards
> Darins
>> What is problem ?
>> regards
>> > Not necessarily.
> in
>> > HTH
>> > Darins
>> >> YES, it is....
>> >> (Java 1.4.2_03)
> preferences -
>> >> java
>> >> > regards
>> >> message:
>> >> > > What's wrong ?
>> >> > > Wolfgang
> task:
>> >> > > "-Xdebug
>> >> > >> nd=y"
> port
>> >> > >> HTH
>> >> > >> Darins
>> >> > >> > thanks
Re: ant task debug [message #268307 is a reply to message #268305] Mon, 23 August 2004 16:43 Go to previous messageGo to next message
You must select "Ant Build..." (notice the three ellipsis after Ant Build).
This realizes the external tools lauch configuration dialog on that
configuration.
"Ant Build" runs the build with no configuration
HTH
Darins
"snpe" <snpe@snpe.co.yu> wrote in message news:cgdk9p$ie1$1@eclipse.org...
> Darins,
> regards
> > Darins
> >> What is problem ?
> >> regards
> >> > Not necessarily.
occur
> > in
> >> > HTH
> >> > Darins
in
> >> >> YES, it is....
> >> >> (Java 1.4.2_03)
> > preferences -
> >> >> java
> >> >> > regards
> >> >> message:
> >> >> > > What's wrong ?
> >> >> > > Wolfgang
Newsbeitrag
> > task:
> >> >> > > "-Xdebug
> >> >> > >> nd=y"
> > port
> >> >> > >> HTH
> >> >> > >> Darins
> >> >> > >> > thanks
Re: ant task debug [message #268318 is a reply to message #268259] Mon, 23 August 2004 17:34 Go to previous messageGo to next message
Originally posted by: mark.melvin.dspfactory.com
This is definitely the tip of the day for me! I was wondering how in
the world I was going to debug my buildfiles and I stumbled across this
thread, and voila! It worked, and helped me solve a nasty bug. Is this
magical string of vmargs in the help somewhere? There is no wa I would
have ever figured this out...but I can be pretty thick at times...
Mark.
> Not necessarily.
> HTH
> Darins
>>YES, it is....
>>(Java 1.4.2_03)
>>java
>>>regards
>>message:
>>>>What's wrong ?
>>>>Wolfgang
>>>>"-Xdebug
>>>>>nd=y"
>>>>>HTH
>>>>>Darins
>>>>>>thanks
Re: ant task debug [message #268321 is a reply to message #268318] Mon, 23 August 2004 18:19 Go to previous messageGo to next message
Not in the help...we ran out of time for beefing up the Ant doc for 3.0.
But it is not special to Ant...these VM args are valid to remote debug any
VM session.
We have a deferred Ant enhancement to essentially set up a launch
configuration that would take care of these pesky details for you.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=24130
Darins
"Mark Melvin" <mark.melvin@dspfactory.com> wrote in message
news:cgdnnu$nd5$1@eclipse.org...
> Mark.
> > Not necessarily.
in
r=
> > HTH
> > Darins
> >>YES, it is....
> >>(Java 1.4.2_03)
> >>java
> >>>regards
> >>message:
> >>>>What's wrong ?
> >>>>Wolfgang
> >>>>"-Xdebug
> >>>>>nd=y"
> >>>>>HTH
> >>>>>Darins
> >>>>>>thanks
Re: ant task debug [message #268331 is a reply to message #268307] Mon, 23 August 2004 21:31 Go to previous message
Thanks a lot, Darin
best regards
> Build). This realizes the external tools lauch configuration dialog on
> that configuration.
> HTH
> Darins
>> Darins,
>> regards
>> > Darins
>> >> What is problem ?
>> >> regards
>> >> > Not necessarily.
> occur
>> > in
>> >> > HTH
>> >> > Darins
> in
>> >> >> YES, it is....
>> >> >> (Java 1.4.2_03)
>> > preferences -
>> >> >> java
>> >> >> > regards
>> >> >> > > the
>> >> >> message:
>> >> >> > > What's wrong ?
>> >> >> > > Wolfgang
> Newsbeitrag
>> > task:
>> >> >> > > "-Xdebug
>> >> >> > >> nd=y"
>> > port
>> >> >> > >> HTH
>> >> >> > >> Darins
>> >> >> > >> > thanks
Previous Topic:TreeViewer - releaseWidget() throws NullPointerException
Next Topic:Java program runs fine on one workstation, not on another...
Current Time: Sat Nov 08 14:36:00 EST 2025
Powered by FUDForum. Page generated in 0.07031 seconds
