Home » Newcomers » Newcomers » Disabling The RESIZING of a WINDOW
Disabling The RESIZING of a WINDOW [message #267777] Fri, 16 January 2009 08:51 Go to next message
Hi..I am developing an editor using SWT/JFace and I am specifying the size
of the window using
getShell.setBounds(200,100,400,500);
getShell().setMaximized(false);
parent.pack();
but its not working.
I don't want the user to maximize the window i.e. I want the size to be
what I have decided..How do I do this??
Re: Disabling The RESIZING of a WINDOW [message #267805 is a reply to message #267777] Fri, 16 January 2009 16:17 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
> size of the window using
> parent.pack();
When you create the shell, what style bits (int argument) are you
passing to the constructor?
See the class Javadoc under the title "Styles:" for what bits can be
used and then look in the SWT class for their meanings.
Hope this helps,
Eric
Re: Disabling The RESIZING of a WINDOW [message #267809 is a reply to message #267805] Sat, 17 January 2009 06:42 Go to previous messageGo to next message
This is what i have done..
public class EditorTry7 extends ApplicationWindow
public EditorTry7()
super(null);
protected Control createContents(Composite parent)
getShell().setText("Graphical Editor ");
getShell().setBounds(200,100,600,400);
//Add tabfolders and groups
GroupandTabfolder5 GT = new GroupandTabfolder5(parent);
parent.pack();
return parent;
public static void main(String args[])
EditorTry7 ET7 = new EditorTry7();
ET7.setBlockOnOpen(true);
ET7.open();
Display.getCurrent().dispose();
I dint get any option as Styles,as there is no argument in "open()"
method..
What should i do as to disable resizing.
Re: Disabling The RESIZING of a WINDOW [message #267828 is a reply to message #267809] Mon, 19 January 2009 16:14 Go to previous messageGo to next message
> public EditorTry7()
> super(null);
<snipped more code>
> method..
Look at your call to the super constructor; do you know why you're
passing null? Do you know the ramifications of doing so, instead of
passing in a Shell object?
Also look at the methods that ApplicationWindow inherits from Window,
specifically getShellStyle()/setShellStyle().
A little reading of the Javadoc and the source code will go a long way.
Eric
Re: Disabling The RESIZING of a WINDOW [message #267855 is a reply to message #267828] Tue, 20 January 2009 09:20 Go to previous message
Thanks a lot !! ur suggestion helped! :-)
Previous Topic:bug with redundant null check warning?
Next Topic:Reports in PDF format
Current Time: Fri Sep 26 05:44:10 EDT 2025
Powered by FUDForum. Page generated in 0.09600 seconds
