Home » Eclipse Projects » Eclipse Platform » getGlobalActionHandler
getGlobalActionHandler [message #266361] Tue, 10 August 2004 21:15 Go to next message
How do I get a reference programatically to the Workbench Actions that I
contributed to an org.eclipse.ui.actionSets?
IActionBars has a method that seems to be the right way:
public IAction getGlobalActionHandler(String actionId)Returns the global
action handler for the action with the given id.
Parameters:
actionId - an action id declared in the registry
Returns:
an action handler which implements the action id, or null if none is
registered
See Also:
IWorkbenchActionConstants, setGlobalActionHandler
To get a reference to an IActionBars I had to downcast IWorkbenchPage to
WorkbenchPage (which doesn't seem right).
private IAction getGlobalActionHandler(String string) {
return
((WorkbenchPage)UIPlugin.getDefault().getWorkbench().getActi veWorkbenchWindo
w().getActivePage())
.getActionBars().getGlobalActionHandler(string);
Then: getActionBars() returns a WWinActionBars.
the WWinActionBars implementation of getGlobalActionHandler(string) returns
null. (is not implemented).
Obviously I am looking in the wrong place.
Arturo.
Re: getGlobalActionHandler [message #266488 is a reply to message #266361] Wed, 11 August 2004 11:23 Go to previous messageGo to next message
Here is another wrong place where I have looked:
instantiated an IAction programatically (And added it to a ContextMenu)
created a corresponding command in the plugin.xml (org.eclipse.ui.commands)
in the constructor for the Action added the instruction:
setActionDefinitionId("com.pragmafs.ui.tasks.refresh");
with the same definitionId specified in the command.
Now, I can see the key binding text in the context menu. But it is still
not activated when I hit the corresponding keys.
Arturo.
"Arturo" <arturo@pragmafs.com> wrote in message
news:cfbrg8$spe$1@eclipse.org...
> Hello,
> Parameters:
> Returns:
> registered
> See Also:
> return
returns
> Arturo.
Re: getGlobalActionHandler [message #266509 is a reply to message #266488] Wed, 11 August 2004 12:27 Go to previous message
Here is something that worked... but it is so kludgy that I am sure that I
am still looking at the wrong place.
The same action that I created before... now I need to manually register it
with some global action handler...
I found some code in WorkbenchWindow that registers the Action... so I
copied it here:
NOTE: this seems wrong (if somebody knows a better way to do this, please
advise)...
IWorkbenchCommandSupport commandSupport =
Workbench.getInstance().getCommandSupport();
IHandler handler = new ActionHandler(refresh);
Shell shell = getViewer().getControl().getShell();
String actionDefinitionId = refresh.getActionDefinitionId();
HandlerSubmission handlerSubmission = new HandlerSubmission(null,
shell, null, actionDefinitionId, handler, Priority.LEGACY);
commandSupport.addHandlerSubmission(handlerSubmission);
Arturo.
news:cfdd7a$6o0$1@eclipse.org...
> Arturo.
> > Hello,
> > Parameters:
> > Returns:
> > registered
> > See Also:
> > return
> returns
> > Thanks,
> > Arturo.
Previous Topic:eclipse 3.0 on win XP and Sun solaris 8.0
Next Topic:repost: How to filter "Open Resource" ?
Current Time: Fri Jul 18 07:29:18 EDT 2025
Powered by FUDForum. Page generated in 0.04491 seconds
