Home » Newcomers » Newcomers » icon.xpm
icon.xpm [message #266290] Thu, 13 November 2008 15:11 Go to next message
Hello Everyone
I was looking for an icon.xpm in my Linux-Eclipse but I couldnt find
any. I found some bug reports where they said this should be fixed but
well, seems its not.
Could someone here provide me with this file so I can put it to my
gnome-panel.
Re: icon.xpm [message #266295 is a reply to message #266290] Thu, 13 November 2008 15:36 Go to previous messageGo to next message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
For the specific example of Eclipse 3.4.1, Have a gander at the icons
available in eclipse/plugins/org.eclipse.sdk_3.4.1.v200809111700/. Any
of them should do the trick for setting up a .desktop file or other
panel shortcut.
Nick
Marc Schlegel wrote:
> Hello Everyone
> gnome-panel.
> Thanks
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: icon.xpm [message #266299 is a reply to message #266295] Thu, 13 November 2008 18:25 Go to previous messageGo to next message
Originally posted by: silver.zachara.gmail.com
Nick Boldt napsal(a):
> panel shortcut.
The better solution would be to distribute eclipse with icons for linux platform, this
with svg or xpm, pls create issue in bugzilla ;)
Re: icon.xpm [message #266301 is a reply to message #266299] Thu, 13 November 2008 21:45 Go to previous messageGo to next message
If you feel that a .png or .gif is insufficient, file a bug here:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
Me, I'm happy w/ either:
a) using Fedora Eclipse, which already includes all the icons and
launchers built-in when installed from .rpm, or
b) creating my own using the supplied icons in the SDK plugin.
>> panel shortcut.
> with svg or xpm.
Re: icon.xpm [message #266304 is a reply to message #266301] Fri, 14 November 2008 04:34 Go to previous messageGo to next message
ok i create issue, because in UBUNUNTU are png and gif unusable as pictures for icons.
Re: icon.xpm [message #266314 is a reply to message #266304] Fri, 14 November 2008 11:51 Go to previous messageGo to next message
I'm a little confused (as usual), because I have Ganymede installed on
Ubuntu (under /opt), and /opt/eclipse/icon.xpm exists (and is used in
the main menu entry).
/Paul
Re: icon.xpm [message #266315 is a reply to message #266314] Fri, 14 November 2008 12:00 Go to previous messageGo to next message
[self-reply -- never a good sign]
Poked around a bit more. Turns out icon.xpm was left over from an
earlier version of Eclipse (Europa, I think). There's no icon.xpm in my
Ganymede installation, and in fact I can't find any icon files of any
sort. Don't know if icon.xpm was dropped intentionally from the
Ganymede distribution for Linux, but I suspect it's an oversight.
/Paul
Re: icon.xpm [message #266321 is a reply to message #266315] Fri, 14 November 2008 12:45 Go to previous messageGo to next message
Originally posted by: 4cs6fcg02.sneakemail.com
--------------030706090204040400070109
Content-Type: text/plain; charset=UTF-8
It is a known bug:
Annoying, yes, I found one on the internet, find it attached (if that
works here?), openSUSE provides one as well, the png.
H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Content-Type: image/svg+xml;
name="eclipse.svg"
Content-Disposition: inline;
filename="eclipse.svg"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiIHN0YW5kYWxv bmU9Im5vIj8+
CjwhLS0gQ3JlYXRlZCB3aXRoIElua3NjYXBlIChodHRwOi8vd3d3Lmlua3Nj YXBlLm9yZy8p
IC0tPgo8c3ZnCiAgIHhtbG5zOmRjPSJodHRwOi8vcHVybC5vcmcvZGMvZWxl bWVudHMvMS4x
LyIKICAgeG1sbnM6Y2M9Imh0dHA6Ly9jcmVhdGl2ZWNvbW1vbnMub3JnL25z IyIKICAgeG1s
bnM6cmRmPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5LzAyLzIyLXJkZi1zeW50 YXgtbnMjIgog
ICB4bWxuczpzdmc9Imh0dHA6Ly93d3cudzMub3JnLzIwMDAvc3ZnIgogICB4 bWxucz0iaHR0
cDovL3d3dy53My5vcmcvMjAwMC9zdmciCiAgIHhtbG5zOnhsaW5rPSJodHRw Oi8vd3d3Lncz
Lm9yZy8xOTk5L3hsaW5rIgogICB4bWxuczpzb2RpcG9kaT0iaHR0cDovL3Nv ZGlwb2RpLnNv
dXJjZWZvcmdlLm5ldC9EVEQvc29kaXBvZGktMC5kdGQiCiAgIHhtbG5zOmlu a3NjYXBlPSJo
dHRwOi8vd3d3Lmlua3NjYXBlLm9yZy9uYW1lc3BhY2VzL2lua3NjYXBlIgog ICB3aWR0aD0i
NDAwLjAwMDAzIgogICBoZWlnaHQ9IjQwMCIKICAgaWQ9InN2ZzIiCiAgIHNv ZGlwb2RpOnZl
cnNpb249IjAuMzIiCiAgIGlua3NjYXBlOnZlcnNpb249IjAuNDUrZGV2ZWwi CiAgIHZlcnNp
b249IjEuMCIKICAgc29kaXBvZGk6ZG9jbmFtZT0iZWNsaXBzZS5zdmciCiAg IGlua3NjYXBl
Om91dHB1dF9leHRlbnNpb249Im9yZy5pbmtzY2FwZS5vdXRwdXQuc3ZnLmlu a3NjYXBlIgog
ICBpbmtzY2FwZTpleHBvcnQtZmlsZW5hbWU9Ii9Vc2Vycy9jb2JyYW5haWwv RGVza3RvcC9p
Y29ucy9NeUljb25zL2VjbGlwc2UucG5nIgogICBpbmtzY2FwZTpleHBvcnQt eGRwaT0iOTAi
CiAgIGlua3NjYXBlOmV4cG9ydC15ZHBpPSI5MCI+CiAgPGRlZnMKICAgICBp ZD0iZGVmczQi
PgogICAgPGxpbmVhckdyYWRpZW50CiAgICAgICBpZD0ibGluZWFyR3JhZGll bnQzNzAxIj4K
ICAgICAgPHN0b3AKICAgICAgICAgaWQ9InN0b3AzNzAzIgogICAgICAgICBv ZmZzZXQ9IjAi
CiAgICAgICAgIHN0eWxlPSJzdG9wLWNvbG9yOiM1NmZiZmY7c3RvcC1vcGFj aXR5OjAuMzY1
MjE3Mzk7IiAvPgogICAgICA8c3RvcAogICAgICAgICBpZD0ic3RvcDM3MDUi CiAgICAgICAg
IG9mZnNldD0iMSIKICAgICAgICAgc3R5bGU9InN0b3AtY29sb3I6IzAwYTJi YTtzdG9wLW9w
YWNpdHk6MDsiIC8+CiAgICA8L2xpbmVhckdyYWRpZW50PgogICAgPGxpbmVh ckdyYWRpZW50
CiAgICAgICBpZD0ibGluZWFyR3JhZGllbnQzNjg5Ij4KICAgICAgPHN0b3AK ICAgICAgICAg
c3R5bGU9InN0b3AtY29sb3I6I2M2MDBmNDtzdG9wLW9wYWNpdHk6MC44MzQ3 ODI2OyIKICAg
ICAgICAgb2Zmc2V0PSIwIgogICAgICAgICBpZD0ic3RvcDM2OTEiIC8+CiAg ICAgIDxzdG9w
CiAgICAgICAgIHN0eWxlPSJzdG9wLWNvbG9yOiNjMDAwZjA7c3RvcC1vcGFj aXR5OjA7Igog
ICAgICAgICBvZmZzZXQ9IjEiCiAgICAgICAgIGlkPSJzdG9wMzY5MyIgLz4K ICAgIDwvbGlu
ZWFyR3JhZGllbnQ+CiAgICA8bGluZWFyR3JhZGllbnQKICAgICAgIGlkPSJs aW5lYXJHcmFk
aWVudDM2NzciPgogICAgICA8c3RvcAogICAgICAgICBzdHlsZT0ic3RvcC1j b2xvcjojMDAw
MDAwO3N0b3Atb3BhY2l0eTowLjYwODY5NTYzOyIKICAgICAgICAgb2Zmc2V0 PSIwIgogICAg
ICAgICBpZD0ic3RvcDM2NzkiIC8+CiAgICAgIDxzdG9wCiAgICAgICAgIGlk PSJzdG9wMzY4
NSIKICAgICAgICAgb2Zmc2V0PSIwLjQzNjM2MzY0IgogICAgICAgICBzdHls ZT0ic3RvcC1j
b2xvcjojMDAwMDAwO3N0b3Atb3BhY2l0eTowLjMwMTk2MDc4OyIgLz4KICAg ICAgPHN0b3AK
ICAgICAgICAgc3R5bGU9InN0b3AtY29sb3I6IzAwMDAwMDtzdG9wLW9wYWNp dHk6MDsiCiAg
ICAgICAgIG9mZnNldD0iMSIKICAgICAgICAgaWQ9InN0b3AzNjgxIiAvPgog ICAgPC9saW5l
YXJHcmFkaWVudD4KICAgIDxsaW5lYXJHcmFkaWVudAogICAgICAgaWQ9Imxp bmVhckdyYWRp
ZW50MzY0MiI+CiAgICAgIDxzdG9wCiAgICAgICAgIGlkPSJzdG9wMzY0NCIK ICAgICAgICAg
b2Zmc2V0PSIwIgogICAgICAgICBzdHlsZT0ic3RvcC1jb2xvcjojZmZmZmZm O3N0b3Atb3Bh
Y2l0eTowLjMxMzA0MzQ4OyIgLz4KICAgICAgPHN0b3AKICAgICAgICAgaWQ9 InN0b3AzNjQ2
IgogICAgICAgICBvZmZzZXQ9IjEiCiAgICAgICAgIHN0eWxlPSJzdG9wLWNv bG9yOiNhODU0
YmY7c3RvcC1vcGFjaXR5OjA7IiAvPgogICAgPC9saW5lYXJHcmFkaWVudD4K ICAgIDxsaW5l
YXJHcmFkaWVudAogICAgICAgaWQ9ImxpbmVhckdyYWRpZW50MzM0NSI+CiAg ICAgIDxzdG9w
CiAgICAgICAgIGlkPSJzdG9wMzM0NyIKICAgICAgICAgb2Zmc2V0PSIwIgog ICAgICAgICBz
dHlsZT0ic3RvcC1jb2xvcjojZmZmZmZmO3N0b3Atb3BhY2l0eTowLjI3ODI2 MDg2OyIgLz4K
ICAgICAgPHN0b3AKICAgICAgICAgaWQ9InN0b3AzMzQ5IgogICAgICAgICBv ZmZzZXQ9IjEi
CiAgICAgICAgIHN0eWxlPSJzdG9wLWNvbG9yOiNmZmZmZmY7c3RvcC1vcGFj aXR5OjAuMDA4
Njk1NjU7IiAvPgogICAgPC9saW5lYXJHcmFkaWVudD4KICAgIDxsaW5lYXJH cmFkaWVudAog
ICAgICAgaWQ9ImxpbmVhckdyYWRpZW50MzI3OSI+CiAgICAgIDxzdG9wCiAg ICAgICAgIGlk
PSJzdG9wMzI4MSIKICAgICAgICAgb2Zmc2V0PSIwIgogICAgICAgICBzdHls ZT0ic3RvcC1j
b2xvcjojZmZmZmZmO3N0b3Atb3BhY2l0eToxOyIgLz4KICAgICAgPHN0b3AK ICAgICAgICAg
aWQ9InN0b3AzMjgzIgogICAgICAgICBvZmZzZXQ9IjEiCiAgICAgICAgIHN0 eWxlPSJzdG9w
LWNvbG9yOiM2NGViZmY7c3RvcC1vcGFjaXR5OjA7IiAvPgogICAgPC9saW5l YXJHcmFkaWVu
dD4KICAgIDxsaW5lYXJHcmFkaWVudAogICAgICAgaWQ9ImxpbmVhckdyYWRp ZW50MzA3NSI+
CiAgICAgIDxzdG9wCiAgICAgICAgIHN0eWxlPSJzdG9wLWNvbG9yOiNmZmZm ZmY7c3RvcC1v
cGFjaXR5OjE7IgogICAgICAgICBvZmZzZXQ9IjAiCiAgICAgICAgIGlkPSJz dG9wMzA3NyIg
Lz4KICAgICAgPHN0b3AKICAgICAgICAgc3R5bGU9InN0b3AtY29sb3I6IzY4 ZmZlYztzdG9w
LW9wYWNpdHk6MDsiCiAgICAgICAgIG9mZnNldD0iMSIKICAgICAgICAgaWQ9 InN0b3AzMDc5
IiAvPgogICAgPC9saW5lYXJHcmFkaWVudD4KICAgIDxsaW5lYXJHcmFkaWVu dAogICAgICAg
aWQ9ImxpbmVhckdyYWRpZW50MzA2MiI+CiAgICAgIDxzdG9wCiAgICAgICAg IGlkPSJzdG9w
MzA2NCIKICAgICAgICAgb2Zmc2V0PSIwIgogICAgICAgICBzdHlsZT0ic3Rv cC1jb2xvcjoj
MjU1YWZmO3N0b3Atb3BhY2l0eTowOyIgLz4KICAgICAgPHN0b3AKICAgICAg ICAgc3R5bGU9
InN0b3AtY29sb3I6IzljN2VmZjtzdG9wLW9wYWNpdHk6MC4yMjM1Mjk0MTsi CiAgICAgICAg
IG9mZnNldD0iMC44MzU4ODMzMiIKICAgICAgICAgaWQ9InN0b3AzMDY2IiAv PgogICAgICA8
c3RvcAogICAgICAgICBpZD0ic3RvcDMwNjgiCiAgICAgICAgIG9mZnNldD0i MSIKICAgICAg
ICAgc3R5bGU9InN0b3AtY29sb3I6I2YxZDdmZjtzdG9wLW9wYWNpdHk6MC42 NzA1ODgyNTsi
IC8+CiAgICA8L2xpbmVhckdyYWRpZW50PgogICAgPGxpbmVhckdyYWRpZW50 CiAgICAgICBp
ZD0ibGluZWFyR3JhZGllbnQyOTc0Ij4KICAgICAgPHN0b3AKICAgICAgICAg c3R5bGU9InN0
b3AtY29sb3I6IzViZjNmZjtzdG9wLW9wYWNpdHk6MC43ODQzMTM3NDsiCiAg ICAgICAgIG9m
ZnNldD0iMCIKICAgICAgICAgaWQ9InN0b3AyOTc2IiAvPgogICAgICA8c3Rv cAogICAgICAg
ICBpZD0ic3RvcDI5ODQiCiAgICAgICAgIG9mZnNldD0iMC4zNTQ4MDMzNSIK ICAgICAgICAg
c3R5bGU9InN0b3AtY29sb3I6I2FkZGJmZjtzdG9wLW9wYWNpdHk6MC4zOTIx NTY4NzsiIC8+
CiAgICAgIDxzdG9wCiAgICAgICAgIHN0eWxlPSJzdG9wLWNvbG9yOiM2NjVi ZmY7c3RvcC1v
cGFjaXR5OjA7IgogICAgICAgICBvZmZzZXQ9IjEiCiAgICAgICAgIGlkPSJz dG9wMjk3OCIg
Lz4KICAgIDwvbGluZWFyR3JhZGllbnQ+CiAgICA8bGluZWFyR3JhZGllbnQK ICAgICAgIGlk
PSJsaW5lYXJHcmFkaWVudDI5NjQiPgogICAgICA8c3RvcAogICAgICAgICBz dHlsZT0ic3Rv
cC1jb2xvcjojZmZmZmZmO3N0b3Atb3BhY2l0eTowOyIKICAgICAgICAgb2Zm c2V0PSIwIgog
ICAgICAgICBpZD0ic3RvcDI5NjYiIC8+CiAgICAgIDxzdG9wCiAgICAgICAg IGlkPSJzdG9w
Mjk3MiIKICAgICAgICAgb2Zmc2V0PSIwLjgzNTg4MzMyIgogICAgICAgICBz dHlsZT0ic3Rv
cC1jb2xvcjojZmZmZmZmO3N0b3Atb3BhY2l0eTowLjIyNjA4Njk2OyIgLz4K ICAgICAgPHN0
b3AKICAgICAgICAgc3R5bGU9InN0b3AtY29sb3I6I2ZmZmZmZjtzdG9wLW9w YWNpdHk6MC42
NzA1ODgyNTsiCiAgICAgICAgIG9mZnNldD0iMSIKICAgICAgICAgaWQ9InN0 b3AyOTY4IiAv
PgogICAgPC9saW5lYXJHcmFkaWVudD4KICAgIDxsaW5lYXJHcmFkaWVudAog ICAgICAgaWQ9
ImxpbmVhckdyYWRpZW50Mjk0MSI+CiAgICAgIDxzdG9wCiAgICAgICAgIHN0 eWxlPSJzdG9w
LWNvbG9yOiNmZmZmZmY7c3RvcC1vcGFjaXR5OjAuODM0NzgyNjsiCiAgICAg ICAgIG9mZnNl
dD0iMCIKICAgICAgICAgaWQ9InN0b3AyOTQzIiAvPgogICAgICA8c3RvcAog ICAgICAgICBz
dHlsZT0ic3RvcC1jb2xvcjojYTg1NGJmO3N0b3Atb3BhY2l0eTowOyIKICAg ICAgICAgb2Zm
c2V0PSIxIgogICAgICAgICBpZD0ic3RvcDI5NDUiIC8+CiAgICA8L2xpbmVh ckdyYWRpZW50
PgogICAgPGxpbmVhckdyYWRpZW50CiAgICAgICBpZD0ibGluZWFyR3JhZGll bnQyOTMxIj4K
ICAgICAgPHN0b3AKICAgICAgICAgc3R5bGU9InN0b3AtY29sb3I6IzBjMDA0 NztzdG9wLW9w
YWNpdHk6MTsiCiAgICAgICAgIG9mZnNldD0iMCIKICAgICAgICAgaWQ9InN0 b3AyOTMzIiAv
PgogICAgICA8c3RvcAogICAgICAgICBzdHlsZT0ic3RvcC1jb2xvcjojZmYw NmYwO3N0b3At
b3BhY2l0eToxOyIKICAgICAgICAgb2Zmc2V0PSIxIgogICAgICAgICBpZD0i c3RvcDI5MzUi
ZD0ibGluZWFyR3JhZGllbnQyOTIzIj4KICAgICAgPHN0b3AKICAgICAgICAg c3R5bGU9InN0
b3AtY29sb3I6I2ZmZmZmZjtzdG9wLW9wYWNpdHk6MC41OTEzMDQzNjsiCiAg ICAgICAgIG9m
ZnNldD0iMCIKICAgICAgICAgaWQ9InN0b3AyOTI1IiAvPgogICAgICA8c3Rv cAogICAgICAg
ICBzdHlsZT0ic3RvcC1jb2xvcjojNjI5ZWM0O3N0b3Atb3BhY2l0eTowOyIK ICAgICAgICAg
b2Zmc2V0PSIxIgogICAgICAgICBpZD0ic3RvcDI5MjciIC8+CiAgICA8L2xp bmVhckdyYWRp
ZW50PgogICAgPGxpbmVhckdyYWRpZW50CiAgICAgICBpZD0ibGluZWFyR3Jh ZGllbnQyOTEz
Ij4KICAgICAgPHN0b3AKICAgICAgICAgc3R5bGU9InN0b3AtY29sb3I6I2My ZDllODtzdG9w
LW9wYWNpdHk6MTsiCiAgICAgICAgIG9mZnNldD0iMCIKICAgICAgICAgaWQ9 InN0b3AyOTE1
IiAvPgogICAgICA8c3RvcAogICAgICAgICBzdHlsZT0ic3RvcC1jb2xvcjoj NjI2NWM0O3N0
b3Atb3BhY2l0eTowOyIKICAgICAgICAgb2Zmc2V0PSIxIgogICAgICAgICBp ZD0ic3RvcDI5
MTciIC8+CiAgICA8L2xpbmVhckdyYWRpZW50PgogICAgPGxpbmVhckdyYWRp ZW50CiAgICAg
ICBpZD0ibGluZWFyR3JhZGllbnQyOTAxIj4KICAgICAgPHN0b3AKICAgICAg ICAgc3R5bGU9
InN0b3AtY29sb3I6IzAwMDAwMDtzdG9wLW9wYWNpdHk6MTsiCiAgICAgICAg IG9mZnNldD0i
MCIKICAgICAgICAgaWQ9InN0b3AyOTAzIiAvPgogICAgICA8c3RvcAogICAg ICAgICBpZD0i
c3RvcDI5MDkiCiAgICAgICAgIG9mZnNldD0iMC44MDEzNDU3NyIKICAgICAg ICAgc3R5bGU9
InN0b3AtY29sb3I6IzM2NTBlZTtzdG9wLW9wYWNpdHk6MTsiIC8+CiAgICAg IDxzdG9wCiAg
ICAgICAgIHN0eWxlPSJzdG9wLWNvbG9yOiM5NTE4ZmY7c3RvcC1vcGFjaXR5 OjA7IgogICAg
ICAgICBvZmZzZXQ9IjEiCiAgICAgICAgIGlkPSJzdG9wMjkwNSIgLz4KICAg IDwvbGluZWFy
R3JhZGllbnQ+CiAgICA8bGluZWFyR3JhZGllbnQKICAgICAgIGlkPSJsaW5l YXJHcmFkaWVu
dDI4OTMiPgogICAgICA8c3RvcAogICAgICAgICBzdHlsZT0ic3RvcC1jb2xv cjojMjI1OWRi
O3N0b3Atb3BhY2l0eToxOyIKICAgICAgICAgb2Zmc2V0PSIwIgogICAgICAg ICBpZD0ic3Rv
cDI4OTUiIC8+CiAgICAgIDxzdG9wCiAgICAgICAgIHN0eWxlPSJzdG9wLWNv bG9yOiMxYTJi
NzM7c3RvcC1vcGFjaXR5OjE7IgogICAgICAgICBvZmZzZXQ9IjEiCiAgICAg ICAgIGlkPSJz
dG9wMjg5NyIgLz4KICAgIDwvbGluZWFyR3JhZGllbnQ+CiAgICA8cmFkaWFs R3JhZGllbnQK
ICAgICAgIGlua3NjYXBlOmNvbGxlY3Q9ImFsd2F5cyIKICAgICAgIHhsaW5r OmhyZWY9IiNs
aW5lYXJHcmFkaWVudDI4OTMiCiAgICAgICBpZD0icmFkaWFsR3JhZGllbnQy ODk5IgogICAg
ICAgY3g9IjM0NS43MTQyOSIKICAgICAgIGN5PSI1NzYuNjQ3ODkiCiAgICAg ICBmeD0iMzQ1
LjcxNDI5IgogICAgICAgZnk9IjU3Ni42NDc4OSIKICAgICAgIHI9IjEzOC41 NzE0MyIKICAg
ICAgIGdyYWRpZW50VW5pdHM9InVzZXJTcGFjZU9uVXNlIiAvPgogICAgPHJh ZGlhbEdyYWRp
ZW50CiAgICAgICBpbmtzY2FwZTpjb2xsZWN0PSJhbHdheXMiCiAgICAgICB4 bGluazpocmVm
PSIjbGluZWFyR3JhZGllbnQyOTAxIgogICAgICAgaWQ9InJhZGlhbEdyYWRp ZW50MjkwNyIK
ICAgICAgIGN4PSIzMTcuMTQyODUiCiAgICAgICBjeT0iNTAzLjc5MDc0Igog ICAgICAgZng9
IjMxNy4xNDI4NSIKICAgICAgIGZ5PSI1MDMuNzkwNzQiCiAgICAgICByPSIx MzguNTcxNDMi
CiAgICAgICBncmFkaWVudFVuaXRzPSJ1c2VyU3BhY2VPblVzZSIKICAgICAg IGdyYWRpZW50
VHJhbnNmb3JtPSJtYXRyaXgoMS4xMDgyNDc2LC0xLjIzODMxNDVlLTcsMS4y NDQwNzQzZS03
LDEuMTEzNDAyNCwtMzQuMzMwMDExLC01Ny4xMzEwNDkpIiAvPgogICAgPGxp bmVhckdyYWRp
PSIjbGluZWFyR3JhZGllbnQyOTMxIgogICAgICAgaWQ9ImxpbmVhckdyYWRp ZW50MjkzNyIK
ICAgICAgIHgxPSIyNTUuOTkyNzQiCiAgICAgICB5MT0iMzUzLjA1ODk2Igog ICAgICAgeDI9
IjMzNC40NDM3NiIKICAgICAgIHkyPSI2NTcuMjYzMDYiCiAgICAgICBncmFk aWVudFVuaXRz
PSJ1c2VyU3BhY2VPblVzZSIgLz4KICAgIDxyYWRpYWxHcmFkaWVudAogICAg ICAgaW5rc2Nh
cGU6Y29sbGVjdD0iYWx3YXlzIgogICAgICAgeGxpbms6aHJlZj0iI2xpbmVh ckdyYWRpZW50
Mjk2NCIKICAgICAgIGlkPSJyYWRpYWxHcmFkaWVudDI5NzAiCiAgICAgICBj eD0iMjc3LjA3
MzQ5IgogICAgICAgY3k9IjQ4Mi43MTUxNSIKICAgICAgIGZ4PSIyNzcuMDcz NDkiCiAgICAg
ICBmeT0iNDgyLjcxNTE1IgogICAgICAgcj0iMTcxLjA3MzQ5IgogICAgICAg Z3JhZGllbnRV
bml0cz0idXNlclNwYWNlT25Vc2UiCiAgICAgICBncmFkaWVudFRyYW5zZm9y bT0ibWF0cml4
KDAuOTkyOTAzOSwwLDAsMC45OTI5MDM5LDMuMTgwMTA3Nyw0LjYzOTM2Njgp IiAvPgogICAg
PGZpbHRlcgogICAgICAgaW5rc2NhcGU6Y29sbGVjdD0iYWx3YXlzIgogICAg ICAgaWQ9ImZp
bHRlcjMwNTgiPgogICAgICA8ZmVHYXVzc2lhbkJsdXIKICAgICAgICAgaW5r c2NhcGU6Y29s
bGVjdD0iYWx3YXlzIgogICAgICAgICBzdGREZXZpYXRpb249IjAuODQ5Mjk3 NjciCiAgICAg
ICAgIGlkPSJmZUdhdXNzaWFuQmx1cjMwNjAiIC8+CiAgICA8L2ZpbHRlcj4K ICAgIDxsaW5l
YXJHcmFkaWVudAogICAgICAgaW5rc2NhcGU6Y29sbGVjdD0iYWx3YXlzIgog ICAgICAgeGxp
bms6aHJlZj0iI2xpbmVhckdyYWRpZW50MzA3NSIKICAgICAgIGlkPSJsaW5l YXJHcmFkaWVu
dDMwODUiCiAgICAgICBncmFkaWVudFVuaXRzPSJ1c2VyU3BhY2VPblVzZSIK ICAgICAgIHgx
PSIxMDQuMTA2NjEiCiAgICAgICB5MT0iNTg0LjY3NjAzIgogICAgICAgeDI9 IjQzNC45NTI4
NSIKICAgICAgIHkyPSI0NjAuMTI5NDYiCiAgICAgICBncmFkaWVudFRyYW5z Zm9ybT0idHJh
bnNsYXRlKDQsLTM4KSIgLz4KICAgIDxmaWx0ZXIKICAgICAgIGlua3NjYXBl OmNvbGxlY3Q9
ImFsd2F5cyIKICAgICAgIGlkPSJmaWx0ZXIzMTE1Ij4KICAgICAgPGZlR2F1 c3NpYW5CbHVy
CiAgICAgICAgIGlua3NjYXBlOmNvbGxlY3Q9ImFsd2F5cyIKICAgICAgICAg c3RkRGV2aWF0
aW9uPSI1LjU0Mjg1NzEiCiAgICAgICAgIGlkPSJmZUdhdXNzaWFuQmx1cjMx MTciIC8+CiAg
ICA8L2ZpbHRlcj4KICAgIDxmaWx0ZXIKICAgICAgIGlua3NjYXBlOmNvbGxl Y3Q9ImFsd2F5
cyIKICAgICAgIGlkPSJmaWx0ZXIzMjc1IgogICAgICAgeD0iLTAuMDM5MjM1 MzgzIgogICAg
ICAgd2lkdGg9IjEuMDc4NDcwOCIKICAgICAgIHk9Ii0wLjIwNzY0ODM4Igog ICAgICAgaGVp
Z2h0PSIxLjQxNTI5NjgiPgogICAgICA8ZmVHYXVzc2lhbkJsdXIKICAgICAg ICAgaW5rc2Nh
cGU6Y29sbGVjdD0iYWx3YXlzIgogICAgICAgICBzdGREZXZpYXRpb249IjUu NDE2NjUzNCIK
ICAgICAgICAgaWQ9ImZlR2F1c3NpYW5CbHVyMzI3NyIgLz4KICAgIDwvZmls dGVyPgogICAg
bHRlcjMzMDUiCiAgICAgICB4PSItMC4wMjA4NDY2ODkiCiAgICAgICB3aWR0 aD0iMS4wNDE2
OTM0IgogICAgICAgeT0iLTAuMTMxODE2MzkiCiAgICAgICBoZWlnaHQ9IjEu MjYzNjMyOCI+
CiAgICAgIDxmZUdhdXNzaWFuQmx1cgogICAgICAgICBpbmtzY2FwZTpjb2xs ZWN0PSJhbHdh
eXMiCiAgICAgICAgIHN0ZERldmlhdGlvbj0iMi43Nzg1Njk5IgogICAgICAg ICBpZD0iZmVH
YXVzc2lhbkJsdXIzMzA3IiAvPgogICAgPC9maWx0ZXI+CiAgICA8bGluZWFy R3JhZGllbnQK
aW5lYXJHcmFkaWVudDMyNzkiCiAgICAgICBpZD0ibGluZWFyR3JhZGllbnQz MzI3IgogICAg
ICAgZ3JhZGllbnRVbml0cz0idXNlclNwYWNlT25Vc2UiCiAgICAgICBncmFk aWVudFRyYW5z
Zm9ybT0idHJhbnNsYXRlKDQsLTM4KSIKICAgICAgIHgxPSIxMDQuMTA2NjEi CiAgICAgICB5
MT0iNTg0LjY3NjAzIgogICAgICAgeDI9IjQzNC45NTI4NSIKICAgICAgIHky PSI0NjAuMTI5
NDYiIC8+CiAgICA8bGluZWFyR3JhZGllbnQKICAgICAgIGlua3NjYXBlOmNv bGxlY3Q9ImFs
d2F5cyIKICAgICAgIHhsaW5rOmhyZWY9IiNsaW5lYXJHcmFkaWVudDMyNzki CiAgICAgICBp
ZD0ibGluZWFyR3JhZGllbnQzMzM3IgogICAgICAgZ3JhZGllbnRVbml0cz0i dXNlclNwYWNl
T25Vc2UiCiAgICAgICBncmFkaWVudFRyYW5zZm9ybT0idHJhbnNsYXRlKDQs LTM4KSIKICAg
ICAgIHgxPSIxMDQuMTA2NjEiCiAgICAgICB5MT0iNTg0LjY3NjAzIgogICAg ICAgeDI9IjQz
NC45NTI4NSIKICAgICAgIHkyPSI0NjAuMTI5NDYiIC8+CiAgICA8bGluZWFy R3JhZGllbnQK
aW5lYXJHcmFkaWVudDMwNzUiCiAgICAgICBpZD0ibGluZWFyR3JhZGllbnQz MzM5IgogICAg
Zm9ybT0idHJhbnNsYXRlKDQsLTM4KSIKICAgICAgIHgxPSIxMTguNzg5ODYi CiAgICAgICB5
MT0iNTQ3LjgxMDI0IgogICAgICAgeDI9IjQzNC45NTI4NSIKICAgICAgIHky PSI0NjAuMTI5
ZD0ibGluZWFyR3JhZGllbnQzNDQ3IgogICAgICAgZ3JhZGllbnRVbml0cz0i dXNlclNwYWNl
ICAgIHgxPSIxNjguMDQxNzkiCiAgICAgICB5MT0iNTUzLjExMzEiCiAgICAg ICB4Mj0iNDM0
Ljk1Mjg1IgogICAgICAgeTI9IjQ2MC4xMjk0NiIgLz4KICAgIDxmaWx0ZXIK ICAgICAgIGlu
a3NjYXBlOmNvbGxlY3Q9ImFsd2F5cyIKICAgICAgIGlkPSJmaWx0ZXIzNTUz IgogICAgICAg
eD0iLTAuMDkzODEwMTA0IgogICAgICAgd2lkdGg9IjEuMTg3NjIwMiIKICAg ICAgIHk9Ii0w
LjU5MzE3Mzc0IgogICAgICAgaGVpZ2h0PSIyLjE4NjM0NzUiPgogICAgICA8 ZmVHYXVzc2lh
bkJsdXIKICAgICAgICAgaW5rc2NhcGU6Y29sbGVjdD0iYWx3YXlzIgogICAg ICAgICBzdGRE
ZXZpYXRpb249IjEyLjUwMzU2NCIKICAgICAgICAgaWQ9ImZlR2F1c3NpYW5C bHVyMzU1NSIg
Lz4KICAgIDwvZmlsdGVyPgogICAgPGZpbHRlcgogICAgICAgaW5rc2NhcGU6 Y29sbGVjdD0i
YWx3YXlzIgogICAgICAgaWQ9ImZpbHRlcjM1OTMiCiAgICAgICB4PSItMC4w NDg2NDIyNzgi
CiAgICAgICB3aWR0aD0iMS4wOTcyODQ2IgogICAgICAgeT0iLTAuMzA3NTcx NTkiCiAgICAg
ICBoZWlnaHQ9IjEuNjE1MTQzMiI+CiAgICAgIDxmZUdhdXNzaWFuQmx1cgog ICAgICAgICBp
bmtzY2FwZTpjb2xsZWN0PSJhbHdheXMiCiAgICAgICAgIHN0ZERldmlhdGlv bj0iNi40ODMz
Mjk3IgogICAgICAgICBpZD0iZmVHYXVzc2lhbkJsdXIzNTk1IiAvPgogICAg PC9maWx0ZXI+
CiAgICA8cmFkaWFsR3JhZGllbnQKICAgICAgIGlua3NjYXBlOmNvbGxlY3Q9 ImFsd2F5cyIK
ICAgICAgIHhsaW5rOmhyZWY9IiNsaW5lYXJHcmFkaWVudDMyNzkiCiAgICAg ICBpZD0icmFk
aWFsR3JhZGllbnQzNTk3IgogICAgICAgY3g9IjEyOC40NTk2NCIKICAgICAg IGN5PSI2Mzku
MjI2MzgiCiAgICAgICBmeD0iMTI4LjQ1OTY0IgogICAgICAgZnk9IjYzOS4y MjYzOCIKICAg
ICAgIHI9IjE1OS45NDMwOCIKICAgICAgIGdyYWRpZW50VHJhbnNmb3JtPSJt YXRyaXgoMi4z
NTA2NDc0LC0wLjQwNzIyOTMsMC4xNDk4ODcyLDAuODY1MzI1NCwtMjUxLjk1 NjMyLDE4Ljg2
OTQ5NikiCiAgICAgICBncmFkaWVudFVuaXRzPSJ1c2VyU3BhY2VPblVzZSIg Lz4KICAgIDxs
aW5lYXJHcmFkaWVudAogICAgICAgaW5rc2NhcGU6Y29sbGVjdD0iYWx3YXlz IgogICAgICAg
eGxpbms6aHJlZj0iI2xpbmVhckdyYWRpZW50MzY0MiIKICAgICAgIGlkPSJs aW5lYXJHcmFk
aWVudDM2NDAiCiAgICAgICBncmFkaWVudFVuaXRzPSJ1c2VyU3BhY2VPblVz ZSIKICAgICAg
IHgxPSIxOTQuNDUwMzMiCiAgICAgICB5MT0iMzMwLjgyODk4IgogICAgICAg eDI9IjMyMy4w
NjMxNCIKICAgICAgIHkyPSI1MTkuOTIwNDEiIC8+CiAgICA8bGluZWFyR3Jh ZGllbnQKICAg
ICAgIGlua3NjYXBlOmNvbGxlY3Q9ImFsd2F5cyIKICAgICAgIHhsaW5rOmhy ZWY9IiNsaW5l
YXJHcmFkaWVudDI5NDEiCiAgICAgICBpZD0ibGluZWFyR3JhZGllbnQzNjQ4 IgogICAgICAg
Z3JhZGllbnRVbml0cz0idXNlclNwYWNlT25Vc2UiCiAgICAgICB4MT0iMjk3 LjIxMDg4Igog
ICAgICAgeTE9IjM0Mi44MDI2NyIKICAgICAgIHgyPSIzMjMuMDYzMTQiCiAg ICAgICB5Mj0i
NTE5LjkyMDQxIiAvPgogICAgPGxpbmVhckdyYWRpZW50CiAgICAgICBpbmtz Y2FwZTpjb2xs
ZWN0PSJhbHdheXMiCiAgICAgICB4bGluazpocmVmPSIjbGluZWFyR3JhZGll bnQzMzQ1Igog
ICAgICAgaWQ9ImxpbmVhckdyYWRpZW50MzY1MCIKICAgICAgIGdyYWRpZW50 VW5pdHM9InVz
ZXJTcGFjZU9uVXNlIgogICAgICAgeDE9IjM3MS4xODIwNyIKICAgICAgIHkx PSI1ODMuNTY1
NDkiCiAgICAgICB4Mj0iMzE1Ljk5NjQiCiAgICAgICB5Mj0iMzc0LjEyMzcy IiAvPgogICAg
PGxpbmVhckdyYWRpZW50CiAgICAgICBpbmtzY2FwZTpjb2xsZWN0PSJhbHdh eXMiCiAgICAg
ICB4bGluazpocmVmPSIjbGluZWFyR3JhZGllbnQzMzQ1IgogICAgICAgaWQ9 ImxpbmVhckdy
YWRpZW50MzY1MiIKICAgICAgIGdyYWRpZW50VW5pdHM9InVzZXJTcGFjZU9u VXNlIgogICAg
ICAgeDE9IjM3MS4xODIwNyIKICAgICAgIHkxPSI1ODMuNTY1NDkiCiAgICAg ICB4Mj0iMzE1
Ljk5NjQiCiAgICAgICB5Mj0iMzc0LjEyMzcyIiAvPgogICAgPHJhZGlhbEdy YWRpZW50CiAg
ICAgICBpbmtzY2FwZTpjb2xsZWN0PSJhbHdheXMiCiAgICAgICB4bGluazpo cmVmPSIjbGlu
ZWFyR3JhZGllbnQyOTEzIgogICAgICAgaWQ9InJhZGlhbEdyYWRpZW50MzY1 NCIKICAgICAg
IGdyYWRpZW50VW5pdHM9InVzZXJTcGFjZU9uVXNlIgogICAgICAgZ3JhZGll bnRUcmFuc2Zv
cm09Im1hdHJpeCgxLDAsMCwwLjI2ODgxNzIsMCwzMjUuNTE3NSkiCiAgICAg ICBjeD0iMjg2
LjM1NDEiCiAgICAgICBjeT0iNDQ1LjE5MzA1IgogICAgICAgZng9IjI4Ni4z NTQxIgogICAg
ICAgZnk9IjQ0NS4xOTMwNSIKICAgICAgIHI9Ijc2LjMwNjM4OSIgLz4KICAg IDxsaW5lYXJH
cmFkaWVudAogICAgICAgaW5rc2NhcGU6Y29sbGVjdD0iYWx3YXlzIgogICAg ICAgeGxpbms6
aHJlZj0iI2xpbmVhckdyYWRpZW50MjkyMyIKICAgICAgIGlkPSJsaW5lYXJH cmFkaWVudDM2
NTYiCiAgICAgICBncmFkaWVudFVuaXRzPSJ1c2VyU3BhY2VPblVzZSIKICAg ICAgIHgxPSIy
ODEuOTA5MjciCiAgICAgICB5MT0iNDA0LjU3MDcxIgogICAgICAgeDI9IjI5 NC41NzE4NCIK
ICAgICAgIHkyPSI0OTMuODc1MzEiIC8+CiAgICA8cmFkaWFsR3JhZGllbnQK ICAgICAgIGlu
a3NjYXBlOmNvbGxlY3Q9ImFsd2F5cyIKICAgICAgIHhsaW5rOmhyZWY9IiNs aW5lYXJHcmFk
aWVudDI5NzQiCiAgICAgICBpZD0icmFkaWFsR3JhZGllbnQzNjU4IgogICAg ICAgZ3JhZGll
bnRVbml0cz0idXNlclNwYWNlT25Vc2UiCiAgICAgICBjeD0iMzE3LjMwNzI4 IgogICAgICAg
Y3k9IjUyNy42NTg4NyIKICAgICAgIGZ4PSIzMzEuNjkxOTMiCiAgICAgICBm eT0iNTgzLjQz
MTI3IgogICAgICAgcj0iMTM4LjU3MTQzIiAvPgogICAgPHJhZGlhbEdyYWRp ZW50CiAgICAg
ICBpbmtzY2FwZTpjb2xsZWN0PSJhbHdheXMiCiAgICAgICB4bGluazpocmVm PSIjbGluZWFy
R3JhZGllbnQzMDYyIgogICAgICAgaWQ9InJhZGlhbEdyYWRpZW50MzY2MyIK ICAgICAgIGdy
YWRpZW50VW5pdHM9InVzZXJTcGFjZU9uVXNlIgogICAgICAgZ3JhZGllbnRU cmFuc2Zvcm09
Im1hdHJpeCgwLjc4NzE3NzQsMCwwLDAuNzg3MTc3NCw4NS4zNzU4MTEsMTIx LjE0MSkiCiAg
ICAgICBjeD0iMjc3LjA3MzQ5IgogICAgICAgY3k9IjQ4Mi43MTUxNSIKICAg ICAgIGZ4PSIy
NzcuMDczNDkiCiAgICAgICBmeT0iNDgyLjcxNTE1IgogICAgICAgcj0iMTcx LjA3MzQ5IiAv
PgogICAgPHJhZGlhbEdyYWRpZW50CiAgICAgICBpbmtzY2FwZTpjb2xsZWN0 PSJhbHdheXMi
CiAgICAgICB4bGluazpocmVmPSIjbGluZWFyR3JhZGllbnQzNjc3IgogICAg ICAgaWQ9InJh
ZGlhbEdyYWRpZW50MzY4MyIKICAgICAgIGN4PSIyNjAuMzE0ODgiCiAgICAg ICBjeT0iNjc4
Ljk4MTI2IgogICAgICAgZng9IjI2MC4zMTQ4OCIKICAgICAgIGZ5PSI2Nzgu OTgxMjYiCiAg
ICAgICByPSIxNTYuNDUxODciCiAgICAgICBncmFkaWVudFRyYW5zZm9ybT0i bWF0cml4KDAu
ODY4OTY1NSwxLjEwNzM1NDFlLTcsLTMuODg3NjE5NGUtOCwwLjE2OTc4MjIs MzQuMTEwMjUx
LDU2My43MDIzMykiCiAgICAgICBncmFkaWVudFVuaXRzPSJ1c2VyU3BhY2VP blVzZSIgLz4K
ICAgIDxyYWRpYWxHcmFkaWVudAogICAgICAgaW5rc2NhcGU6Y29sbGVjdD0i YWx3YXlzIgog
ICAgICAgeGxpbms6aHJlZj0iI2xpbmVhckdyYWRpZW50MzcwMSIKICAgICAg IGlkPSJyYWRp
YWxHcmFkaWVudDM3MDciCiAgICAgICBjeD0iMjkxLjIxMDg1IgogICAgICAg Y3k9IjY2My44
NjE5NCIKICAgICAgIGZ4PSIyOTEuMjEwODUiCiAgICAgICBmeT0iNjYzLjg2 MTk0IgogICAg
ICAgcj0iNzUuNTk2NDk3IgogICAgICAgZ3JhZGllbnRUcmFuc2Zvcm09Im1h dHJpeCgxLDAs
MCwwLjE4MjYwODcsMCw1NDIuNjM0OTgpIgogICAgICAgZ3JhZGllbnRVbml0 cz0idXNlclNw
YWNlT25Vc2UiIC8+CiAgICA8ZmlsdGVyCiAgICAgICBpbmtzY2FwZTpjb2xs ZWN0PSJhbHdh
eXMiCiAgICAgICBpZD0iZmlsdGVyMzc1NyIKICAgICAgIHg9Ii0wLjA0MDY0 NzQ3MyIKICAg
ICAgIHdpZHRoPSIxLjA4MTI5NDkiCiAgICAgICB5PSItMC4yMjI1OTMzNCIK ICAgICAgIGhl
aWdodD0iMS40NDUxODY3Ij4KICAgICAgPGZlR2F1c3NpYW5CbHVyCiAgICAg ICAgIGlua3Nj
YXBlOmNvbGxlY3Q9ImFsd2F5cyIKICAgICAgICAgc3RkRGV2aWF0aW9uPSIy LjU2MDY3MjIi
CiAgICAgICAgIGlkPSJmZUdhdXNzaWFuQmx1cjM3NTkiIC8+CiAgICA8L2Zp bHRlcj4KICAg
IDxmaWx0ZXIKICAgICAgIGlua3NjYXBlOmNvbGxlY3Q9ImFsd2F5cyIKICAg ICAgIGlkPSJm
aWx0ZXIzNzgxIgogICAgICAgeD0iLTAuMDM1MDk3MTgyIgogICAgICAgd2lk dGg9IjEuMDcw
MTk0NCIKICAgICAgIHk9Ii0wLjE5MjE5ODg2IgogICAgICAgaGVpZ2h0PSIx LjM4NDM5Nzci
PgogICAgICA8ZmVHYXVzc2lhbkJsdXIKICAgICAgICAgaW5rc2NhcGU6Y29s bGVjdD0iYWx3
YXlzIgogICAgICAgICBzdGREZXZpYXRpb249IjIuMjExMDIiCiAgICAgICAg IGlkPSJmZUdh
dXNzaWFuQmx1cjM3ODMiIC8+CiAgICA8L2ZpbHRlcj4KICAgIDxyYWRpYWxH cmFkaWVudAog
ICAgICAgaW5rc2NhcGU6Y29sbGVjdD0iYWx3YXlzIgogICAgICAgeGxpbms6 aHJlZj0iI2xp
bmVhckdyYWRpZW50MzY4OSIKICAgICAgIGlkPSJyYWRpYWxHcmFkaWVudDM3 ODUiCiAgICAg
ICBjeD0iMjgxLjg0Nzg0IgogICAgICAgY3k9IjY2My44NjE4OCIKICAgICAg IGZ4PSIyODcu
NDY1NjQiCiAgICAgICBmeT0iNjE3LjI4MzUxIgogICAgICAgcj0iNzUuNTk2 NDk3IgogICAg
ICAgZ3JhZGllbnRUcmFuc2Zvcm09Im1hdHJpeCgwLjg4MjE2MzMsOC4xNzEy NzQzZS0zLC02
LjE5MzEwMjllLTMsMC4xNDUxMDQyLDM3LjMyMzM4Miw1NjUuMjI5NykiCiAg ICAgICBncmFk
aWVudFVuaXRzPSJ1c2VyU3BhY2VPblVzZSIgLz4KICAgIDxmaWx0ZXIKICAg ICAgIGlua3Nj
YXBlOmNvbGxlY3Q9ImFsd2F5cyIKICAgICAgIGlkPSJmaWx0ZXIzODQzIgog ICAgICAgeD0i
LTAuMDgyNjUyODk3IgogICAgICAgd2lkdGg9IjEuMTY1MzA1OSIKICAgICAg IHk9Ii0wLjMy
Nzg1NjQ4IgogICAgICAgaGVpZ2h0PSIxLjY1NTcxMjgiPgogICAgICA8ZmVH YXVzc2lhbkJs
dXIKICAgICAgICAgaW5rc2NhcGU6Y29sbGVjdD0iYWx3YXlzIgogICAgICAg ICBzdGREZXZp
YXRpb249IjEwLjc3NiIKICAgICAgICAgaWQ9ImZlR2F1c3NpYW5CbHVyMzg0 NSIgLz4KICAg
IDwvZmlsdGVyPgogIDwvZGVmcz4KICA8c29kaXBvZGk6bmFtZWR2aWV3CiAg ICAgaWQ9ImJh
c2UiCiAgICAgcGFnZWNvbG9yPSIjZmZmZmZmIgogICAgIGJvcmRlcmNvbG9y PSIjNjY2NjY2
IgogICAgIGJvcmRlcm9wYWNpdHk9IjEuMCIKICAgICBncmlkdG9sZXJhbmNl PSIxMDAwMCIK
ICAgICBndWlkZXRvbGVyYW5jZT0iMTAiCiAgICAgb2JqZWN0dG9sZXJhbmNl PSIxMCIKICAg
ICBpbmtzY2FwZTpwYWdlb3BhY2l0eT0iMC4wIgogICAgIGlua3NjYXBlOnBh Z2VzaGFkb3c9
IjIiCiAgICAgaW5rc2NhcGU6em9vbT0iMS4zOTI1MDAyIgogICAgIGlua3Nj YXBlOmN4PSIx
MDYuNDQ5MTgiCiAgICAgaW5rc2NhcGU6Y3k9IjE4Mi43MTY0OCIKICAgICBp bmtzY2FwZTpk
b2N1bWVudC11bml0cz0icHgiCiAgICAgaW5rc2NhcGU6Y3VycmVudC1sYXll cj0ibGF5ZXI1
IgogICAgIHNob3dncmlkPSJmYWxzZSIKICAgICBpbmtzY2FwZTp3aW5kb3ct d2lkdGg9Ijk5
MCIKICAgICBpbmtzY2FwZTp3aW5kb3ctaGVpZ2h0PSI3NzYiCiAgICAgaW5r c2NhcGU6d2lu
ZG93LXg9IjIxNCIKICAgICBpbmtzY2FwZTp3aW5kb3cteT0iOTQiIC8+CiAg PG1ldGFkYXRh
CiAgICAgaWQ9Im1ldGFkYXRhNyI+CiAgICA8cmRmOlJERj4KICAgICAgPGNj OldvcmsKICAg
ICAgICAgcmRmOmFib3V0PSIiPgogICAgICAgIDxkYzpmb3JtYXQ+aW1hZ2Uv c3ZnK3htbDwv
ZGM6Zm9ybWF0PgogICAgICAgIDxkYzp0eXBlCiAgICAgICAgICAgcmRmOnJl c291cmNlPSJo
dHRwOi8vcHVybC5vcmcvZGMvZGNtaXR5cGUvU3RpbGxJbWFnZSIgLz4KICAg ICAgICA8ZGM6
dGl0bGU+ZWNsaXBzZSBpY29uPC9kYzp0aXRsZT4KICAgICAgICA8ZGM6Y3Jl YXRvcj4KICAg
ICAgICAgIDxjYzpBZ2VudD4KICAgICAgICAgICAgPGRjOnRpdGxlPkxpdSBz aGVuZ2ppZTwv
ZGM6dGl0bGU+CiAgICAgICAgICA8L2NjOkFnZW50PgogICAgICAgIDwvZGM6 Y3JlYXRvcj4K
ICAgICAgICA8ZGM6ZGVzY3JpcHRpb24+Y29icmFuYWlsQGdtYWlsLmNvbTwv ZGM6ZGVzY3Jp
cHRpb24+CiAgICAgICAgPGNjOmxpY2Vuc2UKICAgICAgICAgICByZGY6cmVz b3VyY2U9Imh0
dHA6Ly9jcmVhdGl2ZWNvbW1vbnMub3JnL2xpY2Vuc2VzL2J5LzMuMC8iIC8+ CiAgICAgIDwv
Y2M6V29yaz4KICAgICAgPGNjOkxpY2Vuc2UKICAgICAgICAgcmRmOmFib3V0 PSJodHRwOi8v
Y3JlYXRpdmVjb21tb25zLm9yZy9saWNlbnNlcy9ieS8zLjAvIj4KICAgICAg ICA8Y2M6cGVy
bWl0cwogICAgICAgICAgIHJkZjpyZXNvdXJjZT0iaHR0cDovL2NyZWF0aXZl Y29tbW9ucy5v
cmcvbnMjUmVwcm9kdWN0aW9uIiAvPgogICAgICAgIDxjYzpwZXJtaXRzCiAg ICAgICAgICAg
cmRmOnJlc291cmNlPSJodHRwOi8vY3JlYXRpdmVjb21tb25zLm9yZy9ucyNE aXN0cmlidXRp
b24iIC8+CiAgICAgICAgPGNjOnJlcXVpcmVzCiAgICAgICAgICAgcmRmOnJl c291cmNlPSJo
dHRwOi8vY3JlYXRpdmVjb21tb25zLm9yZy9ucyNOb3RpY2UiIC8+CiAgICAg ICAgPGNjOnJl
cXVpcmVzCiAgICAgICAgICAgcmRmOnJlc291cmNlPSJodHRwOi8vY3JlYXRp dmVjb21tb25z
Lm9yZy9ucyNBdHRyaWJ1dGlvbiIgLz4KICAgICAgICA8Y2M6cGVybWl0cwog ICAgICAgICAg
IHJkZjpyZXNvdXJjZT0iaHR0cDovL2NyZWF0aXZlY29tbW9ucy5vcmcvbnMj RGVyaXZhdGl2
ZVdvcmtzIiAvPgogICAgICA8L2NjOkxpY2Vuc2U+CiAgICA8L3JkZjpSREY+ CiAgPC9tZXRh
ZGF0YT4KICA8ZwogICAgIGlua3NjYXBlOmdyb3VwbW9kZT0ibGF5ZXIiCiAg ICAgaWQ9Imxh
eWVyNSIKICAgICB0cmFuc2Zvcm09InRyYW5zbGF0ZSgtNzguMDEyNTkyLC0y OTMuNzM2NzQp
Ij4KICAgIDxwYXRoCiAgICAgICBzb2RpcG9kaTp0eXBlPSJhcmMiCiAgICAg ICBzdHlsZT0i
b3BhY2l0eToxO2ZpbGw6dXJsKCNyYWRpYWxHcmFkaWVudDM2ODMpO2ZpbGwt b3BhY2l0eTox
O2ZpbGwtcnVsZTpub256ZXJvO3N0cm9rZTpub25lO3N0cm9rZS13aWR0aDoz MDtzdHJva2Ut
bGluZWNhcDpyb3VuZDtzdHJva2UtbGluZWpvaW46cm91bmQ7c3Ryb2tlLW1p dGVybGltaXQ6
NDtzdHJva2UtZGFzaGFycmF5Om5vbmU7c3Ryb2tlLW9wYWNpdHk6MTtmaWx0 ZXI6dXJsKCNm
aWx0ZXIzODQzKSIKICAgICAgIGlkPSJwYXRoMzY3NSIKICAgICAgIHNvZGlw b2RpOmN4PSIy
NjAuMzE0ODgiCiAgICAgICBzb2RpcG9kaTpjeT0iNjc4Ljk4MTI2IgogICAg ICAgc29kaXBv
ZGk6cng9IjE1Ni40NTE4NyIKICAgICAgIHNvZGlwb2RpOnJ5PSIzOS40NDE2 NSIKICAgICAg
IGQ9Ik0gNDE2Ljc2Njc1LDY3OC45ODEyNiBBIDE1Ni40NTE4NywzOS40NDE2 NSAwIDEgMSAx
MDMuODYzMDEsNjc4Ljk4MTI2IEEgMTU2LjQ1MTg3LDM5LjQ0MTY1IDAgMSAx IDQxNi43NjY3
NSw2NzguOTgxMjYgeiIKICAgICAgIHRyYW5zZm9ybT0ibWF0cml4KDEuMjkw Mjg3LDAsMCwx
LjM5MDIyOTUsLTc2Ljc0MzExMSwtMzEyLjcxNTc1KSIgLz4KICAgIDxwYXRo CiAgICAgICBz
b2RpcG9kaTp0eXBlPSJhcmMiCiAgICAgICBzdHlsZT0ib3BhY2l0eToxO2Zp bGw6dXJsKCNy
YWRpYWxHcmFkaWVudDM3ODUpO2ZpbGwtb3BhY2l0eToxO2ZpbGwtcnVsZTpu b256ZXJvO3N0
cm9rZTpub25lO3N0cm9rZS13aWR0aDozMDtzdHJva2UtbGluZWNhcDpyb3Vu ZDtzdHJva2Ut
bGluZWpvaW46cm91bmQ7c3Ryb2tlLW1pdGVybGltaXQ6NDtzdHJva2UtZGFz aGFycmF5Om5v
bmU7c3Ryb2tlLW9wYWNpdHk6MTtmaWx0ZXI6dXJsKCNmaWx0ZXIzNzU3KSIK ICAgICAgIGlk
PSJwYXRoMzY4NyIKICAgICAgIHNvZGlwb2RpOmN4PSIyOTEuMjEwODUiCiAg ICAgICBzb2Rp
cG9kaTpjeT0iNjYzLjg2MTk0IgogICAgICAgc29kaXBvZGk6cng9Ijc1LjU5 NjQ5NyIKICAg
ICAgIHNvZGlwb2RpOnJ5PSIxMy44MDQ1NzciCiAgICAgICBkPSJNIDM2Ni44 MDczNCw2NjMu
ODYxOTQgQSA3NS41OTY0OTcsMTMuODA0NTc3IDAgMSAxIDIxNS42MTQzNSw2 NjMuODYxOTQg
QSA3NS41OTY0OTcsMTMuODA0NTc3IDAgMSAxIDM2Ni44MDczNCw2NjMuODYx OTQgeiIKICAg
ICAgIHRyYW5zZm9ybT0ibWF0cml4KDEuOTg1NzkyOCwwLDAsMy40MTA5MDc4 LC0yODMuMjY2
MDMsLTE2MTUuOTMxNSkiIC8+CiAgICA8cGF0aAogICAgICAgdHJhbnNmb3Jt PSJtYXRyaXgo
MS4zOTk1NDcyLDAsMCwzLjAxODk0NjQsLTY0LjEwMzE3MywtMTM2NC40OTU5 KSIKICAgICAg
IGQ9Ik0gMzY2LjgwNzM0LDY2My44NjE5NCBBIDc1LjU5NjQ5NywxMy44MDQ1 NzcgMCAxIDEg
MjE1LjYxNDM1LDY2My44NjE5NCBBIDc1LjU5NjQ5NywxMy44MDQ1NzcgMCAx IDEgMzY2Ljgw
NzM0LDY2My44NjE5NCB6IgogICAgICAgc29kaXBvZGk6cnk9IjEzLjgwNDU3 NyIKICAgICAg
IHNvZGlwb2RpOnJ4PSI3NS41OTY0OTciCiAgICAgICBzb2RpcG9kaTpjeT0i NjYzLjg2MTk0
IgogICAgICAgc29kaXBvZGk6Y3g9IjI5MS4yMTA4NSIKICAgICAgIGlkPSJw YXRoMzY5NyIK
ICAgICAgIHN0eWxlPSJvcGFjaXR5OjE7ZmlsbDp1cmwoI3JhZGlhbEdyYWRp ZW50MzcwNyk7
ZmlsbC1vcGFjaXR5OjE7ZmlsbC1ydWxlOm5vbnplcm87c3Ryb2tlOm5vbmU7 c3Ryb2tlLXdp
ZHRoOjMwO3N0cm9rZS1saW5lY2FwOnJvdW5kO3N0cm9rZS1saW5lam9pbjpy b3VuZDtzdHJv
a2UtbWl0ZXJsaW1pdDo0O3N0cm9rZS1kYXNoYXJyYXk6bm9uZTtzdHJva2Ut b3BhY2l0eTox
O2ZpbHRlcjp1cmwoI2ZpbHRlcjM3ODEpIgogICAgICAgc29kaXBvZGk6dHlw ZT0iYXJjIiAv
PgogIDwvZz4KICA8ZwogICAgIGlua3NjYXBlOmxhYmVsPSJMYXllciAxIgog ICAgIGlua3Nj
YXBlOmdyb3VwbW9kZT0ibGF5ZXIiCiAgICAgaWQ9ImxheWVyMSIKICAgICBz dHlsZT0iZGlz
cGxheTppbmxpbmUiCiAgICAgdHJhbnNmb3JtPSJ0cmFuc2xhdGUoLTc4LjAx MjU5MiwtMjkz
LjczNjc0KSI+CiAgICA8cGF0aAogICAgICAgZD0iTSA0NTUuNzE0MjgsNTAz Ljc5MDc0IEEg
MTM4LjU3MTQzLDEzOC41NzE0MyAwIDEgMSAxNzguNTcxNDMsNTAzLjc5MDc0 IEEgMTM4LjU3
MTQzLDEzOC41NzE0MyAwIDEgMSA0NTUuNzE0MjgsNTAzLjc5MDc0IHoiCiAg ICAgICBzb2Rp
cG9kaTpyeT0iMTM4LjU3MTQzIgogICAgICAgc29kaXBvZGk6cng9IjEzOC41 NzE0MyIKICAg
ICAgIHNvZGlwb2RpOmN5PSI1MDMuNzkwNzQiCiAgICAgICBzb2RpcG9kaTpj eD0iMzE3LjE0
Mjg1IgogICAgICAgaWQ9InBhdGgyODkxIgogICAgICAgc3R5bGU9Im9wYWNp dHk6MTtmaWxs
OnVybCgjbGluZWFyR3JhZGllbnQyOTM3KTtmaWxsLW9wYWNpdHk6MTtmaWxs LXJ1bGU6bm9u
emVybztzdHJva2U6bm9uZTtzdHJva2Utd2lkdGg6MTU7c3Ryb2tlLWxpbmVj YXA6cm91bmQ7
c3Ryb2tlLWxpbmVqb2luOnJvdW5kO3N0cm9rZS1taXRlcmxpbWl0OjQ7c3Ry b2tlLWRhc2hh
cnJheTpub25lO3N0cm9rZS1vcGFjaXR5OjE7ZmlsdGVyOnVybCgjZmlsdGVy MzExNSkiCiAg
ICAgICBzb2RpcG9kaTp0eXBlPSJhcmMiCiAgICAgICB0cmFuc2Zvcm09Im1h dHJpeCgxLjIz
MzM3NjEsMCwwLDEuMjMzMzc2MSwtMTEzLjUwNzgxLC0xMzcuOTM1MDUpIiAv PgogICAgPHBh
dGgKICAgICAgIHN0eWxlPSJvcGFjaXR5OjE7ZmlsbDp1cmwoI3JhZGlhbEdy YWRpZW50Mjk3
MCk7ZmlsbC1vcGFjaXR5OjE7ZmlsbC1ydWxlOm5vbnplcm87c3Ryb2tlOm5v bmU7c3Ryb2tl
LXdpZHRoOjE1O3N0cm9rZS1saW5lY2FwOnJvdW5kO3N0cm9rZS1saW5lam9p bjpyb3VuZDtz
dHJva2UtbWl0ZXJsaW1pdDo0O3N0cm9rZS1kYXNoYXJyYXk6bm9uZTtzdHJv a2Utb3BhY2l0
eToxO2ZpbHRlcjp1cmwoI2ZpbHRlcjMwNTgpIgogICAgICAgZD0iTSAyNzgu Mjg2OTMsMzE0
LjA2OTU3IEMgMTg0LjUyMzc5LDMxNC4wNjk1NyAxMDguNDI3OTIsMzkwLjE2 NTQ1IDEwOC40
Mjc5Miw0ODMuOTI4NTggQyAxMDguNDI3OTIsNTc3LjY5MTczIDE4NC41MjM3 OCw2NTMuNzg3
NTkgMjc4LjI4NjkzLDY1My43ODc2MSBDIDI3OS44NDg3NSw2NTMuNzg3NjEg MjgxLjQwOTA0
LDY1My43OTc1NiAyODIuOTYwNzgsNjUzLjc1NTYgQyAxOTYuMjk0MTYsNjUx LjM4NzIzIDEy
Ni42NzUxMiw1ODAuMjg3NiAxMjYuNjc1MTIsNDkzLjA1MjE5IEMgMTI2LjY3 NTEyLDQwNC4z
MjMwNyAxOTguNjgxNDIsMzMyLjMxNjc3IDI4Ny40MTA1NCwzMzIuMzE2Nzcg QyAzNzQuNjQ1
OTUsMzMyLjMxNjc2IDQ0NS43NDU2LDQwMS45MzU4IDQ0OC4xMTM5NSw0ODgu NjAyNDMgQyA0
NDguMTU1OTEsNDg3LjA1MDcgNDQ4LjE0NTk2LDQ4NS40OTA0IDQ0OC4xNDU5 Niw0ODMuOTI4
NTggQyA0NDguMTQ1OTYsMzkwLjE2NTQ0IDM3Mi4wNTAwNiwzMTQuMDY5NTgg Mjc4LjI4Njkz
LDMxNC4wNjk1NyB6IgogICAgICAgaWQ9InBhdGgyOTYxIiAvPgogIDwvZz4K ICA8ZwogICAg
IGlua3NjYXBlOmdyb3VwbW9kZT0ibGF5ZXIiCiAgICAgaWQ9ImxheWVyMyIK ICAgICBzdHls
ZT0iZGlzcGxheTppbmxpbmUiCiAgICAgdHJhbnNmb3JtPSJ0cmFuc2xhdGUo LTc4LjAxMjU5
MiwtMjkzLjczNjc0KSI+CiAgICA8cGF0aAogICAgICAgc29kaXBvZGk6dHlw ZT0iYXJjIgog
ICAgICAgc3R5bGU9Im9wYWNpdHk6MTtmaWxsOnVybCgjcmFkaWFsR3JhZGll bnQyODk5KTtm
aWxsLW9wYWNpdHk6MTtmaWxsLXJ1bGU6bm9uemVybztzdHJva2U6dXJsKCNy YWRpYWxHcmFk
aWVudDI5MDcpO3N0cm9rZS13aWR0aDozMDtzdHJva2UtbGluZWNhcDpyb3Vu ZDtzdHJva2Ut
bmU7c3Ryb2tlLW9wYWNpdHk6MTtkaXNwbGF5OmlubGluZSIKICAgICAgIGlk PSJwYXRoMjg4
OSIKICAgICAgIHNvZGlwb2RpOmN4PSIzMTcuMTQyODUiCiAgICAgICBzb2Rp cG9kaTpjeT0i
NTAzLjc5MDc0IgogICAgICAgc29kaXBvZGk6cng9IjEzOC41NzE0MyIKICAg ICAgIHNvZGlw
b2RpOnJ5PSIxMzguNTcxNDMiCiAgICAgICBkPSJNIDQ1NS43MTQyOCw1MDMu NzkwNzQgQSAx
MzguNTcxNDMsMTM4LjU3MTQzIDAgMSAxIDE3OC41NzE0Myw1MDMuNzkwNzQg QSAxMzguNTcx
NDMsMTM4LjU3MTQzIDAgMSAxIDQ1NS43MTQyOCw1MDMuNzkwNzQgeiIKICAg ICAgIHRyYW5z
Zm9ybT0idHJhbnNsYXRlKC0xNCwtMi44NTcxNDI4KSIgLz4KICAgIDxwYXRo CiAgICAgICBz
b2RpcG9kaTp0eXBlPSJhcmMiCiAgICAgICBzdHlsZT0iZmlsbDp1cmwoI2xp bmVhckdyYWRp
ZW50MzY1MCk7ZmlsbC1vcGFjaXR5OjE7ZmlsbC1ydWxlOm5vbnplcm87c3Ry b2tlOm5vbmU7
c3Ryb2tlLXdpZHRoOjMwO3N0cm9rZS1saW5lY2FwOnJvdW5kO3N0cm9rZS1s aW5lam9pbjpy
b3VuZDtzdHJva2UtbWl0ZXJsaW1pdDo0O3N0cm9rZS1kYXNoYXJyYXk6bm9u ZTtzdHJva2Ut
b3BhY2l0eToxIgogICAgICAgaWQ9InBhdGgzNTk5IgogICAgICAgc29kaXBv ZGk6Y3g9IjI5
Mi44MjM4MiIKICAgICAgIHNvZGlwb2RpOmN5PSI0NDEuODM0MDgiCiAgICAg ICBzb2RpcG9k
aTpyeD0iMTI4LjIzMDA0IgogICAgICAgc29kaXBvZGk6cnk9Ijg2Ljg5MDIw NSIKICAgICAg
IGQ9Ik0gNDIxLjA1Mzg2LDQ0MS44MzQwOCBBIDEyOC4yMzAwNCw4Ni44OTAy MDUgMCAxIDEg
MTY0LjU5Mzc4LDQ0MS44MzQwOCBBIDEyOC4yMzAwNCw4Ni44OTAyMDUgMCAx IDEgNDIxLjA1
Mzg2LDQ0MS44MzQwOCB6IgogICAgICAgdHJhbnNmb3JtPSJtYXRyaXgoMC44 NTI5MjYyLC0w
LjQ3MDI3NTIsMC41OTQyMjg3LDEuMjIxMjU5MywtMTk5LjM4NzEzLDExMC42 NDEyNSkiIC8+
CiAgICA8cGF0aAogICAgICAgdHJhbnNmb3JtPSJtYXRyaXgoMC43MTU5Njk0 LC0wLjMwNjU3
NDgsMC40OTg4MTE3LDAuNzk2MTQ1MiwtMTQ0LjU0Nzc1LDE5NC4wNDcyMSki CiAgICAgICBk
PSJNIDQyMS4wNTM4Niw0NDEuODM0MDggQSAxMjguMjMwMDQsODYuODkwMjA1 IDAgMSAxIDE2
NC41OTM3OCw0NDEuODM0MDggQSAxMjguMjMwMDQsODYuODkwMjA1IDAgMSAx IDQyMS4wNTM4
Niw0NDEuODM0MDggeiIKICAgICAgIHNvZGlwb2RpOnJ5PSI4Ni44OTAyMDUi CiAgICAgICBz
b2RpcG9kaTpyeD0iMTI4LjIzMDA0IgogICAgICAgc29kaXBvZGk6Y3k9IjQ0 MS44MzQwOCIK
ICAgICAgIHNvZGlwb2RpOmN4PSIyOTIuODIzODIiCiAgICAgICBpZD0icGF0 aDMzNDEiCiAg
ICAgICBzdHlsZT0iZmlsbDp1cmwoI2xpbmVhckdyYWRpZW50MzY1Mik7Zmls bC1vcGFjaXR5
OjE7ZmlsbC1ydWxlOm5vbnplcm87c3Ryb2tlOm5vbmU7c3Ryb2tlLXdpZHRo OjMwO3N0cm9r
ZS1saW5lY2FwOnJvdW5kO3N0cm9rZS1saW5lam9pbjpyb3VuZDtzdHJva2Ut bWl0ZXJsaW1p
dDo0O3N0cm9rZS1kYXNoYXJyYXk6bm9uZTtzdHJva2Utb3BhY2l0eToxIgog ICAgICAgc29k
aXBvZGk6dHlwZT0iYXJjIiAvPgogICAgPHBhdGgKICAgICAgIHNvZGlwb2Rp OnR5cGU9ImFy
YyIKICAgICAgIHN0eWxlPSJmaWxsOnVybCgjcmFkaWFsR3JhZGllbnQzNjU0 KTtmaWxsLW9w
YWNpdHk6MTtmaWxsLXJ1bGU6bm9uemVybztzdHJva2U6bm9uZTtzdHJva2Ut d2lkdGg6MzA7
c3Ryb2tlLWxpbmVjYXA6cm91bmQ7c3Ryb2tlLWxpbmVqb2luOnJvdW5kO3N0 cm9rZS1taXRl
cmxpbWl0OjQ7c3Ryb2tlLWRhc2hhcnJheTpub25lO3N0cm9rZS1vcGFjaXR5 OjEiCiAgICAg
ICBpZD0icGF0aDI5MTEiCiAgICAgICBzb2RpcG9kaTpjeD0iMjg2LjM1NDEi CiAgICAgICBz
b2RpcG9kaTpjeT0iNDQ1LjE5MzA1IgogICAgICAgc29kaXBvZGk6cng9Ijc2 LjMwNjM4OSIK
ICAgICAgIHNvZGlwb2RpOnJ5PSIyMC41MTI0NyIKICAgICAgIGQ9Ik0gMzYy LjY2MDQ4LDQ0
NS4xOTMwNSBBIDc2LjMwNjM4OSwyMC41MTI0NyAwIDEgMSAyMTAuMDQ3NzEs NDQ1LjE5MzA1
IEEgNzYuMzA2Mzg5LDIwLjUxMjQ3IDAgMSAxIDM2Mi42NjA0OCw0NDUuMTkz MDUgeiIKICAg
ICAgIHRyYW5zZm9ybT0ibWF0cml4KDAuOTkxNjgwNiwwLDAsMi45NDE0NjI5 LC0xNi40NTc1
NjMsLTg1Ny45OTc4MSkiIC8+CiAgICA8cGF0aAogICAgICAgc29kaXBvZGk6 dHlwZT0iYXJj
IgogICAgICAgc3R5bGU9ImZpbGw6dXJsKCNsaW5lYXJHcmFkaWVudDM2NTYp O2ZpbGwtb3Bh
Y2l0eToxO2ZpbGwtcnVsZTpub256ZXJvO3N0cm9rZTpub25lO3N0cm9rZS13 aWR0aDozMDtz
dHJva2UtbGluZWNhcDpyb3VuZDtzdHJva2UtbGluZWpvaW46cm91bmQ7c3Ry b2tlLW1pdGVy
bGltaXQ6NDtzdHJva2UtZGFzaGFycmF5Om5vbmU7c3Ryb2tlLW9wYWNpdHk6 MSIKICAgICAg
IGlkPSJwYXRoMjkyMSIKICAgICAgIHNvZGlwb2RpOmN4PSIyODcuMjQwODgi CiAgICAgICBz
b2RpcG9kaTpjeT0iNDU5Ljg4NjIzIgogICAgICAgc29kaXBvZGk6cng9IjUy LjY0OTcxOSIK
ICAgICAgIHNvZGlwb2RpOnJ5PSIzMy45ODkwNTkiCiAgICAgICBkPSJNIDMz OS44OTA1OSw0
NTkuODg2MjMgQSA1Mi42NDk3MTksMzMuOTg5MDU5IDAgMSAxIDIzNC41OTEx Niw0NTkuODg2
MjMgQSA1Mi42NDk3MTksMzMuOTg5MDU5IDAgMSAxIDMzOS44OTA1OSw0NTku ODg2MjMgeiIK
ICAgICAgIHRyYW5zZm9ybT0ibWF0cml4KDEuNTE3MjMyNywtMC4yODc4ODc0 LDAuMzUwOTA2
MSwxLjg0OTM1NiwtMzEwLjk2NTUxLC0zMTkuNjEyOTIpIiAvPgogICAgPHBh dGgKICAgICAg
IGQ9Ik0gNDU1LjcxNDI4LDUwMy43OTA3NCBBIDEzOC41NzE0MywxMzguNTcx NDMgMCAxIDEg
MTc4LjU3MTQzLDUwMy43OTA3NCBBIDEzOC41NzE0MywxMzguNTcxNDMgMCAx IDEgNDU1Ljcx
NDI4LDUwMy43OTA3NCB6IgogICAgICAgc29kaXBvZGk6cnk9IjEzOC41NzE0 MyIKICAgICAg
IHNvZGlwb2RpOnJ4PSIxMzguNTcxNDMiCiAgICAgICBzb2RpcG9kaTpjeT0i NTAzLjc5MDc0
IgogICAgICAgc29kaXBvZGk6Y3g9IjMxNy4xNDI4NSIKICAgICAgIGlkPSJw YXRoMjk1NyIK
ICAgICAgIHN0eWxlPSJmaWxsOnVybCgjcmFkaWFsR3JhZGllbnQzNjU4KTtm aWxsLW9wYWNp
dHk6MTtmaWxsLXJ1bGU6bm9uemVybztzdHJva2U6bm9uZTtzdHJva2Utd2lk dGg6MTU7c3Ry
b2tlLWxpbmVjYXA6cm91bmQ7c3Ryb2tlLWxpbmVqb2luOnJvdW5kO3N0cm9r ZS1taXRlcmxp
bWl0OjQ7c3Ryb2tlLWRhc2hhcnJheTpub25lO3N0cm9rZS1vcGFjaXR5OjEi CiAgICAgICBz
b2RpcG9kaTp0eXBlPSJhcmMiCiAgICAgICB0cmFuc2Zvcm09Im1hdHJpeCgw LjU5MTY1MDIs
LTAuMzk3ODc1NywwLjI4MDY1NTEsMC40MTQwMTg1LDE0Ljk5NzI0LDQ4Mi4x MzU0MSkiIC8+
CiAgICA8cGF0aAogICAgICAgaWQ9InBhdGgyOTg2IgogICAgICAgZD0iTSAz MDMuNDgxMzgs
MzY2LjQ1ODI2IEMgMjI5LjE0NTY2LDM2Ni40NTgyNiAxNjguODE2NjEsNDI2 Ljc4NzMyIDE2
OC44MTY2MSw1MDEuMTIzMDMgQyAxNjguODE2NjEsNTc1LjQ1ODc2IDIyOS4x NDU2NSw2MzUu
Nzg3OCAzMDMuNDgxMzgsNjM1Ljc4NzgyIEMgMzA0LjcxOTYsNjM1Ljc4Nzgy IDMwNS45NTY2
LDYzNS43OTU3MSAzMDcuMTg2ODMsNjM1Ljc2MjQ1IEMgMjM4LjQ3NzI2LDYz My44ODQ3OSAx
ODMuMjgzMDUsNTc3LjUxNjc4IDE4My4yODMwNSw1MDguMzU2MjcgQyAxODMu MjgzMDUsNDM4
LjAxMTUzIDI0MC4zNjk4OCwzODAuOTI0NyAzMTAuNzE0NjIsMzgwLjkyNDcg QyAzNzkuODc1
MTMsMzgwLjkyNDcgNDM2LjI0MzE2LDQzNi4xMTg5IDQzOC4xMjA4LDUwNC44 Mjg0OCBDIDQz
OC4xNTQwNiw1MDMuNTk4MjYgNDM4LjE0NjE3LDUwMi4zNjEyNSA0MzguMTQ2 MTcsNTAxLjEy
MzAzIEMgNDM4LjE0NjE3LDQyNi43ODczMSAzNzcuODE3MSwzNjYuNDU4Mjcg MzAzLjQ4MTM4
LDM2Ni40NTgyNiB6IgogICAgICAgc3R5bGU9ImZpbGw6dXJsKCNyYWRpYWxH cmFkaWVudDM2
NjMpO2ZpbGwtb3BhY2l0eToxO2ZpbGwtcnVsZTpub256ZXJvO3N0cm9rZTpu b25lO3N0cm9r
ZS13aWR0aDoxNTtzdHJva2UtbGluZWNhcDpyb3VuZDtzdHJva2UtbGluZWpv aW46cm91bmQ7
c3Ryb2tlLW1pdGVybGltaXQ6NDtzdHJva2UtZGFzaGFycmF5Om5vbmU7c3Ry b2tlLW9wYWNp
dHk6MSIgLz4KICA8L2c+CiAgPGcKICAgICBpbmtzY2FwZTpncm91cG1vZGU9 ImxheWVyIgog
ICAgIGlkPSJsYXllcjQiCiAgICAgc3R5bGU9ImRpc3BsYXk6aW5saW5lIgog ICAgIHNvZGlw
b2RpOmluc2Vuc2l0aXZlPSJ0cnVlIgogICAgIHRyYW5zZm9ybT0idHJhbnNs YXRlKC03OC4w
MTI1OTIsLTI5My43MzY3NCkiPgogICAgPHBhdGgKICAgICAgIHNvZGlwb2Rp OnR5cGU9ImFy
YyIKICAgICAgIHN0eWxlPSJvcGFjaXR5OjE7ZmlsbDp1cmwoI2xpbmVhckdy YWRpZW50MzY0
OCk7ZmlsbC1vcGFjaXR5OjE7ZmlsbC1ydWxlOm5vbnplcm87c3Ryb2tlOm5v bmU7c3Ryb2tl
LXdpZHRoOjMwO3N0cm9rZS1saW5lY2FwOnJvdW5kO3N0cm9rZS1saW5lam9p bjpyb3VuZDtz
eToxO2Rpc3BsYXk6aW5saW5lIgogICAgICAgaWQ9InBhdGgyOTM5IgogICAg ICAgc29kaXBv
ZGk6Y3g9IjI5Mi44MjM4MiIKICAgICAgIHNvZGlwb2RpOmN5PSI0NDEuODM0 MDgiCiAgICAg
ICBzb2RpcG9kaTpyeD0iMTI4LjIzMDA0IgogICAgICAgc29kaXBvZGk6cnk9 Ijg2Ljg5MDIw
NSIKICAgICAgIGQ9Ik0gNDIxLjA1Mzg2LDQ0MS44MzQwOCBBIDEyOC4yMzAw NCw4Ni44OTAy
MDUgMCAxIDEgMTY0LjU5Mzc4LDQ0MS44MzQwOCBBIDEyOC4yMzAwNCw4Ni44 OTAyMDUgMCAx
IDEgNDIxLjA1Mzg2LDQ0MS44MzQwOCB6IgogICAgICAgdHJhbnNmb3JtPSJt YXRyaXgoMC44
OTQ1MTA4LC0wLjQ0NzA0NjQsMC41NjEyNjk3LDEuMTIzMDY0MSwtMjUxLjA3 OTI5LDY5LjA0
ODU5NikiIC8+CiAgICA8cGF0aAogICAgICAgdHJhbnNmb3JtPSJtYXRyaXgo LTEuMDk3OTkz
NywtMy42MjYwMzMyZS0yLDAuMTQxNDU5MSwtMS40NDI4NzExLDUzNC43OTEx NCwxMTA0Ljg4
MjIpIgogICAgICAgZD0iTSA0MjEuMDUzODYsNDQxLjgzNDA4IEEgMTI4LjIz MDA0LDg2Ljg5
MDIwNSAwIDEgMSAxNjQuNTkzNzgsNDQxLjgzNDA4IEEgMTI4LjIzMDA0LDg2 Ljg5MDIwNSAw
IDEgMSA0MjEuMDUzODYsNDQxLjgzNDA4IHoiCiAgICAgICBzb2RpcG9kaTpy eT0iODYuODkw
MjA1IgogICAgICAgc29kaXBvZGk6cng9IjEyOC4yMzAwNCIKICAgICAgIHNv ZGlwb2RpOmN5
PSI0NDEuODM0MDgiCiAgICAgICBzb2RpcG9kaTpjeD0iMjkyLjgyMzgyIgog ICAgICAgaWQ9
InBhdGgzNjM4IgogICAgICAgc3R5bGU9Im9wYWNpdHk6MTtmaWxsOnVybCgj bGluZWFyR3Jh
ZGllbnQzNjQwKTtmaWxsLW9wYWNpdHk6MTtmaWxsLXJ1bGU6bm9uemVybztz dHJva2U6bm9u
ZTtzdHJva2Utd2lkdGg6MzA7c3Ryb2tlLWxpbmVjYXA6cm91bmQ7c3Ryb2tl LWxpbmVqb2lu
OnJvdW5kO3N0cm9rZS1taXRlcmxpbWl0OjQ7c3Ryb2tlLWRhc2hhcnJheTpu b25lO3N0cm9r
ZS1vcGFjaXR5OjE7ZGlzcGxheTppbmxpbmUiCiAgICAgICBzb2RpcG9kaTp0 eXBlPSJhcmMi
IC8+CiAgPC9nPgogIDxnCiAgICAgaW5rc2NhcGU6Z3JvdXBtb2RlPSJsYXll ciIKICAgICBp
ZD0ibGF5ZXIyIgogICAgIHN0eWxlPSJkaXNwbGF5OmlubGluZSIKICAgICBz b2RpcG9kaTpp
bnNlbnNpdGl2ZT0idHJ1ZSIKICAgICB0cmFuc2Zvcm09InRyYW5zbGF0ZSgt NzguMDEyNTky
LC0yOTMuNzM2NzQpIj4KICAgIDxnCiAgICAgICBpZD0iZzMzMTciPgogICAg ICA8cGF0aAog
ICAgICAgICBpZD0icGF0aDMyNDMiCiAgICAgICAgIGQ9Ik0gMTc0LjE1NjI1 LDQ3OC42MjUg
QyAxNTcuNzg4NTksNDgyLjg3OTU3IDEzOC4wMDc0NSw0ODQuODc2NjIgMTI3 LjIxODc1LDQ5
OS41IEMgMTIyLjc2MzcxLDUwOS41ODczOSAxMzIuNzI1NTcsNTE4Ljk2MjY4 IDE0MS43ODEy
NSw1MjEuNSBDIDE3MS4wMTcwOCw1MzMuODM4NDkgMjAzLjIzODQyLDUzNS41 OTAxMyAyMzQu
NDYwMDksNTM4LjY5NjUyIEMgMjk5LjMxODk1LDU0My4zMTgyMiAzNjUuMDcw MTEsNTQyLjEx
NDIxIDQyOS4wMzEyNSw1MjkuNzE4NzUgQyA0MzguNDM1NTksNTI3LjI0ODM3 IDQ0OS4wOTc5
Miw1MjUuNjk2MTUgNDU2LjY4NzUsNTE5LjQzNzUgQyA0NTkuODYxNTEsNTEz LjgyNjU2IDQ1
Mi40NzYwNyw1MDguNTEzODYgNDQ3LjM4OTIyLDUxMS4xMzY3OCBDIDM3NS44 NzY5Nyw1MjMu
MTY3OTcgMzAyLjM2NDI0LDUyMi44MjM5OCAyMzAuMzU5MDEsNTE0LjMxNTg4 IEMgMjA5LjYw
MDE5LDUxMS42NjU1MyAxODguMTg3MzksNTA4LjI0OTAzIDE2OS44NDM3NSw0 OTcuNzgxMjUg
QyAxNjYuOTU1NjQsNDk0LjM2MzIyIDE3My40MjM4Miw0OTIuNjgwNjEgMTc1 LjMxMjUsNDkx
LjMxMjUgQyAxODAuNzYxNjEsNDkwLjAxNzcxIDE4My45Njc4LDQ4MS43NDcz NCAxNzcuODQz
NzUsNDc5LjEyNSBDIDE3Ni42NjcwNiw0NzguNjY0MjYgMTc1LjQyMTQ5LDQ3 OC40NzM0NyAx
NzQuMTU2MjUsNDc4LjYyNSB6IgogICAgICAgICBzdHlsZT0ib3BhY2l0eTox O2ZpbGw6dXJs
KCNsaW5lYXJHcmFkaWVudDM0NDcpO2ZpbGwtb3BhY2l0eToxO2ZpbGwtcnVs ZTpub256ZXJv
O3N0cm9rZTpub25lO3N0cm9rZS13aWR0aDoxNTtzdHJva2UtbGluZWNhcDpy b3VuZDtzdHJv
a2UtbGluZWpvaW46cm91bmQ7c3Ryb2tlLW1pdGVybGltaXQ6NDtzdHJva2Ut ZGFzaGFycmF5
Om5vbmU7c3Ryb2tlLW9wYWNpdHk6MTtmaWx0ZXI6dXJsKCNmaWx0ZXIzMjc1 KSIgLz4KICAg
ICAgPHBhdGgKICAgICAgICAgc3R5bGU9Im9wYWNpdHk6MTtmaWxsOnVybCgj bGluZWFyR3Jh
ZGllbnQzMDg1KTtmaWxsLW9wYWNpdHk6MTtmaWxsLXJ1bGU6bm9uemVybztz dHJva2U6bm9u
ZTtzdHJva2Utd2lkdGg6MTU7c3Ryb2tlLWxpbmVjYXA6cm91bmQ7c3Ryb2tl LWxpbmVqb2lu
ZS1vcGFjaXR5OjE7ZmlsdGVyOnVybCgjZmlsdGVyMzU1MykiCiAgICAgICAg IGQ9Ik0gMTc1
LjQ2MzUyLDQ4NC41MTUzMyBDIDE0OC40OTE3NSw0ODkuODkwNDQgMTMyLjAx OTU1LDQ5Ny4w
MzgwNCAxMzIuMDE5NTUsNTA0Ljg4MTc3IEMgMTMyLjAxOTU1LDUyMS41NzE5 OSAyMDYuNTM2
NDEsNTM1LjEwNTE1IDI5OC4zMzQ2NSw1MzUuMTA1MTUgQyAzNjcuNTMxNDEs NTM1LjEwNTE1
IDQyNi44NjU3Nyw1MjcuMzk0NDQgNDUxLjkwNTcxLDUxNi40NTU5NSBDIDQy MS40ODU3Nyw1
MjIuNTE4MjMgMzc3LjY5MTM5LDUyNi4zNDcyMyAzMjkuMDM0NTgsNTI2LjM0 NzIzIEMgMjM3
LjIzNjMzLDUyNi4zNDcyMyAxNjIuNzU1MTgsNTEyLjgxNDA4IDE2Mi43NTUx OCw0OTYuMTIz
ODYgQyAxNjIuNzU1MTgsNDkyLjAxNDU4IDE2Ny4yODQ4Miw0ODguMDg4MTMg MTc1LjQ2MzUy
LDQ4NC41MTUzMyB6IgogICAgICAgICBpZD0icGF0aDMwODMiIC8+CiAgICA8 L2c+CiAgICA8
ZwogICAgICAgaWQ9ImczMzIxIgogICAgICAgdHJhbnNmb3JtPSJtYXRyaXgo MC45MzY5OTk5
LDAsMCwwLjkzNjk5OTksMjYuODQ3NTc2LC0yNy44MTQwODcpIj4KICAgICAg PHBhdGgKICAg
ICAgICAgc3R5bGU9Im9wYWNpdHk6MTtmaWxsOnVybCgjbGluZWFyR3JhZGll bnQzMzI3KTtm
aWxsLW9wYWNpdHk6MTtmaWxsLXJ1bGU6bm9uemVybztzdHJva2U6bm9uZTtz dHJva2Utd2lk
dGg6MTU7c3Ryb2tlLWxpbmVjYXA6cm91bmQ7c3Ryb2tlLWxpbmVqb2luOnJv dW5kO3N0cm9r
ZS1taXRlcmxpbWl0OjQ7c3Ryb2tlLWRhc2hhcnJheTpub25lO3N0cm9rZS1v cGFjaXR5OjE7
ZmlsdGVyOnVybCgjZmlsdGVyMzI3NSkiCiAgICAgICAgIGQ9Ik0gMTc0LjE1 NjI1LDQ3OC42
MjUgQyAxNTcuNzg4NTksNDgyLjg3OTU3IDEzOC4wMDc0NSw0ODQuODc2NjIg MTI3LjIxODc1
LDQ5OS41IEMgMTIyLjc2MzcxLDUwOS41ODczOSAxMzIuNzI1NTcsNTE4Ljk2 MjY4IDE0MS43
ODEyNSw1MjEuNSBDIDE3MS4wMTcwOCw1MzMuODM4NDkgMjAzLjIzODQyLDUz NS41OTAxMyAy
MzQuNDYwMDksNTM4LjY5NjUyIEMgMjk5LjMxODk1LDU0My4zMTgyMiAzNjUu MDcwMTEsNTQy
LjExNDIxIDQyOS4wMzEyNSw1MjkuNzE4NzUgQyA0MzguNDM1NTksNTI3LjI0 ODM3IDQ0OS4w
OTc5Miw1MjUuNjk2MTUgNDU2LjY4NzUsNTE5LjQzNzUgQyA0NTkuODYxNTEs NTEzLjgyNjU2
IDQ1Mi40NzYwNyw1MDguNTEzODYgNDQ3LjM4OTIyLDUxMS4xMzY3OCBDIDM3 NS44NzY5Nyw1
MjMuMTY3OTcgMzAyLjM2NDI0LDUyMi44MjM5OCAyMzAuMzU5MDEsNTE0LjMx NTg4IEMgMjA5
LjYwMDE5LDUxMS42NjU1MyAxODguMTg3MzksNTA4LjI0OTAzIDE2OS44NDM3 NSw0OTcuNzgx
MjUgQyAxNjYuOTU1NjQsNDk0LjM2MzIyIDE3My40MjM4Miw0OTIuNjgwNjEg MTc1LjMxMjUs
NDkxLjMxMjUgQyAxODAuNzYxNjEsNDkwLjAxNzcxIDE4My45Njc4LDQ4MS43 NDczNCAxNzcu
ODQzNzUsNDc5LjEyNSBDIDE3Ni42NjcwNiw0NzguNjY0MjYgMTc1LjQyMTQ5 LDQ3OC40NzM0
NyAxNzQuMTU2MjUsNDc4LjYyNSB6IgogICAgICAgICBpZD0icGF0aDMzMjMi IC8+CiAgICAg
IDxwYXRoCiAgICAgICAgIGlkPSJwYXRoMzMyNSIKICAgICAgICAgZD0iTSAx NzUuNDYzNTIs
NDg0LjUxNTMzIEMgMTQ4LjQ5MTc1LDQ4OS44OTA0NCAxMzIuMDE5NTUsNDk3 LjAzODA0IDEz
Mi4wMTk1NSw1MDQuODgxNzcgQyAxMzIuMDE5NTUsNTIxLjU3MTk5IDIwNi41 MzY0MSw1MzUu
MTA1MTUgMjk4LjMzNDY1LDUzNS4xMDUxNSBDIDM2Ny41MzE0MSw1MzUuMTA1 MTUgNDI2Ljg2
NTc3LDUyNy4zOTQ0NCA0NTEuOTA1NzEsNTE2LjQ1NTk1IEMgNDIxLjQ4NTc3 LDUyMi41MTgy
MyAzNzcuNjkxMzksNTI2LjM0NzIzIDMyOS4wMzQ1OCw1MjYuMzQ3MjMgQyAy MzcuMjM2MzMs
NTI2LjM0NzIzIDE2Mi43NTUxOCw1MTIuODE0MDggMTYyLjc1NTE4LDQ5Ni4x MjM4NiBDIDE2
Mi43NTUxOCw0OTIuMDE0NTggMTY3LjI4NDgyLDQ4OC4wODgxMyAxNzUuNDYz NTIsNDg0LjUx
NTMzIHoiCiAgICAgICAgIHN0eWxlPSJvcGFjaXR5OjE7ZmlsbDp1cmwoI3Jh ZGlhbEdyYWRp
ZW50MzU5Nyk7ZmlsbC1vcGFjaXR5OjE7ZmlsbC1ydWxlOm5vbnplcm87c3Ry b2tlOm5vbmU7
c3Ryb2tlLXdpZHRoOjE1O3N0cm9rZS1saW5lY2FwOnJvdW5kO3N0cm9rZS1s aW5lam9pbjpy
b3BhY2l0eToxO2ZpbHRlcjp1cmwoI2ZpbHRlcjM1OTMpIiAvPgogICAgPC9n PgogICAgPGcK
ICAgICAgIHRyYW5zZm9ybT0ibWF0cml4KDAuOTM2OTk5OSwwLDAsMC45MzY5 OTk5LDIzLjU2
MDc3Miw5MC41MTA4NTkpIgogICAgICAgaWQ9ImczMzMxIj4KICAgICAgPHBh dGgKICAgICAg
ICAgaWQ9InBhdGgzMzMzIgogICAgICAgICBkPSJNIDE3NC4xNTYyNSw0Nzgu NjI1IEMgMTU3
Ljc4ODU5LDQ4Mi44Nzk1NyAxMzguMDA3NDUsNDg0Ljg3NjYyIDEyNy4yMTg3 NSw0OTkuNSBD
IDEyMi43NjM3MSw1MDkuNTg3MzkgMTMyLjcyNTU3LDUxOC45NjI2OCAxNDEu NzgxMjUsNTIx
LjUgQyAxNzEuMDE3MDgsNTMzLjgzODQ5IDIwMy4yMzg0Miw1MzUuNTkwMTMg MjM0LjQ2MDA5
LDUzOC42OTY1MiBDIDI5OS4zMTg5NSw1NDMuMzE4MjIgMzY1LjA3MDExLDU0 Mi4xMTQyMSA0
MjkuMDMxMjUsNTI5LjcxODc1IEMgNDM4LjQzNTU5LDUyNy4yNDgzNyA0NDku MDk3OTIsNTI1
LjY5NjE1IDQ1Ni42ODc1LDUxOS40Mzc1IEMgNDU5Ljg2MTUxLDUxMy44MjY1 NiA0NTIuNDc2
MDcsNTA4LjUxMzg2IDQ0Ny4zODkyMiw1MTEuMTM2NzggQyAzNzUuODc2OTcs NTIzLjE2Nzk3
IDMwMi4zNjQyNCw1MjIuODIzOTggMjMwLjM1OTAxLDUxNC4zMTU4OCBDIDIw OS42MDAxOSw1
MTEuNjY1NTMgMTg4LjE4NzM5LDUwOC4yNDkwMyAxNjkuODQzNzUsNDk3Ljc4 MTI1IEMgMTY2
Ljk1NTY0LDQ5NC4zNjMyMiAxNzMuNDIzODIsNDkyLjY4MDYxIDE3NS4zMTI1 LDQ5MS4zMTI1
IEMgMTgwLjc2MTYxLDQ5MC4wMTc3MSAxODMuOTY3OCw0ODEuNzQ3MzQgMTc3 Ljg0Mzc1LDQ3
OS4xMjUgQyAxNzYuNjY3MDYsNDc4LjY2NDI2IDE3NS40MjE0OSw0NzguNDcz NDcgMTc0LjE1
NjI1LDQ3OC42MjUgeiIKICAgICAgICAgc3R5bGU9Im9wYWNpdHk6MTtmaWxs OnVybCgjbGlu
ZWFyR3JhZGllbnQzMzM3KTtmaWxsLW9wYWNpdHk6MTtmaWxsLXJ1bGU6bm9u emVybztzdHJv
a2U6bm9uZTtzdHJva2Utd2lkdGg6MTU7c3Ryb2tlLWxpbmVjYXA6cm91bmQ7 c3Ryb2tlLWxp
bmVqb2luOnJvdW5kO3N0cm9rZS1taXRlcmxpbWl0OjQ7c3Ryb2tlLWRhc2hh cnJheTpub25l
O3N0cm9rZS1vcGFjaXR5OjE7ZmlsdGVyOnVybCgjZmlsdGVyMzI3NSkiIC8+ CiAgICAgIDxw
YXRoCiAgICAgICAgIHN0eWxlPSJvcGFjaXR5OjE7ZmlsbDp1cmwoI2xpbmVh ckdyYWRpZW50
MzMzOSk7ZmlsbC1vcGFjaXR5OjE7ZmlsbC1ydWxlOm5vbnplcm87c3Ryb2tl Om5vbmU7c3Ry
b2tlLXdpZHRoOjE1O3N0cm9rZS1saW5lY2FwOnJvdW5kO3N0cm9rZS1saW5l am9pbjpyb3Vu
ZDtzdHJva2UtbWl0ZXJsaW1pdDo0O3N0cm9rZS1kYXNoYXJyYXk6bm9uZTtz dHJva2Utb3Bh
Y2l0eToxO2ZpbHRlcjp1cmwoI2ZpbHRlcjMzMDUpIgogICAgICAgICBkPSJN IDE3NS40NjM1
Miw0ODQuNTE1MzMgQyAxNDguNDkxNzUsNDg5Ljg5MDQ0IDEzMi4wMTk1NSw0 OTcuMDM4MDQg
MTMyLjAxOTU1LDUwNC44ODE3NyBDIDEzMi4wMTk1NSw1MjEuNTcxOTkgMjA2 LjUzNjQxLDUz
NS4xMDUxNSAyOTguMzM0NjUsNTM1LjEwNTE1IEMgMzY3LjUzMTQxLDUzNS4x MDUxNSA0MjYu
ODY1NzcsNTI3LjM5NDQ0IDQ1MS45MDU3MSw1MTYuNDU1OTUgQyA0MjEuNDg1 NzcsNTIyLjUx
ODIzIDM3Ny42OTEzOSw1MjYuMzQ3MjMgMzI5LjAzNDU4LDUyNi4zNDcyMyBD IDIzNy4yMzYz
Myw1MjYuMzQ3MjMgMTYyLjc1NTE4LDUxMi44MTQwOCAxNjIuNzU1MTgsNDk2 LjEyMzg2IEMg
MTYyLjc1NTE4LDQ5Mi4wMTQ1OCAxNjcuMjg0ODIsNDg4LjA4ODEzIDE3NS40 NjM1Miw0ODQu
NTE1MzMgeiIKICAgICAgICAgaWQ9InBhdGgzMzM1IiAvPgogICAgPC9nPgog IDwvZz4KPC9z
dmc+Cg==
Content-Type: image/png;
name="eclipse.png"
filename="eclipse.png"
iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAABzenr0AAAABmJLR0QA/wD/ AP+gvaeTAAAA
CXBIWXMAAAsSAAALEgHS3X78AAAAB3RJTUUH0wIOBxQzVlBAtAAACINJREFU eJxll1uPHNd1
hb+9z6nqKzkzIoeSZVO0JdKWYNkGEttBXiIECGAbyGuQv5PX/Ji8BU6QPCUx bMN25CS2eDFF
i+KdFK/TM123s/fOQ9XMUEkBhepzuvvs+1qr5K9++PdxsN0AICiCoOi4FkFl 3APh9UvCv7Qm
jIggCJyYNp3wcQ9On0zfn1nvkQ+2G67duU6iQiWhJBKZnDJJEjOpySmNRj1O 7EmMnzPOYIb5
gPuAh2NhgGPWYWaEFIwgwvAoIA4SfPPy98kAOZSUKkSUipqsmVoqkibmdYWg zFJGLODEiUAi
UHWGfmBwwV3pbRjdCqeE0/v4W8VwUQoJECoVRIQsKKI1mjKVZCoqlERd1VQp s6iVXDKLlCGd
ZtzdkSmVVSjtIIQoFSCiDL6lcyGSgifKccbEEBEkQELIwljnJIk6zVimirqa MZtVLBYzVrOa
ekjIEIidOpBl7ImjoaeRQk3GDFIKNEE0SqiiJIoYYkItASS6sJM+ySIgmqgk oyLU1ZzdnRVn
V0t2lwtWywUAw0GDGMzXNWd3F3zx9IinL19xeNTTqzPQIcR4F0NUyVUFAwgJ lUCkpreeFPKa
AzlRzTOVZWpJLOeJN9Yrrnz7Ld55e4dlVdN3zsGhs3d+hz/cf87Va7d40T5j 0I6ycogAzxTr
wY2u64hk0BsagjKjiorBOsQDneYNIKes1Osa3Sh1ytTzOevFnHfe3uEvf/I+ O+dW9K3zi18e
8Pvrn/Jft6/TxYZUB7VXJAN87Hz3DKWliOBVT8mOJUcjYU3Bh3JawmnYM0D0 Ga0SaVGxqmuW
iwUzrVjvLNk5v2K7aXly5488eH6bed1TRYW7EMUJM8wDK4JpEMxJWuGWUFV6 bfCuJTRAhKQJ
3Ig04kxWlHlVkVMirWukzngp9G3Qd8520/Lxv3/GvRdPKe7UOWNhWIFC4K4k KaACBoji6igJ
mOHuFEDKEUQito6KYMc9oJLYqZacWVTUksit0TzdUL4v3HyoPPjXa9y4d5un 21eYGaoCVQKM
CCHUCR9xMhG4gAIhSk6G1pmihcEVSYXoMxSmhoVcusLhwYZVdZblesYsz9Ck 7L/7dW5+8opP
rl/nZbNBAtyciGCcHAF5DRkngFU5xqpARBFJaMpIrpAyoHOBNo/naCJHOP22 52jY4FVhr3a+
9+MPaOod/vCbn3H98UPWi0RdV6hyQgluAaf2CcaaxvGeKBKjE0krcjUDN3xo CZ+NkyNTE44H
Oq4D3fOG3a9+lUe3nvHo8ROs9NiwooigGqiOFsKDcAgXJARCTg2rggWBIKKj LREkCZIdDcX6
qQfWqzNcurxHhZIlsVuvSV95k2f/8wXDesm59C5VrtAkiL4GxaUjDGIeRDHc DQgiAo+BcCPC
x6ePZFWGDf1ig5U10QvVbEkOUVxHKFaEvBaW6xntZotN1DFGPN6nDsQxKfDl y09KIyghDvIa
lYsj6jAxbF6s5pw/fx4VgQJ753bpS0WqhJwX1PXIFce1FwK3gqTZ2HgauBck xvREBOIDhBME
4op7T5REkhlKRq1iYEZoIud6zvqNtxAH74x6PmK/LnZZ7zaoOoKeRhGFsHIS pbvhpXC84WG4
D+M6Ais9RDAMR3ieIRmw82jtZFfy88cP+OzmDWqtqEqi3qm4/OE+zbNHPPjs Knlm1LlGQhCJ
k4MjnAgfU35S+0KETSUbxYeXHrcWo2HoGg7bZ+R4n6FvOLf7lXEKHMfc0CyU p0b3omO+XjHD
6Ycex0ETGsfGmZ5l0gSjExKjRnA1RAyJnpAWp6OUhs4OIAJXx6aGym1zxJP7 t5lJTa0VOYQ7
v/4PLv75R/zxPxu+OHrIrK6oUhp74VjfTcbGrIwdGqPKwBlw68bOLw2ltLT9 AU33AuItpLyi
DIeU9T7ZJxGZlplz+7tcuHiOu09e8OHujJ0LF3l47S6WgqwVEa8LUycwCBiR PQgZycmZxq50
lNJi3lGsxbwl8TZmwyRgnbyzs+a7P/yAvTdWdK+2fPrxbV69eM7+m/t8+NEP eHD7d7xqn6Ky
ICdF43ggxmiF4z5wwhxjwKOcRF6sZSgNfdmi+g36DsS6CTdARYXttuHjn33C b399jaPNAZnE
z//tVyxLx8XL3yP3ylA63AYi7LW7EBTMDZOC0VOs/VLkQ2lohw0RS8IvEf0h ftK8kM6f+bO/
u3r1Ktu2wfsRJFTg5dEBt2/c5K//9sf0/Yond6/j9MT0R4ky1t0dl0KxDvMe s2b8bKPxpn9J
UGPlfUpzOGJIOCLC7s4F1NxorcPDGdQoxSgYZ3dXnLv0Bv/yDz/lyrv7XPng IxiCvj3EvMNi
wGKgxBi1RYvZlPLhiKZ7SdO/QtgD/w7dYcPQtJhD8XFsAbKHYzgljETQJ2W1 s+CDP/kWjz9/
zG9v/DfXfvd7fvSjn/DWX/wNt27+hkePbzPIlmAEoKBQvMO8oy+HFO+IWBFx iaHbpzQvsa7D
McQhV4JFIjwmSRbOQAEyu6sF3/3Tb3P3s/s8/vwhOSmH245//sd/4sqHl/na 2++xN3+TO5tH
vHx+C283DDIwUPAQ3HcJuUDpE6U3+uYZ7oZgOAPhjkRCZZyijAShA0HFbD3j 3W+9x6c3P+fB
nfsTxQoiRqqUW/c+58a1GxBBXq5Iep6mLLHoASiuOA0+tAxDwcxHZsQRysn7 YxmMXNdjCUYH
jOXyDN+88h737t7jyaOnI6kASRSZeKAfeo76ZhQTQwvy/Es8WBhp2TwmSHY8 DDCYIBoZM2VF
iXAyAovFgncufY37D+7x8NGTiXRGWZlxMomiTrM9pLd+JKbXXlSPYSlihHXB RqjG0ZikuEyO
TIxZSou7kfdW5/jO13/AYr5kdvYsF85cnBwYo1YEFUFzGoXHpAnHg/h/V0xv R8erU932f3UD
nD2zz/8CEw54vRwguq0AAAAASUVORK5CYII=
--------------030706090204040400070109--
Re: icon.xpm [message #266323 is a reply to message #266321] Fri, 14 November 2008 13:00 Go to previous messageGo to next message
> It is a known bug:
Oops: https://bugs.eclipse.org/bugs/show_bug.cgi?id=86848
Hendrik Maryns
Re: icon.xpm [message #266329 is a reply to message #266323] Fri, 14 November 2008 14:23 Go to previous message
As it turns out...I dont need an xpm-file, a png works just fine.
The problem actually was the gnome icon chooser, where I navigated to
the location and no icons showed up. All I had to do was to click "open"
within this folder (having actually no file/icon selected) and then open
the icon-dialog again..suprise, now all kinds of icons show up in the
dialog because now he loaded everything he could find from the folder
specified before.
Previous Topic:issue with jvm options -Xms128m -Xmx1024m
Next Topic:Build Clean is ok but Build Project get error : does not match expected package
Current Time: Sat Nov 08 01:25:12 EST 2025
Powered by FUDForum. Page generated in 0.09949 seconds
