Home » Newcomers » Newcomers » issue with jvm options -Xms128m -Xmx1024m
issue with jvm options -Xms128m -Xmx1024m [message #266189] Mon, 10 November 2008 16:14 Go to next message
Originally posted by: techluver007.gmail.com
I'm starting eclipse.exe as "eclipse.exe -vmargs -Xms128m -Xmx1024m" and
getting JVM Terminated . Exit code=-1 message and eclipse quits. any idea
why I have this issue?
I'm using eclipse 3.4 and jre 1.5.0_06.
Thanks!
Re: issue with jvm options -Xms128m -Xmx1024m [message #266190 is a reply to message #266189] Mon, 10 November 2008 16:24 Go to previous messageGo to next message
Have you tried smaller values. That seems awfully big.
tech luver wrote:
> Hello,
> and getting JVM Terminated . Exit code=-1 message and eclipse quits.
> any idea why I have this issue?
> Thanks!
Re: issue with jvm options -Xms128m -Xmx1024m [message #266200 is a reply to message #266190] Mon, 10 November 2008 20:52 Go to previous messageGo to next message
Yeah. 512MB works fine. Since I need to process huge amount of data, i
want to set it 1024MB. I think 1024MB works with eclipse 3.2 version
Re: issue with jvm options -Xms128m -Xmx1024m [message #266204 is a reply to message #266200] Mon, 10 November 2008 23:50 Go to previous messageGo to next message
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
Consider increasing permgen AND heap, rather than just heap.
http://wiki.eclipse.org/IRC_FAQ#I.27m_having_memory.2C_heap. 2C_or_permgen_problems.2C_what_can_I_do.3F
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: issue with jvm options -Xms128m -Xmx1024m [message #266216 is a reply to message #266204] Tue, 11 November 2008 11:47 Go to previous messageGo to next message
thanks for the reply. I tried with heap and perm size. but no luck.
anything > 512m gives the error. is this some kind of bug? my config is
given below.
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256M
-framework
plugins\org.eclipse.osgi_3.4.0.v20080605-1900.jar
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms256m
-Xmx512m
-XX:+UseParallelGC
-XX:PermSize=256M
-XX:MaxPermSize=512M
Re: issue with jvm options -Xms128m -Xmx1024m [message #266218 is a reply to message #266216] Tue, 11 November 2008 13:59 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
>>> i want to set it 1024MB. I think 1024MB works with eclipse 3.2 version
> given below.
I notice that you are not specifying the -vm argument. You should
definitely do that so you can be certain which JVM is being used to run
Eclipse.
http://wiki.eclipse.org/Eclipse.ini
Also note that there is a practical limit to how much heap and permGen
space a Sun JVM can allocate on Windows. See this:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg73 887.html
Hope this helps,
Eric
> -showsplash
> 256M
> -framework
> -vmargs
> -Xms256m
> -Xmx512m
> -XX:+UseParallelGC
> -XX:PermSize=256M
Re: issue with jvm options -Xms128m -Xmx1024m [message #266225 is a reply to message #266216] Wed, 12 November 2008 00:29 Go to previous messageGo to next message
"tech luver" <techluver007@gmail.com> wrote in message
news:98e9274094966674837b910a39a52e23$1@www.eclipse.org...
> given below. [...]
As a point of reference, I have used -Xmx1024M on Windows XP with every
version of Eclipse from 3.2 through 3.5 M3, and several on the Mac too. I
recognize that doesn't help with your problem, I'm just offering it to show
that Eclipse at least "can" run with that much memory.
How much physical RAM do you have?
Are you sure that you're using the VM you think you are? As Eric says, it's
a good idea to specify it explicitly.
Are you able to launch other Java programs with the same flags? For
instance, if you write a simple "hello world" program in Java and launch it
with the same VM flags, does it work?
Re: issue with jvm options -Xms128m -Xmx1024m [message #266285 is a reply to message #266225] Thu, 13 November 2008 13:37 Go to previous messageGo to next message
still no luck after specifying -vm in eclipse init file. I also tried
standalone java prog and it worked(java Test -Xms256m -Xmx1024m
-XX:+UseParallelGC -XX:PermSize=256M -XX:MaxPermSize=512M).
eclispe init:-
-showsplash
256M
-vm
C:\Program Files\Java\jdk1.6.0_07\bin
-framework
-vmargs
-Xms256m
-Xmx1024m
-XX:+UseParallelGC
-XX:PermSize=256M
Re: issue with jvm options -Xms128m -Xmx1024m [message #266287 is a reply to message #266285] Thu, 13 November 2008 13:44 Go to previous messageGo to next message
physical RAM is 2 GB. for -xmx > 940M, eclipse does not start.
-showsplash
256M
-vm
-framework
-vmargs
-Xms256m
-Xmx940m
-XX:+UseParallelGC
-XX:PermSize=256M
-XX:MaxPermSize=256M
Re: issue with jvm options -Xms128m -Xmx1024m [message #266293 is a reply to message #266285] Thu, 13 November 2008 15:25 Go to previous messageGo to next message
> eclispe init:-
> -showsplash
> 256M
> -vm
As documented in the wiki page (http://wiki.eclipse.org/Eclipse.ini),
the value of the -vm parameter must be the full path of the java
executable, not the directory as you have specified.
Eric
Re: issue with jvm options -Xms128m -Xmx1024m [message #266297 is a reply to message #266293] Thu, 13 November 2008 16:33 Go to previous messageGo to next message
Thanks a lot! appreciated..
It finally worked with following config. Eclipse works with vm path
"C:\Program Files\Java\jdk1.6.0_07\bin" for -Xmx <= 940m, but it throws
error for -xmx > 940m.
-showsplash
256M
-vm
C:\Program Files\Java\jdk1.6.0_07\bin\javaw.exe
-framework
-vmargs
-Xms256m
-Xmx1024m
-XX:+UseParallelGC
-XX:PermSize=256M
Re: issue with jvm options -Xms128m -Xmx1024m [message #266310 is a reply to message #266297] Fri, 14 November 2008 09:46 Go to previous message
With the incorrect -vm value Eclipse will still run, it just will use
whatever JVM it happens to find on your system path instead of the one
you are trying to specify. Whatever JVM that is on your system, it
obviously does not deal with the large -Xmx option.
Glad you're working now.
Eric
Previous Topic:Cannot find the tag library descriptor--sometimes
Next Topic:icon.xpm
Current Time: Sun Nov 09 23:07:57 EST 2025
Powered by FUDForum. Page generated in 0.20954 seconds
