Grid item updates [message #24945] |
Tue, 30 January 2007 06:13  |
I'm facing a weird problem with the Grid widget. Whenever I change the
text or color of a GridItem the UI is not updated immediately, but it is
updated after calling redraw.
This sounds a little weird to me, because I never call redraw on all
other widgets to update the text or colors. I was looking at the code
but I don't see any "update trigger" when changing the text, nor I see a
method to redraw only the updated item. What am I missing ?
Bye
Re: Grid item updates [message #26652 is a reply to message #26569] |
Mon, 05 February 2007 12:25  |
Hi Marco,
Yes the Grid currently redraws the entire client area on every redraw.
But this will only draw rows in the visible range. So the number of
actual rows in the table shouldn't have much affect. How many rows do
you have?
-Chris
Marco Maccaferri wrote:
> On 30/01/2007 17:00 Chris Gross ha scritto:
>> You're not missing anything. Its a bug. There should be a redraw()
>> in the various GridItem setters. It will be fixed in the next update.
> I was asking because I'm experiencing some performance issues when Grid
> needs to handle a huge amount of items. From what I see redraw repaints
> the whole control (including the header, if I'm not wrong), so I was
> wondering if there was some method to redraw only the items that were
> updated.
> If you plan to work on it, I think that it should be a good idea to
> somehow flag the items that were updated and repaint only those.
> Bye
Re: Grid item updates [message #576242 is a reply to message #24945] |
Tue, 30 January 2007 11:00  |
You're not missing anything. Its a bug. There should be a redraw() in
-Chris
> Hello,
> Bye
Re: Grid item updates [message #577235 is a reply to message #25067] |
Sat, 03 February 2007 12:34  |
updated.
Bye
Re: Grid item updates [message #577317 is a reply to message #26569] |
Hi Marco,
you have?
-Chris
> updated.
> Bye
FUDForum. Page generated in 0.08211 seconds
