Home » Eclipse Projects » Spatiotemporal Epidemiological Modeler (STEM) » STEM Build Mac OS
STEM Build Mac OS [message #2624] Sun, 26 April 2009 15:52 Go to next message
Hi again :),
Trying to launch the 0.5.0.I20090423 STEM app from my Mac Pro, I get:
!ENTRY org.eclipse.osgi 4 0 2009-04-26 12:44:07.581
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
at
at
java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
I'm thinking that this might have something to do with my 1.6 VM not
playing nicely with Carbon. I've been using the Cocoa x86 builds for my
own environment. Anyone had any similar issues?
Re: STEM Build Mac OS [message #2654 is a reply to message #2624] Mon, 27 April 2009 09:56 Go to previous message
Originally posted by: daford.almaden.ibm.com.invalid
Miles,
I have almost the exact set up as you, Mac Pro, latest from CVS and a 1.6
JVM, and I have no build or execute issues at all. Everything works as
expected.
Something must be different between our setups. I'm running 3.5M6.
Dan
Miles Parker wrote:
> Hi again :),
> !STACK 1
> (see config.ini).
> at
pLauncher.java:74)
> at
> at
> at
> at
> at
..java:25)
> at
Re: STEM Build Mac OS [message #560932 is a reply to message #2624] Mon, 27 April 2009 09:56 Go to previous message
Miles,
expected.
Dan
Miles Parker wrote:
> Hi again :),
> !STACK 1
> (see config.ini).
> at
pLauncher.java:74)
> at
> at
> at
> at
> at
..java:25)
> at
Previous Topic:STEM Build Mac OS
Next Topic:Air transportation now operational
Current Time: Fri Oct 31 09:45:08 EDT 2025
Powered by FUDForum. Page generated in 0.38815 seconds
