Home » Newcomers » Newcomers » contributing to org.eclipse.jface.text.templates line delimiter problem
contributing to org.eclipse.jface.text.templates line delimiter problem [message #265278] Tue, 07 October 2008 00:15 Go to next message
Originally posted by: besiaka13.yahoo.com
i am contributing a new file template for my custom editor. the extension
point is
and the template content is specified inside an xml file within my plugin
everything works fine (preferences, variables are correctly resolved,
files are created based on template etc) except for one problem
I can't get the line delimiters to respect the line delimiter workspace
preference. the xml file is always parsed in using unix line delimiters
for non variable content inside the template
example
say i have a template
//first comment
//this should be the class declaration
${class_declaration}
the line break between comments and curly braces are always unix encoded
(i am working on os and the xml file was created on os x)
is there a way to get around this?
Re: contributing toorg.eclipse.ui.editors.templates line delimiter problem [message #265280 is a reply to message #265278] Tue, 07 October 2008 00:31 Go to previous messageGo to next message
sorry extension point i am using is org.eclipse.ui.editors.templates
Re: contributing to org.eclipse.jface.text.templates line delimiter problem [message #265334 is a reply to message #265278] Thu, 09 October 2008 05:44 Go to previous message
Tanya wrote:
> Hi, i am contributing a new file template for my custom editor. the
> extension point is org.eclipse.jface.text.templates
> workspace preference. the xml file is always parsed in using unix
> line delimiters for non variable content inside the template example
> //first comment //this should be the class declaration
> encoded (i am working on os and the xml file was created on os x)
When inserting a template we use the line delimiter that is already used
in the file. If that's not what you see then please file a bug report
against Platform Text and attach your template contribution.
Dani
Previous Topic:CVS&Eclipse: How to remove module from CVS repository?
Next Topic:Taverna Workbench
Current Time: Sun Jul 27 06:10:26 EDT 2025
Powered by FUDForum. Page generated in 0.08700 seconds
