Taverna Workbench [message #265237] |
Mon, 06 October 2008 05:53  |
Hi, I'm a Biomedical Engineering,
and I've some problem to install CVS repository of Taverna Workbench. I
already tried much(installing plug-in,update etc..) but the problem is the
always the same: I can't connect with the repository by Eclipse, under
Unix instead is possible!!
By the tutorial the instructions explain:
Prerequisite:
http://www.mygrid.org.uk/dev/wiki/display/developer/Prerequi sites
It's ok.
Paste this location into the Host field:
:pserver:anonymous@taverna.cvs.sourceforge.net:/cvsroot/taverna
and it'ok, but when I try the check-out of CVS the error message is the
same:
Cannot connect to host:connection refused
If somebody has some hints or suggestions please reply to me...
Thanks everybody.
Massimiliano Armento
Istituto Nazionale per la Ricerca sul Cancro,
c/o Centro Biotecnologie Avanzate, Torre B - Piano 2
Largo Rosanna Benzi, 10 - I-16132 Genova - Italy Tel:+39-0105737-288
Re: Taverna Workbench [message #265243 is a reply to message #265237] |
Mon, 06 October 2008 07:17   |
Massimiliano,
It worked fine for me on windows. Are you able to "ping
taverna.cvs.sourceforge.net" this host from command line?
> I already tried much(installing plug-in,update etc..) but the problem
> is the always the same: I can't connect with the repository by
> Eclipse, under Unix instead is possible!!
> Prerequisite:
> It's ok.
> the same:
> Thanks everybody.
Re: Taverna Workbench [message #265266 is a reply to message #265264] |
Mon, 06 October 2008 10:51   |
Eric,
I tried with telnet and pserver aborted...With SSh or EXTSSH it's okay but
the "blank password" is not accepted,so aborted after a little attempts,
while by Unix is always ok...Now I'm looking for another way because it's
very strange this problem..
Maybe the problem is in my port, I'll check if there is another port with
same duty...
Thanks a lot!
>> Thanks for your fast reply!!
>> The problem is that by WinXp shell my firewall not allow the mode ping,
>> but by Unix shell I was able to connect and download the CVS repository!
>> So I think the problem is in the code of Taverna because otherwise even
>> through Unix I would not have been able to download taverna.
>> Can I do a question?What port did you use to set the properties of CVS?
>> Mine in default is : 2401 and you?
> That is the normal port for pserver connections. I was able to connect
> on that port to taverna.cvs.sourceforge.net
> If ping is blocked for you, try using telnet. In a Windows command line,
> type:
> telnet taverna.cvs.sourceforge.net 2401
> If it is able to connect, your command line should go blank and when you
> hit <Enter> you should get a message like:
> "cvs [pserver aborted]: bad auth protocol start:"
> If you can not connect, you'll get an error message stating so.
> Hope this helps,
> Eric
Re: Taverna Workbench [message #265336 is a reply to message #265266] |
Thu, 09 October 2008 06:43  |
the problem seems to be on the corporate firewall, the system
administrator seems reconfiguring the gates to be able to access Internet.
Basically the ISP to which I connected not allowed to leave port 2401, so
because positioned by the Admin. system... I will make if works. If
someone can be useful my experience ...
cheers all
FUDForum. Page generated in 0.10239 seconds
