problem with Help under WinXP Pro [message #264916] |
Sun, 01 August 2004 18:42  |
I have a new Windows XP Pro system with JDK 1.4.2_05 installed (which I
have verified executes java code just fine). When I try and view any of
the Eclipse help pages, the browser window is blank regardless of which
brower I tell the Help system to use (IE, Mozilla or FireFox). The help
system uses the loopback address 127.0.0.1 and some port to access the
help pages.
I believe the Help server is not starting up, but have been unable to
determine why. I believe it is a startup problem because neither Tomcat
or the Sun App Server startup either; after execution of their startup
scripts, http://localhost:8080 and http://127.0.0.1 are unavailable.
Has anyone else using WinXP Pro seen this problem and know of a
solution?
Gil
Re: problem with Help under WinXP Pro [message #276920 is a reply to message #265228] |
Wed, 01 December 2004 04:45  |
Originally posted by: gilblais.yahoo.com
Konrad - I have no such directory of
" workspace/.metadata/.plugins/org.eclipse.tomcat/catalina.*.l og " on my
system and there aren't even any .log files under the plugins directory ????
Gil Blais
"Konrad Kolosowski" <konradk@ca.ibm.com> wrote in message
news:ceo776$niu$1@eclipse.org...
> Help uses embedded appserver to provide content to the browser. There are
> another logs written by Tomcat plug-in. Look at
> workspace/.metadata/.plugins/org.eclipse.tomcat/catalina.*.l og files for
> clues why embedded appserver cannot start.
> Konrad
> "Gil Hansen" <hansengj@sbcglobal.net> wrote in message
> news:MPG.1b78d2aca1a250b1989681@news.eclipse.org...
> > In article <cel0ji$o9c$1@eclipse.org>, michael.keppler@gmx.de says...
to
> > > > determine why.
> > > Try putting your external IP (not the 127.0.0.1) into
> > > Preferences->Help->Help Server->IP.
> > Michael - Thanks for the suggestion, but unfortunately it does not work.
> > One gets a Help Error: "Help cannot be displayed. The embedded
> > application server could not run help web application. Check the log for
> > details." Even if this worked it would not be the ideal solution given
> > my IP address is dynamic.
> > I noticed sarangkamat@hotmail.com also is having problems getting
> > Eclipse 3's Help system to display; he posted the log details today.
> > Here are mine which indicates the issue is that Tomcat cannot be
> > started. The log indicates to me this is a bug under WinXP Pro.
> > --Gil
> > Eclipse .log:
> > !ENTRY org.eclipse.help.base 4 0 Aug 02, 2004 23:25:46.421
> > !MESSAGE Help cannot be displayed. The embedded application server
> > could not run help web application. Check the log for details.
> > !STACK 1
> > org.eclipse.core.runtime.CoreException: Exception occurred starting
> > application server.
> > at org.eclipse.tomcat.internal.TomcatAppServer.start
> > (TomcatAppServer.java:207)
> > at
> > org.eclipse.help.internal.appserver.AppserverPlugin.startWeb appServer
> > (AppserverPlugin.java:145)
> > at
> > org.eclipse.help.internal.appserver.AppserverPlugin.getAppSe rver
> > (AppserverPlugin.java:42)
> > at org.eclipse.help.internal.appserver.WebappManager.start
> > (WebappManager.java:57)
> > at
> > org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning
> > (BaseHelpSystem.java:182)
> > at org.eclipse.help.internal.base.HelpDisplay.displayHelpURL
> > (HelpDisplay.java:156)
> > at org.eclipse.help.internal.base.HelpDisplay.displayHelpResour ce
> > (HelpDisplay.java:80)
> > at
> > > Ciao, Michael.
FUDForum. Page generated in 0.03335 seconds
