Home » Newcomers » Newcomers » EJB 3.0 version choice when creating EJB project
EJB 3.0 version choice when creating EJB project [message #265168] Thu, 02 October 2008 10:42 Go to next message
I am using Eclipse 3.4, jdk 1.5 and JBOSS 4.0.2. I am trying to create an
EJB 3.0 project from Eclipse using the procedure described in Eclipse
documentation and help screens. The project creation dialog has an
drop-down list to select EJB module version. This list only provides EBJ
1.0, 2.0 and 2.1 version. There is no selection for EJB 3.0. As I
mentioned earlier, Eclipse is configured for JDK 1.5 JRE. I had
successfully installed JBoss for EJB 3.0 configuration successfully, so I
know that the jdk version is not the issue. Any suggestions?
Re: EJB 3.0 version choice when creating EJB project [message #265181 is a reply to message #265168] Thu, 02 October 2008 23:31 Go to previous message
I found the reason why Eclipse 3.4 is not offering a choice in the
drop-down list for EJB Module version in EJB project creation dialog. I
have JBoss 4.0 GA installed. The JBoss 4.0 provides support for EJB 3.0
only if you install it using one their installer. I guess Eclipse 3.4
doesn't pick up on some special install configurations created by the
installer, so Eclipse probably thinks that the JBoss 4.0 doesn't support
EJB 3.0. When I selected JBoss 4.2, then the EJB module version added the
3.0 choice in the list.
So I created a project using the EJB project and specified JBoss 4.2 so
that I can select EJB 3.0. Once the project was created, the ejb-jar.xml
still shows version 2.1. I think this is all related to the fact that GA
release 2.1.2 of JBoss tools is incompatible with newest Eclipse 3.4
release.
Previous Topic:Eclipse Event Adapter support
Next Topic:Help with creating EJB 3.0 projects
Current Time: Thu Nov 06 02:41:58 EST 2025
Powered by FUDForum. Page generated in 0.08379 seconds
