Home » Newcomers » Newcomers » JRE 1.4.2 with Eclipse 3.4?
JRE 1.4.2 with Eclipse 3.4? [message #264769] |
Thu, 25 September 2008 12:52  |
There is conflicting information about whether JRE 1.4.2 is sufficient for
Eclipse 3.4.
The official documentation says YES:
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.user/tasks/running_eclipse.htm
- mentions only 1.4.2
eclipse/readme/readme_eclipse.html (in the unzipped eclipse
directory)
- "the Eclipse Project SDK as a whole is targeted at both 1.4 and Java5
VMs, with full functionality available for 1.4 level development
everywhere"
http://www.eclipse.org/downloads/moreinfo/jre.php
- implies that, if anything, it depends on whether you use the EE package
or not ("Eclipse IDE for Java EE Developers requires a Java5 JRE").
Whereas other sources say NO:
http://wiki.eclipse.org/Eclipse/Installation
- says that even Eclipse 3.3 (Europa) requires a Java 5 Runtime
Environment, with no mention of whether use of the EE package is a
deciding factor
http://saloon.javaranch.com/cgi-bin/ubb/ultimatebb.cgi?ubb=g et_topic&f=33&t=025009
- says the same: "If your Eclipse version is europa, you need Java 5 JRE"
And for me, when (in Windows XP) I try to use ...
eclipse.exe -vm c:\j2sdk1.4.2_09\bin\javaw
.. I get a window titled "Incompatible JVM" saying ...
"Version 1.4.2-09 of the JVM is not suitable for this product.
Version 1.5 or greater is required"
I click OK and the window goes away, but Eclipse doesn't start.
So which information is correct? And is there any way of bypassing the
incompatibility warning and forcing 3.4 to use 1.4.2?
Peter
Re: JRE 1.4.2 with Eclipse 3.4? [message #264777 is a reply to message #264769] |
Thu, 25 September 2008 13:34   |
Peter,
Comments below.
Peter Ford wrote:
> for Eclipse 3.4.
That's true for the platform.
> directory)
> Java5 VMs, with full functionality available for 1.4 level development
> everywhere"
Yes that's true of the platform.
> package or not ("Eclipse IDE for Java EE Developers requires a Java5
> JRE").
Yes, WTP requires EMF which required Java 5.0.
> deciding factor
Sounds like an oversight, but again, it's statement about the platform.
> 5 JRE"
If you use WTP or anything else downstream from EMF you need 5.0...
> the incompatibility warning and forcing 3.4 to use 1.4.2?
What projects are you expecting to be able to use? Why would it even
matter I have to wonder too given that 1.4 is close to end of life...
> Peter
Re: JRE 1.4.2 with Eclipse 3.4? [message #264780 is a reply to message #264769] |
Thu, 25 September 2008 14:24   |
Originally posted by: eclipse-news.rizzoweb.com
Peter Ford wrote:
> for Eclipse 3.4.
> directory)
> everywhere"
> package or not ("Eclipse IDE for Java EE Developers requires a Java5 JRE").
> deciding factor
> JRE"
Basically, none of those is strictly wrong, but some of them are not
clear or complete. The Eclipse wiki page was too broad a statement, so
I've fixed it. The JavaRanch forum post, well you should take everything
you read on a forum (including this one) with an appropriate grain of
salt and consider the authority of the person writing it. The first two
references above are both correct; it does depend on which plugins you
have installed.
If you are trying to run the Java EE package (with WTP plugins), it
definitely needs Java 5 or JDK 1.5. If you want to keep your installed
package but bypass the Incompatible JVM error, you can try removing this
line from eclipse.ini:
-Dosgi.requiredJavaVersion=1.5
Note that doing so will, at the minumum, disable many or all of the
JEE/WTP specific plugins (because they require Java 5). If you don't
need JEE features, I'd recommend getting the Java Developers package
instead. Or just get a 1.5 JVM/JDK.
Hope this helps,
Eric
Re: JRE 1.4.2 with Eclipse 3.4? [message #264808 is a reply to message #264780] |
Fri, 26 September 2008 14:13   |
Eric Rizzo wrote:
> Peter Ford wrote:
>> Hi,
>> for Eclipse 3.4.
>> directory)
>> everywhere"
>> deciding factor
>> JRE"
>> eclipse.exe -vm c:j2sdk1.4.2_09binjavaw
> have installed.
> Hope this helps,
> Eric
My own particular issue is actually a non-issue, as it turned out that I
was wrong to think I needed to run Eclipse on JRE 1.4.2 (see other post).
But there is still the question of why it wasn't working.
The important thing that I left out of my original post was which package
I was trying to use when I got the error.
It was the Java Developers package - the 85MB zip file.
I note from http://www.eclipse.org/downloads/packages/compare-packages
that even the non-EE package includes Mylyn, and from
http://www.eclipse.org/mylyn/downloads/ that Mylyn seems to require JRE
1.5.
So does that explain why I got the error? And does it mean that the 3
bits of official documentation I listed need updating to say that 1.5 is
the minimum (or to explain how to start Eclipse without Mylyn)?
Peter
Re: JRE 1.4.2 with Eclipse 3.4? [message #264939 is a reply to message #264808] |
Fri, 26 September 2008 14:56   |
Peter,
That's a very good point. It looks to me like Eclipse Classic is the
only download that doesn't require Java 5.0. That makes the
recommendation at the top of the page awfully weak. Please open a
bugzilla asking to make the statement more strongly. In fact, there
really ought to be a way to find out the JRE level required for any
particular package, and currently it's guesswork; that's no good. The
other things ought to be fixed up as well. When you open a bugzilla,
please append the bugzilla number to this thread.
Thanks!
Peter Ford wrote:
> Eric Rizzo wrote:
>> Peter Ford wrote:
>>> Hi,
>>> sufficient for Eclipse 3.4.
>>> directory)
>>> and Java5 VMs, with full functionality available for 1.4 level
>>> development everywhere"
>>> EE package or not ("Eclipse IDE for Java EE Developers requires a
>>> Java5 JRE").
>>> deciding factor
>>> Java 5 JRE"
>> so I've fixed it. The JavaRanch forum post, well you should take
>> everything you read on a forum (including this one) with an
>> appropriate grain of salt and consider the authority of the person
>> writing it. The first two references above are both correct; it does
>> depend on which plugins you have installed.
>> installed package but bypass the Incompatible JVM error, you can try
>> removing this line from eclipse.ini:
>> Hope this helps,
>> Eric
> I was wrong to think I needed to run Eclipse on JRE 1.4.2 (see other
> post). But there is still the question of why it wasn't working.
> package I was trying to use when I got the error.
> JRE 1.5.
> is the minimum (or to explain how to start Eclipse without Mylyn)?
> Peter
Re: JRE 1.4.2 with Eclipse 3.4? [message #264954 is a reply to message #264939] |
Sat, 27 September 2008 15:39   |
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gbjb97$c93$1@build.eclipse.org...
> Peter,
> That's a very good point. It looks to me like Eclipse Classic is the only
> download that doesn't require Java 5.0. That makes the recommendation at
> the top of the page awfully weak. Please open a bugzilla asking to make
> the statement more strongly. In fact, there really ought to be a way to
> find out the JRE level required for any particular package, and currently
> it's guesswork; that's no good. The other things ought to be fixed up as
> well. When you open a bugzilla, please append the bugzilla number to this
> thread.
The issue is really kind of trickier than it seems on the surface. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=174515 for a related topic.
I do think that clearer documentation on the web site would help, and I
think we should simply be recommending that people use the newest JVM
version they can, and understand that if they're on a downlevel VM some
functionality may be missing. The way I would put it is: "Most of the
Eclipse core is able to run on Java 1.4.2, but every version of Eclipse
contains some functionality that relies on Java 5 or even Java 6. You may
not need this functionality, depending on what you're doing with Eclipse."
The problem is that describing exactly what functionality is and is not
available on a given VM quickly gets into way more detail than is
appropriate for a downloads page. Someone planning on using Eclipse to edit
PHP scripts shouldn't have to read about the JSR199 API, for instance.
I really think it comes down to the question of how we show that some
functionality is unavailable, without intruding on the experience of people
who don't need that functionality. Unfortunately, that is a very hard
challenge.
Re: JRE 1.4.2 with Eclipse 3.4? [message #265004 is a reply to message #264954] |
Mon, 29 September 2008 12:22   |
On 9/27/2008 3:39 PM, Walter Harley wrote:
> "Ed Merks"<Ed.Merks@gmail.com> wrote in message
>> Peter,
>> thread.
> challenge.
I actually think the problem in Peter's particular case is that the
"Eclipse IDE for Java Developers" package specifies
"-Dosgi.requiredJavaVersion=1.5" in its eclipse.ini
While I understand that Mylyn requires 1.5, I don't think anything else
that is "crucial" to the Java dev tools does, so it seems to me that
this is an unnnecessary restriction for that package (Mylyn is, IMO,
still an optional piece of functionality that should not prevent the
entire tool from loading).
I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=248976 about this.
Eric
Re: JRE 1.4.2 with Eclipse 3.4? [message #265051 is a reply to message #265041] |
Tue, 30 September 2008 05:09  |
Peter,
Thanks for the taking the time to open a bugzilla!
>> else that is "crucial" to the Java dev tools does, so it seems to me
>> that this is an unnnecessary restriction for that package (Mylyn is,
>> IMO, still an optional piece of functionality that should not prevent
>> the entire tool from loading).
>> about this.
>> Eric
> If bug 174515 is all that happens when Eclipse tries to load in a JRE
> that's insufficient for its plugins, then it does seem like it might
> be worth making eclipse.ini less fussy - or telling users how to do
> themselves it in the documentation.
> Anyway, here's my bug:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=249063
> Thanks everyone for your help,
> Peter
Current Time: Thu Oct 23 00:17:26 EDT 2025
Powered by FUDForum. Page generated in 0.08304 seconds
