Home » Archived » BIRT » BIRT 2.2.1.1 won't work without Cairo on Solaris
BIRT 2.2.1.1 won't work without Cairo on Solaris [message #264538] Tue, 15 January 2008 14:56 Go to next message
I have an application with working BIRT charts on Solaris/Sparc/Motif
under Eclipse 3.2.1 with BIRT 2.1, using the "-DR31ENHANCE=false" VM flag,
since I don't have the Cairo graphic library.
I upgraded to Eclipse Europa 3.3.1.1 with BIRT 2.2.1.1 and now the
application's BIRT charts don't work! Everything else works correctly.
I've run across a couple of bug reports that seem to indicate potential
problems with SWT not respecting the R31ENHANCE flag, but the bugs are for
SWT 3.1, which is *prior* to the working Eclipse 3.2.1 installation, so
I'm not sure if those bugs are still valid.
Unfortunately, in our customer's environment (government), I can't
guarantee that Cairo will be installed, so I really need a non-Cairo
solution.
Before I submit a bug, does anyone know what happened between these
releases that might explain this?
-Dan Hoyt
Senior Systems Architect, TSC
Re: BIRT 2.2.1.1 won't work without Cairo on Solaris [message #264728 is a reply to message #264538] Thu, 17 January 2008 02:10 Go to previous message
I believe this flag should still work, so it looks like a bug to me.
David
"Dan Hoyt" <dan.hoyt@tsc.com> wrote in message
news:aa60ceaa8767731209a2f632c4a32e93$1@www.eclipse.org...
>I have an application with working BIRT charts on Solaris/Sparc/Motif under
>Eclipse 3.2.1 with BIRT 2.1, using the "-DR31ENHANCE=false" VM flag, since
> solution.
> -Dan Hoyt
Previous Topic:How to set chart data dyamically in birt
Next Topic:Getting a chart's preferred size
Current Time: Mon Sep 08 00:50:41 EDT 2025
Powered by FUDForum. Page generated in 0.04259 seconds
