Home » Archived » BIRT » org.eclipse.birt.report.viewer.utilities.WebViewer to SWT application
org.eclipse.birt.report.viewer.utilities.WebViewer to SWT application [message #264267] Thu, 10 January 2008 03:42 Go to next message
First off, good year to all!!!
Second, I need some help for you!
In my swt application i want run a
"org.eclipse.birt.report.viewer.utilities.WebViewer" BIRT plugin
This is my snippet:
public class TestWebBrowser {
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
shell.setText("BIRT Example");
final Browser browser;
try {
browser = new Browser(shell, SWT.NONE);
} catch (SWTError e) {
System.out.println("Could not instantiate Browser: " +
e.getMessage());
return;
WebViewer.startup(browser);
try {
WebViewer.display("C:\\birt\\prova.rptdesign",
WebViewer.HTML, browser, "frameset");
} catch (Exception e) {
// logger.error(e);
e.printStackTrace();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
When I run this snippet i received this error:
Exception in thread "main" java.lang.NullPointerException
at
org.eclipse.birt.report.viewer.ViewerPlugin.getResourceStrin g(ViewerPlugin.java:159)
at
org.eclipse.birt.report.viewer.ViewerPlugin.getFormattedReso urceString(ViewerPlugin.java:181)
at
org.eclipse.birt.report.viewer.utilities.WebappAccessor.getW ebappPath(WebappAccessor.java:152)
at
org.eclipse.birt.report.viewer.utilities.WebappAccessor.star t(WebappAccessor.java:68)
at
org.eclipse.birt.report.viewer.utilities.WebViewer.startWebA pp(WebViewer.java:369)
at
org.eclipse.birt.report.viewer.utilities.WebViewer.startup(W ebViewer.java:410)
at it.cedacosrl.test.TestWebBrowser.main(TestWebBrowser.java:28 )
Now, the problem ( I suppose ) is in the "WebappAccessor" class where
the row: "Bundle bundle = Platform.getBundle( pluginId );"
try to load the resource bundle of
"org.eclipse.birt.report.viewer.utilities.WebViewer".
Obviously the problem is in the osgi, where there is not load the
necessary bundle.
Somebody can have a idea to give me?
Thanks in advance.
Stefano
Re: org.eclipse.birt.report.viewer.utilities.WebViewer to SWT application [message #264356 is a reply to message #264267] Fri, 11 January 2008 13:28 Go to previous messageGo to next message
Originally posted by: jasonweathersby.alltel.net
Stefano,
Do you have all the plugins that the viewer requires in your plugins
directory and did you add the viewer plugin to your project dependecies?
Jason
> This is my snippet:
> public static void main(String[] args) {
> try {
> e.getMessage());
> return;
> try {
> // logger.error(e);
> shell.open(); while (!shell.isDisposed()) {
> display.sleep();
> display.dispose();
> at
> at
> at
> at
> at
> at
> necessary bundle.
> Thanks in advance.
> Stefano
Re: org.eclipse.birt.report.viewer.utilities.WebViewer to SWT application [message #264389 is a reply to message #264356] Sat, 12 January 2008 08:57 Go to previous messageGo to next message
Thanks Jason for you replay.
First off, I want to be sure that you understand that my application
don't have the rcp style, I want run this plugin inside my swt
application where I use some jface class. So my application don't use
the rcp framework and as you can see from my snippet i want to test the
use of webviewer plugin with the swt browser class.
Now, I put some plugin in the class path of this application ( I saw
that the vm trows some null pointer exception and so I try to meet its
request ;-) ), but I suppose that the problem is inside the osgi
framework, because it not be instantiate by my snippet.
Thanks thousand!
> Stefano,
> Jason
>> This is my snippet:
>> try {
>> e.getMessage());
>> return;
>> try {
>> // logger.error(e);
>> display.sleep();
>> display.dispose();
>> at
>> at
>> at
>> at
>> at
>> at
>> necessary bundle.
>> Thanks in advance.
>> Stefano
Re: org.eclipse.birt.report.viewer.utilities.WebViewer to SWT application [message #264466 is a reply to message #264389] Mon, 14 January 2008 10:20 Go to previous messageGo to next message
Stefano,
Can you email me the project or explain how you setup the project?
When you call the startup for the WebViewer this should start the
required plugins for BIRT.
Jason
> Thanks thousand!
>> Stefano,
>> Jason
>>> This is my snippet:
>>> try {
>>> e.getMessage());
>>> return;
>>> try {
>>> // logger.error(e);
>>> display.sleep();
>>> display.dispose();
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> necessary bundle.
>>> Thanks in advance.
>>> Stefano
Re: org.eclipse.birt.report.viewer.utilities.WebViewer to SWT application [message #264578 is a reply to message #264466] Tue, 15 January 2008 17:26 Go to previous messageGo to next message
Oh, Jason, how much patience!
Thanks again for you answers,
I'm sorry for my bad English...
Ok, I try again to explain my project. I want to use the birt viewer
plugin in my swt application. My swt application is not a rcp
application neither a plugin project, it only a simple swt application
as you can see in my last snippet. I put in the class path of my
application the plugin that contain
and com.ibm.icu
I hope that this could help you... then me :-)
Thanks!
> Stefano,
> Jason
>> the use of webviewer plugin with the swt browser class.
>> Thanks thousand!
>>> Stefano,
>>> Jason
>>>> This is my snippet:
>>>> try {
>>>> e.getMessage());
>>>> return;
>>>> try {
>>>> // logger.error(e);
>>>> display.sleep();
>>>> display.dispose();
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> where the row: "Bundle bundle = Platform.getBundle( pluginId );"
>>>> necessary bundle.
>>>> Thanks in advance.
>>>> Stefano
Re: org.eclipse.birt.report.viewer.utilities.WebViewer to SWT application [message #264595 is a reply to message #264578] Wed, 16 January 2008 00:52 Go to previous messageGo to next message
Stefano,
I believe I understand and I do not think the viewer plugin can work
this way. One way may be to use the BIRT runtime and copy the viewer
plugin and its required plugins to birt runtime plugins directory and
then do a platform startup. I have not tried this though.
Jason
> and com.ibm.icu
> Thanks!
>> Stefano,
>> Jason
>>> its request ;-) ), but I suppose that the problem is inside the osgi
>>> Thanks thousand!
>>>> Stefano,
>>>> dependecies?
>>>> Jason
>>>>> This is my snippet:
>>>>> try {
>>>>> e.getMessage());
>>>>> return;
>>>>> try {
>>>>> // logger.error(e);
>>>>> display.sleep();
>>>>> display.dispose();
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> necessary bundle.
>>>>> Thanks in advance.
>>>>> Stefano
Re: org.eclipse.birt.report.viewer.utilities.WebViewer to SWT application [message #264859 is a reply to message #264595] Mon, 21 January 2008 03:01 Go to previous message
Thanks Jason,
for hour I take this workaround:
Deploy the webviewer application in a embedded tomcat solution, then
I'm starting the tomcat when I start my swt application by inside it.
Thanks thousand
> Stefano,
> Jason
>> application as you can see in my last snippet. I put in the class
>> path of my application the plugin that contain
>> and com.ibm.icu
>> Thanks!
>>> Stefano,
>>> Jason
>>>> application don't have the rcp style, I want run this plugin inside
>>>> my swt application where I use some jface class. So my application
>>>> don't use the rcp framework and as you can see from my snippet i
>>>> want to test the use of webviewer plugin with the swt browser class.
>>>> saw that the vm trows some null pointer exception and so I try to
>>>> meet its request ;-) ), but I suppose that the problem is inside
>>>> the osgi framework, because it not be instantiate by my snippet.
>>>> Thanks thousand!
>>>>> Stefano,
>>>>> plugins directory and did you add the viewer plugin to your
>>>>> Jason
>>>>>> This is my snippet:
>>>>>> try {
>>>>>> e.getMessage());
>>>>>> return;
>>>>>> try {
>>>>>> // logger.error(e);
>>>>>> display.sleep();
>>>>>> display.dispose();
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> necessary bundle.
>>>>>> Thanks in advance.
>>>>>> Stefano
Previous Topic:Embeded internationalization?
Next Topic:Accessing design.xsd through EMF API (using generated design.ecore)
Current Time: Thu Jul 24 05:36:22 EDT 2025
Powered by FUDForum. Page generated in 0.11776 seconds
