Home » Newcomers » Newcomers » Draw custom text on Table
Draw custom text on Table [message #264289] |
Mon, 15 September 2008 06:22  |
is it possible to draw custom text on the table?
I have Table and TableViewer and if there is not data to show, I would
like to display text with such message. I'd like the message to be in
first row, but go throw the more columns or to be in a special place (eg.
in the middle of control).
Agata
Re: Draw custom text on Table [message #264552 is a reply to message #264354] |
Fri, 19 September 2008 14:26   |
Putting a Label on the Table should work, snippet:
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setBounds(10,10,200,200);
shell.setLayout(new FillLayout());
Table table = new Table(shell, SWT.NONE);
table.setLinesVisible(true);
table.setHeaderVisible(true);
shell.open();
Label label = new Label(table, SWT.CENTER);
label.setBackground(table.getBackground());
label.setBounds (5, table.getHeaderHeight(), table.getSize().x - 2 * 5,
table.getItemHeight());
label.setText("no items here");
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Grant
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:gannqe$qk9$1@build.eclipse.org...
> Hi Agata,
> Ok. Looks like SWT-Table doesn't support SWT-Paint :-( The only trick I
> now see is that you are setting a background image which has the draw
> back that it is rendered behind the Grid-Lines (you could turn them of
> of course).
> I've CC'ed the swt-newsgroup maybe some of the others has a better idea.
> Tom
> Agata Vackova schrieb:
> > I tried to use paint listener (
> > table.addPaintListener(new PaintListener(){
> > public void paintControl(PaintEvent e) {
> > e.gc.drawText("No data", 100, 100);
> > ), but it doesn't work: method paintControl is not called at all.
> > Agata
> > Tom Schindl wrote:
> >> Owner Draw doesn't help here I guess because if there are no rows
> >> there's no owner draw because it is bound to Table/TreeItem but a
simple
> >> SWT.Paint-Listener should do the trick.
> >> Tom
> >> Eric Rizzo schrieb:
> >>> Agata Vackova wrote:
> >>>> Hello,
> >>>> would like to display text with such message. I'd like the message to
> >>>> be in first row, but go throw the more columns or to be in a special
> >>>> place (eg. in the middle of control).
> >>> You can probably use the Owner Draw feature to do this. See some
> >>> examples on the Snippets page:
> >>> http://wiki.eclipse.org/index.php/JFaceSnippets
> >>> Hope this helps,
> >>> Eric
> B e s t S o l u t i o n . at
> Tom Schindl JFace-Committer
Re: Draw custom text on Table [message #264580 is a reply to message #264552] |
Mon, 22 September 2008 04:38  |
Thank you, works fine (except the weight of the label - it it very short,
I'll have probably to hardcore the weight of the label)
Agata
> public static void main(String[] args) {
> shell.open();
> display.dispose();
> Grant
>> Hi Agata,
>> of course).
>> Tom
>> > Agata
> simple
>> >> Tom
>> >>>> Hello,
>> >>> Hope this helps,
>> >>> Eric
Current Time: Thu Jul 24 17:58:55 EDT 2025
Powered by FUDForum. Page generated in 0.09360 seconds
