Home » Eclipse Projects » Eclipse Platform » Automated PDE build fails to build fragment/plugin combo
Automated PDE build fails to build fragment/plugin combo [message #263822] Mon, 26 July 2004 16:23 Go to next message
Originally posted by: mark.melvin.dspfactory.com
Well, once again I am hoping someone can help me out here...
I have modeled a plugin/fragment wrapper around some JNI code &
libraries in exactly the way the SWT/SWT.win32 plugin/fragment works.
I created a plugin, my.plugin.wrapper, and then I created a fragment -
my.plugin.wrapper.win32. The fragment contains all of the .dll's (in
/os/win32/x86/) and the jar file (in /ws/win32/myjar.jar).
Now - if I have this plugin and fragment in my workspace, all of my
dependent plugins (requiring my.plugin.wrapper) see the API contained
within the jar file and work fine. However, if I try to run my
automated build - it fails to compile my plugins depending on
my.plugin.wrapper because it can't resolve any of the classes contained
in the jar file provided by the fragment.
NOW - if I manually copy the "/ws/win32/myjar.jar" tree from the
fragment into the plugin dir which uses it (so I now have
my.plugin.wrapper/ws/win32/myjar.jar) - all of the dependent plugins
compile. What the heck? Shouldn't this resolve through to the "ws" dir
found in the fragment? Isn't that what a fragment is for? Here is what
my manifest.mf looks like for my wrapper plugin:
Manifest-Version: 1.0
Bundle-Name: %pluginName
Bundle-Vendor: %providerName
Bundle-SymbolicName: my.plugin.wrapper; singleton=true
Bundle-Version: 0.0.2
Bundle-ClassPath: $ws$/myjar.jar
Bundle-Localization: plugin
Eclipse-AutoStart: true
Provide-Package: my.api.package.in.the.jarfile
And the manifest.mf for the fragment is:
Bundle-Name: %fragmentName
Bundle-SymbolicName: my.plugin.wrapper.win32; singleton=true
Fragment-Host: my.plugin.wrapper;bundle-version="[0.0.2,1.0.0)"
Bundle-Localization: fragment
Any help would be much appreciated.
On another note - when I actually get it to compile by copying the jar
file over to the plugin, the build still utlimately fails during the
gather.bin.parts stage of the fragment with the following error:
\my.plugin.wrapper.win32\@dot not found.
Any ideas on this one?
Mark.
Re: Automated PDE build fails to build fragment/plugin combo [message #263831 is a reply to message #263822] Mon, 26 July 2004 17:32 Go to previous messageGo to next message
More information...running the build in verbose mode yields the following:
[javac] Using JDT compiler
dropping
<my_build_path>\eclipse\plugins\my.plugin.wrapper\ws\${ws}\myjar.jar
from path as it doesn't exist
dropping
<my_build_path>\eclipse\plugins\my.plugin.wrapper.win32\ws\${ws}\myjar.jar
dropping <my_build_path>\eclipse\plugins\my.plugin.wrapper.win32\@dot
SO - it looks like it is *trying* to do something right - but the
automated build can't resolve ${ws} across fragments, or @dot for that
matter. I'm thinking these are bugs. If I don't get a response from a
PDE guru, I guess I'll go file a bug.
Mark.
> Mark.
Re: Automated PDE build fails to build fragment/plugin combo [message #263836 is a reply to message #263831] Mon, 26 July 2004 17:48 Go to previous message
Hmm... Explicitly specifying configs=win32,win32,x86, and renaming my
assemble targets appropriately has caused the resolution of the jarfile
to work (the automated build now can resolve the ${ws} alias in my
fragment classpath).
The only problem now is the "@dot" issue. The build fails in the
"gather.bin.parts" target of my fragment with:
Getting closer...has anyone come across this problem? I only found one
other reference to it with no responses, and no discussion in Bugzilla -
just that it was "fixed in last yesterday's build". But I think the bug
I found (Bug 66839) is a different animal altogether.
Mark.
> dropping
> dropping
> Mark.
>> contained in the jar file provided by the fragment.
>> dir found in the fragment? Isn't that what a fragment is for? Here
>> is what my manifest.mf looks like for my wrapper plugin:
>> Thanks,
>> Mark.
Previous Topic:PDE build error
Next Topic:Eclipse Debug Problems (3.0)
Current Time: Fri Jul 25 23:30:48 EDT 2025
Powered by FUDForum. Page generated in 0.08026 seconds
