Home » Archived » BIRT » Using Spring ApplicationContext from my scripted datasource
Using Spring ApplicationContext from my scripted datasource [message #263673] Fri, 21 December 2007 05:31 Go to next message
Originally posted by: erikvaningen.gmail.com
Hi all,
We use the Birt Viewer ((J2EE App/Plugin). In our reports we use
scripted datasets. From the scripted datasets we would like to acces the
Spring application context in order to retrieve the data from the Spring
beans.
What would be a good way to do this?
Kind Regards,
Erik
Re: Using Spring ApplicationContext from my scripted datasource [message #263698 is a reply to message #263673] Sat, 22 December 2007 17:59 Go to previous messageGo to next message
Add the Spring libraries and configuration files to the viewer's
classpath (WEB-INF/lib) and use Spring as usually.
Snjeza
Erik van Ingen wrote:
> Hi all,
> beans.
> Kind Regards,
> Erik
Re: Using Spring ApplicationContext from my scripted datasource [message #263705 is a reply to message #263698] Sun, 23 December 2007 08:11 Go to previous messageGo to next message
How do I reach the spring application context from a scripted datasource?
> Snjeza
>> Hi all,
>> the Spring application context in order to retrieve the data from the
>> Spring beans.
>> Kind Regards,
>> Erik
Re: Using Spring ApplicationContext from my scripted datasource [message #263708 is a reply to message #263705] Sun, 23 December 2007 11:59 Go to previous message
A scripted datasource is an ordinary Java class. You can call the spring
application context in the following way:
ApplicationContext context =
ClassPathXmlApplicationContext("/applicationContext.xml");
or in any other way you prefer.
The most important thing is to set the classpath correctly.
Snjeza
>> Snjeza
>>> Hi all,
>>> Spring beans.
>>> Kind Regards,
>>> Erik
Previous Topic:Plug-in Development Target Definition for Testing BIRT Extensions
Next Topic:Dependency on Xerces 2.8 and Apache.xml.resolver 1.1: needed?
Current Time: Tue Sep 16 20:09:38 EDT 2025
Powered by FUDForum. Page generated in 0.03411 seconds
