Home » Eclipse Projects » DSDP - Target Management » Multiple prompts for user ID/password
Multiple prompts for user ID/password [message #26269] Thu, 28 August 2008 15:05 Go to next message
I am using a dstore connection from Windows to an AIX machine. I was
previously connecting to a running server and was being prompted once for
my user ID and password when I connected (as expected). We just got the
dstore daemon running and now when I connect to the daemon, I am sometimes
prompted a second time for my user name and password. I tried to narrow
down exactly when it prompted twice and when it prompted once but it seems
intermittent. The second prompt indicates the password is optional and I
succesfully connect whether I enter the password or not. Why would I be
prompted a second time for my user ID and password when connecting to the
dstore daemon and why would the password be optional the second time? I
looked in the user's guide and couldn't find info about it. Thanks!
Re: Multiple prompts for user ID/password [message #26309 is a reply to message #26269] Thu, 28 August 2008 21:05 Go to previous messageGo to next message
Now I am also regularly seeing a failure to connect. The error indicates
"RSEG1242" and says "Daemon failed to launch server on <my machine> using
port 0".
We start the daemon with the following command:
cd /opt/rseserver; /usr/bin/perl ./daemon.pl 4075 12200-12209
We also enable SSL using the instructions in the RSE User's guide.
Could we have set up something wrong causing the connection error and
multiple user ID/password prompts?
Thanks.
Re: Multiple prompts for user ID/password [message #26347 is a reply to message #26309] Thu, 28 August 2008 21:51 Go to previous messageGo to next message
Sorry for the multiple posts but I realized that I didn't mention that
when I see the connection failure message, sometimes it does seem to
connect anyway after getting prompted for my user ID and password a second
time. Although whether the connect actually works is intermittent.
Also wanted to reiterate that when I was connecting to a running server,
everything worked as expected and the strangeness started once we started
connecting to the daemon.
Thanks.
Re: Multiple prompts for user ID/password [message #26386 is a reply to message #26347] Fri, 29 August 2008 10:28 Go to previous messageGo to next message
Hi Denise,
I've never seen this problem before. Could you open a bugzilla bug for this
and describe your configuration in as much detail as you can?
Dave
"Denise Schmidt" <denise.schmidt@lmco.com> wrote in message
news:29d89c9a6acced1023fe4df762d92030$1@www.eclipse.org...
> Thanks.
Re: Multiple prompts for user ID/password [message #26423 is a reply to message #26386] Fri, 29 August 2008 11:49 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245714 has been opened.
Thanks.
Re: Multiple prompts for user ID/password [message #576843 is a reply to message #26269] Thu, 28 August 2008 21:05 Go to previous message
port 0".
Thanks.
Re: Multiple prompts for user ID/password [message #576857 is a reply to message #26309] Thu, 28 August 2008 21:51 Go to previous message
Thanks.
Re: Multiple prompts for user ID/password [message #576868 is a reply to message #26347] Fri, 29 August 2008 10:28 Go to previous message
Hi Denise,
Dave
> Thanks.
Re: Multiple prompts for user ID/password [message #576876 is a reply to message #26386] Fri, 29 August 2008 11:49 Go to previous message
Thanks.
Previous Topic:Multiple prompts for user ID/password
Next Topic:Terminal window sends "cd /" -- how to prevent this?
Current Time: Sat Jul 26 03:11:11 EDT 2025
Powered by FUDForum. Page generated in 0.26947 seconds
