Home » Eclipse Projects » Eclipse Platform » How to set the RCP main app icon
How to set the RCP main app icon [message #263428] Fri, 23 July 2004 04:35 Go to next message
shamefully I have to say that I didn't find it on my own:
How to I set my own RCP main icon (usually left to the
title bar)??
Do I have to define a feature or should/can I do that
programmatically (where?) ?
Thank you very much for your help,
Daniel Krügler
Re: How to set the RCP main app icon [message #263433 is a reply to message #263428] Fri, 23 July 2004 04:47 Go to previous messageGo to next message
Originally posted by: mbo.shift-think.net
Hello Daniel
As far as I know, you have to recompile the 'eclipse.exe'. You can provide a
customized icon file there which will be used for your executable. But you
will need Visual C++ or GNU C (on Linux).
Let me know if you want details on how to achieve this. I don't know if
there is an easyer way. I have the necessary setup, so if you want me to
recompile the binary, let me know.
Chers,
Michael
"Daniel Kr
Re: How to set the RCP main app icon [message #263444 is a reply to message #263433] Fri, 23 July 2004 05:00 Go to previous messageGo to next message
Hello Michael,
Michael Boeni schrieb:
> Hello Daniel
Thanks for your answer, but obviously I did ask my question the wrong
way: I don't want to modify the Eclipse look-and-feel, I only want to
write my own RCP app using Eclipse. Now this self-written app should
have its own main window icon. Currently my very simple app (written
according to Ed Burnette's nice tutorial) shows a kind of default icon.
I strongly hope and assume that this default icon can be reset to a
user-defined one. But currently I don't see how to realize that...
Thanks for your help,
Daniel
Re: How to set the RCP main app icon [message #263446 is a reply to message #263444] Fri, 23 July 2004 05:42 Go to previous messageGo to next message
Originally posted by: user.domain.invalid
I think you have to define your own product extension (as in org.eclipse.platform),
and then enter your image(s) to the windowImanges-Properties, as in the following
snipped out of the eclipse/plugins/org.eclipse.platform_3.0.0/plugin.xml:
<extension id="ide" point="org.eclipse.core.runtime.products">
<product name="%productName" application="org.eclipse.ui.ide.workbench" description="%productBlurb">
<property name="windowImages" value="eclipse.gif,eclipse32.gif"/>
<property name="aboutImage" value="eclipse_lg.gif"/>
<property name="aboutText" value="%productBlurb"/>
<property name="appName" value="Eclipse"/>
<property name="preferenceCustomization" value="plugin_customization.ini"/>
</product>
</extension>
Peter
Daniel Krügler wrote:
> Hello Michael,
>> Hello Daniel
>> provide a
>> you
> Daniel
Re: How to set the RCP main app icon [message #263449 is a reply to message #263446] Fri, 23 July 2004 06:12 Go to previous messageGo to next message
Thank you very much for that hint! But regrettably it doens't work. I
extended my core plugin with the following:
<extension
<product
name="My Name"
application="My Application">
<property
value="MyImage.gif"
name="windowImages"/>
</product>
</extension>
and copied MyImage.gif into the directory where that core plugin.xml
is located. After startup of the app the default icon remained.
Any ideas?
Thanks in advance,
Daniel Krügler
user@domain.invalid schrieb:
> following
> </product>
> </extension>
Re: How to set the RCP main app icon [message #263450 is a reply to message #263449] Fri, 23 July 2004 06:33 Go to previous messageGo to next message
you must do a FULL product definition (as in org.eclipse.platform),
and start your RCP with the additional parameter -procuct <productid>.
Perhaps you read in the Help->Platform Plug-in Developer Guide->Programmer's Guide->Packaging and delivering Eclipse
base products->Defining a Product->The products extension point
with your own images :-)
Peter
> <extension
> <product
> name="My Name"
> <property
> value="MyImage.gif"
> </product>
> </extension>
> Any ideas?
> Thanks in advance,
> Daniel Krügler
>> Hi,
>> the following
>> </product>
>> </extension>
Re: How to set the RCP main app icon [message #263467 is a reply to message #263450] Fri, 23 July 2004 08:19 Go to previous messageGo to next message
> Guide->Programmer's Guide->Packaging and delivering Eclipse base
> Regards,
> Peter
Many thanks Peter - I got it working!! (The biggest problem was that I
did not provide the -product program parameter in my first attempt...)
Have a nice weekend,
Daniel
Re: How to set the RCP main app icon [message #263600 is a reply to message #263467] Fri, 23 July 2004 21:22 Go to previous message
FYI there's an example of this at:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -ui-home/rcp/index.html
(in Nick's Browser example). And there is documentation on the extension in
Eclipse help.
Ed Burnette, co-author, Eclipse in Action
www.manning.com/gallardo
www.eclipsepowered.org
"Daniel Kr
Previous Topic:Eclipse 3.0 and RTF copy
Next Topic:DLL file placement
Current Time: Thu Oct 23 00:28:22 EDT 2025
Powered by FUDForum. Page generated in 0.04742 seconds
