Home » Eclipse Projects » Eclipse Platform » Plugins & class loaders
Plugins & class loaders [message #263097] Thu, 22 July 2004 06:50 Go to next message
Originally posted by: mbo.shift-think.net
Hi all
I have two plugins 'core' and 'entityMgmt'. The Core plugin is responsible
for providing the overall functions, that should be used
by the other plugins. This includes loading a class at runtime to establish
an 'initial context' for access to a remote session bean.
I have tried several things and am currently trying to work out the problems
I have with dynamically loading classes at runtime
(class not found exceptions) using a class loader (thanks to Ilya).
I am not really sure if I understood the overall concept of the plugin issue
and would appreciate help on this.
My current problem is that the 'initializePersonManager' returns a
NullPointerException, not idea what's wrong.
ConnectionManager.java (core)
package com.shiftthink.connect.fatClient.core;
import java.util.Hashtable;
import javax.naming.Context;
import javax.naming.InitialContext;
import javax.naming.NamingException;
import javax.rmi.PortableRemoteObject;
import com.shiftthink.connect.entityMgmt.PersonManager;
import com.shiftthink.connect.entityMgmt.PersonManagerHome;
public class ConnectionManager
public static PersonManager initializePersonManager(PersonManager
mgr)
try
Context context = getInitialContext();
Object obj = context.lookup("PersonManager");
// Create a pMgrHome reference
PersonManagerHome pMgrHome = (PersonManagerHome)
PortableRemoteObject.
narrow(obj, PersonManagerHome.class);
mgr = pMgrHome.create();
return mgr;
catch (Exception ex)
System.out.println("INIT Problem: "+ex);
return null;
private static InitialContext getInitialContext()
class InitialContextGetter implements Runnable
InitialContext result;
public void run()
try
Hashtable env = new Hashtable();
env.put("java.naming.factory.initial",
"org.jnp.interfaces.NamingContextFactory");
env.put("java.naming.provider.url",
"localhost:1099");
result= new InitialContext(env);
} catch (NamingException e)
result=null;
ClassLoader loader =
PreferencesManager.getDefault().getClass().getClassLoader();
InitialContextGetter getter = new InitialContextGetter();
Thread getterThread = new Thread(getter);
getterThread.setContextClassLoader(loader);
getterThread.start();
try
getterThread.join();
} catch (Exception aEx)
aEx.printStackTrace();
return getter.result;
EntityApplication.java (entityMgmt)
And here is the code of a method of the other plugin that makes use of the
'core'
plugins classes and functions:
public PersonDto[] getPersonList()
// Create PersonManager instance (remotely) and try to
access data.
PersonManager pMgr = null;
PersonDto[] personlist = null;
try
pMgr =
ConnectionManager.initializePersonManager(pMgr);
personlist = pMgr.getAllPersons();
for(int i=0; i < personlist.length; i++)
System.out.println("Name: " +
personlist[i].getStDescriptivenameFind());
catch (ClassCastException e)
e.printStackTrace();
catch (RemoteException e)
catch (Exception exc)
System.out.println(exc.toString());
//exc.printStackTrace();
return personlist;
By the way: "PreferencesManager" is the 'plugin application' of the core
plugin.
Thanks for your help!
Michael
Re: Plugins & class loaders [message #263202 is a reply to message #263097] Thu, 22 July 2004 11:09 Go to previous messageGo to next message
Originally posted by: chaves.nospam.inf.ufsc.br.ok
With no stack traces for the NPE it will be hard to help.
Michael Boeni wrote:
> Hi all
> mgr)
> try
> return mgr;
> return null;
> public void run()
> try
> "localhost:1099");
> result=null;
> try
> 'core'
> access data.
> try
> pMgr =
> return personlist;
> plugin.
> Cheers,
> Michael
Re: Plugins & class loaders [message #263228 is a reply to message #263097] Thu, 22 July 2004 11:25 Go to previous messageGo to next message
> Hi all
Launch your runtime workbench under Debug mode (use F11, for instance).
Then set a breakpoint on NullPointerException. In the Debug perspective
find the Breakpoints view, and click on the J! button in the toolbar.
Choose NullPointerException. (Re)run your workbench. When the NPE happens
see if you see what is wrong...
Chris
Re: Plugins & class loaders [message #263256 is a reply to message #263228] Thu, 22 July 2004 12:03 Go to previous messageGo to next message
Hi all
Here is where i get the 'nullPointerException':
Michael
"Chris Laffra" <chris@eclipsefaq.org> wrote in message
news:cdom8c$atk$1@eclipse.org...
> > Hi all
responsible
establish
problems
issue
> Chris
Re: Plugins & class loaders [message #263258 is a reply to message #263228] Thu, 22 July 2004 12:05 Go to previous messageGo to next message
By the way, here is the code of PreferencesManager:
import org.eclipse.jface.preference.IPreferenceStore;
import org.eclipse.ui.plugin.AbstractUIPlugin;
* @author mbo
* TODO To change the template for this generated type comment go to
* Window - Preferences - Java - Code Style - Code Templates
public class PreferencesManager extends AbstractUIPlugin
private static PreferencesManager prefsMgr;
public PreferencesManager()
prefsMgr = this;
protected void initializeDefaultPreferences(IPreferenceStore store)
store.setDefault("connectServerURL", "connect.shift-think.com:1099");
public static PreferencesManager getDefault()
return prefsMgr;
> > Hi all
responsible
establish
problems
issue
> Chris
Re: Plugins & class loaders [message #263295 is a reply to message #263256] Thu, 22 July 2004 13:51 Go to previous messageGo to next message
> Hi all
> Cheers,
> Michael
This means your preferencemanager is being used before it is created.
When do you think it should be created?
Chris
Re: Plugins & class loaders [message #263332 is a reply to message #263295] Thu, 22 July 2004 15:37 Go to previous messageGo to next message
If you create a manifest for the PreferencesManager plugin you can make it
get initialized the first time it is accessed. That you fix your problem.
news:cdouq4$rod$1@eclipse.org...
> > Hi all
> > Cheers,
> > Michael
> Chris
Re: Plugins & class loaders [message #263382 is a reply to message #263258] Thu, 22 July 2004 17:28 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Did you:
1) Specify PreferencesManager as the class="" in the plugin.xml
2) Do you have have a manifest file? If you do, then the plugin.xml
class="" will be ignored.
If one of the above is not correct, your PreferencsManager would not be
used as the Plugin instance of your plugin.
But if all you wanted was the classloader from PreferencesManager you
didn't need to do getDefault(), this would be sufficient:
PreferencesManager.class.getClassLoader()
Thanks, Rich Kulp
Re: Plugins & class loaders [message #263431 is a reply to message #263382] Fri, 23 July 2004 04:42 Go to previous messageGo to next message
Hello all
I do not have a manifest file but I have now specified the 'class='
attribute in plugin.xml. Now I get the following exceptions:
java.lang.NoClassDefFoundError: org/jboss/logging/Logger
at org.jnp.interfaces.NamingContext.<clinit>(NamingContext.java:102)
at
org.jnp.interfaces.NamingContextFactory.getInitialContext(Na mingContextFacto
ry.java:41)
at javax.naming.spi.NamingManager.getInitialContext(NamingManag er.java:662)
at javax.naming.InitialContext.getDefaultInitCtx(InitialContext .java:243)
at javax.naming.InitialContext.init(InitialContext.java:219)
at javax.naming.InitialContext.<init>(InitialContext.java:195)
at
com.shiftthink.connect.fatClient.core.ConnectionManager$1$In itialContextGett
er.run(ConnectionManager.java:64)
at java.lang.Thread.run(Thread.java:534)
at
com.shiftthink.connect.fatClient.core.ConnectionManager.init ializePersonMana
ger(ConnectionManager.java:36)
at
com.shiftthink.connect.fatClient.entityMgmt.EntityApplicatio n.getPersonList(
EntityApplication.java:85)
at
com.shiftthink.connect.fatClient.entityMgmt.EntityApplicatio n.run(EntityAppl
ication.java:59)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
INIT Problem: java.lang.NullPointerException
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cdpbec$gkr$2@eclipse.org...
> Did you:
> Thanks, Rich Kulp
Re: Plugins & class loaders [message #263500 is a reply to message #263431] Fri, 23 July 2004 10:40 Go to previous message
Do you know where the org.jboss.logging.Logger is? You are missing the
jar for it.
Thanks, Rich Kulp
Previous Topic:Updating to 3.0
Next Topic:Edit workbench preference page
Current Time: Sun Jul 27 08:54:24 EDT 2025
Powered by FUDForum. Page generated in 0.06789 seconds
