per-project compiler settings, shared via cvs [message #262696] |
Tue, 20 July 2004 13:34  |
Originally posted by: eclipse.afyfe.com
A co-worker set up per-project compiler settings for a project. As a
result, the file .settings/org.eclipse.jdt.core.prefs was created in the
project directory, and this new directory and file were both checked into
cvs.
When I did an update, I got them. This did not enable "Use Project
Settings" for the compiler options, so I selected it myself via the
project properties.
However, eclipse did not use the settings in the .settings directory.
Instead it created for me a new file
metadata/.plugins/org.eclipse.core.resources/.projects/PROJ_ NAME/org.eclipse.jdt.core/.jprefs
and used it instead. This file, unlike the other, is not shared via CVS.
When does eclipse use one or the other? And can I request that it use one
over the other?
(We collectively use eclipse 3.0 on either osx and winxp.)
--Andy Fyfe
Re: per-project compiler settings, shared via cvs [message #262706 is a reply to message #262696] |
Tue, 20 July 2004 14:35   |
Originally posted by: akiezun.cutthis.mit.this.edu.andthis
Andy,
this is not supported yet.
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=59258
a.
> cvs.
> project properties.
> over the other?
> --Andy Fyfe
FUDForum. Page generated in 0.03791 seconds
