Home » Archived » BIRT » Preview tab is missing
Preview tab is missing [message #262652] Tue, 04 December 2007 15:37 Go to next message
Originally posted by: rainer.home.de
I have installed eclipse from deb and then downloaded birt with the
eclipse updater. When I create a birt project and a report, the preview
tab is missing. The .log file:
eclipse.buildId=M20060921-0945
java.version=1.6.0
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 2 1 2007-12-04 20:22:15.316
!MESSAGE NLS missing message: initializer_error in:
org.eclipse.core.internal.runtime.messages
!ENTRY org.eclipse.osgi 2 1 2007-12-04 20:22:15.317
!MESSAGE NLS missing message: fileInitializer_fileNotFound in:
!MESSAGE NLS missing message: fileInitializer_IOError in:
!MESSAGE NLS missing message: fileInitializer_missingFileName in:
!ENTRY org.eclipse.ui 4 4 2007-12-04 20:22:22.174
!MESSAGE Unable to associate action set with part:
org.eclipse.birt.report.designer.ui.editors.ReportEditor. Action set
org.eclipse.birt.report.designer.ui.previewActionSet not found.
My configuration:
- Debian Testing
- Eclipse 3.2.0
- Birt 2.1.2
Re: Preview tab is missing [message #262658 is a reply to message #262652] Tue, 04 December 2007 16:01 Go to previous messageGo to next message
The preview tab is defined in the
org.eclipse.birt.report.designer.ui.preview plugin.
You don't have this plugin or it is broken.
Snjeza
> java.version=1.6.0
> My configuration:
> - Debian Testing
> - Eclipse 3.2.0 - Birt 2.1.2
Re: Preview tab is missing [message #1389141 is a reply to message #262658] Fri, 27 June 2014 07:52 Go to previous messageGo to next message
same issue here. Preview tab is missing. Installed twice.
any other suggestion?
regards
Re: Preview tab is missing [message #1389223 is a reply to message #1389141] Fri, 27 June 2014 10:03 Go to previous messageGo to next message
José,
What version are you using? If the latest verions, 4.4, I believe the preview tab has been removed in favor of the normal output options from the toolbar. Let me know.
Re: Preview tab is missing [message #1389359 is a reply to message #1389223] Fri, 27 June 2014 13:46 Go to previous messageGo to next message
I'm using Eclipse Luna.
Re: Preview tab is missing [message #1389602 is a reply to message #1389359] Fri, 27 June 2014 22:55 Go to previous messageGo to next message
Yep. In Luna, the Preview tab was removed. This was done in favor of the toolbar option. Adding to this, the best way to test your designs how they'll actually look is to use an external browser so you can test across the different browsers. To set this up, go to Window -> Preference -> Report Design -> Preview. On the preview window, select the "use external browser" check box. To specify which browser you want to use, you can navigate to the web browser section under the general tab or by clicking the link below the checkbox. Hope this helps.
Re: Preview tab is missing [message #1390889 is a reply to message #1389602] Mon, 30 June 2014 02:18 Go to previous messageGo to next message
Hi Michael
so, the correct way to preview is....
Re: Preview tab is missing [message #1390918 is a reply to message #1390889] Mon, 30 June 2014 03:20 Go to previous messageGo to next message
Use the "View Report" drop down in the toolbar to select the output to preview in. The old preview tab was just a straight html output, so if you liked that preview, choose HTML from the drop down list.
Re: Preview tab is missing [message #1798568 is a reply to message #1390918] Tue, 20 November 2018 08:35 Go to previous message
Yes you are right, its from the tool bar View Report
Previous Topic:Access Dataset Result in Script
Next Topic:"dataSetRow" is not defined
Current Time: Fri Nov 07 19:17:01 EST 2025
Powered by FUDForum. Page generated in 0.04254 seconds
