Home » Eclipse Projects » Eclipse Platform » (Rcp) help in a separate plugin
(Rcp) help in a separate plugin [message #262566] Tue, 20 July 2004 05:29 Go to next message
Originally posted by: arnauann.ufrima.imag.fr
I want to integrate a help plugin in my RCP application. it works fine
when the help files (toc.xml, html..) are in the main plugin but I want to
separate the help in a specific plugin.
I don't understand in what plugin the differents files must be installed.
I don't know if the toc.xml files must be in the main plugin or in the
help plugin.
This is what I did:
plugin.xml:
<extension point="org.eclipse.help.toc">
<toc file="toc_Concepts.xml" />
</extension>
toc_Conecpts.xml:
<toc label="Concepts" >
<topic label="Concepts">
<link toc="../helpplugin/toc_Concepts.xml"/>
</topic>
</toc>
The helpPlugin contains the toc_Conecpts.xml and the html files.
I have no error in the log file but it does not work.
Does anybody know the solution?
Thanks.
Re: (Rcp) help in a separate plugin [message #262648 is a reply to message #262566] Tue, 20 July 2004 11:10 Go to previous messageGo to next message
Originally posted by: dorian.birsan.net
Does your RCP app include the org.eclipse.update.configurator plugin? If
yes, and your're running on a FAT32 file system, restart with -clean.
If you don't include the configurator plugin, then make sure both plugins
are listed in the config.ini.
"arnauann" <arnauann@ufrima.imag.fr> wrote in message
news:cdiomk$cfs$1@eclipse.org...
> help plugin.
> This is what I did:
> plugin.xml:
> </extension>
> toc_Conecpts.xml:
> </topic>
> </toc>
> Thanks.
Re: (Rcp) help in a separate plugin [message #263212 is a reply to message #262648] Thu, 22 July 2004 11:13 Go to previous message
Thanks for your help.
> > Hi,
> > help plugin.
> > This is what I did:
> > plugin.xml:
> > </extension>
> > toc_Conecpts.xml:
> > </topic>
> > </toc>
> > Thanks.
Previous Topic:strange menu/toolbar behavior
Next Topic:strange menu/toolbar behevior
Current Time: Sun Nov 09 13:41:16 EST 2025
Powered by FUDForum. Page generated in 0.03631 seconds
